Old Apr 27, 2014 | 03:06 PM
  #3871
PFTWHFTB's Avatar
Well, we expect pictures and videos with music and voice over all done in four part harmony shortly after your return! ;-)
Lol I can guarantee lots of pictures and videos, but I can't guarantee the voice over and four part harmony part, although voice over would be a nice touch.
Old Apr 27, 2014 | 06:28 PM
  #3872
Cascade Wanderer's Avatar
Veteran: Marine Corp
You got some great photos of some of my favorite places in Oregon!
Old Apr 27, 2014 | 07:03 PM
  #3873
RAINSTATEBEAR's Avatar
Originally Posted by PFTWHFTB
Anyone install the Mopar 7 pin wiring harness for towing a trailer with brakes? And has anyone installed a brake controller?
Mine is manual lift
Sent from the hand of the RSB himself!!!
Old Apr 27, 2014 | 08:08 PM
  #3874
aeb949's Avatar
I installed the 7-pin harness about a month ago. It is pretty simple as long as you are reasonably handy. Make sure you focus on preserving as much length as you can as you work forward. Mine was just barely long enough on my JKUR. The battery orientation changed with the 3.6 and I don't think they updated the harness, so it gets a little tight at the end. I focused on keeping mine away from any moving parts or exhaust as much as possible, so that may have contributed to my issues with the harness length. It fit on the first try but I was getting worried it wasn't going to reach the terminals as I was getting it finished.
For the brake controller, I ended up going with the Tekonsha Prodigy wireless unit and it works very well. This controller is installed on the trailer rather than in the Jeep. I can tell you that it would be simple to install a controller in the cabin of the Jeep. Chrysler makes it very easy with a handy grommet though the firewall in just the right place. The hardest part is finding the right 12V power lead to tap. I did some research on various forums and found out what the right wire was - found it under the dash and would have been a breeze, but in the end went with the wireless unit. If you have any trouble figuring it out let me know. I think it was the tan wire coming off the brake switch under the dash.
The only issue I had with the Prodigy wireless controller was when using a pintle hitch on my Adventure Trailer Horizon on washboard roads. The pintle allows some front to back motion and the brake controller got sort of confused as the trailer was bouncing forward and back. Only happened once and was not a biggie, but for regular work with a pintle I would want the brake controller in the vehicle rather than on the trailer. Here's the trailer and Jeep in Anza Borrego this spring.
Good luck!
Old Apr 28, 2014 | 01:54 AM
  #3875
PFTWHFTB's Avatar
Originally Posted by aeb949
I installed the 7-pin harness about a month ago. It is pretty simple as long as you are reasonably handy. Make sure you focus on preserving as much length as you can as you work forward. Mine was just barely long enough on my JKUR. The battery orientation changed with the 3.6 and I don't think they updated the harness, so it gets a little tight at the end. I focused on keeping mine away from any moving parts or exhaust as much as possible, so that may have contributed to my issues with the harness length. It fit on the first try but I was getting worried it wasn't going to reach the terminals as I was getting it finished. For the brake controller, I ended up going with the Tekonsha Prodigy wireless unit and it works very well. This controller is installed on the trailer rather than in the Jeep. I can tell you that it would be simple to install a controller in the cabin of the Jeep. Chrysler makes it very easy with a handy grommet though the firewall in just the right place. The hardest part is finding the right 12V power lead to tap. I did some research on various forums and found out what the right wire was - found it under the dash and would have been a breeze, but in the end went with the wireless unit. If you have any trouble figuring it out let me know. I think it was the tan wire coming off the brake switch under the dash. The only issue I had with the Prodigy wireless controller was when using a pintle hitch on my Adventure Trailer Horizon on washboard roads. The pintle allows some front to back motion and the brake controller got sort of confused as the trailer was bouncing forward and back. Only happened once and was not a biggie, but for regular work with a pintle I would want the brake controller in the vehicle rather than on the trailer. Here's the trailer and Jeep in Anza Borrego this spring. Good luck! <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=549139"/>
Nice set up! Thanks for all the info, I've spent some time searching the web with lot of success so far.
I'm pretty handy and I ordered the wiring harness to put the 7 pin in. I'm thinking I shouldn't have too many problems with it, but I'm a research junkie, so I try and get every ounce of info before I do anything. I'm thinking of cutting. Hole in my factory bumper to put the 7 pin in that once I get my popup so I know the best place to put it.
I also ordered a Tekonsha Prodigy P3, it seemed to have everything, was highly rated and a best seller. I had to order all the wiring harnesses (2) to hook the brake controller to my jeep. I found a nice video for my actual model, 2011 JKUS, and it seems easy good to hook the controller up.
I should have everything in about a week and then I will have to make the time to install it. So hopefully in a few weeks I'll be good to go. I'll post some pictures of it all if I'm not too busy swearing at the process.
Old Apr 28, 2014 | 04:54 AM
  #3876
Clark Collins's Avatar
Veteran: Navy
Originally Posted by ShakyJake
You have to pencil it out. What will it cost you to do the trade plus mods vs. just gearing and reinforcing what you have. If the Rubi idea is just for the lockers, forget it. I replaced my Rubi e-lockers with ARB airs and never looked back. The motor and transmission improvement is the better question. If you are unsatisfied with the 2010 powertrain, 35's are only going to make it worse and you will be happier with the newer models.
If I upgrade to a Rubicon I will not want to spend more on lockers or regearing. What is wrong with the stock Rubi lockers? What makes the ARB lockers worth the extra investment? Would the stock 4.10 gearing on a new Rubi work well with the 35s?
Old Apr 28, 2014 | 05:31 AM
  #3877
aeb949's Avatar
I found a nice video for my actual model, 2011 JKUS, and it seems easy good to hook the controller up. I should have everything in about a week and then I will have to make the time to install it. So hopefully in a few weeks I'll be good to go. I'll post some pictures of it all if I'm not too busy swearing at the process.
I am sure you will do fine. I forgot to mention that if you don't have a Rubi or some type of suspension lift, you may not have room to crawl under the Jeep to do the harness install, but I am sure you would have noticed that by now. Jack stands will work if needed.
I am also a research junkie, but I didn't discover any factory harnesses that would work for a brake controller on a JK. (Practically every other vehicle under the sun but not the JK for some reason). All the research I did pointed to having to tap a wire from the brake switch. It would be great if you didn't have to do that.
Old Apr 28, 2014 | 07:09 AM
  #3878
BIG D's JK's Avatar
Need help. I am building an off road trailer I have a 4x6 frame welded and I'm ready for the axle and not sure where to start. I want my jk wheels to bolt right on. Can I just buy a 5 lug axle from tractor supply? Thanks any input would be great
Old Apr 28, 2014 | 07:46 AM
  #3879
Not sure but check a junk yard maybe u can get one from a wrecked JK
Old Apr 28, 2014 | 08:48 AM
  #3880
NMBruce's Avatar
I would also look at how hard will you be off roading, I have a 2013 Rubicon with the 5-speed auto and 3.73 gears, which when in 4 low gives me something like a 55 or 60-1 crawl ratio. I have done some off roading, not rock crawling and it does great. I would stick with the stock lockers until something failed, then maybe upgrade.
Today I am switching over to 285/70/17, which are 33 tires, so it will be interesting to see if there are any changes in power or MPG. With the stock tires, I get good mpg, 18.5 over all (low 14 to 22) and I have pulled 3000lbs (tow dolly & small pickup) with the set up and it worked good (10-14mpg). So far I love the set up I have and it has done everything I have wanted it to do.
I think the 4.10 & 35 will do just find, with the 3.6L & 5-speed auto.
