PDA
View Full Version : Modified JK Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 [140] 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296
  1. Help with Overdrive on an Auto Trans.
  2. 35's, 3" lift and REAR ds
  3. OEM spare carrier with oversized wheel/tire
  4. Alternative for on-board air
  5. A lift and tires - the best first mods!
  6. Lift and tire questions how to do it right
  7. Pentastar V6: JK vs. Challenger
  8. rubi disconnect or not
  9. Lift Kit Suggestions
  10. Can someone explain offset axels after a lift? Pics?
  11. Sloppy Steering and breaking, whats wrong???
  12. tire question
  13. Rc 1.25" bl
  14. Rock Krawler 2.5" Max Travel System
  15. Auto Gears
  16. tire light is flashing
  17. Hi-lift or Bottle jack... A few questions
  18. Rear Axle Question After Lift????
  19. Anyone have pictures of 285/70/17 on stock rims with 1.5 spacers and no lift?
  20. Toyo vs Nitto - 37" Mud Terrain
  21. Opinions??
  22. Just ordered a Shock and Coil standard kit from Northridge today. Did I do right?
  23. so i guess this means my axle seals are leaking?
  24. 17" -vs- 18" with 35" tires on JKU
  25. My Teraflex Experience...
  26. What is the best lift for 35s?
  27. P0430 code after a lift?
  28. Split Rear Exhaust
  29. Axle Shaft Replacement Question
  30. 2012 ARB Compressor Mount / other on-board air options
  31. Trying to get 35s on my stock 17” wheel with 1.25” TF spacer
  32. Relocation of Marker lights
  33. caster
  34. 35" Nitto Trail Grappler Tire Pressure
  35. spacer on top of a spacer?
  36. 2.5" BB, what a difference...
  37. does the diablosport predator turner turn off the electronic swaybar light?
  38. Suspension GURU's
  39. Solid diff cover problem....
  40. Easy ? Who makes these wheels?
  41. Headers and exhaust
  42. Teraflex 2.5 bb question
  43. Is alignment needed after installing BB and disconnects
  44. snorkles
  45. rubbing with 35s and 2.5" TF BB
  46. 4" lift and 37's. Rubbing?
  47. Regearing ??????
  48. Driveshaft ????'s with Auto and 3" lift
  49. TF BB install
  50. 12 2 Door Owners what evap skid fits???
  51. Will 8.5"X17" wheels with 5.3" backspacing work with 285/70r17 tires?
  52. New bumper and fogs dont work and low tire light
  53. Rubicon 35 spline F/R Shaft questions.
  54. Installed 33's now Jeep doesn't roll the same. Are breaks on?
  55. How much does a Track Bar affect...
  56. Harnesses
  57. Superchips Flaspaq updates ?
  58. Rubicon Advice request - because stock isn't good enough!
  59. 1" BL on 2011 jku ??
  60. Caster
  61. Help With Wheel & Tire Purchase
  62. Rear Pinion Angle
  63. trackbar issue
  64. Trackbar help
  65. ripp supercharger
  66. Death wobble question
  67. smittybilt xrc10
  68. spedometer and tire question
  69. regearing vs performance mods
  70. H2O Proof Winch Worth it?
  71. Programmer help!
  72. Poison Spyder Tire Carrier - Rubber Bumpers Crushed?
  73. Can I have some help with tire and lift sizes
  74. Stock Rim Question
  75. Teraflex 3" or AEV 3.5"
  76. Tire Dealer refused to mount 275/70/18 ?
  77. Switching from factory 16's to 17's and trail grapplers. Do I need to align?
  78. Daily 70 mile daily round trip commute
  79. Fender Flares
  80. Control Arms Need?
  81. Rear Pinion Angle with Stock Driveshaft
  82. 15x10 American racing AR-23 rims
  83. Help with lift install
  84. Bad Intake manifold gasket
  85. Mirrors/ Blind Spots
  86. Lift option
  87. horn works kinda?
  88. clearance problem with rear u-joint and gas tank
  89. Help with Nitto Trail Grappler Tires size
  90. Death wobble be the death of me!
  91. For those with Bushwacker Flat flares
  92. Dana 30 carrier ??
  93. Anyone go the Recovery way first?
  94. Tone ring code
  95. PRESS RELEASE: TeraFlex JK Tera44 Front Replacement Axle Housing
  96. The Great Tire Debate 35 or 37
  97. mirrors or relocation bracket...
  98. Quick release nuts on rugged ridge xhd?
  99. Stripped holes on AEV Beadlock, what's the best option?
  100. anyone know a way to order a warn winch without wire rope?
  101. another newbie looking for advice
  102. Upgrading brake caliper?
  103. Lift Recommendations Needed
  104. Gearing for 2012 MANUAL
  105. Funky tire wear on flat tow
  106. Where to buy wheels canada
  107. Stock lug wrench doesn't fit lugs on new rims
  108. confirm my pinion angle thinking is right here...
  109. "shudder" in steering wheel over bumps?
  110. rubbing
  111. Programmer help!
  112. What to watch for?
  113. Anyone in a 2012 with 3.73 gearing and 35's?
  114. Getting a little flack from a tire installer
  115. Baja MTZ or ATZ experience?
  116. Install Help in NC?
  117. Lift kits
  118. what should i do?!
  119. 4.56 or 4.88
  120. Evo frame plug question
  121. olympic jacklite bracket
  122. Bedline myself or take to Rhino
  123. Olympic 4x4 defender rear bumper review.
  124. Hypertech ups the game!
  125. can a detroit truetrac lsd be used with 35" tires?
  126. Bedlining interior of JKU
  127. Body Armor wrap-around tailight guard install
  128. Did I level my 2012 Rubi right?
  129. First post/Clayton 3.5 premium system install
  130. can i keep my d44's?
  131. which to choose
  132. LCA recommendations
  133. Strange Noises?
  134. quick alignment question
  135. AEV lca brackets???
  136. Mounting tires cost
  137. What is the best rear adjustable track bar?
  138. need tire and rim help
  139. JKS Sector Shaft Reinforcement Kit Anybody?
  140. Gearing Chart for the 3.6 2012 Motor?
  141. Next up-grade
  142. Rusty's gussets?
  143. Trimming Fender Liners
  144. AEV 3.5 Lift
  145. Which Winter Snow tire?
  146. Any cargo liners that cover the wheel wells and back of seats?
  147. Putting a budget boost on a budget boost
  148. Building up my jk. Was looking for feed back and ideas.
  149. Rugged Ridge Power Operated Soft Top
  150. Pretty sure shocks arent supposed to do this...
  151. Tires
  152. Questions About TF Front LCA Install
  153. Smittybilt over size tire carrier # 2743 with 35 on factory wheel
  154. EVO JK Rock Stars
  155. Affordable Lifts - Rough Country - Skyjacker
  156. lift suggestions...
  157. Rear drive shaft issue at tcase source of knocking noise or another issue altogether?
  158. Springs off-set after lift..LCAs didnt fix....?
  159. Would this work?? upgrading from 2.5" TF Coils to 4" Rancho Coils
  160. Trailer Hitch Ramp Help...
  161. what 40" tires to get??
  162. Gear Ratio for the 2012 JK 3.6L
  163. Help needed in locating a set of Addicts
  164. Where to buy tires?
  165. AEV Rear Corner Guards
  166. Help with Warn 9.5ti winch
  167. What gears do i have??
  168. Will my wheels work with a lift
  169. Something to protect painted edge of window frame
  170. Wanting a new project!
  171. Pics of 2,5" lift kit with stock tires
  172. BFG KO or Cooper ST MAXX?
  173. How to install track bars
  174. Starting to have clutch issues with my '08 rubi and 67K Km
  175. Would This Tire & Wheel Combo Work???
  176. Lift for 2012 JK--Anyone know if older kits fit 2012 JK?
  177. Adjustable control arms
  178. Keep the 17's or go to 15's?
  179. StarScan Question
  180. Rear Control Arms - What length to set them to???
  181. jk pulling right. camber off
  182. How many have an in-line fuse for your winch?
  183. CA SMOG LEGAL HEMI SWAP - Who has done it and what do I need to know?
  184. tailgate
  185. My Rear Bumper Build for under $215!!
  186. rusty's long arm upgrade
  187. Rugged Ridge Tire Carrier Linkage
  188. Rear Bumper W/Tire carrier Question
  189. Which OME Lift for 2Door?
  190. Lets talk Exhaust..... What aftermarket brand are you running?
  191. Spidertrax spacer help!!
  192. Which CAI to get
  193. Teraflex+OME Shocks or Fullout OME 2'' Lift
  194. Drag link bar and trackbar alignment help
  195. Rhino-Lined Hinges??:o
  196. First lift- good suspension plan?
  197. Wanted, rear tire carrier pictures and testmonials on likes and dislikes..
  198. Installing front/rear track bars with Teraflex kit - help
  199. Bedliner idea
  200. Rock Krawler jk 2.5 Max Travel Pro midarm system
  201. Superior front axle shafts........help
  202. Loctite, TPO & torque thread values
  203. Rampage bumper and vacuum pump
  204. Will I end up spending more money than I think?
  205. adjustable control arms
  206. Bumpers/Tire Carrier and Gear ratio? Help me out!
  207. Wheel and tire question
  208. tracbar bolts
  209. Will Nitto Trail Grappler and XD Addict fit 2012 Unlimted Sport with no lift?
  210. Has any one tried this yet ???
  211. What gears are the best
  212. Recon winch
  213. 3.5inch front coil springs.
  214. advise on lift and tires
  215. Is the back bumper with the tire rack worth the extra money?
  216. 3" BDS coils
  217. 3.6 pentastar strength
  218. Traction Control confusion
  219. Duel Stabalizer
  220. body armor bumpers
  221. Tire carrier option
  222. Throttle Body Spacer
  223. Right wheel wobbling!
  224. Wheel wells
  225. Jeep shakes alittle at 52-55mph
  226. Off Road Evolution Vs Teraflex Long Arm Kit
  227. Your 2012 Pentastar upgrades
  228. Bent sway link over tie rod again.
  229. Ideas and suggestions for front axle trusses
  230. Hesco striker kit
  231. 285/75/R16 Soft 8 Question
  232. Anyone have some miles on the Safari TSR's yet?
  233. Lockers?
  234. Running 35' with 3:73's
  235. Evo fender/armor question!
  236. xd series rims
  237. Sterring dampening shocks
  238. JK Lean
  239. Death Wobble Help
  240. re-gearing question
  241. will 2012 jku coils and shocks fit 2010 2dr sport?
  242. Need Help With Extended Swaybar Links
  243. LOD Gen 3 Rear Bumper Shorty Question - Frame Backing Plates
  244. Advice needed on KMC Addicts
  245. Goodyear MTR w/Kevlar: load Range C or D?
  246. Extra Parts??? ORV suspension
  247. Weep holes for snorkel?
  248. Can your run 40" 15.50 on D44 Axels?
  249. What is the best Skid plate for Ripp Long tube headers?
  250. matte black pro comp 7028
