View Full Version : Stock JK Tech
- What is this and why is oil leaking from it?
- License plate bracket removal
- Tires
- Automatic
- Check engine light troubles
- Sport suspension vs sahara suspension
- security enclosure
- Steering wheel vibration/grinding while in bumpy turns??
- Original skid vs "improved" recall skid
- Soft Top Window Scratched
- Stock Fog light wiring??
- Center Console with arm rest
- Gear Question
- Factory mopar slider pic request
- Cargo Mat, 2-door, rear seat removed.
- Your thoughts on this oil seepage...
- 2dr driveshafts
- Adjustable height front seat lowers itself
- 305x70x16 on stock 2012 JKU
- Free Tire
- another tire question...
- Adding hooks to bumper
- side mirror ???
- Common causes for a whiny engine???
- Death wobble? :(
- Spark Plug Wires?
- Engine trouble plz help!!
- Rock sliders
- what are the vents for on inside of tailgate for?
- bumper questions
- Locker Questions
- BFG KM2 Question...
- Shaky Shifter
- What would YOU do if the front locker on your Rubicon broke?
- 2008 stock soft top fit my 2011 ?
- Need advice please - P0128 code and dealer explanation
- 18" tires
- anybody going to a pickapart salvage yard for jeep parts...i have a request
- Quadratec maps
- High pitch whine, decreased gas millage?
- Alarm...
- Passenger Side Entry Light?
- Rear Carpet/Lid?
- E break/manual sliping on incline!?!?
- Water Sound in Hardtop
- Larger tires on 2010 two door with stock everything else
- Clicking noise in 4lo
- I'm hesitant to call it "death wobble"
- 2010 hard top on 2011
- How fast can i go?
- TPMS display reads wrong tires
- PCM burnt out/warranty ?
- Heater fan noise
- Tranny issues
- Lift with BL question
- Warrenty issues
- JK Rubicon Front axle Quadratec side diffrential bearings vs OEM? BIG $$ difference.
- What to do first?
- Manual transmission fluid change
- Swapping Gears from Bent Housing to New Housing.... Questions???
- anyone know what tool you need to disconnect 2012 fuel fittings?
- Cold Start Clicking & Spark?
- So, is the cylinder head issue resolved with the 2013 models?
- Rear Floor Cover Fastener
- Oil?
- Spiderweb shade Ultramesh or Trailmesh
- warm starting problems
- 1k to spend...
- HELP! Dana 44 - 2012 Rubi
- Can I use a 2 Door Steering Box on a 4 Door???
- Engine warning light- EGR failing?
- I did somehing kinda dumb
- Diff fluid 75w90 or 75x140 Hurt?
- Need to remove gas tank on jku, any tips ect?
- Know how to replace inner shift boot?
- Northridge address???
- steering wheel replacements
- HELP!! EVERYTHING is going heywire! I'm stranded!
- Towing with Jk
- Light grinding noise
- Does 2013 Rubi JKU offer brown/saddle leather seats?
- power loss question
- Need Help ASAP
- 10th anniversary rubi unlimited price....keeping my sport.
- Jeep dead
- Factory radio upgrade.
- Rattle coming from?
- Door handle quit working. Need help!
- Is a sport JK worth drive off road
- resurface rotors?
- 2013 JKU Rubi Pinch Seams Done at Factory!
- What axle ratio is in the 2013 Rubicons?
- 4hi 4lo lights not working
- Battery connections
- Wobble, but not death wobble
- 2013 Rubicon making weird noise :-(
- Summer top preferences
- Gas milage
- FOB Battery Lasts 2 Weeks
- 2008 Limited Life Time Power-Train Warranty Issue
- Gas spilling everywhere
- DTC Code Question
- Rubicon Question
- 265/75r16?
- Plastic air dam
- Ball Joint and U-joint Replacement
- manual trans issue
- Radiator Fan HELP!!
- Front axle shortage?
- something doesn't look right
- Royal purple
- Looks like my Jeep is breathing.......
- Frustrated with leaking top... Help or suggestions needed
- Lifetime Max Care & Sway Bar Disco
- Easy entry front seat standard on 2009?
- What is this behind my bumper?
- Wrangler CRD Turbo hoses HELP!!!!!
- Diff fluid
- Getting in Jeep and squashing down seats - what can I do?
- Stay with stock wheels??
- Need some advice nitto dura grapplers.
- Key Won't Turn in Ignition
- 730N Question...
- Mopar Splash Guards
- Warranty ending soon: what to check for?
- Mid Rivers Jeep St. Peter's MO purchase
- Engine oil
- Seat Covers
- Anniversary Rubicon... shorter tires than regular rubicon?
- 2011 Tranny?
- Window tint on 2013 rubicon option?
- Passenger Side Wiring Issue
- Hard Top Leak Help! Past 36k warranty...
- Saddle Leather Tear / Rip
- front glass
- Rock Sliders
- Torque Spec for JK
- tow capacity
- One key, manual locks - can I install remote start and use the kit for my spare keys?
- Offroad heros soft top
- Installing JKS Quick Disconnects
- cruise control and headlight
- Burned out clutch in 4low on rocks
- Disabling Brake Lights
- Cold air intake
- Flood Rebuild Questions
- Florida - OK to go without side mirrors?
- I love my JK but...
- Radio help??
- Dana 44 in 2012Sport
- How do I clean the intake manifold?
- Uconnect issue
- Left Rear rotor scraping noise
- Hard bump, lose speedometer, and then all idiot lights
- Ipod touch and my 2009 Sahara
- ambient temp
- Wavy rear plastic window normal?
- HVAC Blower Motor stopped working
- lights turn signals and brights not working, I have a 07 rubi JK ?
- Replacement tops
- Esp help
- PSI for Goodyear Wrangler SR-As
- Gear Ratio???
- Transfer case drive shaft seal issues?
- 2012 JK Engine pinging / knocking
- EGR Tube Leak
- Diesel in Ram
- Can anyone tell what type they are.
- TPMS light won't turn off
- Top Cleaner/Conditioner/Protectant
- Transfer Case Shifting
- How to best clean the undercarriage on my JK
- Rattle noise-wind related- coming from lower passenger side-AHHHH!!!!
- 2012 JKU grey smoke
- jeep death wobble help
- Help removing pinch bolt?
- jcr bumper
- Help my JK makes Owl sounds
- Stock Tires w/ 2.5" of lift
- Clock time
- Transmission problem in automatic?
- 3m paint protective film patterns
- Squeaky clutch pedal
- MetalCloak suspension - price quote
- buying used soft top advice
- Coolant Fluid?
- Powerstroke.
- Transmission and drive shafts?
- Rattle
- Need opinions on tires.
- Hypertech Max Energy Programmer HELP!
- alignment help
- Stock JKU tire size?
- Hardtop Alignment Pins 2011 hardtop on 2009 JK
- P0300 engine code
- Fuel Overflow Warranty Notice
- Whats the best value ?
- Pcv valve
- Changed my auto trans fluid today
- Hit and run
- 2010 Starting issue.
- Soft top question
- Bikini top for jku
- Good old windshield replacement
- 12v power outlet not working
- 2012 6 speed shifter knob rattle?
- Plows on your JK/JKU
- First time in snow.. wheel hop?
- pavemeant ends cab curtain tanno cover and top reveiw
- 2012 quit and won't start.
- Hard top to soft top
- Unhappy with Purolator PureONE
- oem 4dr soft top
- Anyones 2013 Soft Top Leaking?
- Bestop Superdoors on 2012+
- ANOTHER newb tire question.
- clutch and throw out bearing
- 2010 unlimited 6sp shifter problems! Help!
- OEM Rubicon Locker Study
- Cleaning engine bay correctly
- Selling stock parts from 2013 jku rubicon and no idea what to ask for price?
- Need help, transmission fluid level.
- Tail Gate Water Leak
- Air vents universal?
- Trade Hardtop, Black for Silver
- Fuel tank inlet
- Looking for some oem half doors for my full doors.
- Cargo security options
- jk just shut off
- 2013 Rubicon sloshing noise in dash
- Battery question
- 2012 Problems with new cylinder head
- Stock Track bar?
- 17" Rubicon wheels
- Side mirrors "fall"
- Bigger Tires with no lift
- Tinted windows on premium softtop?
- Any ideas? The dealership couldn't find the problem.
- Help minnesota
- Power widow power door locks washer squiter all wont work....help
- Sahara fenders on Rubicon?
- Anyone else have a weird shifting into OD in the auto?
- Storage options for zip-out windows
- Painted flares
- 15 inch rims on a 2011
- Wheel spacers?
- Minnisota Members HELP!
- Problems playing Ipod with U-Connect
- Fender flares
