View Full Version : Stock JK Tech
- Custom rim and tires
- Are the 2014 remote keyfob same as 2008
- Air dam support bracket hanger.
- recommended lift?
- Need help replacing my 2008 3.8!
- Best way to fix...
- Pressing brakes produces an air (swoosh) sound??
- Teraflex 1.25" body lift
- Wide Angle Mirrors
- 10 yr aniversary
- 10 yr aniversary
- Interior panel part number
- Alternator
- Remote locks and starting
- Spare key....
- Help with Vibrating noise near A/C Knobs
- jk performance upgrade?
- Could Driveshaft Vibrations damage anything?
- Bestop trektop(not nx)
- Grinding gear
- Replacing O2 Sensor-- help
- Seat Cover
- Goodyear Territory Anybody use Them
- Hardtop
- I think my dealer is F@&:$ing me
- Oil Change Computer
- Cargo Net
- Identifying JK7 Dana 44 Gear Ratio
- What options are necessary and which are not?
- Rust touch up paint
- ESP Off question
- Gap between windshield and dash... lost stuff?
- Odd noise when accelerating after shifting into gear.
- This sound
- Part identification
- Anyone knows the cause of this ?
- JK Stock Curb Height Measurements
- Tie Rod Replacing
- Fair Trade? What should I expect?
- Trektop NX vs. Stock Soft Top
- AC compressor loud, is everyones the same??
- Airbag Rattle Fixed! 2012
- Bump stop
- 4WD quit working
- Sahara hardtop compatible with Rubicon?
- space behind the front of console?
- Daily Driver, 2014 Rubi, 4.10 Gears, AEV 2.5 Lift, 35" BFGs... Do I need to regear
- Is there room?
- Gear Oil
- Does anyone know how much a factory soft top is?
- Tire repair question
- 2010 soft top on a 2008
- EGR Valve Pricing
- Ballistic vs Neoprene
- Upgrade to Rubicon shocks
- 2013 stock rubicon parts on my sport after my brother lifts his?
- Feels like gas pedal is less sensitive...?
- Defective Head In 2012s
- Anyone have stock 1/2 doors and leak problems?
- Spare tire carrier
- Seat Cracking
- Headlights flickering???
- 2012 2 door - tore off my rear license bracket off-road...
- License plate delete cover problem
- Trip three for "P0302"
- Parking lights coming on when steppjng on the brakes
- 07 jk crash report
- 2013 jku fan shroud
- getting closer to curing my front end woes
- 2 Door Jeep Owners!
- Im Having a few issues....
- Any gains to be made?
- Axle shake on 09 X
- Catalytic Converter Location on 3.6 Motor
- What rubber hose is this?
- P0300 & P0152 Codes - What to do next?
- How to Check DTCs w/Out a Reader
- Tail Light Flip Issue.
- 3.21's
- Slave cylinder plastic piece.
- Wipers move intermittently an inch when car is off.
- !? 911 electrical help ?! HELP PLEASE
- Any brand coolant?
- 2007 Auto Trans not shifting
- Sudden rise in oil?
- HELP w/ JK
- JKU X offroad capabilities.....
- Windshield washer question
- Drag link bar replacement
- loss of gas milege
- Clutch problem HELP
- Teraflex OR AEV Leveling Kit???
- 4Lo not working
- Anyone running 285/75/70 Tires?
- Electrical Question
- Bent stabilizer: leave it on or take it off
- 21/2" lift kit
- 2008 Rubicon front differential lock sensor
- who is running 4.10s on a 3.8 with 33's
- rear axle stuck on the pumpkin side
- skid light
- When to do the first oil change?
- Well, she started burning oil
- Help me identify this Mopar Premium soft top! ...what is this thing?
- installing gibson exhaust.
- Steering wheel help
- 2007 2 door right front seat won't latch.
- Half door lock cylinders
- Windshield defroster
- 10k miles service
- Washer fluid won't spray
- Summer engine oil
- Towing Capacities.
- Front Diff Leakage
- What snow depth is a challenge?
- CB radio mount
- Oil
- Three questions before ordering lift and tires.
- Half Door Upper Window Skins?
- 2013 Parasitic Drain Update
- Foggy windows
- Which Tire?
- Argent or Black Pintlers on Granite Jeep
- 2014 stock getting 13 mpg..?
- Button next to trac control?
- Anyone else have a 6 speed that has or had a hard time shifting into first?
- Ax and hi lift jack mount??
- Dipstick
- sale pricing
- OEM Switches
- Help me get more heat for rear foot passenger...please?
- 2010 4-Door Sahara Issue
- 2007 engine knocking
- Need help diagnosing this noise
- First time Death Wobble! OH NO!
- excessive engine braking?
- switches in stock trim
- Did shimmy/ DW return?
- Differential Fluid for a Sport 2009 JK
- Freedom front panel/rear soft top cover option?
- Adjustable vs Non-Adjustable Ball Joints
- A/C Not Turning On!
- Anybody's mopar gas cap cover fit like crap?
- I love craigs list 275 70 18 AT under $500 bucks
- 2007 Sarah sometimes won't start
- Actron AutoScanner (code reader), would this work?
- Waterpump replaced at 20,000 miles
- Bad battery?
- Stock upholstery removal?
- 2011+ Wranglers....Dash bowing around 430N radio...... Solution?
- Different Experiences/Different Dealerships
- Vibrating or Rattling type noise at 1500 rpm?
- Mopar mud guard issue on 2013 Sahara 2 dr.
- Tire Size Options on Stock Rubicon X
- Help with differential issue
- Nitto Trail Grappler M/T
- Gearing?
- 2014 unlimited automatic trans
- Rubicon X Thread
- What size lift
- 2.5" lift advice
- Sounds like water/liquid is running/dripping behind my dash
- Can someone help me with a leak problem, pictures included...
- Alignment keeps changing
- Help on 10mpg
- 2014 JK Soft Top - Front sides flapping (near door surrounds) - suggestions?
- 2013 Interior Pricing?
- tire carrier
- Rear wheel squeal
- Argh! Can't turn!
- Rampage 595001 Freedom Top Storage Bag and subwoofer on a JKU
- are people still having any issues with the teraflex monster trackbar?
- Where to find P/S heated side view mirror glass?
- twin piston WJ caliper swap?
- License plate mount to spare??
- Check engine light
- 2014 Getting water on the driver's side floor
- Motor oil on my air filter???? 2012
- Please help me with this question....Thx!
- Loud high pitched noise when driving
- Serpentine belt part number?
- No start, jumped then flashing crazy lights
- 100% factory OEM Heated seats in a 2012
- Concerned about open diff/have BLD quesiton
- driver airbag simulator resistance
- Stock Gears
- Anyone know what gears im running?
- Problem matching gecko paint.
- Blend door
- Stock driveshaft service
- Gas mileage change
- gears tires and speed questions.
- Nav update
- Tpms
- Tip Start
- 2012 with 24k Miles, do I need to do anything besides Oil Chg and Tire rotations yet?
- Slow dealer service, but mod friendly?
- Oil change/tire pressure sensor.
- Beginner Question -- Motor Oil and Filter Brand Preference
- looking for part number
- Auto transmission help--slipping gears
- This is why I love my stock JKU!
- Mopar sunrider soft top 2013 vs 2014
- Do any Rubicon owners add quick disconects to thier Rubicons ? ~?
- so what can I do about the passenger grab bar?
- Dealer fail on the power steering recall... PS broke on the trail
- Coolant leak
- Steering wheel squeak
- Cylinder 5 misfire P0305
- part numbers for the 19/60 jku springs
- More questions on 2013 JK
- Difference between The ne coolant Oat and Hoat.
- time to do head gaskets?
- Oil burn 3.8 warranty work
- Ideas for bumpers and fenders?
- 2014 JK - Upgrade to auto headlights
- factory block heater
- High Pressure Power Steering Hose Connector
- Took a vid of my water pump noise....
- Humming vibration when turning left
- One more soft top question...
- front locker light flashing
- Apples!!
- When you wash it...
- Coolant reservoir level fluctuation?
- Soft top clicking noise passengers side
- Transmission fluid cocktail
- Re: Fluid changes.. Diffs, Transfer Case, Tranny, etc...
- My jeep dont like 2nd gear
- Soft Top Question
- Rubi Poll
- Windshield Bullseye Repair
- check engine light comes on and no throttle responce
- EB light
- Electrical help needed for hardtop
- What's leaking?
- 2007 Rear softtop tinted wondow
- Do I hsve/need transmition cooler for towing
- Using a K&N air filter with the 3.6 engine
- Esp bas
- Direct Wire Rear Defroster?
- Tips for getting the top up quicker??
- Help please! Auto trans issue.
- Trans problems
- Rainy day leaks....
- upgrading the interior
- Programming on Plain Key?
- 7 secs to shift?
