View Full Version : Stock JK Tech
- Rubi springs
- So what's the grti-like stuff on my hood, and how do I get rid of it?
- Power steering
- stock bumper
- Hard top squeak and my ghetto fix
- Jeep pulls to the right in 4WD?
- Flex
- Great News. My 2010 Navigation Map Update is here.
- 2-door with 4-door springs: owners chime in please
- shoe polish on soft top windows........
- 2007 JK Front Differential
- Drake Hood Hold Downs ? Any Good?
- Where To Find Replacement Hardware
- Mannual Tranny Question
- Sluggish hesitation when switching gears???
- Will a 2010 softtop fit my 2007 JK?
- What backspacing?
- Slipping on turns
- Driving on 0....?
- tpms dash indicator..anything else?
- How fast can you drive in 4high!?
- What oil do your recommend?
- Tire Advice from those of you in the Icy North
- Smittybilt CRES
- Aftermarket hitch reciever..
- Can you use too much friction modifier?
- Water drips off the top with door open?
- Soft top and dealership advice
- New JK starts, stops after 1 sec. And this 6 times...
- Take off the plastic covers on the tail gate hinges?
- Tire Storage
- Mopar Matte Black Hood Decal on a Rubi?
- Quality of 3.8L V6 Components
- trans axle shifter bushings
- Resetting the hours on the dash
- Bug Deflectors
- Engine Failure Check in
- Removed/Replaced Front Axle, steering wheel crooked?
- 2007 JK Engine blown!!!
- Swap plain OEM JK bumper for OEM JK Rubicon bumper?
- Small Tear in Factory Seats
- Squeaky headrest
- Price check please...
- Which one is the drive tire in the rear
- Oil change schedule
- rad cap cold
- Touch up paint for Hard top?
- Freedom top leaking
- Mysterious Wet Floorboard
- Low Tire Pressure Light won't turn off
- First Mods done, questions on leveling kit, wheels, and tires.
- Maintenance after sitting for 10 months...
- Cowling Plastic Fasteners
- Mexican made Engine?
- Warranty Informaiton - Need Help
- Removing pass side airbag cover
- limited slip
- 70K mile brakes
- Have you fit a '07/'08 Hardtop on a '09 or newer JK Unlimited?
- Mopar Kayak Carrier??
- How can I get more flex...
- Help! How to disable the initial Seat belt chime alarm!?
- Rubicon sticker
- Seat Adjusting Down On It's Own
- Clutch Chatter
- Rubi Dana 44 rear question..
- Any other "07"s need piston rings
- Engine light on ?
- Knocks or ticks...
- wiring harness for freedom top
- Manual Transmission Fluid Change ..
- Oil seal leak and general questions
- Ok lift done, is the stock suspension worth anything?
- Locker light flashing....
- Coming up on three years, should I replace my battery?
- Stock 2010 JK UNLIMITED SPORT mods, is it safe?
- 4 Door Hard Top
- Jeep and Guns...it just rolls of the tongue
- Vibration in drive train
- AC Knob Removal
- 2010 Engine Issues?
- Rubicon switch????
- Dust coming in fresh air vents - preventable?
- Running Hot
- Engine Oil question here...
- Why V6???
- Heater not getting hot, HELP!
- Freedom Panel whistles
- Bent Door Hinge?!?!?!?
- Hard Top Making Creaking Sound
- timing cover leak
- Hard Top Installation
- Evap Canister source?
- Custom hood painting??
- Unable to read from OBDII port?
- trac lock 385 bucks!!!
- Interesting Engine Sound
- Manifold Bolt Size
- On the road again .....
- Flat Black Hood Decal
- My time for new tires - Firestone Destination MT
- Exhaust Pipe extreamly rusted?
- Wheel well plastic divider rubbing on frame?
- Front Locker
- 2009 2DR Jeep JK - My 50K mile comments
- Soft Top and Snow
- RealWheels Grill Guard
- new engine
- Aftermarket Soft Top
- Rear axle seal is leaking, help me decide what to do
- Weight rating for stock tire carrier?
- new steering wheel
- Seat Covers
- Tailgate Cargo Rack
- 10,000 miles between oil changes?
- Burning your clutch?
- steering stabilizer braket Broke
- Rattle from back of jeep
- Aftermarket grab bar
- stock wheels painted with bedliner
- HELP!!! Check engine light P1404
- Are your bump stops supposed to make contact while street driving?
- Slider with steps
- 2009 wheels on 2011 JK?
- Removing Third Brake Light Cover
- Annoying manual transmission feature.
- Compass
- Need Some Help Here - Battery Warning Light and LOUD Metallic Rattle
- POLL!!! Powder coat vs. Spray/bedline stock rims
- Carwashing the jeep
- Operating Temperature
- How to turn off Change Oil indicator?
- Rivot gun for stock fenders?
- ignition question
- Sticker residue HELP!
- rattle under dash
- Falling out of 3rd gear?
- One Headlight brighter then other
- Best way to tow your JK.
- Anybody know what this switch does?
- Calling all painted Rims
- 09 Sahara Auto Gears?
- 2007 windshield pic!
- need help on freedom top
- Jeep Shaking like crazy!
- Leaking coolant
- How bad is it to.....?
- Cruise Control INOP
- TPMS-I have searched but still no difinitive answer
- A/C Vents
- Stock wheels hitting tie rod, steering stops?
- Door rattle
- Stock Shift Knob Removal?
- Measuring 5 on 5 bolt pattern
- Software upgrade = More power?
- Interior Squeaking Fixed.......FINALLY!
- Smoke Tail Lights
- Rugged Ridge Sound Deadener
- Xmas gift list....re-post
- Help a newb out - what are these straps for?
- How many miles do stock dueler at last?
- How many miles on stock dueler at?
- 2009 2dr Rubi Shocks on a 2010 2dr Sport
- Just hit 50k miles. Service suggestions?
- Dark Oil
- Crawl ratio on Rubis?
- snapped my brake line
- track bar bolt hitting brake line?
- Paper vs K&N vs Airaid - My severe test results
- How to get Fresh Air Ventilation with Hard top on & window up?
- Door weatherstripping
- Click in the steering column
- hard top touch up
- Smittybilt G.E.A.R. Tailgate Covers .. Any good or Not worth it?
- No heat on driver side
- Change to full synthetic at 10k km's
- OEM Remote Start Antenna Placement?
- ESP BAS/Traction Control light stayed on
- Air Filters
- Should I switch to synthetic diff fluids before the 15k mile..
- axle seal leak
- radiator help!
- Dead in the water
- infinity subwoofer bracket?
- 2010 soft top
- oil consumption 08 rubicon
- Deep rattle sound from engine compartment on cold start
- Oil loss diagnosis found
- Death Wobble
- Cold air from dash area
- Front brake pads, Dana30-44 are they the same.
- will this be ok?
- half doors ??
- Soft top leaks onto back seat
- Cut down a Dueler...Now what!
- Soft top issue HELP a newb out!!
- 33X12.5X17 on stock Moab rims
- No skid plate.
- Changed Muffler?
- Back gate open on road
- Windshield Replacement
- need help P0100
- grinding noise in front when in 4wd
- Lug nut size?
- Struggle Putting Softtop On
- Any issues?
- squeak, squeak, squeak
- Hardtop question
- Hardtop good price
- Patching up firewall Insulation
- What is this?? (34611-B Hose)
- 2 dr and 4 dr flares
- 2008 JK Sahara Unlimited tires/wheels
- P2173 - High Airflow / Vacuum Leak Detected (slow Accumulation)
- No Engine Crank Or No Engine Start Due To Electronic Lockup Of The WCM / SKREEM
- Hard Top Rear Glass Replacement
- Jeep Upgrade Question
- Passenger side air bag
- Option codes
- Need transmission help asap
- Gas Cap message question
- Where is my brake fluid going?
- Driveshaft Exploded and My EVAP Canister Caught on Fire
- Engine Acting Up?
- Unlimited rear headrests
- Engine temp gauge broken again...
- 2011 Sahara Wheels
- 2007 Wrangler tire pressure sensor compatible with a 2009 Ram 1500?
- Cylinder / Spark Plug Order
- New Clutch, New Issues
- What is trans-axle fluid?
- Green puddle under driver side rear axle...
- Stinky Heat
- Transmission and transfer case capacities
- Sqeeking Brakes
- Warn wireless driving lights installation?
- dealer flushed heater core twice still no heat on drivers side
- Rumble strip feeling upon acceleration.
- Stock Hardtop Question
- Defrost/defog annoyance
- Sticker Removal
- hoist a top for jeep unlimited hardtop???please help>>>
- Spring Setup - 2 choices
- Dual tops... Or 1/1/2 tops
- Advantages to having Freedom 3-Piece Hard Top on 2 Door Wrangler?
- Rear Seat Won't Fold Down
- Flat tire, do I need some TPS service kit?
- How do you adjust the windshield ?
- wheel stud
- Which Floor mats?
