View Full Version : Stock JK Tech
- Need ideas. EAP/BAS lights and braking action during on/off ramp turns
- Door will not close - sometimes
- Seat height adjuster
- 2012 JK M/T Classic II's
- 2011 jku a/c ?
- 2012 JKUS Regearing Question
- Drivers seat height adjustment
- Axle Seal Leak....stopped?
- Realistic off road capabilities of stock '12 JKU Sport?
- Pinging Problem?
- Anyone else have a ticking/nocking sound at startup?
- Passenger Side Leak 2012 JK
- Middle console removal.
- what are those grates on inside of tail gate for
- Driveshaft boot
- Idiot parts manager
- Max Lift
- Noise from engine
- Jeep 2010 JK noise
- Can the dealership turn on the DRL?
- Lower heater hose leaking near firewall
- checking codes
- which air filter?
- Code help!!!!!! Please.
- Recommendations for ordering Tuffy products?
- Considering OE JKU Rubi tire swap to help with mileage
- Stock Coolant Type?
- soft top to a hard top?
- 2012 oil change
- Oil change interval
- Should I sell me super faulty CRD Jeep?
- Strange Noise at 2000 RPMS
- Boom mat
- Gad mileage sucks !!
- tire rotation
- Front Bumper
- Well I Bent My Door
- Checking oil
- Build Sheets
- 2012 back in the shop
- Northridge bolt kit end all solution for death wobble?
- rADIATOR FLUID
- Motor Oil Disaster
- EGR Valve Backorder
- OEM coils, throw away or attempt to sell?
- Tpms
- 12 Manual Tranny - issues?
- Rear locker won't disengage
- Soft top loose at front corner
- JK - Loose drive to rear wheels
- How do I remove a D44 Locker Coil Wire?
- Tpms
- exhaust manifold hardwear?
- Front Bumper & Airbags
- Can someone ID this mystery part?
- Hard top and soft top exclusive of each other?
- Suprised at diff gunk on magnetic plug 4500 miles
- Horn goes off constantly when locking the Jeep
- Anyone had this soft top zipper problem?
- HELP! 5 cylinders...can I drive to the parts store?
- 08 JK Vin locations?
- 3.6 Pentastar opinion
- Soft top C Pillar flapping
- Confused about gear oil
- Need Help identifing leak
- Passenger side speaker rattling
- upgrade my JKU saraha ? ie should I trade in for a rubicon
- Starting in 2nd gear
- My turn with the 3.8L POS
- Gobi rack install gone bad
- possible leak need some advice
- somebody with a 2012 save me a trip and look for me
- What happened to my Jeep!
- URGENT!! Please Help.
- Egr valve
- This fell off my 3 week old JKU
- Help with dynabeads
- Question about noise in 6 speed...
- weird sounds coming from the rear
- JK wandering after installing new ball joints
- Adding A/C to a 2008 jk
- Muffler rusted stuck.. need help
- When I Turn And Brake...
- New 2012 JKU
- tj fog lights
- whats a sensible price for a hard top
- Tire Rotation
- 3.6 pentastar tick issue
- Is my sport tinted?
- changed ball joints now axle shaft won't go in all the way
- Best place to buy tinted windows for soft top
- 2012 not needing leveled
- Rear headrest "collapse"
- Tpms
- shifter removal
- Can I fix my non working front stock rubicon locker? *see pic*
- Intermitant cranking issue
- Whining engine noise. Hmmmmm?
- Pannel lights are on, what do I do? What do they mean?
- TPMS sensor dimensions
- ugg before i bring my jeep into the stealership...
- 2012 Jeep JKU Sahara rough idle and vibrations
- D44 axle seal leaking
- 2011 JK - Hole in the Firewall
- 2012 no complaints
- Royal Purple Fluids
- What will happen when the throwout bearing fails?
- Soft top steaps Life expectancy
- Tinted soft top windows
- How to tighten the steering wheel
- Factory JK 16" aluminum wheels?
- Looking at the Teraflex leveling kit...
- Unlimited Sport with Rubicon Wheels. Spacers?
- Ipod connected to USB port
- What is this thing?
- another basic Sway bar link question..
- Soft top tight on one side - loose on the other
- Grill guard! Which one to pick?!
- Rust on an 09!?
- rear ended...
- Tow hitch wiring harness
- Freedom top panels
- To cut or flat fenders
- what could gas mileage be
- 1 more quick question before I sign up for my 2012
- Front lic plate holder?
- Death wobble on the FOX 59 news
- cab cover
- Max tire size on stock suspension?
- Rubicon Rear Locker Light won't stop blinking/ Rear wheel "drags" around corners
- Where can I find the silver bumper section around the fog lights?
- I need a new Tailgate door, what fits?
- Freedom Top question
- Leather repair
- Screw in freedom tops
- Fair price for stock rubicon tires???
- Stock 3.73 and 4.10 rpm question...
- Alternatives to smittybilt Cargo Net
- What is Diff between 2dr and 4dr rubincon lift
- what are these wires for?
- 3:73s and 35s 6 speed?
- Ordering new Rubicon Tuesday. 2012 owners , let me hear your 2 bits....
- how are the jks body holding up
- Soft rop question?
- Sluggish in Hot Weather, Rough Idle
- What the....? Jeep up and died on the road running errands....
- Dash speakers - how to turn back on...?
- 2012 axles trying to figure where i can sell
- Help!!! 2012 JKU Showing Signs of Rust
- Tightening Bolts After Off-Roading
- gap at upper, rearward passenger doors after install softop
- Jeep wants to stall randomly
- Slapping???
- DVD player question
- Question!
- HP/torque fluctuations
- transmission leak by oil filter??
- tera flex 2.5 coil suspension installation rear trackbar question.
- Does the 2012 unlimited trunk has the same dimensions as the 2010 model?
- accident
- Gear fluid?
- Sail panel plastic
- MBRP spare tire re enforcement bracket
- 3500lb toy hauler tow experience
- Does JK 2011 have an Oil level sensor ??
- Rain...
- Does the 2012 sport s come with a condenser skid plate?
- Hardtop Mix and Match?
- Rubicon Slider Hardware?
- Good Deal? 2012 rubicon
- stock bumper
- Clunking and violent shaking in 6-speed shifter
- 2.5" Series II Suspension
- 2012 brake caliper bolts fell out! 8k miles!
- Tint Question
- Braking issue..
- ThermoSteel for exhaust manifold leak?
- Hardtop storage front end down?
- Transfer shifter loose???
- 2012 cruise control issue
- new jeep recall?
- 2012 jk is this a normal thing
- To Good Of A Deal???
- 13" factory brakes
- xhd and superwinch install question
- 2009 soft top on a 07 unlimited
- after head replaced, something with coolant blew
- Is it right?
- Cleaning stock fenders/bumpers...Getting the black back...
- Rough Country 4" short arm lift 2dr
- Track bar bracket Q??
- Driving tips for when to use 4hi vs 4lo? And the hot oil light?
- new 3.6 and 5 speed automatic combination comments?
- Sahara springs and shocks vs rubicons
- Jeep CPU Tricks/Reprogramming (Turning off Dummy Lights/Chimes, ESP, etc)
- 6 speed roar
- Towing with 3.21 gears.
- Source for "generic" roll bar mounts
- Unlimited Rear Seat Removal
- Sun Rider Question
- Stay with Sahara Stockers 18's?
- Please Help Me
- Squeaking
- Hot tubes behind center dash
- OEM Heated seat installation?
- Trouble with transfer case linkage
- 33" duratrac on stock rear carrier?
- Putting the windshield down?
- Identifying my tread wear (wrong section eariler)
- man trans capacity
- what does this button do
- Ball Join Question!
- Stock hinges repainted
- Bestop door surround kit - opinions?
- hill descent control
- JK Accelerator
- Metric vs SAE for 2012 JK Models
- On board computer problems
- Bikini header? s
- khaki soft top on white jeep
- Loose brake pedal
- noise
- Front end rattle
- Goodyear Silent Armor for DD
- Esp
- Airbag Light....
- Normal Gear Wear
- Got the ESP off....Now, how to turn it on???
- Clunking near brake
- Filter1 Wix Filter Supplier Experience?
- 2011 hardtop to 2007 jku
- Measurement ? for a 2012 stock rubicon 4dr with hardtop...
- engine electric fan won't Work help
- 2012 jk bogs after water crossing
- New wheel question for a '12 Sahara Unlimited
- Post Manual Programming Features with Sequences - Enable / Disable
- Damage to front crossmember?
- Buying a new soft top! Help me decide please...
- Soft top leaks?
- Power window actuator?
- Rear locker top switch???
- Wheel paint?
- 2009 mopar soft top
- it's finally raining...
- 17" Wheel Question, Need Help
- Best Way to clean under the hood?? (engine, everything else)
- Who has built mopar half doors?
- Heater Water Shutoff
- Electrical issues after removal of factory rer nav and infinity system
- Disarming the 2012 JKU Seatbelt alarm
