View Full Version : Modified JK Tech
- Bullydog 40410
- Zone Offroad 4" lift.
- 285/75r17 question
- Which diff fluid?
- Oil & Engine skid options - Auto Rubi
- Oil change
- 1310 CV Driveshaft
- AEV vs RC Rear D44 diff slider/skid plate (any opinions?)
- Does this jeep have a lift?
- So confused...
- changing from 285 to 315s with 2013 jk
- Dynatrac Disappointment
- Break it DOWN! Need someone to explain parts and pieces, and how they work
- Transmission cooler
- Which Stinger can fit a 20" light bar and has fogs????????
- 2" Full Traction Premium Coil Lift - Anyone running this lift?
- jeephut, worst customer service ever
- arm upgrade
- Below Freezing temps means.....
- Arizona Rocky Road Antennas
- Which new tires?
- acceleration - steers left / brake - goes right
- Stock JKU Wheels
- Synergy tie rod and 15" rims
- Shovel Mount $15
- 4wd problem
- Centerforce dual friction clutch
- Just ordered Duratracs for stock wheels! 725/70r18. Questions inside.
- 2.5" Lift, Flat Fenders, and 37s.
- 37in tires
- Which gears for dynatrac 44
- Noises after installing Rough Country 2.5" spacer lift
- which coils
- Best skid to protect my e sway bar motor..
- RCV axle shafts came in less than 24 hrs!
- Springs to actual height
- crack in tie rod threads????
- Truck-Lite headlight question
- 2.5inch bb on stock 2010 jeep wrangler sahara unlimited with factory wheels and rims.
- York OnBoard Air w/3.6
- Negative affects from wheel spacers?
- poison spyder hood louver color matched?
- Synthetic winch cable selection
- Prepping for a long drive questions
- Will this frankenlift work?
- Chalk test question
- OPINIONS- POLL - Which tire carrier set up
- Jk grille
- 2.5 off road
- Upgrading my lift
- 3.5" Lift and 33's and now WHAT HAPPENED TO THE GAS MILEAGE???
- Fuel tires and lift
- RIPP Superchargers 2012-2013 TUNE UPDATE!!
- PSC RockBrawler Trail Wiring Harness
- Type of greese for warn 9.5 rebuild.?
- Breaking loose control arm bolts
- Beefing up front axel. Few questions.
- Good front end alignment shop in DFW
- Is this a goo price for MTR Kevlar Tire 37X12.50R17LT
- A different kind of axle question
- cb radios
- Mild 2014 JK Buildup
- New Fuel Tank Needed...Again
- Very very VERY bumpy ride.
- Who makes the most encompassing/largest front floor mats?
- Custom Colored Lug Nuts
- Anyone have the new Drake dash top storage tray?
- Help with lift kit decision
- Tire size, weight and gearing question
- Stiffer springs
- Tire pressure
- Chinese ARB copy!!
- Clicking noise in front end (HELP)
- Going big, tire help plz
- AEV Pintlers with 285/75/17 KM2s
- Rock Krawler's poor customer service.
- Best MT for on and off road
- JK Wheel Spacers
- What is NEEDED for a 3" lift?
- Most Important Skid Plates To Buy?
- Wiring options for third brake light on a swing-away tire carrier?
- Any MyGiG lockpick users with multiple cameras?
- Gear issue
- Twin ARB Compressor Problem
- RCV axles
- Metalcloak 2.5 duroflex vs RK 2.5 X factor
- Smittybilt XRC swingaway tire carrier and third brake light issue
- Aev fuel caddy but stock rim won't fit
- What Did You Pay For Remote Car Starter?
- Stock amp location
- Body Lift Questions (and pic request)
- Winch lube
- Help buying new Wrangler Duratrecs. Looking to buy online for decent price?
- 285 vs 315 road manners
- Rancho RS9000xl shock help/info question please
- Need a spare wheel for roof mount, what works?
- kargo master roofrack
- How do I get my drag off?
- Failing t-case?? About to explode??
- Spiderweb shade or Dirty Dog shade with Freedom Panels
- Supercharger thoughts
- axle upgrade??
- 2.5" Lift Question
- hi lift hood mount and a pillar lights?
- DW issues, drag link, pitman arm
- After market HEADLIGHTS? Recommendations?
- Rear corner armor
- High flow catalitic converter
- Broken sway bar and links.
- Axle side CA mount
- LCA and alignment
- Mods throwing trouble codes????
- 33's snd tire pressure
- Raptor bed liner on bumper?
- Anyone have experience with the rugged ridge hurricane flat fenders?
- Exhaust Tips on Stock Exhaust
- shocks
- I need a powder coater in Charlotte, NC
- Re-gearing ideas?
- Diablosport/RIPP Superchargers Needs a 2014 in the West Palm Beach area
- Spooling synthetic winchline- should it be messy or neat?
- Poison spyder DIY swing down carrier
- FOX ATS Steering Stabilizer Install Question
- 2012 on 37s
- 2010 jk hemi 5.7 swap install
- Chrysler Voided My Engine Warranty for Using their Mopar Cold Air Intake.
- Mopar dome hood for cheap!?
- Clutch Advice
- Truck lites (I'm Sorry)
- Size &Type Of Springs
- Rimzonline.com review
- leveling coils
- Faded ProComp 7089 Alloy
- AEV Hood Install ???
- ABS and fiberglass grill?
- Hemi people, what is it?
- moisture problem
- Drilled door handle design like logo?
- Ace enginering slant back tire carrier?
- Locking Hood Latches??? Any experience or suggestions?
- what sliders are these?
- Balancing and PSI for 35x12.5/17.
- Oiled vs Synthamax Filters
- 315 Rub Front Bumper
- Super Swamper TSL Boggers
- leveling kit pucks or springs
- Looking for 37 12.5 17 General Grabbers saw them at SEMA
- Where to buy Viking Winch line
- Flex problem
- Best Ball Joints for D30.
- what shocks to buy?
- Coil Spacer Question
- Smoking Deal on Gas Cap Cover
- Why move the vacuum pump?
- New 3870 superchips 2011+ programs. Are they working for anybody??
- some one please check this link
- ACE mid width bumper
- Rotopax Creative Mounting Ideas
- 35" tires - aggressive but quiet
- Largest Duractrac size I can run on stock suspension and sahara wheels?
- Alignment question after lift
- Caster
- Rock Krawler 3.5 with 35s?
- Tires
- is -1.1* Camber OK?
- Is 5.4* caster OK?
- Which 3.25 lift
- KC led headlights
- leveling kit??
- Ace Pro Series rear bumper
- Order of my lift build??
- Procal with manual?
- Procal or Flashpaq
- Jerry Cans or Rotopax?
- Rear Bumper
- Are these 17" or 18"
- People who have 37s does ur jeep drive stright???
- Rugged Ridge Hurrican Flat Flares
- Need fresh opinions on Fierce Attitude MT
- Is there a storage container that fits well in the "trunk" area of a JK?
- So what wheels are everyone running?
- what wheels are these? Bushwacker red Jeep
- Mickey Thompson ATZ or ProComp Xtreme AT tire?
- Skid plate or relocate?
- New 2014 JKUR Build
- Building corner armor, what lights to use?
- Axle Suggestions
- Lift kit and keeping the rake?
- Syngery 3" coils or Rock Krawler 3.5" coils
- 2014 jkur too wimpy of battery for Warn winch?
- Getting alignment in pittsburgh
- I'm tired of oil change mess....
- Which rear 1" coil spacer - Teraflex or others?
- Need help to decide buy JKUR manual 13 or auto 14?
- 3.6L Catch Can Questions!
- Nitro hammer in sleeve for D30
- PSC Hydro Assist pump help
- Mopar Lift Warranty…just an FYI
- Roof Basket
- RC 2.5 coil lift with 1 inch coil spacers
- Best U-Jounts?
- Pavement Ends Sprint Top for 2dr
- 37" tire necessities
- 2.8l CRD
- Something's got to give. Which will it be?
- Long Arm vs Short Arm?
- Will this Borla Cat-back fit on my JKUR with Teraflex 4' lift?
- How to remove Front and Rear tow hooks?
- JW Speaker backorders
- Rancho 9000xl Question
- 2012 JKR — Uncorrectable DW after multiple attempts
- getting vibrations from my 2 door jk
- Gear oil?
- What's this hood ? and a few queries...
- Can you upgrade 4" tera flex to long arm
- Question about drag link flip kits
- Stock tune but change fan temps
- Help Please
- wild boar grille with arb bumper
- Bigger tires!!!
- Just sold my 37s
- More lift?
- Electrical Distribution Panel?
- springs! need help.......open me! Lol
- Whats the wear on your 35's?
- Evo or PSC tirecarrier/bumper - RR tire carrier crapped!
- OEM Rubicon rock rail or OEM side step hardware for 2012 or newer JK
- Long term wear from "BIG" tires?
- Synergy Jeep JK Front Track Bar Brace and teraflex track bar
- Great Jeep shop in San Dimas California
- Fuel Boost Rims
- high tuck exhaust?...but is it quiet?
- Liberty light bar on a jk?
- Frankenlift on a 2 door 10A Rubi with auto
- Finally got my Jeep home from the shop...sort of!
- How much lift did i get?
- TeraFlex Swaybar Quick Disconnects [Part Number: TER1753010]
- electric radiator fan problems after mud riding
- 07 JKU popping noise while braking
- A/C Heater Blower Motor
- Electrical Help Please
- Thoughts on Mopar 2" Lift??
- Rock krawler lift with fox shocks
- Warn Power Plant
- '12 JKU Best Value Soft Top
- AEV 3.5 SC DualSport lift or MOPAR Stage III 3 inch lift
- How often do you check tire pressure?
- Complete my lift
- AEV Seatcovers
- Some Notes on My AEV 3.5 SC Lift Install
