View Full Version : Modified JK Tech
- Helpt me with my newest dillema!!!
- Go Pro Camera
- Pitbull Rockers for a DD>? or what would be the best MT
- I need new front shocks for my '09 2 door Rubi.
- Yukon Zip Lockers?
- how to check if your front inner C's are bent?
- Synthetic rope first time use
- Detroit Truetrac Differentials
- MAMBA OFFROAD TYPE M7 --any thoughts????
- JK with 6 speed AUTO and MDS
- KOR Tire Skewer
- Code Question..
- Pro Comp 152 Rock Crawler Series Street Lock Wheels
- Looking for photos of 37x12.50x16 Irok Radials on an Unlimited
- Rubicon with 3.73's?!?!
- New JK AND lift need help with the ride
- Front Coast 1310 DS install
- New Glove Box
- Suggestions for new rims
- about nitto and bfg tire
- XD Addict vs. Black Rhino Imperial
- SPEC Stage 3+ clutch
- OME Light Duty Sping Partnumber Confirmation
- Sway Bar Length
- PSC hydro steering with Ripp Supercharger and PS cooler?
- Sway bar link Question
- 35" on order, Now what?
- RK 3.5" Mid Arm Flex VS Evo Enforcer
- anyone try rk's rrd shocks?
- AGR JK Xtreme Steering Box
- Lift Help, Whats the best lift that you can keep lifting?
- pics of stock front lower control arms
- Best shocks for taking abuse and going wheeling often
- Mounting winch to a Roadmaster tow bar baseplate... crazy?
- My Brand New High Lift Jack is putting rust stains on my Jeep!!
- Need Assistance for Lift + Wheels + Tires
- Comment on my build
- OBA Quick Coupler Mount
- Rectangular Tube Front/Rear Bumper Pics Needed
- Help me choose
- Genright swing away tire carrier
- XRC bumper and X20 winch for 2012
- Another mopar sun boney question
- Suspension question
- ARB skids?
- JKS Quicker Disconnects
- Spacer thickness?
- Shifter knob
- 2.5 lift vs 3.0 " lift
- Bolt Size needed?
- What fender flares are these?
- Got A smokin deal on some Xterrains.
- Weird experience
- what are true 35s?
- Rugged Ridge Synthetic Air Filter
- Rear floor mats, no carpet
- Help With KC HiLiTES and Bumper.
- Which odds/ends would you replace while doing AEV 2.5" lift...?
- Seat Cover Failure
- Questions On Lift - EVO Coil / Teraflex
- Looking for new tires....any suggestions??
- Manual tranny fluid
- Help! Jeep doesnt go forward?
- Sahara with 16 inch wheels and no lift...
- Air pressure sencors.
- Rear wheel mount.
- $4000 to spend on lift and tires.
- new JK owner want to know a few things....
- do i need a new driveshaft
- Installing Evo Drag link flip kit
- Clicking in steering?
- Ok got around 1000$$ to spend
- Talk me out of line-x? Montaliner instead?
- SRC tire carrier latch problem...
- Getrag 238 Thoughts? Which donor?
- RC Hybrid Stubby Roll Call
- Help please!
- engine mods?
- after bumper & winch.. leveling kit or better springs?
- Best 4 inch suspension lift kit
- Soft vs Hard durable Fender Flairs
- Cold air intake
- Superlift???
- stock bumper accents color match.
- ATX Slab mounting question
- Wheel & Tire Info Request
- tire size
- Wheels/backspacing
- Does an ARB Diff cover question?
- ok teach me ! still have question..
- 2010 JKU Axle Assemblies in 2007 JK
- 40"tires or 37"
- Quick question about VDP Stubby End Cap install
- Wheel spacers
- new 2012 jk sahara 4" lift or 6 1/2 lift long arm
- 2011 Rubicon?
- 3rd Brake Light
- Coil Springs Worn Out
- ARB or OX
- Can Someone Look at Their Brake Pedal for Me??
- Should I go with the stinger??
- Looking to buy stock turn signals
- aev or rock krawler?
- Extra $1000, what to do?
- Just got my first jeep, need advice.
- Tinted lenses
- Gears chattering ?
- New member, new JK owner, new build
- 2.5 to 4 inch build
- Bigger tires and Standing Water
- Black dual exhaust?
- Rear frame cap that works with EVO frame mount D-rings?
- Nitro Axle Dealers
- broken windshield...need lightbar suggestions
- powder coating rims
- Will this HEMI work ??
- Lift/leveling
- Smaller Pulley for RIPP?
- Fix ride without lifting
- Carpet out?
- Budget boost
- Uwharrie/4 door Question
- 17"X9" wheel with a 4.5" back spacing
- sorry to ask basic question.
- Programmers for the 2012
- 3.6L auto trnas shift point mod?
- How difficult is it to regear your axles yourself?
- Stubby bumpers
- Tuffy security deck--weather resistant?
- Side steps.. which ones do you guys recommend?
- Electrical problems with 2012 ?? Input appreciated
- OME heavy 2.5" lift
- Just Lifted
- Taking doors off for first time
- Which front drive shaft for 2012 Unlimited, 2.5" lift?
- Teraflex Leveling Kit: Wheel spacers needed?
- Lift Installed...Need a answer...
- Will this fit?
- Smittybilt tube doors mod?
- Putting a 3.5" lift on my 09 jk unlimited looking at 35" tires.
- Winch storage????
- 2010 Unlimited -Driveshaft Replacement
- Color matched after market bumpers ?
- 2in lift on 2010 2 door
- 2007 Wrangler Steering Stabilizer - What do you recommend?
- YJ Lockers
- HELP! Issue with AEV ProCal TPMS Setting
- NEED HELP! 5.13 OR 5.38 GEARS FOR 2011 4 DOOR WITH 35KM2"s
- ball joints shot
- what compressor u runing? need one for my 12' rubi
- spare tire delete? pros? cons? pics?
- Powertank??
- Mopar 44 axle/drive shaft
- Rig still walks
- New PSC Ram steering causing ESP to kick on
- 4" Teraflex Long Arm Should I Do It?
- Teraflex quick disco help
- In and out play on front t-case yoke
- fox 2.0 shocks vs bilstein 5100
- Nemesis Industries Odyssey Flares
- Gears or drive shafts first?
- Weight or size
- Home install
- Paint Diff covers?
- Falken wild peak bs mt tire
- Duplicolor Spray Bedliner...I got the runs.
- Tire carrier question - is this correct?
- Anyone running an AEV tire carrier with EVO D-rings?
- Those with Ace Sliders, I have a question...
- dynomax rock crawler exhaust system!!
- What mods can be swapped from 2007 to a 2012?
- 15" wheels on JK
- sound deadener removal
- Rear track bar bracket?
- Plasti-dip and the weather
- Flimsy flat fenders
- Homemade Bikini Top help
- ARB rear bumper W/ AEV tire carrier
- Rough country suggestions
- Bolt on rock rails
- Trouble regearing issues with..........
- Bumper and winch or gears
- Off Camber roof rack for surfboards?
- Flashpaq Help!!
- MT Sidebiter centerbore?
- PSC brawler lite front bumper with stock fog lights?
- Please help Identify!
- On-Board air system
- Coil Overs??? Has anyone tried this?
- Evo Tire Carrier & ? Bumper???
- Rubicon with wheels smaller than 17's...
- Additional modifications to lift a 2012
- Where can i get these screws??
- Need Help Picking Bilsteins
- 285/75/17 TOYO MT on stock wheels
- Rugged Ridge Stubby Bumper
- HELP! - Compressor switch wiring
- Viper throttle body...problems
- Just installed AFE Power Magnum Force CAI...
- MPG with 35's no re gear?
- AEV Procal Reprogram?
- Can I...
- ARB On board air - Switch mount??
- Need 2012 drivehaft help!
- sbc swap
- Window Tint
- Exaust
- Changing shocks mounts
- -Question- SKID ROW SKID PLATE
- S&B cold air intake. Feedback??
- My rear springs look Jacked-Up, this cant be right
- Over compressing springs
- Loose Sector Shaft
- Lift kit 2nd mod
- what do i need?
- rear end bounce PLEASE HELP ME
- Tire and Speedometer
- putting a 3.5 in lift on my 2009 jk unlimited need help w/ tire sizes.
- Tie rod flip?
- Katzkin leather Seat Covers
- 2.5 rubicon express lift pucks
- Fox Steering Stabilizer
- am I missing anything?
- Mini spool
- LoD rear tire carrier with stock wheels
- Tips for self install on 4" lift
- Question about Bushwacker fender finish
- Nitto trail grapplers or toyo open country mt
- Rough Country 4" sport vs trail lift
- r u guys concern about tire weight?
- Rough Country 4" Lift??
- Gibson metal mulisha exhaust?
- What should I by myself as a B-Day present?
- about Rock Krawler bump stop
- wheels and tires (no lift??????)
- Lift Questions.. WHAT WORKS??
- Tire/Wheel tech?
- Superchipped
- Pinion angle
- skid plate advice
- Clutch replacement
- AEV procal tire pressure setting...
- Anyone modified the tray in the door panel?
- PRESS RELEASE: EVO MFG 3" Plush Ride Coils - NOW AVAILABLE
- ATX Slab Beadlocks for a DD - need help today
- Trackbar
- Question about painting sliders
- Lowest preasure without beadlocks?
- Newbie question for mounting light brackets
