View Full Version : Stock JK Tech
- Hard top
- Manual shift lever malfunction on 2015 JKU
- Tire cover recomendation
- 2014 ETC and traction control lights
- Help me identify this small rubber pad
- 2012 JK Starter Solenoid Not Disengaging
- front pinion seal
- 2016 Auto Transmission Pan Bolt Torque
- Soft top hard window?
- Smoking brakes
- 2017 Factory heavy duty tire carrier question
- new used JkU, check engine came on and more
- MAN Those Doors Are Heavy!!
- Removing tree sap from my soft top.
- hardtop questions
- Finally wanting to get "popping out of gear" fixed
- Jeep turn off in water
- Very strange issue with cabin vent airflow
- Door lock not working
- License plate stock bracket and LOD
- Door Plug Question
- 2016 unlimited ABS problems. Engine dying
- Stock 2010 JK, blown engine - options?
- Wire near brake in drivers seat
- Gear oil for rubicon
- Shop is confusing me help spend my money
- Bent axle
- "New" 2015 jku with 8k miles running hot.
- Feeling fortunate
- Trail Products Bumper
- Dana 30 Axle Housing
- Hardtop question
- Leak front drivers area
- K&N cabin air filter replacement
- Help me identify this brake noise!
- Tire size with stock suspension
- Check Engline Light - EGR valve code P0406
- Stock JKU Rubi shocks and springs on a 2010 Sahara 2D?
- NP231J synchro keys.
- Rubber gaskets.
- Best CB Location
- 2013 JK 3.6L engine knock
- Off road trailer build question
- Great touch up paint
- Throttle position sensor
- Shocks that are too short.
- How do you disconnect the Rubicon e-locker plug
- Have a lifetime warranty? Check with dealer before the 5 yr inspection
- 10th Anniversary Hood - What bug shields will fit it?
- Warn Industrial Series 15 in a Hard Rock Bumper??????
- Whining/heavy wind like noise when I let of the gas 6 speed ?
- Door removal
- Jeep starts but doesn't stay running.
- AC not cooling dealer can't diagnose
- Dented oil pan. Replace or leave?
- This thing
- Rear locker light keeps flashing
- Making the rear light change with original parts at no cost
- JK Front Seats
- is a PROGRAMMER worth purchasing?
- Shuddering
- Check engine ?
- Water in fuel tank??
- JK speedometer error?
- Stock Spring swap
- 2016 steering has a thump when return to/past center.
- 40k miles and blew a rear axle seal
- Contacting Chrysler
- Monday Rant!
- JK stiff throttle spring?
- Brake Pads That Don't Squeak
- 2012 jk rear bumper tire carrier
- Catalytic converter 420 code ?
- Brakes or traction control issues?
- BesTop TrekTop NX Twill in Canadian Winter
- 2009 JK Overheating with AC on and climbing hills
- 2009 JKU Dash Freakout (Video) help!
- 2015 JKU Veering Right Even After 2 Separate Alignments
- Smell antifreeze but no visible leaks...
- Help Steering Shimmy
- Same height 315/75/16 and 315/75/18
- 2012 JK D30 dust shields - keep or not?
- New Engine just put in my 2014 JK
- 2007 Break Problem
- steering box
- towing a 3500 lb trailer
- Jk 3.8 stalls out at higher rpm???
- Help -- Seat won't recline
- Check engine light: Oil sensor sender code: JKU 2014 50k
- 4wd shifter cable linkage issue
- OBD-II Scanner
- Kill switch
- 2012 jku stalling on highway
- Stock Tire Carrier to Tailgate Torque Specs.. help:)
- Build Sheet Info - Easy
- Clock spring, or no?
- Stuck starter
- Truk lites
- ESP/BAS light code C121E–BRAKE PRESSURE SENSOR COMPARATIVE PERFORMANCE
- Heater Core Swap in 30 Mins
- 2012 6 speed help
- Tie Rod End Replacement Questions
- Lost Key
- New jeep owner!
- 2016 JKU 4.10's Install Question
- Alarm sounding engine doesn't crank.....because of thieves
- 2016 Jeep Sahara Unlimeted
- Dash Bolt Help
- Jk stock track bar maintenance
- Oil leak
- Power windows
- 2014 Premium Softop on 2012?
- Oil leak
- 2010 JKU Auto Transmission Troubles
- 2007 Jeep Wrangler Sahara Hardtop Issues
- 2008 jku transmission woes
- Electrical Issues
- Front door stock soft top seals
- Heater core hose replacement tips?
- Zipper...
- on board menu operation
- OEM air box, picture and ?
- Control arms for a 2009 JK unlimited
- hinge bushings
- seized d30 spider gears?
- Pop on acceleration.
- Need help wth evap hose issue
- Electric life power window kit: Anyone use it? Opinions / advice?
- 4 door jeep with roof racks.
- anyone have the steering wheel button lights flicker? and fix?
- Softtop Owners
- 13 JKU Feels Like it Tugging
- Missing Windshield piece?
- Warm weather startup knock?
- Jeep clicks 1 and 2nd time then starts
- P0205, and P0520 Codes same time out of the blue
- Jk rear seat prices
- Tire rotation
- Got this cumputer code
- 2010 JK Runs then stalls and won't restart untill 1 hour or so.
- program your Jeep
- Tow package help
- Grinding/Dragging from the rear
- Buzzing from Transfer Case shifter area
- Urg, Driver ball joint
- Bent soft top frame
- Smell gas fumes outside of vehicle
- Shot U-Joint passenger side plus my 5 cents
- Front fender flare clips
- P0404 code on 2010 wrangler
- Troubleshooting my 6 speed manual
- 30k Maintenance Menu
- 2014 JKU Sahara coolant temps
- Oops, Mirror Cowl Dent
- Question About Rock Rails...
- U1402 - Implausible Engine Temp & P1281 engine performance AFTER dealer "repair"
- 2012 stuttering from 1600-1800.
- Jeep won't start just clicks and windshield wipers, which are off, wipe after attempt
- 2015 Wrangler Freedom Top Rattling Noise...
- Check engine light codes!! Any help would be great!
- Any "Remedies" for Window Crank Hitting Knee?
- Motor mount/Tranny mount problem after collision
- Engine options
- Bottom radiator hose cold top hose is hot
- shift linkage broken
- Won't shift into 4L (JK, X, 08')
- What year soft top do I have?
- A/C Blower Motor Not Working
- Bent tailgate corner
- IN JK Cat / Engine Hell with our 2007 Rubicon Unlimited
- Towing
- Transfer case pouring out fluid at transmission joint only 350 miles
- Broken manifold stud...
- Lower Control Arm Question
- 1st Jeep
- Wheels really hot
- Jeep or 4x4 Shop in Nassau County NY
- Sevice problem help
- Anyone Using Trail Products Bumpers?
- Windshield Wipers Won't Shut Off and a Bunch of Other Weird Stuff
- Recommendation on new tires, spacers and budget lift
- Rattle with engine under load.
- Air Bag Recall
- Air: Fresh vs. Recirculating
- Tie Rod End Boot
- 2013 JK Rubicon Autostart Not Functioning
- Technical Bulletin Labor Hours
- Oil Filter ADBV (Anti Drain Back Valve) Test for Cold Startup Noise
- RPM's at 70mph?
- Oil change mistake
- Power steering goes on and off randomly
- Rock Hard Brand Tire Carrier Reviews?
- Best Front Bumper for the $
- 2007 jk will not accelerate/bogs down ?
- Sway bar articulation issues (maybe?)
- Engine light
- Front Brakes
- Jk p0402 code tired of my jeep breaking so much
- Stock Shock Swap
- Ticking noise coming below, looks like front driveshaft has issues ? took VIDEO
- Driver Side Motor Mount
- Check engine code P 0340
- Nitto Trail Grappler or Toyo Open Country R/T??
- 2012 Jeep wrangler renegade package
- Broke The End of the Hinge Pin Nut Off
- Soft Top Required (Now)
- Bestop soft top
- 2008 JKU and 8 year old son wants to put a lift kit on
- Jeep in failsafe limp mode, code P0344
- Seat Heater Switch.
- Wheel Hop
- Doors wont unlock with fob and buttons inside, lights flash randomly on their own
- Threaded brass insert for factory bumper
- Sahara flare dent
- Well, finally happend. An oil leak.
- Wheels shake/turn when going over bumpy road
- Jeep Wrangler JK Driveway Power Steering Flush
- Clicking noise from front drive shaft Repezza joint
- Seat belt flapping
- Remove Stock front bumper reinforcement steel
- Clock spring recall...still a myth?
- Will a 2010 Soft Top fit a 2015
- Jeep towing an enclosed trailer safely
- LT285/70R17/D or LT255/80R17/E Stock Wheels, No Lift
- PCM, WCM, or what???? - MERGED
- Zip tie Mopar part.
- A/C wont engage 2010 JK
- Bad vibration
- Small scraping grinding noise
- 2015 jkus coolant leak mystery.... HELP
- Could I run 295/65/18 on a stock JK???
- Anyone using HotHead Polycarbonate Soft Top Windows?
- New Shoes
- Stock track bar replace bar or bushings?
- Need help, 2012 JKU stalling, smells like fireworks
- How-To Tuesday: Jeep JK Programming Features
- where can I find passenger side pillar moulding?
- Weird beep and speedometer wacky
- Cross bar roof rack
- Clock Spring Repair
- Quadratec Quick Release Mirror Movers with Square Head
- TOB Noise or Something Else?
- JSPEC 3.5" J Kontrol suspension system
- Will this work? Ignition key question
- Help finding the factory door panel pin retainers
- Under the sun inserts.
