View Full Version : Stock JK Tech
- 2 Door Interior Dimensions
- Engine Blown at 57k Miles?
- Rubicon springs
- '11 Soft Top on a '13?
- 2013 Rubicon automatic transmission overheating
- Steering stabilizer question?
- The 3.8L is awesome!!
- Good place for Mopar parts
- Dealership made me laugh
- towing with stock 09 sahara
- whos still stock?
- Soft top question
- Rear power windows no longer work...
- Mopar new parts
- Jk Headligh Bezel Install
- Exhaust Leak
- Side mirror cracked?
- less than 30,000 miles and my transmission is locked. Has anyone had this happen?
- popping in driver seat
- brake light on dash at stop lights
- Drag Link Play/greasing
- Rear windshield washer
- Will stock soft top windows from a 2008 fit a 2012
- 3.8 L power !!
- Soft top question
- Jeep starts, runs 3 seconds, stalls
- '12 Fan cranking on high
- 2013 unlimited rubicon
- Pitman arm question
- Programmer question
- oil capacity?
- Four Bad Ball Joints at Under 36,000 Miles. Really?
- 2012 soft top on 2010 help
- Odd steering in my 09 JK
- Help with waterpump..
- Alloy Wheels: Anyone know what causes this?
- sun roof panel options ...
- Are these bad ball joints? video
- 2008 Rubicon Transmission Squeal at Cold Idle 6spd
- Fender-liner plastic rivet: how to reattach
- JKU Soft Top value
- Warranty Question
- DTE drives me nuts
- Front E-locker wont disengage
- A " transmission stuck in park or gear fix"
- Mirror Relocation Bracket Question
- Scotts Performance Reusable Stainless Oli Filters
- Engine knock
- Rust on windshield mounts
- 5lb. Fire Extinguisher Roll Bar Mount
- New stock tire recomendation?
- Where to buy evap canister online?
- 2013 JK flat towing
- Lug nut studs
- Rpm surges
- 5 year lifetime powertrain warranty inspection results
- Maximum Tire Size
- Flashcal
- 10'TH Anniversary Paint Problems (Anvil)
- Mopar Hardtop Headliners
- fixing bad tire wear
- 2013 Premium Soft Top Boot
- factory mirrors
- Rough Country Suspension Lift
- Dealerships and warranty work - general question
- Soft Top Help!
- A/C not cold - help diagnose.
- Rear backup camera location
- Rear Brakes Axel Seal Opinion
- Spacers?
- Driver Door Surround??? Broke
- Tires and Rim
- spark plug wires
- Surprise under hinges when installing Tera Flex Tire carrier!
- My Gig lockpick V.5 install
- tranmision cooler
- Seat Removal
- Water on floor
- Question about soft top roll bar brackets
- Questions about towing
- Power Door Lock Switch Installed in Half Door
- GF JK Crash PICS, Frame Damage?
- side mirrors rattle... fix?
- TPMS question;
- Sources for the shade tree jeeper
- EGR code P0404
- Need some help,
- Starting and check engine light
- control arms
- Help please
- Nearly new 265/70r17 duratracs for sale
- 265/70r17 duratracs for sale
- 2012 Mud Flaps
- Driving without windows -- sail panel damage?
- OK to leave out drain plugs?
- 08 rubicon help
- gas leak filler hoses 2009 Unlimited Rubicon
- K & N drop in filter
- Installing BigBoy seat bracket
- Stock Rubicon slider help
- JK 2012 Engine Tick and Fuel Economy Issue?
- Power Steering Fail, HELP!!
- Tranny Fluid Leak?
- Soft top replacement header bar
- Hood cover?
- 2013 softop clear windows?
- Soft Top Questions
- How to remove shifter knob ?
- Input on bds lift ???
- Miles on Rubicon shocks?
- Rockstars or Pintlers?
- 2010 Engine Knock - NO CODE
- Mirror relocation electric mirrors
- head liner for 2 dr softtop
- Getting ready to go bigger!
- Help!!! Passenger door wont close!
- Help!! Losing Power and Dash lights up like a Christmas tree!!
- Ball Joint Question
- Tinted windows scratched on front doors
- Need Help Identifying
- Possible oil leak?
- Dw...question about drag link, pitman arm and tie rid ends please help!!
- spring part# and lift question..(again)
- Action shot cam
- Greenish fluid collectin on front axle end
- What does UConnect cost to install ?
- Rocker Covers ?
- Spring and shock question
- stock rim wieght
- 35's and stock gearing?
- 'Knocking' sound from rear end every time I go over bump
- Not sure what to do next
- 5 point harnesses on back seat of 2dr JK?
- 2007 3.8 oil burners
- Quadratec replacement soft top (quadratop)
- Is there a definitive solution to the dry start knock on the 3.8?
- 2012 JKUR Low Fuel indicator
- Unknown Vibration
- Recommendations for Jeep Dealer Service in Southeastern MA
- Differential Oil Change
- What could have caused this?
- Silver JK/JKU accents other than black
- 5 new tires and rims 2013
- Replace stock rims
- What do you guys think?
- Surprise when changing transfer case fluid today.
- Hey all, 33s on stock 16 inch rims?
- Possible bad u-joint?
- Topless weather
- Is there a "verified" fix for the water behind the dash noise?
- Wobble wobble
- Rear Bumper/tire Carrier
- Driving with hardtop window open?
- cruise control surges
- Uconnect and iphone 5 problems
- brake smell
- Jeep pulls right with Rubi take-offs - no lift
- One door hinge won't budge!!!!
- steering stabilizer
- Soft Top Cleaner/Protectant..Need some help post muddin last year.
- The tube above the front spring bump stop
- New jeep owner
- Break in period?
- 3.8 Missing and Rough Idle
- clank/rattle in front end?
- What Radio is this ??
- clanky rattle in front end on bumps?
- traction control question
- in desperate need of a soft top
- Burning oil unnaturally
- What did i break exactly...
- UOAs on 08 Unlimited, 25,000 to 60,000 miles
- Freeze plugs.
- 2013 esp
- Tailgate arm popped out, WTF ?
- Rear window washer question?
- Can't seem to find the perfect tire...
- D rings on a stock bumper.
- Dealers for ordering?
- Smart door stop
- Advice needed on Cab cover or Full Cover
- Dealer add-ons
- Removed my hard top for the 1st time. Got a question!
- diagnose my drips
- Why does my jk do this?
- Factory trimmed pinch seam.
- Axle question
- Slipping out of overdrive
- Loss of torque at 2500 rpms
- 2" shock spacer lift. What do I need to know?????
- Antifreeze blowing off @ High RPM
- Where can I buy a new 4 door soft top from with the NEW spring assist????
- Wheel speed sensor?
- Water infiltration paassenger side
- Painting Fender Flares
- Painted Stock Wheels Advice
- Sway Bar Link Grease Leak?
- Wet Floor Board
- Tie rod drag link replacement
- 2008 JKU Sahara Overheating
- Rear wheel came off at 65mph!
- Soft top question
- Effing visor stickers!
- Tire pressure guage
- 2012 JK Radio/Light Issues
- Front diff issue
- thinking about a hardtop for 2010 2 dr in knoxville tn
- Jeep Wrangler Soft Top Question...
- Opinions Please
- Problem shifting into 4LO
- 3.6l burning oil
- Trading off 2012 for 2013 Auto.
- 2012 passenger shock removal?
- Steering Box Issue
- Any Samsung Galaxy/Fascinate cell users having problems with UConnect Blue Tooth?
- Auto transmission will not move past Neutral
- 2012 - Noisy Throw-Out Bearing
- Clutch issue, can't shift into gear
- Oil Question
- Product recomendations
- Canoe hauling
- Whats wrong i cant shift into gear,please help me!
- Bestop?
- stock rear bumper hook
- Starting problem
- Stock Infinity sound system sounds like crap!
- removing factory fenders...How hard?
- New JKU keeping it stock
- Catalytic converter replacement
- Sway bar light flashes, and Power loss
- Gas tank missing gallons?
- How big of a tire can I go on a stock Jk?
- HELP!!! 07 AUTO clicking/rubbing when in reverse
- Newbie needs help!
- 2013 clutch sqeek
- Which 15x8 wheels do you recommend?
- Will this tire setup work
- Gap between the dash and windshield
- MSRP Sticker Price vs Purchase Price
- What is this?
- Upgraded to a Rubi
- Hard / soft / bikini top
- Black opps rims?
- 3.21s to 4.56s
- death wobble or not ???
- Pintlers or XD series Addicts?
- Next Generation?
- What line is this?
- Soft Top Bow Bracket
- AEV or TF 2,5?
