View Full Version : Stock JK Tech
- Took '11 into dealership for recall and they also flashed the PCM?
- Storing SunRider Soft Top
- Hard top availablilty update - April 2011
- AIR Horns
- Question about the k13 brake recall
- Auto transmission problems, Could use some advice
- How to tow 4 wheel drive 2-door w/o a flatbed - Need help ASAP
- How to diagnose spun bearing?
- HELP!! Breather tube problem
- Rev Limiter / Governor Question
- rear axle hop ?
- Floor 2008 JK and RPMs up but no speed increase
- Dash lights came on randomly
- 6spd trans
- Need help with factory mirrors
- Catalytic converter issues - need help
- Please help me figure out the piece I need for my soft top.
- Help! Broke bolt on door hinge pin..
- Another 'maybe' sign for a CRD Wrangler...
- disabling honk when locking
- Stock 17 tire size
- Hardtop seal replacement
- passenger seat.
- Has this happened to anybody else....I hope not
- Both Headlamps Quit Working
- mirror under 20.00 doors off
- Squeak when turning left. Ideas?
- EVC problems, No MPG, DTE, etc.
- wiring horn ...electric air horn
- Removing the "RUBICON" letters
- 2011 Wrangler Power Inverter
- Need help
- Planning on getting a Soft Top, I need some answers, please.
- Got a bizarre one folks!
- Sahara fenders?
- DIY Fuel injector cleaner
- OEM jack stoarge
- Trim pieces around windshield WTF
- Auto trans shifter cable comes off
- Popping sound coming from bottom corner of windshield
- Anyone use the Bestop HOSS window storage duffle?
- Manual to auto windows and locks?
- Who uses high mileage oil in new engine that consumes oil?
- 07 Wrangler Rear Dana 35 or 44?
- Transfer case linkage
- Click in steering wheel
- Rubicon Springs on Sport JKU, w/ aftermarket bumper and/or winch
- Differences in stock North American : European Models
- puttin some rubi stuff on sahara? ?
- TPMS Sensors
- fog light problems
- wind noise
- hot oil light
- what to do with screws.....
- Esp bas light help
- What size tires for stock rubicon wheels
- Help! Got a slight vibration when in reverse...need info/replys
- JKS disco setting
- anyway to make the rear seats recline more
- Anybody completely remove spare tire and bracket (third light as well)
- D44 Rear Housing
- EVAP Help
- ESC issues - warning triggers on highway in high wind and ESC engaging itself in 4lo?
- Auto tranny temperature range
- Rubicon skid plates
- 2007 Wrangler No Start , No Spark please help.
- Broken rear window zipper on JKU soft top...easy fixes? New rear window needed?
- Unit Bearings
- E-Disco Question (on the dumb side)
- JK Hood
- Serpentine belt length
- Jeep Will Not Start
- 2008 soft top fit a 2011 (JKU)
- 2010 Soft top back on but have extra pieces??
- Soft top differences? Sunrider vs. non-sunrider?
- Reseting the Change Oil on Dash.
- Picture Request: AEV 3.5in lift on 2 Door
- 2011 Unlimited Soft Top
- Weird smell
- crack/click when starting to accelerate
- Hardtop to softtop transition, I think I'm missing something...
- Ok alignment brain fart moment.
- 18 in. rims down to 16 in. rims
- f***ing all door locking!!!!!!!!?????
- Super stiff gas pedal
- Am I the only one that didn't know?
- Creaking front end; ball joints?
- half door leak
- Front Axle Breather Fitting - Sheared Off - Help!
- Hardtop removal with Gobi rack
- engine oil
- Softtop, shade 4 me n the dogs
- new wheels/tires & tpms
- Loose Front End
- 2007 - 2010 Soft Top question
- Should I change to synthetic oil?
- Need some expert advice so I don't get screwed...
- Jeep to put in hemi v-8 in wrngler rumor?
- Anyone have a spare/broke/burnt out power window switch?
- Lube Stock Driveshafts?
- New Lower Control Arms = What kind of grease?
- Extended warranty purchase
- Question - Removing Scratches from Soft Top Windows
- Hardtop Torx Brackets-Can they be removed?
- finally decided to schedule a service appointment for my JK..
- Slave Cylinder How do I get it back in?
- Rubicon Rims
- Are all soft top windows interchangable?
- Vacuum Bleeding Clutch Slave Cylinder
- what this things on my jk
- Pulled apart gauges, now not reading correctly.
- 2007 sahara spitting gas when filling up
- Need a favor - Underhood snapshot please
- Goodyear Wrangler DuraTrac's
- Clockspring or no?
- dealership big Bo Boo no oil left in transfercase leaked out on 900mi trip
- Is this the begining of the end?
- WTF With the DTC codes?
- Rubicon Stickers Peeling Off
- 15K Service
- A/C Vent not working (w/ picture)
- 2011 Stock Rake
- Will a front bumper from a 2011 fit a 2010?
- Transfer case trouble shooting questions...
- Cruise control and brakes stiffness
- can i tow this ?
- Steering wheel not aligned
- Building from up from stock base
- New Brake Pads at 32,000 Miles
- Removing running boards on 08 Sahara Unlimited
- Groaning noise under flex with stock '08 JKU Rubi
- Axle U-Joint Information Needed
- Very rough idle
- Vinyl Grey Seat bottom Replacement
- Anyone have an issue with the rear swaybar shifting?
- arm rest
- How do you check axle U-joints?
- Soft Top install (Door Surrounds) issue
- BLD Discussion
- New Brake Pads
- Extended-Life Oil Filters and Oil Change Interval
- Is this going to cause ESP problems...
- Leather - Luxury or Practical?
- Forum pictures
- Front end shake at 55mph
- Stock tow hooks are fucking weak!
- Quick tire question
- New TSB
- ESP problem
- Chassis Lube?
- Jeep will start but guages blank, stuck in park, wipers won't turn off??
- 4k Miles and back to the dealership it goes
- How hard is it to take off rear gate?
- Darn laminated joists....
- soft top nightmare
- security system problem
- Hour meter on instrument panel
- Spun Bearing; possible cause?
- How to identify a Rubicon's shock and springs?
- Overheating engine light went ON
- Just wondering...
- Dead JK No Start/Dash
- This is what happens when you drive a brick in windy conditions
- hardtop hardware question
- JK turned 100,000........let the fun begin.
- Sirius Radio Help
- Just got my 08' Rubicon, options?
- Sahara 2007 4dr service manual
- Wusssshhhh sound when turning engine off?
- JK Shutdown
- 2007- 2010/2011 OEM Soft Top Differences
- Seat bolster wear
- Too much blue?
- Gear ratio?
- Water leaking from muffler
- Death wobble
- removing the drag-link tie-rod end off at the pitman arm
- stock seats arent very comfortable
- After lift engine is misfiring **help**
- Squeak Issues with Driver's Seat
- Rubi Springs
- Singer Sewing machine Noise, ie throw out bearing Fix?
- Mechanical differences of the 2010 Islander...
- Removing front seats and what not to do.
- Rigth Rear Brake Seize
- where to get a rubi trans case ?
- Help !! Off Road Evolution Windshield decal Installation
- Wheel Stuck on Hub
- Any way to turn off automatic ratcheting system??
- Rain from the soft top
- This is a test
- TSB Coverage Information
- Where to Buy Interior Trim Fastener Hardware
- Grade 8 Washers - No good fit!?
- Towing a camping trailer?
- What is the name of this green?
- Rock Rail Install
- Will my old softtop fit?
- Rust--Hinges and Rock Rails
- Interesting trend/fad: swapping matching color tops with '11 JK?!
- Advice needed
- Suggestions on extending Tire Rack for bigger tires?
- replacing stock shocks
- Scratches in windows
- Hard Top
- tire pressue
- Stock fenders
- Code P0171
- Soft to hard
- Spark plug change interval?
- A very nice ride
- Need advise
- Need 2010, 2011 Soft top info
- Trouble Codes
- Need to replace thermostat...help!
- 12 volt dc sockets suck
- Quick Q regarding A/C
- Passenger Seat won't lock in place...
- Remove hard top pieces?
- Blackstone Oil Analysis Report
- Stock shocks - more harsh as they age?
- Rusty Drive shafts
- Steering Question (Not the "clunk")
- Wrangler to get Hemi ?
- Coasting in Neutral Damage?
- Fuel Gauge Issue
- Confirmed steering boxes are junk..
- Recall for brake lines
- Too late to rotate
- Fuse Mystery
- Engine light?
- Bluetooth GPS Question
- Black Plastic Protectant
- Cleaning Bottom Surfaces
- Stock tow package come with 4:10's rumor true?
- Anybody ever import a diesel JK into the states?
- Does anyone know where to hook up a fuel pressure gauge?
- Bushing affecting mounts?
- diff oil
- Radiator Drain
- noob
- JK Oil Burning?
- Installing Smittybilt JH45
- Best Source for Tinted Window Kit
- Needed way to pressurue up tires, cheap, fast, temporay
- Just Drained and Filled Front and Rear Diffs for the First Time...WOW
- 2010 auto tranny fluid question
- Brakes sqeaking all the time?
- thinking about taking a dealership to Court
- A little over 23,000 miles and the dealer says I will need brakes soon? WTF
