View Full Version : Stock JK Tech
- Broken Tie Rod
- kenda klever
- Engine Loosing Coolant
- Time for tires!
- What to use on rubber door seals
- Throwout Bearing just replaced 2 weeks ago
- Radio Changing Chanels Itself
- Hard Top Interchange
- 2013 2-Dr. soft top. Am I missing pieces?
- Jk bumper restoration Easy!!
- Keeping Old JK's Young
- Whats next for my 2009 JK 4 door?
- seatbelt tensioner
- 2014 vs. 2015 Rubi
- New trailer question
- Im having a wierd issue ....help me out please
- New Jeep but has used parts?
- tail light screw clips
- Swapping the Auto for a 6 speed Manual
- Need Mechanic input. Shifting troubles
- Dash display, sport vs sahara
- 2014 JKU Soft Top question...
- No start - doesn't even try!
- plasti dipped
- JKUX to Rubi shocks & sprigs
- What fender and where to buy lights ?
- What are these two detailed build codes?
- This morning got started off on the wrong foot
- 08 Engine Concern
- 2008 JK 2 door Heater Blower problem
- Looking for guidance with axle seals '10 JK Unlimited X
- Front Passenger Door Leak!
- I just bought an 07 and am now hearing a slight ticking noise. video here PLEASE help
- wobble at 55-65 only
- Running a 3.8 with no O2 sensors
- Rampage jerry can tool box holder and mount
- What's it worth?
- Traffic light hates my Jeep
- Door measurements
- pulsating at idle
- 33" tires w/o lift kit
- Looking for help with my wind shield washer reservoir
- 2 door compartment space
- Roll Bar Mouldings
- Changing sport fenders to Sahara color matched
- 2013 jeep engine oil pressure switch malfunction.
- Air bag light.
- PLEASE HELP! My 07 JK with trouble codes P0201-206 and P0304!!
- Complete soft top removal?
- 2014 build number question
- 17x8.5 rims on 2015 Rubicon hard rock
- pinkish sludge around oil pan gasket?
- 2015 steering wheel lock
- 2015 colors
- JK Engine Oil DipStick
- Hardtop keyed :(
- any cure for a whistle sound
- stock jk
- 4th right rear axle seal wth!!!!!!!!!
- A pillar clunk
- HELP! Transmission noise--shifting from R to D and the aftermath
- Auto Trans shift
- Lights and Wipers Flash on when starting up
- Engine swap
- 2009 manual 2 door accelerating on its own?
- Trans cooler line leak
- Blinker/brake light isn't working, but running light is
- Is this a concern?
- New stock bumper with fog lights
- Stock air intake?
- location of oil pressure switch and a rattle.
- Soft Top Zippers
- Tie Rod and Center Link - Lotta Play - HELP!
- Do I have a possible problem with my diffs?
- Check Engine Light
- New Clutch while Trans Being Repaired?
- Rear cargo difference between 4door and 2door without rear seats
- Help! 4WD Shift Knob Removal 2010 JK
- Brakes
- Painted hardtop question
- we all have clocks that lose time....
- Why do I sometimes have to crank my JK 3-4 seconds before it starts?
- Half Door help
- Softop question
- P0206 P0306 & Fuel Injector removal
- windshield wipers are terrible.
- 07 JK stall/ wont start
- Replacing Spider Gears.
- Anyone use BOSCH QuietCast BRAKE PADS for their JK? Need your opinion
- 50K miles MPG data - every tankful 2012 JKUK
- New JKU question(s)
- 2014 JKU oil filter cap o-ring location
- drag link, vertical play?
- JKU leveling kit
- Seat Risers
- Ball joints
- Heated seat switch
- Problems with windows.
- 2015 JKUR ATC Concern
- Traction Light, ABS Light, ESP BAS Light On - Having trouble troubleshooting.......
- 1st time changing diff fluid question
- 2011-2013 wranglers being recalled for heated mirrors
- Need some purchase advice asap!!
- 4wd light
- 2011-13 recall for side mirror electrical connector
- Looking to buy a Smittybilt winch
- Rear Main Seal Leak... Maybe?
- Sunrider Soft Top?
- sedosa cloth?
- Key sticks in ignition
- BFGoodrich AT VS. ProComp AT
- Group's Input re: Synthetic Oil
- Brand new rubicon problems
- Can You Teach Me to JKU? (Things that took you a while to figure out)
- 2011 Automatic transmission maintenance
- Average alignment cost
- Recommend a Jeep Dealer San Diego area
- is there a switch for fog lights I'm somehow missing? pics please
- Roof Alignment
- 2013 JKU Sahara axles
- Duratrac 275/70R18 on Stock Sahara with OEM 18"????????
- rear axle seals and bearings
- Front Passenger Seat of 2dr back portion wiggle.
- Electrical gremlin....help!
- Spark plug failure
- Chriping noise
- bicycle bell noise
- Dealer denied warranty service
- Handbrake Assembly Part #
- What am I doing wrong?
- Most common problems w/JK
- AEV Snorkel install
- Lifters sticking on 3.8
- where do you store your freedom top knobs?
- Missfires 300 + 305
- error codes p2122 and 2127
- Need help with headrest clamps
- Purolator PureOne oil filter O-Ring issue
- Clutch is soft and its hard to shift gears after replacing Master and slave cylinder?
- Side steps
- Freedom top holding water
- Tape covering rear seat mounts in floor of JK
- Keep it, trade it, or dump it? What should I do?
- Oil change reset
- Hunting troubles
- Aftermath of 3.8L engine swap
- Buying Rubicon shocks and Springs off of CL ????
- Is there anyway to lock and unlock Jeep JKU with key and not have alarm go off?
- 2014 2dr rubi rock rails
- Rear driveshaft replacement
- Help: what is this connector?
- Esp for dummies
- BF Goodrich mt km2 35 12.50 18 or GOODYEAR WRANGLER DURATRAC TIRES LT275/70/18.
- Surface Rust Under the Car
- Jeep 2013 Sahara 4 door double towing
- Coolant Flush Question
- HELP! Jeep won't start
- Gear question
- Engine Squeak?
- Hardtop fitment question
- Mopar Beadlocks
- Lifetime Powertrain Warranty cover fixes for codes P0455 & P0430?
- HELP , where do the positive / negative wires from the battery lead to ?
- Torquing Track Bar Bolts: Best Method
- Shimmy after small bumps.
- 2007 hard top on 2013 JK 2 door
- rim protection for winter
- 3.8 vs 3.6 underwhelmed
- TPMS question.
- transmission failure on an 08
- 2015 JKUR and Not Happy!
- Soft Top Removal for winter
- Pics of 33"s on stock 16" Sport Rims
- o8 auto rubi trans failure???
- play in tail gate
- change tire size or install a lift?
- Brake Pedal
- 17 vs 18 stock wheel?
- Tuner to improve fuel consumption.. how exactly does this work?
- What is this?
- 2012 JK tuners....any of these tuners any good for the JK?
- Whats a fair price for half tread 35x12.5x17 BFG KM2s?
- 2012 battery - sudden death
- Lots of issues, small amount of time.
- Oil Filter Survay
- oil pressure senson P0520 fault code
- Hard top sealed tight?
- Anyone own more than one vehicle?
- Rubicon Sway Bar Problem
- Need to prop up cell phone on 2011+ upper dash panel
- Rear door vent ?
- Tube Bumper plus Hidden Hitch on front of JK Unlimited
- Wide Tires Bad?
- Windshield Wiper Fluid Leak
- Changing Heater Hoses
- a headlight/foglight questions
- Clutch Master Cylinder Replacement: Link to Step-by-Step Procedure
- 4.10 ring and pinion
- adding a 12v outlet?
- Takes several key turns to start. Starter ? WCM ? or Battery ?
- trans line leaking again.
- drive line vibrations?????
- Fog light out. New bulbs?
- Oil change
- Oil consumption solved!!! (for now)
- Jack point?
- 2015 Wrangler owners need to read
- VERY annoying brake chirp on 2012 JKU!
- Stoopid little door pocket net things.....
- P06DD Code on 3.6
- Low Windshield washer light
- Rust
- What is this?
- Over Heating
- 2-Door Hard Top Question
- Help with a new Rubicon
- Mystery switch
- Disable HSA on 2014 JK
- Diff oil amounts on dana 44
- Simple Mods
- Jeep repair In north county san diego
- Purchase Decisions.....another 11 vs 12 help!
- Firestone Destination A/T as daily drivers
- Hi jack mount
- Never Without An Issue
- Is the JK really that uncomfortable?
- tie rod adjusting sleeve
- can't find a 2007 rear bench seat anywhere??!!
- 35's on a stock rubi? Just kidding its a thank you
- Upper Oil Pan Leak. Help/Info Pleas
- SRC side armor fitment
- Failed Cam position sensors - AGAIN!!!
- Soft Top Alignment With Windshield Frame
- failed smog test????02 sensor catalyst
- jeep smokes from under hood occasionally
- Dash alignment issues
- What lift should I get? Help!
- Max Tow Group Factory Diff Fluid
- shift lock manual override
- manual transmission shifts without clutch
- BF Goodrich 35 12.50 18 mpg ?
- Temperature gauge and alarm honk out of whack
- Auto Trans will not leave PARK (Until it feeeeels like it!)
- Leveling Spacer
- The noises have begun!
- Oil Change Problem
- If You're Using Fram Oil Filters, Better Read What Happen To Us
- Offical Jeep App
- A Replacement axle shaft…
- Tie Rod Ends - Hex Hole on Threaded Shaft
