View Full Version : Modified JK Tech
- Decisions...
- Pinch Seam
- Skyjacker Control Arm Bushings and shock question
- Time for the next mod. Choosing a front bumper. ARB vs XHD!
- Rustys 2" Basic Kit - Feedback wanted
- corbeau baja rs front seats
- On a college budget -- Smittybilt vs. Highrock (tire carrier)
- Couple of questions about LOD rear bumper
- JK lift kit from Mopar
- Colder Spark Plugs
- Stock driveshaft boot
- Need advice for next upgrade
- BB on a stock 4dr
- lifting jeep jk
- Looking for a place to buy XD Hoss Wheels
- Muffler relocation
- Winterizing My JK
- safari straps divider
- 275/70/17 stock rubicon
- Before I pull the rope Got a Q:
- 2dr 5" lift in front
- New: Maxxis 764 Bighorn
- Really need help finding a spot for onboard air...
- 22's on 2010 JK?
- Just Had 538s installed
- Bumper with Tire Carrier - Swing with gate style
- Mopar Steel Wheels
- rubicon lockers dead need help with new locker selection
- Help Warrior hood mount hi lift
- 35s with only 1 3/4 inch lift?
- oversize tire carrier?
- 5.13 gears initial impressions
- 2.5 teraflex lift
- 4" Lift and Problems Galore????
- smittybuilt src rockers
- 3" Teraflex lift kit in Atomatic Unlimited X 2009
- What size front bumper, full, mid or stubby? Poll
- Window shape??
- pulled over for no doors. Can you recommend good tube doors.
- Will a 34.5" TERRA Grapper fit on the back door?
- Rock sliders, body mounted vs frame mounted???
- Where can I find these clips
- My next mod is YOUR call - Flat Fenders or LOD Rails
- MAX SIZE Hub centric Spacer
- Non-Factory fog lamp mounting help for LoD Mid-Width
- rear control arms?
- New shock what to buy help
- Clutch fan
- rock krawler kit, need help!
- wires to rear dif
- Mopar tire carrier, any good or garbage?
- Question Regarding the Differential Locker!
- ice chest rack for the back of jeep
- Rear Sway Bar links question, Do i need aftermarket ones?
- Long arm 4 inch full traction
- Question about a moderate lift and leveling...
- Question on powder coating stock wheels
- Ripped My steering Stabilizer off last night!
- Best quality most affordable 2.5" lift
- Need advice on hitch bike rack
- Rocks in the treads
- winch rope question
- Rampage Jack Mount POS!
- aftermarket GPS
- Anyone with 33's, 4.88 gears and auto trans?
- New Guy with a jeep
- My set up and a SuperChip Flashpaq.
- Coast DS Leak at Diff!!!!!!!
- Anyone using TeraFlex 1.5" Performace Kit #1351500
- Wheel and tire sizing??
- how come i only have this problem?
- Power Adapter - AC and/or DC in rear cargo area
- I have a 4 inch lift. Are 37's gonna work? REALLY NEED TO KNOW
- NITTO terra or trail?
- What is the difference between a Hawse Fairlead and a roller Fairlead?
- mud bogs and airing down???
- Which Shocks
- Dealerships and Oil Pan Skid Plates
- 3.73 vs 4.10 for a DD
- Death Wobble / Caster correlation?
- spacers for new wheel bolt pattern?
- POLL: Silver or Agent Pintlers on Black 2-dr JK?
- What tire size do you recommend?
- Sahara axles upgrade? wich one?
- Has anyone ever had their synthetic winch line or cable stolen from their winch?
- Bilstein 5160s?
- New to Jeeps, probably dumb question but need help
- D30 upgrade or d44??? Need help
- Teraflex 2.5 in Spring and Shock lift...
- ABS, Trac Control lights stuck on
- What do you guys think i should do
- 538s going on in the morning
- difference in winch cable
- i looked and can;t find the answer. tire clearance help needed :)
- Steering Stabilizer installation
- Bumpstop extension question
- Rear Pinion - Too much movement
- VDP stubby conversion kit
- wheel and tire size ?
- PRESS RELEASE: Rough Country 1-1/4″ Body Lift w/Shifter Adapter for 6-Speeds
- Strange Wobble (40-50mph and 60-70mph)
- Wheel Spacers, Loc-Tite, and re-torquing
- tire size?
- 20" SRT8 Wheels - 33x12.50x20 MTZ's - Do I need to Modify 2010 4dr JK?
- Currie rear spring retainers limiting travel?
- Help with a rounded lug nut
- Leveling Kit or Wheel Spacers 1st
- 4.88's or 5.13's
- My new Upgrades.... What do you all think?
- Wheel/Tire Combo Suggestion
- Superchip vs Hyperchip
- long arm/short arm 3-link/4 link 3.5 inch/5.5 inch
- New JK Unlimited .. Dilemma?
- Rubi shocks plus 2" BB... can i get by without shock extensions
- OrFab Rear Bumper question
- Finally ready to mod. What do you think?
- Warn Powerplant
- 4 door windjammer
- Rim/tire help
- 2-door JK with simple hardtop mounted Roof rack seen in downtown Chicago
- Genright Aluminun corner guards?
- POR 15 Interior
- Anyone running an Expedition One Bumper?
- Fit 35 spare on Mopar rear rockcrawler bumper?
- Tire shop can't balance 35" KM2s?
- Spare Tire Question
- Beadlock help
- Axel Sleeves, where to buy them?
- what is your gas milage with lift?
- JKS Trackbar Brace
- ARB snorkel?
- XRC8 Winch, clutch lever. A pain in the butt or is it me?
- 37 for 16" rim
- Rear Trackbar Rubbing Question
- Advice on Pinion Angle - Please look at PICS and advise
- Please Tell Me I'm Done
- Rugged Ridge light bar-does it really cut down noise like it advertises?
- front lower control arms
- Rear Seat Belt Idea (4 door).
- Rock-Slide Engineering Ridge Series Rear Bumper & Tire Carrier
- Roller Rockers for 3.8
- Rounded Shock Post?
- Help need front tow hooks
- Spare Tire for Jeeping Trailer
- HELP!!!! did I install my sway bar end links correctly???
- ARB Front bumper question
- True-Trac with 35's
- Rock Krawler coil overs WHO'S GOT THEM?
- When to flash Jeep for regear...
- looking for others thoughts...
- bump stop?
- dual steering stabilizer
- Pro Comp Tires
- Next phase advice
- Easy Driveline Question - New Driveshaft & Pinion Angle, etc..
- TF Leveling Kit - Lost bolts, nuts, and metal sleeve for swing arm links - size?
- PSC Economy Kit
- Suspension help
- 4.88's, Six Speed, and 33's - Are you running this mix?
- Low tire pressure warning - question
- jeep is dangerously all over the road
- Got Air?
- A question about exhausts..
- KMC and XD Alloys
- show me your 17"18" wheel with 33" 35" tire!!
- Decision Paralysis - I just can't decide which tire I should buy.
- Rugged Ridge Sound Deadener vs Hothead Headliners
- Big Foot: Big O X/T
- 3" lift and 35" tire with 17"-18" will be good? recommand !!
- Tread Wright Tires
- TF Rear Upper Control Arm Help
- help! BDS lower front CA's! spherical joint on the axle side or frame?
- Where can I find basic lift info / guides?
- snorkel and winter
- 3" long arm lift with longest travel
- Grab handles
- Squeak driving me crazy!
- M.O.R.E. 1" body lift conflict with 2010 Rubi Unlimited
- what is the difference?
- PSC and high steer compatibility?
- Help with Tire Advice
- which way to go
- Lift
- Finally. No more esp light and pumping brakes
- Which Teraflex lift package, or something comparable?
- Dunlop MUD ROVER Tires
- Torn Between 2 Bumpers
- Loud Bang and some movement in the front end
- Solid Diff Covers D30 and D44
- What bedliner?
- Gears or transfer case
- Hanson Rear bumper install questions
- Where to tap for adding brake controller?
- Rugged ridge front skid plate
- Superchip Flashpaq and Force Air Intake
- trail master lifts
- Anybody route air compressor lines/fittings to bumpers?
- About to Start College... Need a Little Help...
- Best lift for daily driver and 35s
- Need Lift Help Before I Start
- Help!!!! Trouble installing new winch line
- Available hubcentric wheels?
- How much can a battery take?
- Mounting locations for aftermarket gauges?
- King shocks?
- Covering for Tuffy Cargo Drawer?????
- Auburn elec. locker installed.
- brake pads
- Synthetic winch line installation question?
- Steel or Aluminum
- Tie rod boot/bushing blown out ??
- Bumper Safety Question
- installing rugged ridge front skid, an opportunity to center winch
- Need a better way to grease zerks
- Heim joint won't loosen
- Textured Powder Coat??
- Locker combo
- Exhaust upgrade?
- Horn Blasters Airhorn Install
- hardtop and bedliner ?
- What octane do u use?
- SHOCKS?? Teraflex VS Skyjacker VS black diamond A/T
- Thoughts on Load Ranges for JK tires?
- anyone running a 2 dr without rear sway bar
- WHo's running a RIPP or Avenger S/C kit in their 3.8L JK?
- 2010 bumper fog lights
- 265/15/16 or 285/75/16 on stock 16"' steelies?
- Tire & Wheel help please,,,,
- Rugged ridge xHd rear tire carrier studs
- Alloy USA axle U joints?
- How Should I Go About Painting These???
- Aussie Locker Question
- Newbie here, need help with a lift
- check engine light/gascap error message (list of mods and timeline)
- whats up with this noise
- Another "ticking" noise thread
- rc 2.5 budget lift
- What Fluid type in my Dana 30 differential and how much?
- Can't get into my Tuffy underseat lockbox!
- Bigger tires = Different shocks???
- Genright fenders
- What To Do With This Money
- Pitman arm problem (included in full traction kit)
- Rear Bumper and Tire Carrier shopping/need suggestions
- 4.10 and 35's
- Tires
- Bestop Emergency Top - Anyone using it?
- Picture Request: Anyone got Pro Comp Series 7289 Cast-Blast™ Finish Alloy Wheels?
- 2" Spacer Lift, Replacement Shocks not needed?
