- AM/FM + Sirius Radio Cutting In & Out
- Cruise Control Problem
- JL led fogs
- Under seat amp/sub/lockbox
- 3rd brake light wiring
- Adding PIAA horns - easiest install ever
- Stock head unit has to be used for something…
- Help…keep killing window switches
- JK as a Toad behind RV with LED
- 2014 Wrangler Radio Issues
- Radio better with hard top plug disconnected
- Adding PIAA Horns - and keeping the stock too - no relay needed?
- Speaker upgrade
- Can't find correct halo light wiring diagram
- Potentially Changing HU with premium Audio
- Factory radio display doesn't come on.
- Radio cuts in and out
- Burnt wire under the hood
- Pulled wires from hardtop wiring harness
- Fuse box/Aux power strangeness
- Custom secondary fuse block
- 13 JKU Limp mode w abs/traction light on
- 12 JKUR no start and code readers don't comunicate.
- Problem with A/C
- Replacing LED fog lights
- Rough country shock broken
- Radio doesn't want to turn off when Jeep is turned off.
- LED Bulb error codes
- Best Stereo antenna for reception in the mountains?
- Tricks to remove stuck CD?
- Is 9 Drive really worth it??
- BXBuilt Bi-LED headlights
- Install LED dome lights soundbar removed
- Dash stays lit after door removal
- Third Brake Light Blocks Camera Placement
- Fog lights (LED Xprite) don’t turn on
- 2007 Sahara - No Compass
- What us this? What's it do?
- High beam DRLs?
- Eq settings
- Replacing battery issues
- Light gremlins??
- '12 Door Harness Replacement?
- ECU Issues
- No Fuel Reading
- IDatalink and Pioneer head unit issue
- Electrical Household plug inverter
- CB install
- Lux Rock Lights
- Do I have an amp from the factory for the speakers?
- LED Headlight issues
- aux light switch install
- Radiator Fan Issues
- Jeep in limp home mode
- Replacement radio
- No Crank. Ignition? Wiring? 🤷🏻♂️
- No voltage to o2 heater circuits
- Raxiom Aux Cube Lights
- Radio Popping...
- What is this screw holder called?
- Factory Sub wiring
- Installing 2011 jku factory touch screen in 2007 jku
- [Help] Adding OEM Powered Locks/ Powered Windows/ Keyless Entry/ Auto Start to a 2007
- Hot Oil / electrical issue
- A Little Help Needed
- Wiring help for my new rear mirror
- Accessories-household plug converter?
- JKU lighting switching options
- Need help!!
- Wrangler JKU 2008 - All O2 sensors disconnected, still codes p0031 p0037 p0051 p0057
- 2107 jku door wiring harness disconnect
- External lights stuck on and turn signals not working
- 430n difference between production years
- New Radio Recommendations
- 2014 JK Hard Start even after full night on trickle charge
- 2008 JKUR Brake Lights Not Working (Third Brake Light Works)
- TPS CEL after jump start
- Adding Lights to RSE Bumper. Need Some Advice
- Rear speakers/subwoofer suddenly stopped working
- Channel 6 open found during code chexk
- 2013 JK Radio Died
- Upgraded Speaker Setup; Ceiling Mounted Amps
- 1 Second Engine Shut down
- Upgrading sound system
- Sound bar question.
- Want to upgrade the 150w inverter
- Engine Oil Temp Sensor P0195
- Why doesn’t my AC Work!!
- door locks
- 2012 jk cam sensor code
- Instrument Cluster / Radio Issues
- JK 2013 Battery dead due to HVAV servo running
- Wiring Diagrams
- Crazy Lights
- Reverse Lights Always On
- After having gone for a swim, headlight issue (controller?)
- Towing harness issues
- High Beams and Low Beams Switched
- Its almost as though I have removed the battery!!
- Entertainment
- 2008 Rubicon
- mon autoradio est déclaré "hors tension" par l'ordi de bord
- I am at a loss! Right Rear light issue.
- DRL malfunction after T-tap for new headlights
- 2013 sound system upgrade.. a few questions
- radio swap need help rbz 430
- Identify Fused Connection
- One headlight stays on while driving
- JKU Wiper Grinding
- Aftermarket Stereo help
- Unconnect SMS notification
- 2010 Sahara with RHR NAV radio replacement compass does not work
- Amp wiring issue
- P R N D Not showin up on instrument cluster, no start
- Viper Remote Start
- 2014 JKU Sahara sound system questions
- Help
- 07 2DR overhead speakers
- 2009 Jeep Wrangler JK Dash Harness
- Tuners and Programmers
- JK unlimited Ignition Key sense
- Installing cube lights help
- Headlight issues
- Failed Remote Start, Check Engine Light
- 2009 Wrangler door locks
- Pink and black wire in ignition switch connector???
- 10A/Hardrock front bumper fog light bulb replacement
- Radio not working
- Purpose of "passenger door node" circuit?
- Fog light issue - so weird
- Severe Electrical Issues
- 2016 JK Rubicon - Dome light, Heated seats and center console receptacle wiring
- Stereo Shorting
- wanting to upgrade music system to alpine
- Battery Wire question- pic attached
- Driver Side LED Headlight not working
- S-tech switch pod - Baja designs Onx6+ wiring question
- GPS and off road mapping options
- Horizontal lines on backup camera
- Plastic Rivets
- Whirring noise while driving
- Weard Electric short
- Light bar Bracket?
- Jk wont shift after engine replace Help!!! No broken linkage.
- Electrical help....please !!!
- Remote Start
- Bracket for KC LED Fog Lights JK Rubicon Recon OEM Steel Bumpers
- Map Files
- Rubicon "Off-Road" tab accessory switches
- installed new led lights
- Dead Jeep, Help!!
- Excessive Parasitic Draw
- Activating a backup camera
- Upgrade stereo head
- Backup Camera
- 2009 JK X gauge cluster lights all come on with no power
- Help w/backup camera
- What is this harness for on my radio?
- Jeep dying and not starting,electrical issue need help!
- Tail Lights stay on - not brake light switch
- Automatic Locks not working
- Front Washer Not Working
- LED Lightbar suggestions.
- Best speaker upgrade for loudness and clarity
- I'm $13k in and still unresolved, please help!
- Electrical Problem - Crazy Dash Lights
- High Current Draw Ignition Off
- Aftermarket LED taillight issue
- Bus Bar or Power Distribution location?
- Fusable Link & Engine Not Starting
- Fuse Tap For ARB Compressor
- LED Turn Signals
- Door light switch on jK
- Quadratec Heated LED headlights?
- ARB Compressor Set & Forget
- LED lights to fog switch on 2014 JKUR - help!
- LCD digital Android dashboard cluster for Wrangler JK
- Thinking about a 730N upgrade, Think Again!
- KC Pro6 Gravity Light Bar 2014 Jeep Wrangler JK Modified Wire Keeper
- Battery drain. Blend door actuator? Clicking noise
- Air temp issue
- Sub-Woofer Removal
- Want to add power door locks to a 2012 JK
- 4WD Dash Lights not working properly ('08 jku x 85k miles)
- Information needed about WRANGLER Android Headunits
- Code p0662. PLEASE READ THE WHOLE THING
- Audio System Help!
- RES Radio
- 2011 130 Radio Fm/Am radio irratic after BT pairing
- Rugged Ridge Ballistic heated seats
- Need Battery Terminal for 2013 JKU - Please!
- 2014 jk stereo receiver not working
- Wiring DRL to fuse box??????
- electrical cover
- What Buttons Function with the PAC RP4-CH11?
- Electrical nightmare
- Windshield Wiper Switch Broke
- Cooling Fan Wiring
- What do you do with the 2008 JKUR Radio/Nav screen
- Drawing Vault
- WindShield Nuts??
- Wrangler Jeep tilt sensor
- Convert Home subwoofer to car
- Abs, esp bas check engine and speed meter not working
- Horn not working
- Uconnect Stereo Cuts On and Off
- Coolant Light, Wipers, and Brake Lights??
- Crash Sensors
- Mopar headed seats
- JK Instrument panel not working but wipers on
- ISO Procal User in Michigan Area
- Upgrading to MOPAR LED headlights
- Rear LED Run Brake Turn
- Stereo & Brake Controller Won't Power Off
- sway bar actuator plug type
- Rubicon won't start - TIPM?
- Need help with OEM upgrade and rear fade loss
- stock radio plays SAT/BT/CD but no sound with AM/FM
- JK dead in the morning with no end in sight. Help!
- Aftermarket Stereo doing weird things
- Surprise wiring discovery
- Nav issues?
- Battery Dash Light and Smoke Out of Exhaust
- Sirius XM with new HU
- Wiring Solution for Replacing Factory Seats with Mastercraft Baja RS Seatsft
- Driver side door electrical issues
- Which wire is the Field Sense wire on the alternator of a 2015 Jeep Wrangler Unlimite
- 2014 No Reverse Lights, ODB-OK, Wiring Diagram?
- Random windshield wipers, dash lights, etc. - Aftermarket stereo involved?
- I think I finally broke it...won't crank
- 730n replacement options
- Stereo/Speaker Replacement Questions
- Electrical Connection for Towing
- Adding an amp to stock 2016 Alpine, no nav, not touch screen, system
- Help!! In the woods and won’t start
- P0523, P0335, Car Won't Start After Battery Terminal Was Loose
- Random elec issue?
- Aftermarket camera operation question
- 2012 JKU with CEL and P0642 code
- Cooling fan coming on more than I would expect
- BRP subwoofer box.
- Tapping the fog lights for added light bar
- 2 options, Anti Theft Code Solution for Radio Navigation P68245849AB
- pcm replacement on 2011jk
- Air conditioning staying on !!!! Please help
- Malfunction Indicator Light (MIL) - I'm lost
- Help needed with 2017 JKU Sound System
- Jeep briefly shuts off and comes back on while driving
- Warn Winch Wiring Question, Ground and Positive to Battery
- Best Remote Start For 2015 Sahara? OEM kit or $99 Amazon specials?
