- FOR SALE - ProRock 44 front and D44 Rear
- Built JK Rubicon Dana 44 Front Axle Assembly Complete C to C
- Dynatrac pro rock 44 front axle
- D30 Front axle for sale
- PSC Bombproof D44 Diff covers and Fox ATS stabilzer
- New Dana 30 Teraflex Diff Cover & gasket
- Adams Front 1310 EXTREME DUTY driveshaft
- D44 Rear for Sale - TN
- Atlas 4.3 Transfer Case with JK shift kit
- 2014 JKU Dana 44 Rear Axles 30 spline
- Front Drive Shaft for Jeep JKU Auto
- Prorock 60 Housing and inner shafts for sale
- Built Rubi axles front and rear
- WTB - JKU Front Axle Assembly
- Built JK rubicon rear axle
- D30 TruTrac
- Front D30/Rear D44 3.21
- G2 HD Dana 44 front axle housing
- PR44 Front / Non Rubi D44 Rear
- Built JK D44 Axles For Sale
- 4:10 gears and rear 3:73 axles so. Cal
- CenCal 2008 Dana 30 4.88 gears
- NV 241 Transfer Case For Sale
- Dana 44 Rear Axle with Dynatrac Trail Leader Package Upgrade.
- Sprintex Supercharger
- NEW - Teraflex Upper and Lower Ball Joints with Knurl (3442022)
- Rubicon stock axle shafts front and rear
- Dana 30 & Dana 44 ---> 5.13 gears and locker
- D44 G2 Diff Cover
- Ford Super Duty Axles One Ton
- Jk dana 30 front complete axle-3.73 gears from a 2015
- Jk built Dana 30
- Dynatrac/Currie axles
- Front dana 44 housing
- 2009 2 door steering box freshly rebuilt drilled and tapped
- 2016 Rubicon axles for sale $4000
- [WTB] Knuckles
- Dana 44 open carrier and gears
- Rubicon Transfer Case, New in Box, 2012+ Auto Trans
- 2011 rubicon axle shafts, front and rear set. $300 pick up only. Ventura Ca.
- Custom made 1310 drive shafts, front and rear
- Jeep Wrangler Spider Gears OEM
- D30 axle shafts
- Dana 30 & 44, 456 gears, C-gussets and Synergy Ball joints
- rear D44 open carrier non Rubicon and 321gearset (NORTHEAST CT)
- Dana 30 front carrier with spider gears, never used brand new
- Dana 60 SD build (New York)
- [FS] Rubicon Dana 44 rear axle
- FS: Dynatrac PR44 Unlimited COMPLETE axle - San Diego
- Stock D30/D44
- Great condition Dana 30 front axle, can ship
- NEW in box, JK Rubicon 5.38 gears and Master Install Kits, $500 shipped
- JK Rubicon D44 Axles F+R- 5.13s, E-lockers,Truss, Gussets, HD Balljoints
- 1310 Coast front drive shaft.
- Artec JK Rear Axle Truss Kit
- Ten Factory front axle kit for Dana 30 or Dana 44- up to $800 value gift certificate
- WTB: Dana 44 housing or complete.
- FLORIDA: JK Rubicon Dana 44 Complete F&R Axles; 4.10 gears and factory e-lockers
- Delphi 2 door steering box (CT)
- Ten Factory Non-Rubi Rear D44 Chromoly 30 Spline Axle Shafts....
- Stock 30/44 axles
- FEELER: 2012 Rubicon Rear 44 w/ EVO Rockstars & Chromoly Shafts
- Poison Spider 44 Diff Covers
- Stock Rubicon Front 44 Housing
- Dana 44 Rubicon Axle Housing
- Used Synergy 4.5" rear springs
- NEW Trusses, Brackets, Gussets, Skids and more
- JK Rear Teraflex HP 60 Complete
- Semi built Dana 30 & Dana 44 with 4.56 gears
- Feeler: PR44U 35 Spline RCV ARB, D44 Artec Trussed, 4.88 Gears, TrailReady HD17s
- FS: 2013 JK Steering Box - San Diego, CA
- 5.13 Dana 30-44 gear sets
- Dakota customs hemi conversion
- Rubi Front D44 Axle Housing - full Artec armor w/ high steer bracket
- 3.8L Motor / Engine
- Dana 30 3.21 NO KNUCKLES Western CT
- Rubi D44's Trussed,Geared,etc.
- 4.56 Gears and Diff cover
- Front Dana 30 with control arms
- Yukon 5:13 Gears And Install Kits-New Unopened- Dana44 Jeep Wrangler JK/JKU Rubicon
- Front Rubi D44 with elocker and 5.13 gears
- Jeep JK Dana 30/44
- JKU - JE Reel 1310 Front Driveshaft
- 2007 Jeep Rubicon Front and Rear Drive Shafts, Phoenix
- JK Rubicon front axleshafts (<1000 miles) $100
- offroad evo jk d44 protek front truss kit
- Jeep JK Rubicon Complete Rear Differential/4.10/e-locker
- Artec LCA Skids
- SOCAL: Complete Built Dana 30 - Sleeved, Gusseted, ARB Locker, etc
- 2017 JKUR Front Driveshaft
- 2012 JKU Sport Rear D44
- FS: ProRock 44 Unlimited, Rubi Rear axle, Racelines, Pitbull Rockers
- FS : New ARB Lockers for D60
- New Mopar Performance Brake Master Cylinder & Booster / will ship
- JK Synergy HD Ball Joints - NIB
- Brand New Coast 1310 Front Driveshaft
- Front Stock Driveshaft - 2016 JKUR - $100
- [FS] Northeast 2017 Rubicon Front Driveshaft
- Broken or working Rubicon E-locker and Rubicon shafts
- gears and diff covers
- Stock Driveshaft from 2016 JKU automatic with only 1500miles. $100
- (Great lakes) Feeler* WTB rear D44 carrier non rubi
- Artec Truss/Armor kit for JK D44
- Factory Ten axle shafts
- Jeep Rubicon Dana 44 axles front/rear
- 42RLE Automatic Transmission
- 3.8L Motor
- Transfer Case Adapter
- Built D30 and D44
- Ten Factory Rubicon Dana 44 kits
- New 4.56 Yukon gears, install kits, and true trac
- Front dana 44.
- FS: Yukon 5.38 Rear Gearset for Dana 60 Axle.
- Front 4.88 Axle with RCV BBK and Rear Dana 44 Rubicon Axle BBK and extras
- {FS} Dana 30 front / Dana 44 Rear NYC
- Riddler Dana 44 Differential Cover and Lubelocker
- Built dana 30 and built dana 44
- ARB D30 and D30 housing with truss
- front and rear Dana 44 ring and pinion - rubicon 3.73
- Build Jk D44 rear
- RCV Perfomance Gift Certificate for $1185.00
- D30/44 4.88 gears and install kits
- Dana 44 axle 3.73 gears
- Rubicon D44 Front Axle Take Off
- Yukon Rubi 5.13's. Brand new. Front only.Teraflex rear track bar bracket
- Dana 30 built front axles
- NorCal - Dana 30 - 3.73 Gears -
- front and rear rubicon axles low miles
- Built rear 44
- Rubicon transfer case
- BRAND NEW Synergy Dana 44 Ball joints top/bottom
- 5.38 Ring and Pinion 44 Front 60 Rear
- FS: Set of BRAND NEW Dana 44 Posion Spyder Diff Covers, custom paint
- Set of Dana 44 Front and Rear Axles, Complete, 4.10 gears, 500 miles.
- Front Rubicon axle shafts
- Teraflex high angle CV joint
- 2011 JK 3.8 engine needed in San Diego
- Dana 30 and Dana 44
- Rubicon Express Front Driveshaft for AUTO 2012-2016 Only
- Front JK Rubi parts
- Front driveshaft
- Dana 30 Front D44 rear 5.13 Yukon Ring and Pinions from Northridge 4x4 Brand New
- Dana 30 44 410 gears
- 2013 jku factory driveshaft
- Trussed Dana 30
- Dana 30 & Dana 44
- Rear Rubi built axle
- Dana 44 F+R rubicon. e-lockers. yukon 4.88 gears + master installs NOT INSTALLED
- North NJ- 2 Ujoints 5-760x
- Dana 30 w/G2 4:88 gears, Eaton E locker, and more.
- Yukon Zip locker For Dana 30 for sale
- 2007 JK Rubicon Ring & Pinion 4:10's Front and Rear
- D30/44 Axle Set
- JKU axles
- WTB Rubicon E Locker
- D30 Parts - 4.88's, Synergy Ball Joints, HD diff cover, axle shafts, Outer Knuckles
- SoCal. 3.73 D30 & D44
- Rear Dana 44
- Flywheel from my manual 2012 Unlimited Sport
- Dana 44 stock rear axle shafts from an Unlimited Sport
- FR and RR 44s, built front, 5.38s
- ARB Diff Covers, D30 and D44, brand new in box
- Oem rear driveshaft
- [FS] CT D44 Rear Axle from '09 JK, ARB, 5:13 Yukon gears
- Built Front D44 Rubicon housing $750 in Bay Area
- 2015 JK Rubicon D44 complete front & rear axles 4.10 gears
- Dana 30/Dana 44 from 2014 Sport
- Jk Dana 30
- JK 44 rear with ARB and 5:13s
- 2015 JK Rubicon D44 complete front & rear axles, and wheels/tires.
- 3.8 Liter and automatic for sale
- Anybody looking for Rubi diff's?
- Front Dana 30/Rear Dana 44 axle set 3.73
- JKU CV Rear Driveshft
- Manual Transmission 2007-11 (3.8L) NEED!!
- 2010 D30, Yukon 4.88, E-locker, Artec Armor Truss/Gussets
- Driveshafts & Control Arms
- OEM JK D30/D44 3.73 Gears ($125)
- Teraflex front big rotor kit
- 2012 Dana 44 Rubicon Axles Complete $3500
- 2012 Sport TC (Automatic)- Mobile, Al
- Dana 44 Rubicon Axles
- Stock 2012 and up 2 door JK Auto driveshafts front and rear
- Looking for a Rubi T-case
- Synergy Tie Rod - FS or FT
- D44 front and rear axles
- Dana 30 w/ 4.10s, C-Gussets, Riddler diff cover, spare shafts
- Dana 60: MOPAR Military Spec Rear Dana 60 Complete Axle Assembly (4.10 gears)
- Sport Transfer Case
- FS: Dana 30 COMPLETE Front Axle, Dana 44 Complete Rear Axle, Driveshafts
- Rubi front axle
- Built front & rear 2014 Rubicon Axles
- Built D30 & D44 fs
- FS-Southeast- Rubicon Dana 44 Front well built
- d30 front end
- (FEELER) Front and rear d30 and d44 3.73
- Aussie locker xd-14480 for jk dana 44 rear
- [FS] Northeast - Bolt on 1-Ton JK Axles
- 2015 Rubicon Dana 44 front and rear complete axles w brakes
- 2013 Rubicon E-locker with Carrier
- JKU Sport Transfer Case + Rubi Tires
- dana 30 4.10 gears no steering knuckles
- stock axle shafts
- 07-15 JK Rubicon 32 Spline Chromoly Rear Axle Shafts
- Poison Spyder Dana 44 Diff Covers
- *FEELER* d30/d44 axles 4.88s/17 inch method rim
- Alloy USA Rear Axle Shaft Non-Rubi 30 Spline
- Prorock 44 / ProRock60
- Rubicon Axle Shafts and Rear Axle
- D44 D30 & rear driveshaft
- RCV rear axle shfts
- Brand New Synergy Ball Joints Set of 4
- 2014 Dana 30 / 44 Axles Set
- Prorock 44 front and Prorock 60 rear
- 2 door rear DS Rebuilt CV with Teraflex joint
- FEELER: 2015 rubicon axles,front and rear,complete
- 2013 Rear Rubicon Axle Shafts
- SOLID front rubi d44 diff cover
- Dana 44 rear ARB locker 35 spline and nitro 35spline shafts
- rubicon stock locker
- dana 30 axle
- 2007 JK 3.8 and transmission
- Camaro LS accessory brackets New
- JK Rear OEM Rubicon Rear Driveshaft
- New D60/10.5 Diff covers: BTF, Ballistic, 05+ SD
- OEM MOPAR Dana 44 Rear Center Differential Gear Kit Part# 68035575AA
- 4.56 Upgrade to Front D30 less than 2k mi
- Front drive shaft
- 5.38 (Rear Only) Gears 4.10 Gears (Front & Rear Dana 44) Rear Rubicon OEM Locker
- Rubi D44 Front 4.10 Ring and Pinion Gear
- New Currie Dana 70 Rear Axle Assembly
- Like New Dynatrac ProRock 60 High Pinion Rear Axle Assembly
- Any intrest in a built front D44 housing that needs to be rebuilt?
- D44 rear gear set 4.10
- Front Rubicon Chromos-Partial set
- Arrington 426 Hemi engine, perfect for the ultimate engine upgrade!! - $12,500
- 2015 Jeep Rubicon JK Front Driveshaft
- RCV axle shafts Used for Dana 44 Rubicon JK
- 2013 Rubicon Dana 44's w/ E-lockers 35k miles
- [FS] 3.21 NON RUBI Gears + Carrier 5K on them.
- 1 Ton Axles ARTEC, REID - Completely rebuilt all new bearings, races and seal.
- Mopar Rear JK Rubicon passenger side axle shaft 68003558aa
- arb locker d30
- Axle shaft
- (2) Ruffstuff Dana 44 Diff Covers
- 2014 Dana 44 Axles Jeep Rubicon 4.10 Gears Electronic Lockers
- artec axle truss 4402
- Bunch of Brand New in Box JK Parts
- 2012 Jeep JK Rubicon Front D44 complete axle assembly 4.10 E-Locker
- 2013 Dana 30 & 44
