View Full Version : JK CB & HAM Radios
Pages :
1
2]
3
4
5
6
7
8
9
10
- Ear piercing noise
- Midland 75-822 Antenna Mount
- Pa horn?
- What Kind of CB Mount is this?
- CB antenna mount
- Installed CB and Stereo in Dash "Finally"
- Cobra 19 install question...
- RF filter
- cb mic bracket
- Need some help tuning a Uniden 980 Bearcat CB (In dash install)
- CB with Bluetooth
- Rear sub box/cover removal
- CB antenna warning on lower channels
- Antenna
- Cobra CB Help!
- Has anyone mounted a CB antenna to a Gobi Rack?
- How doyou run theCB power line through the firewall on a 2012?
- Uniden bearcat??
- CB install help!!
- Rugged Ridge CB Mount powder coat grind off
- Charlotte NC: anyone have a SWR meter?
- What type of comms do you use when you run trails?
- stock CB Questions
- 2 m offroad nets
- Cobra 75 WX ST Install
- This Has To Be My COOLEST INSTALL YET!!
- CB power source
- Need help SWR 2.25/2.5
- ICOM E92D HANDHELD WITH HM-175GPS Mic
- CB box location inside?
- My VHF/UHF antenna mount
- Overhead radio mount
- CB Issues :/
- New to CB...Just got Cobra 19 ultra III...need antenna suggestions
- DUAL TECHNOLOGIES SKYPRO XGPS160 – Tablet Satellite Receiver
- JEEP WRANGLER JK PILLAR MOUNTED RAM MOTORCYCLE FORK STEM MOUNT For Phone, CB Etc...
- A little cb help.
- FT-857D Install in a 2012 Jeep JK
- Tricky screw
- CB Questions: Do I really need one?
- Bull whip photos request...
- Why do some folks mount their CB antenna on front bumper?
- Icom 2820H - D-Star
- G-whip 9:1 balun arrived
- THE WILLIS RESILIENCE TRUCK - A Custom Built Communications Centre On Wheels
- CG ANTENNA PW-100 12V DISTRIBUTION PANEL - Good Alternative To The RigRunner
- CN2CA’2 WRANGLER JK MOBILE DX-PEDITION To Morocco
- MOBILE HAM RIG Complete!
- THE "RED PORCUPINE" - Dont look at this if in-cab gadgets bother you...
- JK TAILGATE ANTENNA POLE MOUNTS - Ham Radio
- JEEP WRANGLER OAKLEY EDITION - FULLY LOADED - Ham Radios Included!
- Yaesu FTM-400D installed in 2014 JK
- Radio Mounting pics
- Whip antenna for cb
- 4WDX Mobile HAM Radio Club
- Mounting compact CB to a storage shelf?
- No drill cb mount
- Newbie CB question Cobra or Uniden
- Workman SWR-2T problem
- HAM RADIO - A 4x4 Introduction For My Little Man
- CB antenna question
- High SWR reading (5)
- Am I missing something? CB parts check please.
- Are they still in Business?
- Ham help
- Question about Cobra 75 install
- How do I ground my cb antenna?
- Technical Advice Needed Regarding the mounting of a flag to a firestick antenna...
- CB & Gauge Cluster
- can anyone in NJ help me out?
- SIRIO T3-27 - Excellent Flexible Small Jeep Antenna
- WARNING - 3rd Brake Light CB Antenna Bracket Does NOT Work Without Modification
- Best Affordable CB Radio
- High SWR assistance
- F/S New ADJ LED Lighting-Pioneer-Numark-Rane-PreSonus-Behringer-Chauvet Intimidator
- CB question about close up transmitting.
- Cant X-MIT, but can recieve. need help.
- Tuned my Midland
- Tuning a Cobra 75 w/4' Firestick
- CB antenna mounted in license plate holder.
- Is there an ideal length for coaxial cable in a CB installation?
- Cb pa speaker
- Jeep CB channel?
- Tuning help
- Bad SWR meter?
- CB Antenna Mount Question
- HAM Antenna Mounting
- Need Teraflex style cb mount help ASAP
- skreetch when done talking help?
- TM-D710GA install in JK
- CB tuning
- cobra Ultra 19 III install without hard wiring?
- FYI Firestik heavy duty antenna spring not a good idea
- Anyone running a Ft-857d?
- SWR Off the Carts
- Best portable handheld CB
- Possible Mic Issue
- CB & Antenna Questions
- Rugged Ridge CB mount issues
- Cenntral Pa CB Installation?
- CB antenna is hitting my Jeep while offroad.
- Easy Midland 75-822 Mic holder
- Central or Near Central Indiana Jeep Ham Operators??
- 2014 JKU Sport HAM Radio install
- Any one have a good cb installer in orange county ca???
- CB users
- Thoughts on the bluetooth Cobra 29 LTD CB Radio?
- COAX wire routing
- Antenna tuning and hardtop removal
- Not sure what CB coax cabel is needed.
- quick question about firestik quick disconnect
- CB PA Siren
- Going through firewall, driver side
- Passed Technician and General
- CB help!
- Wison 5000 trucker antenna instead of whip?
- Super high SWR with good ground....
- Anyone in the Duluth, MN area have an swr meter?
- CB help
- No idea
- Ham and CB ?
- 2M/70cm freqs for Vegas
- Denver CB Shop
- 4x4 Ham Group
- CB or not to CB
- no sound, no swr reading... Help!!
- Anyone in Orange County with a SWR meter?
- Uniden Bearcat C B 's
- I grounded my tailgate. I think...
- Removing the plastic header trim from a 2013 JK
- Grounding my antenna mount?
- Will a PL-259 connector fit through the JK tailgate vent?
- Grounding the mount
- Need help with SWR readings.
- DIY - [CB Radio Install]
- Ham Radio advice
- My SWR is high now but wasnt before
- Teraflex CB antenna Mount Question.
- cb help needed.......
- Antenna and off-road light
- another cb antenna location question
- Antenna rubbing THRU hard top coating
- Cobra 148 GTL mounting suggestions and advice
- Overhead console cb mount
- Can't transmit after carwash
- Midland 75-822 handheld in cab reception
- Help cb noob
- SWR Meter
- cb antenna cable
- CB Hook up question?
- Is this the end for my Cobra 75?
- CB Ant Mount
- Uniden 520 xl power not consistent
- Need a 2M Mobile for Jeep, used?
- 2014 JKU - Where to route antenna line between cabin to engine compartment
- Anytone AT5558-UV Ham dual band install
- 50 watt linear?
- Swr change with top off!
- Anyone seen this yet?
- SWR Tuning for CBs Made Easy
- Best location for a PA speaker?
- Best cb radio for the money
- No noise on my CB ?
- New cb
- Anyone using gmrs radios for trails?
- What you think
- Cobra 18 WX ST2
- Modding ur cb
- CB antenna spring
- Got the CB installed
- CB wiring - connector identification help needed!
- CB tuning in Orange County, CA
- Grommets for cb cable
- HT HAM Vehicle Setup
- CB Wiring
- How often doyou use your CB?
- Firestik side mount w/ 5' antenna
- Midland 75 822
- 5/8 wave, double 1/4 wave.
- Handles!
- External speaker
- Antenna watt rating
- Antenna help!
- Need help adjusting 4" firestik with swr meter
- Dang cable!
- Smallest Mod Ever!
- CB antenna mounted on front bumper bar?
- Unique Ham Remote Head Location - on the Visor!
- New CB
- CB Mic in Cigarette Ligher
- cb radio help
- cb antenna help
- CB Install Help!
- Antenna Mount
- Which Connects First . . .
- HAM N00bie...
- Antenna Mount.
- Need cb antenna help
- Cb antenna mount!?
- HELP Please! Cb radio antenna coax route problem
- cobra 29 lx awesome mount!
- '09 Rubicon Unlimited - 2m/70cm setup with scanner
- Whip mount on stock rear bumper
- CW PADDLE,SINGLE LEVER P-6 DESIGN by K8RA
- cobra cb
- How to become a licensed ham radio operator
- Uniden ptc 104
- Removing Tuning Screw Giving Me Best SWR ratio????
- ICOM IC-7000 Remote install with video on Nav System
- How to keep the antenna out of the way in the Garage.
- Enlighten me.
- JK vs XJ... and the XJ is winning... Arrrrrgh!
- Cool Tech Ultra Mount
- HELP! Rugged Ridge XHD Tire carrier CB Mount
- JK Hardtop RFI Tip
- Which would have better reception?
- My HAM radio install
- rand mcnally tnd510/bearcat bct15x tether
- Front mount
- Does JEEP sell cb's now????
- Help!!!!!
- Mobile Mount Question
- Tuffy Overhead console for CB
- Help with cb for the average user
- CB trouble
- Antenna on license plate
- Galaxy DX94XP & Tuffy JK Overhead console fitment
- Extension Question
- New Mic or New Radio
- Using SWR meter with Cobra 75 WXST
- Antenna for Ham
- First ever cb installed and tuned. Want opinions on setup and SWR readings
- Stealth in-dash speaker install for CB, ham, etc.
- cb center console mount
- Detachable or Removable CB Mount? Can it be done?
- cb radio/ factory radio ant
- DIY bracket for multiple antennas on rear gate
- CB Install in Stock Location
- Install in Maryland/DC area?
- CB Antenna Adapter
- Cb relocated
- Stealthy, clean in-dash CB install
- Cb mount
- Ft-857
- CB rabio Kit HELP?
- 2013 CB Mount
- Installed Uniden 510XL
- High SWR Reading and can't figure it out.
- high SWR reading and can't figure it out.
- Ground question
