View Full Version : Modified JK Tech
- HELP...need 3-4 inch lift $800 or less
- Tire search
- What would you do?
- Controll Arms ?
- Aftermarket seat, airbag function.. Help...
- Rugged Ridge tail light guards
- RC quick discos
- Fender whack and bedlined fascia - should I do it or a bad idea?
- Another newbie tire question :)
- front end sag need springs help
- Superchips vs AEV
- T.F. 2.5" Coil Lift/Great Price/Great Experience
- what lift size should i get for ohv trails?
- Goodyear Wranlger MT/Rs or Duratracs?
- gear change effect on 4-Lo
- Which mirrors?
- Full Traction 3" Lift Install Tomorrow!
- Mopar Trektop
- Rugged Ridge Wheels, Offset?
- AEV Snorkel and C.A.R.R. Rotobar
- Hella Light Lens...
- Wheels - Powdercoat, Paint, or Bedline?
- Spacers
- Bedlining bottom of tub myself, bad idea?
- front lift only
- Lift advice needed??
- Totally confused...
- Anybody running the currie 4 inch lift ?
- how to make mbrp exhaust a bit louder?
- 35s with Dana30. Sleeves/ gussets necessary?
- Difference between the 2.5" and 3" TF lift kit
- Yakima Load Warrior basket???
- Please! Need info/ advice !
- OR-Fab Swing-A-Way Tire Carrier - Your Opinion.
- Fender flares ?
- Evap canister concerns with muffler relocation???
- 35's?
- OME Shocks for TF 2.5 ?
- long arm vs flex arm
- breather tube extensions
- Backspacing
- AEV Wheel Backspacing and Offset?
- Curry AntiRock
- 2dr "x" automatic, gears
- 2.5 Budget Boost or 1.5 Performance Leveling Kit?
- 4" lift + 35s + fender chop??
- Need advice on my Lift/Tire project
- Teraflex springs and OME LT shocks
- LoD VS Expedition One Rear Bumper/Tire Carrier? Which One?
- How to turn the stereo off with ignition?
- Stock KM's to 285/70R17 KM2's - Load C to D
- Rubicon with 1.75" lift--questions...
- 2dr gear question
- Psi
- AEV lifts
- OR fab tire carrier rusting!!
- Toyo tires
- D ring size?
- Newbie with a question regarding the "Newbie Question Section"
- What is max weight on a tire/wheel combo for the stock spare tire carrier?
- Installed intake, 1 week later i get ETC light and then MIL light
- Is this normal for tire carriers?
- Winches and road salt?
- Wheel Center Caps
- Which Flat Flares are the best
- TIRE CARRIER - What is the benefit?
- Regearin
- Issues with stock drivetrain and 35s on a Sport
- Which Dana 30 Aussie to order? JK or Standard ???
- Air Lift suspension, anyone?
- How do your Bilstein 5100's sit? pic request
- need a quieter exhaust than my gibson twin outlet cat back, to much drone
- 33x12.50x17 do i need spacers?
- M.O.R.E. Front Bumper
- more power
- what lift with factory rims?
- 4.88 gears versus 5.13 for 4 door auto jk
- bb lift question? track bar
- Rough Country customer service...
- MBRP exhaust with Rock Hard Skids
- Flowmaster Part numbers / Help!
- 37" Krawlers?
- gearing question
- UPGRADES: What should I do next?
- 2nd set of 37x12.5x17's which tire this time?
- Help: What is this? Sway Bar Link?? Is it stock?
- Firestone destination M/T
- Advice
- 3.5" Rock Krawler lift
- Master install kit
- Best 3.5" - 4" lift - need your opinions and prices
- Steering stabilizer
- Help...Where to buy tires/wheels combo...Help!!!
- Has anyone added air bags to their springs?
- Can JKS Upper Control Arms be shortened to compensate for castor adjustment?
- Install RK tie rod with wheels on the ground?
- Procomp series 152 where to find centercaps?
- Looking for coil spacer lift help
- Basically lft question
- What next???
- What to do first?
- 38s vs 40s which tire size is the best?
- Xenon high clearence flat fenders
- Rims
- Powdercoating wheels
- Jacking up my JK?
- snorkel that fits the RR light bar?
- 325/70/17 on stock spare tire carrier?
- rugged ridge half doors painted
- 2.5" terflex bb lift kit
- Teraflex 2.5 coil lift vs. 1.5 performance leveling kit
- Tires & Wheels-Mickey Thompson Classic II question
- Exhaust question
- Jeep weight
- Winch Mount - Body Armor front bumper
- Teraflex Steering Stabilizer limits left turn
- Nitto Trail Grappler
- Fitting 35's
- tire size
- wheel offset?
- Rough Country 3.5 or 4in lift?
- A few EVO LCA skid questions...
- teraflex 2.5 coil lift help (in the middle of install)
- Help with wheel choice
- Yakima roof rack JK 2 DR Custom install
- 33's on a 17" rubicon rim
- Fish vs. Elephant
- K&N Air Filter
- Sway Bar Quick Disconnect
- Evap Cannister Question
- Ace + Rubi Rails
- Question regarding the Rugged Ridge XHD bumper with skid
- Anyone have the OR fab tire carrier
- Teraflex S/T swaybar
- Maxxis Bighorn ,anybody have some input ???
- Need help deciding on lift.
- Mickey MTZs vs Nitto Trail Grapplers
- 2-2.5" lift which one?. 17/8 or 17/9 cragars?
- Rockhard 4x4 rear bumper & tire carrier
- 08 to 11 hardtop
- Drake Fire Extinguisher Mount
- Just installed Teraflex 2.5" coil kit.
- Top 3 - HELP me decide!!
- axle ratio, danas 33"s
- Adjustable track bar install
- teraflex adjustable track bar and steering stabalizer
- AEV snorkel with ram air tip
- Tire/spacer mount question
- Hemi owners-Any problems with 4-lo and stock brakes?
- checking how much lift before d/s
- original rims on big tires
- 2 stage or 3 stage Winch
- Bumpers or lift 1st
- Drake hood latches--any good?
- Steering Question
- Question about Lifts & 35s & spacers & leveling...
- 3 or 4 inch teraflex?
- Trac bar bracket broke?
- What kind of seat belt
- Fluid leak after drive shaft install
- evo suspension
- Best cat back
- Budweiser Tap Shift Knob?
- am i f***'d? (rubbing)
- WARN M8000 winch problems....
- Rust proofing your underside
- Goodyear MT/R: 315 or 35?
- roof rack with softop?
- Exhaust Upgrade
- What width and offset for a 15" wheel?
- Trying to decide between 295 70 17 and 305 70 17 terra grapplers.
- Superchips./Bully Dog which one to buy?
- Frame Questions
- Need help with wheels
- Regearing question
- Rock Krawler 3.5 Plus
- Best lift to fit 35's under $400
- what is everyones favorite tune on the superchips flashpaq and why?
- Daystar Lift
- Please help
- OX lockers
- Garbage Bag waterproofing??
- Coil lift for 33's......???
- OR-FAB sport cage
- Coast 1310 Driveshaft Maintenance
- How to adjust Front & rear trac bar?
- Bedlined fenders??????
- Hub centric vs. Lug centric...Any difference in ride?
- 3.73 33's vs 35's HELP ME CHOOSE!
- bikini jammer duster
- Tire help!
- RBP revolvers
- wheel balancing HELP!!!!!!!!!!!!!!!
- 35" Trail Grappler vs. 35" Toyo M/T
- Broke it? Upgrade it! [Front Track Bar]
- Mopar Front Bumper D-Ring/Crush Can Replacement
- Superchips flash pack
- Stock Rubi Gears
- Question about ProCal
- jeep squeaking
- Over 2.5", what else needs replaced
- New Misch Dashboard Organizer?
- Has Anyone modified a Banks cold air
- Detroit TruTrac help!
- Another Lift Question...yes I used search so don't waste your time telling me.
- Broken spacer.....
- Death Wobble
- Anyone running Hella's 4000 rallye Euro beam?
- DuraTrac Tires or Wrangler MT/R Tire with Kevlar?
- Dash mount Bully Dog tuner
- Question about Rims/Jeep Wrangler Islander
- Whats the best seat covers
- OR-FAB Sway Bar Skid Plate
- Axle seal leak through the axle?! Need peace of mind
- TPMS swap?
- 35s going on! What do i do with auto trans??
- OME shocks
- Looking for bilstien 5100 shocks
- Mountaineer Rack for 07-11
- what brand 15 for jk?
- TF 2.5 Coil + OME Long Travel Shocks
- Anyone running JKS ACOS.
- Anyone ever DIY swap Rubi44 internals into a pr44?
- Superwinch EPi 9.0??
- Poison spyder VS river raider evap skid
- NEED HELP!!! (track bar, steering problems)
- is regearing really tht big of difference
- OK so 35s with 3.21 gears...need info/ opinions!
- Rock Hard harness bar
- Help me Jeep Yoda, your my only hope :)
- Anyone using rancho rs9000x adjustable shocks??
- Best way to clean AEM Brute CAI?
- T-max WHEEL SPACERS???
- Installed Rancho 9000s nut keeps coming loose?
- clickin underneath after lift install
- Jerry Can Mount - Need ideas
- Gear to Tire Ratio question
- Teraflex 1.5 performance leveling kit with 1/2 inch pucks
- Lod fog lights?
- Front trackbar help...Im lost
- will this actually help us out on performance????
- Help me choose a new front bumper.
- Evo build. What things I will need?
- Expedition vs Rock Crawler, How is the build different?
- Ball joint options?
- Installing my own lift kit
- I have a few questions about 15 in wheels?
- AEV Geometry correction front control arm brackets. I have Questions?
- In the market for axle shafts? Which ones?
- Stubby Bumper Conversion by VDP
