View Full Version : Stock JK Tech
- Throttle Body size
- Soft top_rear window_horizontal track bar
- Dangerous Steering Issue To Watch
- Soft-Top Left Down in the Rain!
- Wrangler X oil
- Stock ride height
- Dtc c123c
- Back Seat-Belts Lock Up
- Store soft top under hard top
- Who is the most JK tech savvy?
- velcro strap?
- Installing sunrider windows
- Relay Rod Tie Rod Connection
- Such thing as ruining a torque on a bolt?
- OH Shit Handel End Caps
- Popping clutch to start JK?
- Problem coming out of 4lo.
- New tires
- Mud cleanout & infiltration
- Cracking noise coming from right side of dash....
- 4 lo smacking sound
- Anybody use "never seize" on lug nuts?
- Squeaky Breaks: 09 Unlimited (4 door)
- noise from manual shifter area
- Jeep is in a Coma!
- Ching Chong sound
- Mother !#% son of !#@%! piece of !#% oil change light!!
- Tree Sap on Soft Top
- noisey trans?
- 2 DR soft top, putting it up alone.
- Tire/wheel question
- Dirty Fog Light Lens
- In need of a clip joint
- Disabling ESP - Easy!
- bent axle tube?
- center console
- Dumb freakin luck...
- Tip: Removing Stock Fender plastic clips
- Sweet! Dealer flashed my JK to add E-Disco for Free!
- Window scrape
- Auto Unlock feature resets when doors are removed.
- My fix for transfer case cable
- Atf 4 ??
- is dot 4 brake fluid what i need?
- anyone use valvoline syntec 5-20?
- Rear Seat Cover
- Axel Bearing
- My first Dent.. stupid door!
- Installing factory tow hooks on factory bumper
- BAS light
- Help! Too much water? Won't start?
- Leaking Dana 44 Pinion Nut
- Front driveshaft the same for 2dr and 4dr?
- Installing New Soft Top
- Need Help With Code: U1417
- E brake failure
- Steering Gear and Clock Spring
- Hard Top Touch-Up
- Loud Noise from Stereo Speakers
- T-Case knob, can I just cut it off?
- Regular, Mid Grade or Premium Gas????
- What size tires??
- Tires
- Clutch replacement?
- Thin sheetmetal on hood
- Oil Analysis
- 1st gear issues stuck!!
- Draglink question
- Door Help Please
- Turned off ESP and still came on ?
- Bare Floor?
- Spark plug servicing at 35,000 km's???
- Changing from 18" to 17" tires?
- Look at my Spark Plugs
- Clutch sound
- wheel weight
- 2wd Value?
- Axles
- Axle Seal Question
- Need a starter? Who has one?
- Fuel cap
- top questions
- Gas Milage
- Tire Pressure Devise Question.
- Back Seat floor Carpet
- timing cover leak question
- Silver Piece on Rear Bumper
- Rear Frame Cross Member Size.
- ASP, Axle lock,Sway Bar Disc control failure
- need a new throw out bearing already??
- 09 auto shifts different than an 08
- Alignment
- fitment
- Transmission question Th350
- wheel weight
- Which synthetic tranny fluid for 6 Spd Rubi?
- First time with the new soft top
- crazy sound coming from gas tank?
- Voided warranty
- Need Softop Hardware?!
- Relocating the rear axle shock mounts -- anyone done this?
- Rubi Springs vs. X Springs
- Drag Link Tie Rod End
- Removal of Stock Stereo for aftermarket
- wheel bearing? u-joint?
- esp/bas
- How much can I REALLY tow?
- Retrieving Code P0440?
- Do you have to remove rear wheels to install Ebrake lever?
- First Oil Change, Jiffy Lube, Mobile 1
- squeeking noise from wheel area??
- Gear oil
- Starting Issue
- stereo buttons program door locks?
- Back Doors don't unlock autmatically
- Door Lock Issues?
- water leak
- Need a little help
- Hard Top Wiper Blade Changing
- Loud ticking while idling
- ESP Disable Procedure Clarification
- need some help dealer cant duplicate
- Electronic Ingition 77 CJ-5
- Smittybilt hitch
- How to replace a throw-out bearing and clutch?
- Rubicon take off springs vs Stock X springs
- OEM battery--no separate warranty??
- stupid question where is my radiator petcock/drain?
- Who has Cleaned out their fuel filter?
- Fixed Steering now wobble?
- Correct way to install a cotter pin..
- "Clanking"sound when in 4-Lo
- Oil leak problem, maybe?
- Need Help Fixing this Hose-thingy to my Axle
- Wheel/Tire "Whistle"
- Axle or wheel? Problems with rearend.
- Change oil filter without draining oil?
- Air Vents
- Rubber thingies in header latches
- Oil pan kinked.... Can I still drive it?
- Broken Engine Part?
- Moog balljoints
- kumho tires
- Life of Brake Pads
- OEM sterring stabilizer
- Top of Sound Bar Wearing
- Oil Consumption....
- Front Panels without Back, Is this right?
- does the tpms have to lay flat?
- help with diff oil
- Evap Canister Hose Broke - Need a little help
- Weird sound when starting engine
- Unlimited Front Windows Wouldnt Go Down
- Will these tires Fit
- TPMS when changing stock wheels to stock wheels
- Where Is The Engine Number??
- rattle when pressing in the clutch pedal at rmps above 3500
- Rattle at the back after having top off a few times.
- stock gearing ??
- Have you seen the inside of your parking brake?
- Driver Seat
- Good Wax
- 255x85R16 w/ 4.5" backspacing - space under fender?
- Useful for all JK owners SHOP MANUAL
- Free Source of Owner's manual?
- A/C Colder on Passenger Side
- Driveshaft question
- 09 JK mirror relocation question.
- A/C vents smell bad
- 2008 Unlimited OEM RR Window Fits, LR Doesn't
- Will they fit
- Inline transmission filter
- Vibration: Drive Shaft or Torque converter?
- Is a high pitched noise upon Deceleration normal? NEED Answer ASAP Please?
- Plastic thingy
- Clover Patch Convert-A-Top
- Door rattle
- Moving to Canada soon. Question on winterizing.
- Wash-Out Interior
- Longer crank time when egine is cold
- Has anyone tried the Top/Cap EZ Lift hardtop hoist?
- Rear head rests won't fold??
- Anyone tried relocating the venting hose of the Auto Trans?
- Service Costs?
- So what oil are you guys using in auto tranny?
- Rubicon has 35k on the odometer.......
- Question on Soft Top Windows and Back Glass
- Parking brake cable broke (snapped?!?)
- Jeep soft top flaps!
- city mpg is better than hywy mpg
- Differential Drain and Fill Plug Sizes?
- Anyone else have a layer of darker stuff in the bottom of the coolant resevoir?
- Heat shield rattle
- Sound from behind the dash
- Clunk Noise in the Rear End
- Bike Carrier Damages the Swing Gate???
- Yet another ABS/BAS ESP light thread.
- Are these the half doors we've been waiting for?
- Clutch Problems Part II
- TPM sensor, Powder Coated Wheel & Now check engine light
- Rear Diff leakage...concern?
- Hardtop Torx Bolt Torque Values?
- 4-Door Hardtops ~ 07 and 08 Compatibility?
- Water Sloshing in Fredom Top- Factory Weep Hole?
- Turn the rotors?
- Auto door locks Code Please
- JK is at 20k inspection -- some guidance please
- Unsprung weight
- oil change light at 2540 miles
- Mud Stained Soft Top - How do I clean it?
- Got some odd tire wear going on
- unremovable door
- Anti Sieze on Diff Plug?
- 2 door tumbling backseat stabilization
- Novus 3
- "Hot Oil" light
- gear oil weight
- black sludge comes out of differential?
- How can you check if the hill assent is working?
- thunk sound from the back?
- Unlimited owners... how big?
- hardtop Hoist without garrage
- softtop fix?
- Opinion on brakes needed!
- battery question
- Adhesion Problem on Hinges
- Steering pump?
- Steering Column
- Tires on a stock JK
- Actual height of Rubicon Tires?
- Clutch TSB
- Door Lock Question
- Mystery part
- how to adjust emergency brake?
- Center Console for my 2007 Unlimited
- suspicious manifold emissions leak
- How heavy is the stock flywheel?
- Soft top material repair?
- Seat Height Adjuster (Broken?)
- lift pics and ARB front bumper question
- 2007 front bumper
- Is this thing gonna wake up soon?
- Bolt size?
- Aftermarket Jk goods for shipping in Canada?
- Help with canyon of mystery behind my dash
- Hard Top Hoist/Cart, Freedom Top Stand=TOP OFF!!
- Engine codes and sputtering
- TMPS question
- Question about hard top wiring
- Axle Differential Fluid Changes
