View Full Version : Stock JK Tech
- Ordered Factory 3 piece Freedom top how long of a wait?
- 2011 Wrangler Owners with No Transmission Skid Plate.
- 33 inch tires with no lift
- Best $150 mod I have done yet
- I did it!!!
- Clutch Squeaking?
- Spark plug socket size?
- Can I adjust my fogs lights?
- Radio visor
- is this normal?
- '08 soft top to '11
- Ok so i found the leak...now what?
- Overheated last night
- Where to get factory hitch
- Soft top through winter
- Steering has tightened up
- Fender Liners
- Stock steel wheel weight
- Sport S Shocks same as Rubicon?
- Clock Spring Warranty
- Ball joints
- Suggestions for rim upgrades on a 12 sport
- Remember the gas heaters in the old VW's?
- hard top help
- Any way to re-center stock rear axle?
- hard top scrapes
- mopar mud guards
- Any ideas on a canoe rack?
- Widest tires for stock 17 JK wheels?
- front bumper
- Yakima Bike Hitch Rack Interferes with Spare Tire
- Changing lock cylinders
- 2012 JKU Rattle Part 2
- license plate holder options
- Soft Top Windows
- front driveshaft
- Switching stock wheels at dealer
- Strange scraping noise coming from rear brake...help!
- Door hinge bolt sleeves? Where to get them other than dealer?
- 4.10 Rubi gears swappable into D30/D44 non-Rubi?
- CEL, TPMS, serached and still a problem.
- Smittybilt GEAR seat covers
- wind noise with stock soft top
- soft top window roll
- I need help with my plug wires
- Whitch clutch???
- stock diff covers.
- Transfercase differences
- Where to buy dash pieces
- Cold Starts below 32 degrees
- A few questions
- Need Help Guys!!!!
- New Ride!
- Chilton or Haynes guide for JK?
- Interior rattles! Any ideas on how do get rid of them?
- P0430 code issue
- MyGig Help
- shifting problem
- Can you get painted fenders on a sport
- Help me out, soft top question
- 2011 JKU w/7500 miles needs new auto trans?!?
- Start Up Tick
- For those who replaced your stock 3.8
- Removing power/ heated mirrors on 2011/12 models
- Shift knob 'arm' sizing for '11 ???
- 2012 traction control
- clicking noise when accelerating
- Carpet Removal
- After 4 years found the buzz rattle
- 2008 JK - Engine stumbles and exhaust blows a cloud upon startup.
- 3.6 Pentastar
- Whistle from above with the front top folded back
- Rubi shocks.
- Windshield wiper resting low on the windshield
- Any way to mount Jerry Can on stock bumpers?
- New 2012 owner!!! Saying Hello!
- ok so im out $100 wtf!
- 2012 Sahara bumpers
- Squeak for first mile.
- Intake leak
- Ams oil filter
- Rear Brakes?
- Debating between a softtop or bikini/windjammer combo.
- very suprised
- Start up noise...how much damage does this actually cause, if any?
- Brief engine rattle at start-up
- Trans problem auto...
- 3.8 engine...what were they thinking?
- This snapped off coming out of a mudpit today.
- whats the clock spring?
- Squeal near wheel when not braking
- Water leak once again
- 2dr back seat
- Why can't Chrysler/Jeep make exterior black parts that don't suck?
- auto window light blown?
- Seat Height Adjustment Lever Issues
- Transmission Clattering
- 2012 Glove Box Handle on an 08
- Question about our 4wd systems-newb question?
- Rough idle
- question for mechanics
- So...why front rake anyways?
- Stock Wheel Stains?
- Oil change
- Tell me what the blank button is for please...
- Thule Revolver 964 doesn't fit should I get an extension?
- Just to make sure im not alone...
- Whats the toe setting for 32" tires?
- Rear seat belt removal
- power steering pump
- AC Vent Rings ???
- My Luck (heater hose)
- engine idling at 2000 rpm?
- Differential Help!
- Clicking noise when in 4 high from front axle. Any ideas?
- Startup Thud.
- How much is a painted 4 door hard top in mint condition worth?
- need engine help, Jk 4d manuel died on me on the fwy
- Repair rear wheel fender
- 2012 JK Rubicon Torque Specs.
- JKU rear seat fit in a 2011 JK
- Factory Sound System
- jJust failed an oil consumption test - dealer said in spec - any suggestions
- metric wrench and socket set?
- Auto JK Rubicon Regearing?
- factory bolt size
- Ball joint failure - gradual or sudden? Something went POP and I cant figure it out..
- stock rubi rail paint question
- Whats a soft top worth?
- How do you remove the right shock?
- Dealer Inventory
- systems connected to electronic sway bar
- Will JKU Soft-Top Windows Fit 2-Door?
- Engine Stalling
- something rolling around in dash?
- Weird Oil Leak...
- Hood issue when driving on the highway
- New to me Jeep, have some questions about it's quirks
- lower tire pressure
- '08 JK won't pass TX inspection - 02 and Catalyst show "not ready"
- So the JK factory front drive shafts are all the same?
- 2011 Fuel Filter
- 35's ON STOCK 17 INCH RIMS
- Passenger side automatic window
- 1.5" tf performance lift question
- New Windshield Whistle Fix??
- Rear locker trouble
- Weird sputter into 3rd and 4th gear.
- tuner
- Radio buttons on back of steering wheel of 2012!
- 2010 hardtop
- Jeep shakes when I back up an incline but not on flat ground.
- Smoke on start up on my 2012?
- Smoke on start-up on my 2012?
- Rubicon rails to Sahara steps
- Not-So-Good Vibrations...
- Freedom panel seals
- Rad & driver side vents
- 2012 JKU Rubi 410's vs 373's
- For those trying to get oil changed somewhere besides the dealer
- Is this a good price?
- Rear window busted
- Rotational Squeak/ Squeel 2012
- OEM Soft top compatible with bestop replacement windows?
- Usaa?
- rpm drop
- Right side door leak
- Factory service manual
- HELP!!! need clutch help!!
- 2012 2 dr Rubicon Trailer Tow Group
- Smell from back right brake?
- quick question about stock jeep limitation
- How long is a stock track bar?
- a pillar clunk/pop only when cold.
- Need help removing the engine splash shield
- 2012 exhaust/lift question
- OEM JK tracks wierd
- cold start up
- 2011 sport, what is the wire that goes into the door????
- Power windows n locks?
- 15W40 Heaven!
- Wanted::: Stock or aftermarket parts for a 2007 JK 2wd - 4wd Conversion
- 2007 rubicon unlimited frt and rear locker issue
- Chirping Noise
- Rubicon vs Sahara overall wheel weight, measured.
- brake scrubbing
- What is this?
- towing causing ABS to freak out?
- Recall
- Fuel filter, replaceable
- A-Pillar Guage Pod for 2011
- Gasoline overflows during fillup
- 2012 Noises
- Olympic rack
- Solution for faded platic fender flares and bumpers
- BF Goodrich Rugged Trails
- Orientation of stock shocks
- Anyone regeared their stock jk without adding larger tires
- Whistling?
- removing Jack 2011
- online resource for TSBs on 2012s?
- Clutch not slipping but seems to be engaging very high
- Overheating due to Mud?
- Any dealer orders with 5-hole classic wheels
- Remove rear seat headrests on '09 Unlimited
- AC/Heat Fan Speed Help
- Bought a new Soft Top, some questions
- Need a favor - Fuel filler opening
- Need repair manual
- I just bought 5 rubicon take-offs for my 4 door '08 sahara
- Plasti Dip Bumper
- 1rst gear standard problems and warranty
- Door actuator not working, help
- Newbie questions about axles and ratios
- Mopar trailer hitch and departure angle?
- Z MAX micro lube
- vomiting gass 2010
- Sirius Radio Antenna
- HELP the Newbie...2WD to 4WD No Gear
- Right Side Thud - What is it?
- Where to find used 6 speed?
- Lift or Spacers
- 2012 leaking differential fluid?
- 2011 4 door windows vibrate down. Any suggestions?
- Red light to the right of temp gauge
- thermostat
- Can i fix Windsheild channel
- Gorilla Lug Wrench
- How to remove decals?
- paint questions
- need advice on mileage to change spark plugs.
- hardtops what fits what
- Leaking pinch seam?
- trans line oil drip w/ pics
- New Battery
- 08 hard top on 07?
- 2011 USB jack stopped working...
- rust by windshield screws
- how to put the windshield down
- 2WD Question
- buzzing
- Price For New Key?
- can the new 2012 engine fit the old jks?
- About to throw in the towel....
- what is this on the steering linkage?
- Extreme shake in stock jk
- Will I need an alignment after off roading?
- 1/2 Doors for full doors ?
- horn delay
- Battery going bad?
