View Full Version : Stock JK Tech
- PIC REQUEST: Mineral Grey Moabs on a White Unlimited
- 2010 burning oil
- Door Removal
- 08 Auto Trans Noise
- Soft top removal
- decent looking mud flaps for a Rubicon?
- Where did you buy your Transmission Filter?
- 2012 jk
- Slight sqeaking sound when turning right
- ESP BAS what the heck are they?
- Steering Stabilizer replacement
- Torque specs on catalytic converter 3.6 pentastar
- How does the hill descent work?
- Warning Lights HELP ( ESP/BAS,ABS,Traction Control)
- Cigarette Lighter HELP!!!
- Jammed Seat Belt Fix
- Seat Covers
- Rust on winsheild brackets
- 2009 jku
- Do i need to lift my car?
- 2011 clutch problems at 18,000 miles.
- Intermittant Rough Idle PLUS choking out during driving
- Which one is clntrol arms?
- How to reconnect rear defrost connector wire to window?
- Moog steering part numbers?
- Oil filter sandwich adapter, sending unit, & control arm
- Pennsylvania Owners - Wheel Spacers
- jk manual shift boot retainer thingy snapped.
- Need Help w/ Tire Size
- Window tint hole?!
- 2013 Sport S vs Sahara
- 2012 owners manual?
- Rubi spring swap
- TPMS from a 2010 work on a 2011?
- Which Hitch?
- 2011 Starting Issues!! Help??
- Driving on sand and manual trans problem
- Poor gas
- Diagnose my bad clutch
- taking doors off
- Tire advice....please...
- Stock rubicon subwoofer question
- 2012 Rubi Dana 44 Diff Covers not the same.
- Fenders.
- Stock evaporator cannister
- 2011
- Flood
- Horn Intermittent Sounding
- Leak
- 2012 3.6L Oil Filter Info
- JKU Electircal Issue
- Help with my jack kit
- Please help identify this part
- Bestop bow knuckle compatible with OEM
- Rear hardtop window seals
- 11+ JK Center Stack Switched Outlet Connectors
- Bedline stock fenders and bumpers
- 2013 dragon jeep headlights
- '10 Manual Trans Shimmy
- Do Jeep rims fit on a Toyota Tacoma?
- Oil leak diagnosis
- '12 JK draglink on a rubi (is it bent from fact)
- Seat Belt Rattle NOT THE DOOR PILLAR
- Wheel Offset Help Please.
- Loud noise from door
- Startling amount of rust on 07 JK
- Rubi locker parts????
- Water in Front Hard Top Panel..
- What is this for??
- Sub not working
- Neutral rollover......WHAT THE???
- clutch ticking noise
- auto start question
- Why does my Pentastar sound like a donkey?
- Rear speakers
- My fenders are falling off!!!!!!!!!!!!
- 2009 hardtop on 2011
- cant get sun visors back on, is there a trick?
- Final Decision on Steps!
- FED UP with Fenders !!
- 2012 soft top
- Diff size?
- 2013 Leather Trimmed Seats Pictures?
- Removing Rubber "Nipples" On Hood....
- 2012 acting weird
- Stock JK 2 door tires
- soft top leak?
- 08 JK Clock Spring
- Rino linning
- Rough runnin
- Timing
- Engine Break-in period
- How much should i sell my stock 17" 5 star rims and tires for?
- Tire help please :-)
- Hill assist
- Brake Pedal Noise...
- Savegre wheels
- New Soft Top 2013
- Help please! Stuck in huntington beach..
- Soft top window
- cracks on dash
- Front Driveshaft CV replacement?
- 2013 JK Pics Thread
- Rear ABS plugs.
- A little warning if you are buying antifreeze for your 2013 JK (or other 2013 Jeep).
- how do i use factory rubicon sway bar quick disconnects?
- window roll up
- Bimini top / Cargo net attachment tip
- Code P0830
- HELP... With tires
- Can you change the color of the Jeep you just ordered??
- Mud/splash guards
- do i need c gussets already
- 92 Jeep Wrangler YJ Ground Cable
- What is mygig? I must be dumb
- New 2013 Rubi Wheels .... what do you think?
- Emergency top for getting stuck in rain????
- Auto dimming mirror and map lights
- Mygig
- How many miles are stock JK going with the stock auto trans before rebuild???
- Question about the 3.6 RPM at 70 MPH
- Remove stickers
- lift for 12 Rubicon
- $10 Mudflap
- Oil leak
- Diff removal
- Has anyone replaced the steering box themselves
- '07 3.8 throwing P2110, P2173, P0507 codes. I'm stumped.
- pic request: tire height stock vs 33's
- Mojave Production Numbers
- anybody making a locker replacement for a RUBICON d44 front yet?
- 730N RHR Keeps Losing Home Address
- Mygig wm4?
- Moisture Under Floormats
- help
- Gas Mileage with speedo off?
- Pentastar Head AA - AB Issue-2
- new jk owner with top questions
- Jeep not starting
- Fender cut
- Hard top inside cleaning
- Mud Tires on Stock Sahara
- Was this a fluke?
- Will these tires fit?
- Leather seats in my 2012 altitude 4dr
- I did the tune up in a can. It works!
- 2011 hard top fit a 2013??
- gear lube info found online, good reading
- Lost patience and broke red tab off electrical connection when taking the doors off..
- Rushing water sound on first start up
- 2011 knocking!!!
- 2012 Oil Filter
- napa 5w-30w full synthetic oil
- # of drain plugs?
- Drivetrain vibration when starting out
- Cylinder head issue and No warranty..
- Has anyone had this problem ?
- 6-Speed shifting issues
- uh oh
- billet metallic??
- Tech Service Bulletin 06-002-07: Throw Out Bearing And Clutch
- Excess play in 6 speed manual shifter?
- 2012 Value
- bumbper
- Oil change indicater
- Clearing Odometer Messages ?
- Photoshop help 2013 Black JKU with the dark stock wheels
- Hard Top Driver's side leak
- YJ/TJ Parts Swap Help
- Soft Top Window Storage
- Stock JK bumpstop
- Rubber gromets in tub?
- valve body
- Needing 92 Wrangler body Parts.
- repetitive slave cylinder problem
- Locker relay mod usages
- Should I trade or not
- B&M cooler help
- compass 180degress off
- Loose and missing caliper bolts?
- What should I do??? Help me decide...please!
- Take key out of ignition, Jeep thinks its still in there
- another diff lube question
- Click vs Tick?
- Strange noise from my manual transmission
- Rubi 32s on Sport S with 3.21 Axle-extra strain on Pentastar?
- How much and what weight diff fluid for front RUBICON d44 axle?
- Rear window straps? 2012 soft top unlimited
- record new trail using Trip Log
- New "Pentastar V6" production at the Chrysler Group Trenton South Engine Plant
- Hard top
- Soft top
- Question about idiot lights
- Used MOPAR Wheels hold any Value?
- Strange auto transmission problem
- Weird hesitation in reverse after going through big puddle?
- tire size question??
- Pentastar Spoof Tick Video
- JK Stock tyre wanted in UK
- Transmission skid plate recall
- Muffler size.
- Broke the front axle...in bad location.
- What should be regularly serviced?
- 2013 Rubicon wheels
- Oil consumption
- Pentastar Engine Assembly Date vs. Build Date
- Softtop vs hardtop on leaks
- Soft Top mounting question.
- Rubicon shocks
- Frame rust, under carraige , one possible solution :)
- Starter issues?
- Back in the shop
- 2012 softtop work on a 2007?
- Kayak Rack Install
- raining andoid app
- pentastar head problems?
- Looking for lights/lightbar
- Vivd Linq help, recalabrating my speedometer.
- Stock JK with no lift. 33x12.50?
- Two last tire questions and I think I have a decision
- 2013 Auto Climate Control - Does it Work?
- Lift kit and warranty..
- Radio staying on with the doors off.
- MyGig,,,
- Sunlight and the Dash
- Power mirror relocation?
- Square Turn = Power Loss and Traction Control Warning
- Rough Idle Problem
- Front crossmember
- has there been a recent "tuner shoot out"?
- Driver Seat keeps lowering/ Nav wont remember home address JKU 2012
- Jeep wont start after 1 hour of playing stereo with engine off
- Storage net removal
- '13 question <what are the wheels> ??
- front axle trouble
- Help with intsalling soft top?
- leaky transmission.
- Riddler Diff covers
- Legality of chopped fenders???
- Z-Max or not
- No lift! What tires?
- Starter Problem----Think it is heat related???
- FYI - Differential fill plugs
- BFG Rugged Terrains T/A or Definity Dakota A/T
- wheel balancing with aftermarket wheels
- !!! just lost reverse WTF!!!
- Transmission Pan RTV Red VS Black
- Door Storage Problem
- What are these for ?
