- inverter wired remote
- Factory Infinity amp wiring
- Stereo has no sound
- Key Fob
- Fixing the JK
- 2011 JK dash connector question
- replacing radio
- Head unit upgrade, worry about rain?
- Third Brake Light Wiring
- Need your help on a stereo
- Powered window stuck at times
- Adding Nav to 2018 Sport
- Front Left Turn Signal Issues
- DS18 Tailgate Shallow Subwoofer/Midrange Speaker Box
- Instrument cluster dimmer
- Door Locks for 07 Unlimited X (4 door)...need help
- Jku coolant fan not working properly when running the AC
- Aircon issue
- TIPM Issues on 2012 Wrangler
- Modify Front Turn Signals For Tires?
- Code P0481 fan 2 control circuit
- Led halo lights
- Traction control/hazard light wire
- I need help restoring original stereo setup!
- Hardwire DASH CAM
- Nav Shows "Guidance by Garmin"
- Electrical connections under drain plug?
- Modding the Rubicon sway bar and locker switch?
- Newest issue with 07 JK
- Headlight issues
- Door Lock Issues
- 2007 JKU Dome light disaster
- 2015 missing amp and wiring problem!!
- Alt Whine... Challenge
- P0340 cam shaft position sensor
- Baja Designs lp6
- Amp installs in rear cargo bin?
- 2012 Sport Multi-Function Switch Schematic
- Fan/ AC Issue
- 2011 JK stock inverter
- Battery Cable Wiring?
- Wrangler Speakers
- 2007 Starting problems
- under seat wiring harnesses?
- RGB headlight kits?
- Door chime irritation
- Error Codes Due to Electrial?: EGR and Radio Codes
- Need help to figure out a 3 prong connector. Help
- Guess this wire ?
- Turn Signals in All Directions - Driving me in Circles
- Intermittent Stock Radio 130
- Wiring Trouble Front side marker light
- Backup Camera help
- Random electrical issues
- Low voltage issue
- P2504 and Christmas Lights
- Pioneer AVH-2330NEX using a Maestro harness - No Sound
- JKU Rubicon Electrical Gremlin
- Top mounted / windshield bar mounted Off-road lights - preferences?
- Trigger wire for backup camera
- weak/absent front passenger turn signal
- Need electrical help! Not TIPM
- Door ajar wiring, 2008 JK
- Anyone ever had a winch immediately kill your battery?
- Wiring heated mirrors 2008
- JKU backup camera install for $110
- 730n Uconnect / Voice Recognition not working
- RHB Travel Link issues
- Please help, can’t find anything to help with this problem.
- Help with wiring 4 PIAA horns
- Random Radio Output
- Turn signal junction box?
- Raxiom Digital Dash installation
- RES Stereo Upgrade
- Head lights, tail lights, etc.
- Ugh... Turn Signal Issue Caused by Me
- Door Wiring Harness Connector
- 2013 JK Battery Issue
- Intermittent Problem with Electrical (?)
- Headlights Won’t Stay On- 2015 JKU
- Wired LEDs to the dome light and they don’t turn off
- H4 light upgrade-Canadian Jeep with DRL
- Clutch bypass
- Rant about uConnect module/harness
- Installing LED Halo Headlights
- Adding back-up camera to stock 430 radio
- Sometimes my Jeep won’t turn over
- CD tries to eject when opening door
- Start issue
- Rearview backup cams for OEM radios?
- A real doozy of a problem
- Trac control
- Please need help with rear Turn-light indicator
- Stock headlights issues
- RHB radio installation headaches
- Aftermarket Tail Lights W/ Integrated License Plate Light?
- Wiring for lights
- TiPM/Wiring Harness Nightmare
- 430n maps
- Installing Hella Horns 2016 JK Hard Rock
- Third Brake Light Fuse??
- I broke off the defrost knob!
- Electrical issues
- Bypass Computer
- Marine speakers vs Dry speakers
- Another Parasitic Power Draw thread. :)
- Poison Spyder Rock Brawler front bumper and fog lights.
- RIGID Radiance POD XL - Now Available
- Use spare spots in OEM lower dash switch panel?
- PIAA 520 Fog ligh grill guard a.k.a. rock guard or cover
- 2011 JK No Start, No Crank
- LED lights and wiring?
- WTF... my key ISN'T in the ignition!
- Battle of power control modules
- New pcm in but engines stalling
- Brake lights staying on
- Anyone upgrade their interior/exterior lighting?
- Flrsch5
- Sides of stock radio are dimly lit?
- Uconnect Radio 130
- Euro (ECE) Tail Light Conversion With Amber Blinkers
- After Market Remote Start Help
- wipers on, no turn signals, headlamps on, no cabin lights...
- Installed ALPINE back up camera(HCE-TCAM) is something missing ?
- LED Headlights on Low Power
- interior lighting and stereo not working
- Adding mini amp...
- Need help with OBD2
- Flashing lights and chimes, then Jeep dies
- 2018 Jeep Loc instal
- Speakers ?
- 07 J/K electrical issue
- Electrical Issues Caused by Sway Bar Disconnect?
- 2014 wrangler stereo question
- 2014 wrangler (j13 iod fuse)
- 3.8 JK cut out and not starting
- What LED bulbs?
- Has anyone found LED headlights that are not Super BRIGHT?
- 3rd Brake Light Option for Tramp Stamps
- Need help with hanging light harness under my glove box
- Dome Lights - with a Caveat
- Factory fog lights to S-Pod help
- JK dead after Brake pads replacement
- Anyone use security screws for mounting aftermarket radio
- Alpine back up camera
- No Electical Power entire Car
- Installing new USB charger power outlet
- Seicane on a '09
- Strange Problem
- JL Audio Speakers Installed
- EURO to US taillight conversion
- installing 2016 oem fog lights in a 2008 jku
- Factory Floor Sub Volume Control with Alpine i207-WRA
- OEM Electrical Connectors (Chassis-Side Tail Light Connector/Pigtail)
- Interior Light issue
- Best Manuel to automatic lock kits?
- Auxiliary Reverse Lights Hammerhead Bumper
- Starts on it's own
- Need program key and only have one
- Engine Off Battery drain sources (solved)
- 430n rhb black screen when in reverse
- Adding RHR
- Adding custom waypoints into 430n nav unit
- Aux/House battery setup in the rear of a JKU part time?
- How big of a job to replace battery cables?
- Electrical issues (behaves as if battery not connected)
- Radio question
- Alternate use of sway bay disconnect electrical
- High beam trigger led bulbs
- Electronic A/C Heater Conversion?
- Replace factory sub with powered sub
- HELP! Weird tail light wiring...
- JK front license plate bracket
- Aftermarket radio w/o harness adapter
- Piggyback fuse issue and no power to Suitech A-pillar switches
- 2014 wrangler unlimited replace amp
- Radio Options
- Push Button Start in a JK - Issues
- Help! Code p0113 after replacing thermostat
- LED halo headlights
- Splicing into dome light to add LEDS, Add-a-fuse didn't work
- Do I need separate grounds
- wiper arm sync
- Difference between programmer and tuner
- wiper arm surprise
- 07 JK - onboard compass
- Locker dash light flasking.
- Hardtop wiring adapter?
- How to wire kc 8 pro6 gravitylight to spod for 2016 jk
- Fan/overheating issue
- Eliminating soft top noise and vibration with 52" light bar
- Hyper flashing turn signals
- Rubicon Steel Bumper 10" Lightbar Fairlead Bracket
- Horn inop
- 2017 Jeep JKU Feeding Wire Through Firewall?
- HID lights
- Backup camera wiring help needed
- "Factory" remote fobs with aftermarket keyless entry?
- brandmotion backup camera
- Running light wires on 15 JK
- Change-Over Relay
- What is This Dash Light Telling Me?
- Aftermarket Stereo Help
- Aftermarket Pioneer radio power question?
- Power Window Switch Light 08 JKU
- 2018 JL Lights switch panel
- Winch disconnect install.
- Slotted "vent" under steering wheel
- HID sealed projector retrofit
- h4 to h13 adapter
- Alternator Output
- Radio swap
- Electrical issue on 2017 JK
- usb port came apart
- Sourse for wiring harness connectors? (power locks specificallY)
- Factory radio
- Help selecting top quality LED Halo Head lights
- Need help on my 2015 3.6L JK
- Courtesy lights
- what's the Best radio option for a 13 jk wrangler.
- Fog lights that match color of JW Speaker headlights?
- Aftermarket backup camera issue
- Pcm light & Traction Control Light
- Fuse #18
- Jk radio compatibility
- What scanner to buy that reads more than basic codes
- SiriusXm Antenna
- Best cell phone mount
- Synchronized Lighting
- New MyGig questions
- What headlights do you have?
- Can't add remote start with manual trans.
- JK Suddenly, W/O Warning Croaked!
- Grounding problem?
- 3.8 Alternator Death Whine
- What radio harness is this???
- Rigid or KC/IPF?
- Swapped in gifted MyGig. Transfer Sirius?
- Front turn signal issue
- P0520/22 Engine Oil Pressure Sensor/Switch Replacement
- Alpine vs. Pioneer
- JK going CRAZY
- Latest firmware for uconnect system
- 430n
- Should I go amber or red rock light for a White JK?
- 2012 JK new fog light caused turn signal problem
- Removing rear speaker
- Rigid Ignight leds AWESOME!!
- Eléctrica problem
- Eléctrica problem
