View Full Version : Modified JK Tech
- Front drive shaft
- Raptor bedliner question
- flat fender
- Front left tire wobbling. Please help this girl!
- Drivers side higher than the passenger?
- Rear Bumper With Winch?
- Gear breaking period 4w or 2w?
- radius arm long arm
- Lifetime Warranty and changes to my Driveline?
- 2.5" bb lift
- Lift and gears
- RR bumper weight
- Train horn
- TeraFlex Elite LCG JK 3 Inch Long Arm Suspension
- What Tire Size
- how much mpg can you really lose or gain because of unspung weight?
- Optima blue top hold down?
- ride comfort with with 35x12.5 r15 c rated all terrain tire?
- Just wondering about 37s
- For those with tube doors...
- Aussie - Air - Electric or LSD
- JK Brawler Lite Front Bumper with Brawler Bar Install Help?!
- TPMS on aftermarket wheels and tires
- dana 30 or change prorock 44
- ready lift
- Poison spider
- all bfg km2 users!
- What order to buy my upgrades?
- offroad heros SUT top??
- Body armor hjgh clear front bumper
- 315/70/17
- 1inch BL--Do I need a motor mount lift/
- Ripp Supercharget Gen 1 Kit
- gear brands, what are yall running?
- 4 inch lift advice needed
- 39 inch Krawlers
- adjustable ball joints
- Factory 18" sahara rims with TF 2.5" lift?
- Feature comparison Diablo vs Superchips vs Hypertech
- 1" sheet metal plug
- Body Armor Roof Rack and AEV snorkel
- Treaflex 2.5 bb or leveling kit?
- What to do, What to do
- wanting to make the switch
- Odd issue with pulling to the right
- Smittybilt XRC VS Expedition One Trail Series, Tire Carrier/ Bumper
- Best place to buy Pro Comp wheels?
- From Sheep to Jeep - OME Lift Install ?'s
- 5.75" back spacing enough for 285/70r17 tires
- Mesh top question
- Brake fluid
- 287/75/17
- terrible tire wear on outside of front tires?
- HD Alternator
- Fender Flare Question
- Help with next mods
- Silly question... Aftermarket hitch
- Please help me understand
- Roof racks that work with a body lift
- Gussets and Sleeves
- RC stinger on a stock bumper?
- Axel housing question?
- Budget boost question
- Will a 265/70/18 tire on stock 18's rub?
- Front locker problem
- Rear Bumper/Tire Carrier Newbie Questions
- calling on mechanics...
- Hella lights
- AEV snorkel template help
- Will Duratrac 325/65R18 fit on stock 2012 sahara 18" rims?
- Spacer with hub kit??
- Length of time to change Superchips tune?
- MT/R or BFG AT ???????
- JKS Adjustable Rear Spring Mounts Write Up?
- PRESS RELEASE: EVO-1095 Jeep JK (07+) 1.5" HD Leveling Kit
- Swaybar Disco Length with Uneven Coil Sag
- 2010 w/ superchips vs 2012 penastar
- What else do i need for 2.5 lift and 295 70 17 tires
- Looking for wheels
- CV style yoke vs. adapter
- Truth about Dana 30s
- Complete Skid Plates System
- Rugged Ridge throttle body spacer
- JK shake
- New Jeep Owner need help accessorizing.
- K&N Filter FIPK
- LCA drop bracket
- Control arm questions (which, brands, etc)?
- Coil Rubs bump stop with OME 2.5" lift
- biggest tyres for a jk unlimited rubicon with 2" lift
- TF leveling kit+35"s ?
- 1310 driveshaft install...with cam bolts?
- Rim Offset
- 2 post lift and lift points on a JK with long arms....
- OR-FAB tire carrier question
- Rear bumper with jerry can - which type?
- TPMS....Pro-Cal Question
- Help a newbie with gear questions
- Pro Comp tires experiences? Quadratec buy 3 get 1 free rebate
- how much lift and what kind?
- Locker experience
- Looking for input - Lift/Leveling issue
- Electronic Stability Control problem with 35s
- Under seat locking storage advice
- Ques re Arb "cycling"
- Another noobe question
- Dallas or Ft. Worth shop to install EVO sleevs and gussets
- ripp mods snorkel intake
- Question about wheel spacers
- PRESS RELEASE: M.O.R.E. Jeep JK Wrangler Hide-a-Step
- Which air filter for a snorkel with a pre filter?
- Rusty's Front Control Arm System
- steering box shaft thread
- Gear Oil???
- Bushwacker flats and terraflex performance leveling kit
- Death wobble
- IS this the ABS line? And how do I not make it my limiting strap??!! :-(
- Should I need a front DS?
- camber worries
- Question regarding front bumper replacement and air bag issues.
- Spring question
- 2.5 TF + (?) Body Lift?
- Gears for 35s?
- Installing sleeves
- 2011 JKU 1" body lift....2 extra Pucks ?
- Viair OBA wiring question
- rock ring for XD monster wheel????
- the truth about shock extenders ?
- 2010 Sahara with 4.88 vs 2012 Stock Rubicon
- Badlands Winch on factory bumper update!
- is there such thing as tie rod flex with 37's?
- Realign Lights?
- nubi question, spring height
- TeraFlex 2.5, Ready To Buy, One Last Thing D:
- Tcs light flashing
- Priced out Goodyear Wrangler Authority tires today - any reason not to get this size?
- 4" lcg teraflex vs. 4" full traction
- 37" tire choices with 16" rim
- C or D rated 35??
- Gussets good or bad?
- Full Traction cross member instructions?
- AEV JK Front Bumper Skidplate and stock JK front bumpper???
- Terraflex sway bar links
- Which programmer is best?
- Bottom Axle Truss good or bad ?
- Exhaust System
- flashpaq
- Any thing to upgrade for 33
- front air deflector / skid plate replacement recommendations
- Which brand of shock?
- Power window and locks
- Dealer Installed Mods?
- gears or superchip for 33"
- Tire size impact odometer reading?
- programmers???
- Possible to add Tire Carrier to Mopar Rear Bumper?
- New/Not Ugly Rear Bumper?
- Hi-Lift Jack
- First 2012 drive shaft boot torn!
- Yet Another Modified Stock Bumper Post
- Spare 35" on rear door setup advice needed! Thanks!
- I have 2.5Tf BB what can i do to get more height???
- Best lift for a DD
- TF 2.5" Spring Lift - Rear Travel?
- Teraflex 2.5 vs Skyjaker 4 inch?
- Terafelx Rockguard Slider Fitment Problem
- Could be a silly question about aftermarket wheels
- 2011 JK Rubicon Unlimited Build Up
- SC Programmer
- About to buy.....
- mileage went from 19 to 14 mpg???
- 4" lcg teraflex long arm
- Finaly got 33's!!!!
- Xrc smittybuilt hitch capacity?
- teraflex lift versatility
- Anyone running 15" Black Rock 909's on a 2011 or 2012 JK?
- Rock rails
- Duratrac 315/70/17 tires
- Well after a month my RK 3.5 lift came in...
- what size gears do i need ??? for this!
- Need Approval From the Board
- Bully Dog Tuner
- Tire Rotation
- superchips transmission software
- Superchip Users In High Elevation (specifically high elevation)
- would a new top fix the leaks
- How are your black wheels holding up???
- Flat fender flares
- Teraflex Performance Leveling Kit ?
- American Racing ATX Artillery (Series AX1816) Teflon
- ENGO Winch
- ESP/BAS Light on after 3" lift installed
- Which Gears to buy
- Black rock wheels??
- Do i need the whole JKS Quicker disconnect kit?
- 2012 Reprogramming and gears
- JK w/ 35x12.5" tires
- Extra fuel
- currently 35s and 3.5 Lift and thinking of 37s and 4'' Lift
- bitten
- Pic requests TeraFlex 2.5" coil kit
- 22" Beadlock Wheels
- Mods for dd jk
- Bedlining the rockers....
- Not a lot of money
- Supperchip-ordered
- Trail grapplers
- Can you install additional sliders over rubicon rock rails?
- Pr 44
- Tires
- Pitbull Rocker Radials vs KM2s
- Best rims for snow?
- What's a good economical rear bumper/ tire carrier?
- Looking for best tire carrier
- Need help with shifter
- 295/65R18 or 275/70R18 Durtrac's
- Hood decal???
- "beefing up" axels
- XRC STINGER and FOG LIGHTS?
- Help with tire chirping noise after 5 tire rotation
- A little experiment that maybe helpful.
- Poison spyer tire carrier and 2012 jk ???
- 2012 tuning
- 2012 Re-Gear?
- Expedition one core mid width front bumper???????
- Another lift Question...
- Currie 4" or teraflex long arm 4"
- superchips tuning
- AEV rear bumper and spare tire carrier
- Got a good start
- ACE tube fenders??
- Rough Country BB
- Rear Dana 80
- Smoothest way to run 37s
- stock rims lol
- CJ-style roll bar in a JK?
- Bone stock jeep needs mods, what is the best order?
- Rear Axle Shaft Upgrade - Need Your Recommendations
- License plate mount.
- aFe Cold Air Intake and Other Small Add Ons
- 2012 JKU sahara 4-door, auto, 3.73's. Concerns regarding 35" tires
- safari top
- Painting OEM side steps question.
- Rugged Ridge xtreme heavy duty tire carrier measurements
- Suggestion/Opinions needed for first major Mod
- 18x9's with 3.5" BS
- Auto or Manual Trans for Hemi
- Help needed with lift advice
- Lift add ons
- 5.13's in a 2011 2 Dr Auto with 295/70/17 Nitto Terra Grapplers
