Superchips Flashpaq for JK, Initial Impressions
Old Sep 1, 2009 | 07:16 PM
  #671
Lee's Avatar
Lee
What gears do you have?
Old Sep 1, 2009 | 07:46 PM
  #672
Lee's Avatar
Lee
His name is Ruger. He's a nine year old Weimerainer. I like your pup too!
Old Sep 2, 2009 | 07:20 AM
  #673
R0ck's Avatar
Got my Superchips from Northridge last night!
I got it all updated this morning before work, but I still have about a half tank of 85 octane; our lower grade here in the mountains. We have 85, 87, 91. I'm going to try the 87 Performance Tune first, but should I wait until I my next fill up with 87 octane or would I be okay with the 85 octane at high altitude (5,430 ft)?
Old Sep 2, 2009 | 07:38 AM
  #674
JKsJK's Avatar
you'll be fine with 85 - won't do any harm, you just won't get 100% of the benefit. it will take a little while for it to all work out anyway, so i would go ahead and install it.
Old Sep 2, 2009 | 07:44 AM
  #675
RATM's Avatar
One of my jobbers ordered a SC for me today and I will dyno it on a DynoJet to see what it will or will not do....
Old Sep 2, 2009 | 07:52 AM
  #676
RichRock's Avatar
Mine is "out for delivery". OOOh the suspense!
Old Sep 2, 2009 | 08:04 AM
  #677
JPop's Avatar
Because you are at such high altitude, you just can't get the same amount of air in which is why you have the lower 85 grade. The one stop down in fuel grade (from 87 to 85) will burn at about the same efficiency as 87 would at closer to sea level. So I would just place the octane rating on the Flashpaq at 2 above what your putting in the tank, and let the PCM sort the rest out.
BTW, the air has about 20% less density than what the majority of us our dealing with, making it harder to burn all the fuel your pouring in, hens the quicker burning low octane you have available.
Old Sep 2, 2009 | 09:08 AM
  #678
R0ck's Avatar
So by placing the Flashpaq at 2 above you mean if I'm putting in 85, set it to 87, putting in 87 set it to 91, and so on? Or am I misunderstanding what you meant?
Old Sep 2, 2009 | 09:23 AM
  #679
JPop's Avatar
Yep, that's pretty much it. With the 3 Octane levels you have available (85, 87, 91) I probably avoid the mid-grade. I also would revert back to Octane levels as normal if you are going to be under 3,000 feet for extended periods.
So at your altitude I would run as follows,
85 Octane for 87 setting and Mileage XS
91 Octane for 93 and Tow setting
Old Sep 2, 2009 | 09:52 AM
  #680
Atl JK's Avatar
Yeah, I'm in Denver and I can't tell much of a power drop off around town from how it felt in Atlanta. I think its due to my CAI and flashpaq. It does start to struggle a little in the mountains above 9000'. The CAI sounds different too, its a kind of strange hollow sound. Makes sense though...
I've been running 87 (mid grade) on the 87 tune. Maybe I should try 85 with the 87 tune. No scratch that I'll run 91 in it next tank (and the appropriate tune) and see if I can tell a difference.
