View Full Version : Stock JK Tech
- Interior Upgrades
- Cylinder 6 misfire P0306- no other codes
- 2018 JKU Issues
- CHMSL wiring question
- Fuel neck, venting issues
- Starting Issue - loss of power
- Wiring Diagram
- Engine Won't Crank
- Dust shields
- Sway bar, rear. Concern
- 2015 Rubicon running hot… then fine after burping… then hot again. Help!
- 2008 Jeep Fuel Relay issues
- New to me 2007 Wrangler
- Engine compatibility...???
- 2012 Jeep Wrangler Unlimted Sport 4dr_Power Transfer Issue
- 2wd front suspension questions
- Can't Find Removal Information anywhere for trans
- Axle ? During Ball Joint Installation
- Fuel Injector Wire Colors
- New Heater Core - Cool at Idle
- Cat code - is there a work-around.?
- 2017 JK engine cover pivot bracket gromet?
- Injector Connectors HELP
- Chasing High Misfire on Driver side Bank 2,4,6 Jscan question
- Need help identifying missing interior parts/model numbers
- CV boot leak, can I grease it temp to safely get a week of short driving ?
- Oil Bypass Valve in a 2015??
- Rain leaks - front passenger area
- New motor time? Annoyed
- 2008 JK Misfire
- Hardtop parts
- Is this sound "marbles in a can"? Trying to figure out the source
- Newbie JK owner .. new to this group
- TCS alert - parking break problem?
- Jeep transmission help
- Coolant temperature sensor issues
- Front carpet replacement with rubber?
- 3.6 misfire cylinder 2
- 3.6 Fuel Injectors
- Stock radio
- oil leak - coolant leak - pressure test
- Code 394
- Spare key
- P0298
- Head Gasket Failure
- Brake Vacuum Booster Pump Failed?
- 2008 JK Misfire
- Removing a supercharger? Worth it? How hard?
- Another 3.8L Lifter Tick Thread
- Advice concerning my exhaust manifold (driver's side)
- JKU Fuel Injectors, Coils, Plugs?
- TCC p0740 does not reset….WHY?
- 2012 Brake Circuit issues
- Help, rear carrier questions
- Zingy Gas Pedal
- 2015 JK No Lift Vibration under load
- 2013 so many codes
- NSG370 nightmare. Please help
- Is 2014 a bad model year?
- Need advice - bad rear diff
- Jk d30 hypoid offset + pinion drpth dimensions needed
- 2015 JKU Lifter/Rocker tick, plus coils & plugs - advise please
- Drivers side marker AND turn signal work intermittingly
- No front signal lights
- how to test thermostat?
- Gas overflow when filling up
- Gallery plug mystery
- Metal Pieces in Rear Differential - I assume it's shot...not safe to drive?
- J-Scan ABS Bleed help needed
- 2008 jk Coolant Leak
- Overheating - 2016 JKU
- P0420 and P0430
- power steering
- MIS FIRE - Don't forget Boots
- Intermittent TPMS/Sentry light issue
- Oil cooler replacement
- Rear wheel well repair!
- Gas mileage sucks when check engine light comes on
- Blend Door Operation
- Help bloody check lights?
- Interesting Issue. Need ideas!
- Winch Plate for Stock JK Bumper
- No crank - random occurence
- Odometer Reprogramming?
- Delphi fuel pump for 07 JKU?
- Alarm will not shut off 2016 JKU.. any ideas?
- Fueling Up Issue
- 3.6 multiple cylinder misfire rough idle loss of power
- Broken Drive Shaft - 2008 JKU Rubicon - Questions
- Parking Brake Clutch Disengage
- Shutting off fuel pump
- Carobotor K1 radio help (Speaker fade front to rear)
- 2012 Rubicon JKU Automatic code P0473
- blowing hot and cold air
- Sudden spike in engine temps / heater blowing hot and cold
- 3.6l thermostat
- Repair Manual for JKU 2012
- Jeep bucks, shuts off, and kicks back on
- 2013 Jeep Wrangler Sport with multiple DTCs.
- Transmission Fluid Leak
- Steering Wobble
- First step into a larger world, now what is this noise?
- P0018, P000D, P0300 Tried Multiple Fixes
- Issues with ignition light and traction control
- Radiator cap
- hot air on passenger side but not driver side
- 08 3.8 rebuilt - no compression
- Help with clips…?
- Tranny Leak Questions
- AC/Heater control knobs do nothing
- no horn, steering wheel buttons and traction control light on
- New Cat from stuck o2 sensor?
- Just Rolled Over 350,000 Miles...
- Freedom Panel Leaking
- Auto Heat works part time
- 2012 Jeep JK Unlimited Sport S - 3.6L Pentastar Engine
- Putting it back together
- dead battery
- 2015 Jeep Wrangler Part Identification
- Confused about axle seals and diff fluid - send help!
- Potential engine failure at 45k
- 2015 fuel pressure issue. 3 garages still not solved!
- Coolant sensor help
- Grinding felt at gas pedal
- Transmission Issues 2017 JKU P1731, P0730, P0732
- Looking for Shocks
- Noise when accelerating
- Taillight Harness for Flat Towing a 2017 JK
- P0304 Troubleshooting
- Track/Guide Blend Air Actuator Arm
- Coolant gauge and Heater up and down
- Diff fluid question
- 3.6L Timing Rebuild
- 2014 JK radiator flush
- My JK is Haunted
- Torque specs for NAG1 / W5A580 transmission
- 2014 Automatic stall
- Torque Converter Clutch Solenoid
- Jeep JK Engine Tock Sound
- Electrical Geounds at left-rear of engine block
- Heater core or the plastic box?
- No Menu Button for EVIC access
- Wiring diagram 2011 JK Wangler Unlimited
- Front axles out - can I run in 2WD with no diff lube?
- How to ID JK OEM radiator?
- Door Limiter Strap
- JK no start
- 2013 jeep wrangler jku...need input
- Noise 1st to 2nd gear
- Front axel/yolk play
- 2010 2D 4x4 Gas Tank Replacement
- Any good stock tierod replacement options?
- Dies when cold runs great the rest of the day
- How do I access the marketplace
- Water Pump Leaks
- 2017 JK first key turn nothing, second turn starts
- HELP!! Can’t get jeep to start
- Knock knock....
- Completed JK Rubicon Axle Swap- Issues
- Camshaft position sensor seal
- Coolant leaking from the water pump
- 2015 CEL code P0741
- Door storage bins
- Got these codes-advice?
- Bosch injectors in a 3.8?
- Jeep JK motor mounts
- Pitcock vs hose removal to drain radiator
- 18 JK running hot
- P0344, P0369, other - reason battery?!
- Front wipers not working properly
- OEM Gold Brake Calipers
- Trans pan bolts on JK
- Brake Rattle
- HOAT Coolant ph test
- Another no heat thread
- Door Locks Gone goofy
- Engine Shut Down
- Brake Switch Causing Hyper Flash?
- 2011 JK heat
- What Power Steering Fluid--2008
- Just Another Cylinder Head Thread
- Engine Temp Issues
- 2017 Jeep wrangler will start, sun for about 3 seconds, and then will power down
- Multiple Codes after replacing Camshafts.
- Door hinge worries
- Why do door locks do this?
- Clutch Vibration ticking noise
- 08 JKU No Crank No Start
- Cloth door limiter endpoint connectins - hook and loop/guide
- Can you help me identify this coolant hose that wen 💥?
- Front speed sensor, what came out doesn't match
- Low Heat on Driver's Sude
- Shifter button not working
- 2011 jku low oil light
- 2013 Wrangler Mic not working
- Coolant Leak 08 3.8L JK 2DR HELP PLS...
- Alfaobd VVT System Test
- fuel light on
- P/N heater control unit 2016 75th Anniversary edition
- 2014 2015
- Bad Slave Cylinder seal???
- Left Rear Window Operates Only From Rear Switch
- Rubicon Sway Bar
- Help with Alignment
- Dana30 question
- 2012 JK Rad Fan Ghost Issue with P0480 code
- How do you get passenger tie rod out???
- JK 3.6 Belt Tensioner support bracket leaking coolant?
- Engine and transmission 07 wrangler Sahara
- Engine Codes shortly after head gasket replacement
- What are these buttons?
- Passenger side door leak
- Replace rear d35 with d44
- Wiper MultiFunction Switch
- Half Door Upgrades, mirrors & locks
- *VIDEO INSIDE* Here's a video I did on the new sky view hard top from Putco
- Bottoming out and losing control over bumps (low mileage stock JKU)
- P0128
- Post wreck rough idle and vibration
- How to replace oil pan transmission? Wrangler JK 3.8L
- 2013 CEL issues and I'm stumped!!!
- JKU 3.6 running warm @ hwy speed
- Intermittent stalling
- Jeep Wouldn’t Unlock, Now Won’t Start With Alarm System Activated
- Help please over heating issues
- JKUR may be possessed?
- Fender flares
- STP or CAD file help!
- Help, cranks but will not start
- Reservoir Coolant Level
- Trail damage
- Tubed door latches
- flywheel alignment / index
- P0349 Camshaft position sensor A circuit intermittent Bank 2 - 2015 Jeep Wrangler 2-d
- Tire Air Pressure
- Bypass stock ATF cooler
- Help JK Ticking After Lifter Replacement
- cranckshaft sensor location
- 2018 JKU running hot
- Jeep JK stalled at light, won’t start now
- Intermittent starting issues
- Clutch does not engage - Vehicle won't move
- P0038 P0058 2009 Wrangler
- Weird shudder while idle comes down
- When I accelerate my JK it fills me with errors
- B1A25-invalid key
- air bag warning light
