View Full Version : Modified JK Tech
- Need a little help making up my mind
- WTH is going on with M/T?
- yes, another one asking questions about lifts!
- Screw mirror relocation. Low profile mirrors with no doors
- Accelleration problem
- Dynomax super turbo muffler cat-back dual exhaust install
- Dynomax VT Cat-Back Exhaust Installed (video)
- not adjustable control arms for a 4 inch lift
- What Do I Need?
- Please double check this wheel / tire combo
- Bushwacker flares
- 35s, tire carrier?
- Next Modification?
- Does anyone have any experience with the Black Box Logistics 50" DRX Led light bar?
- New lift and 37's question
- Rear end sensor plug meet a tree lim the tree lim one
- mount for putting bucket seats in rear of JKU
- Tie Rod and Drag Link
- Hanging JCR Bumper to Paint?
- Teraflex suspension systems?
- Mercenary fastback Tops
- Tired of tires.
- Remington RTC ... Give us your .02...
- trackbar adjustment or what is needed here
- Safety Advantages/Disadvantages
- 44" light bar
- Axle breather hose
- New Dynomax Exhaust, is it damaged? Or supposed to be like this?
- New tires -- Looking for advice.
- Rusty's jk lifts
- RC 2.5'' lift, Series II or Premium Kit
- Torque Settings-Help Needed
- Air Intake and Exhaust Suggestions??
- 15" Rims on a 2008 JKU
- Wheels for wrangler!?
- Which lift kit to get?
- dash disassemble help??
- Rugged Ridge XHD Bumper or new All-terrain modular bumper ..?
- Need Guidance on Proper Lift Geometry
- Jk Gun Rack??
- Advice on fender flare & Grille Mod - Professional or DIY?
- Diesel conversion?
- Help with grinding/groaning noise when turning right.
- ProRock 44 Arrived Today - Plans for me Build - Guidance Wanted
- tpms needed?
- Hardtop lift for Garage
- Trektop NX
- Prop shaft issue after lift - please help
- Do you HAVE to recal when regearing a 2012
- Taking jeep interior apart
- Shock absorber advice
- Hemi jk
- JK wont start no crank.
- Rusty's or Rock Krawler?
- ARB Bumpers
- Question about Teraflex sway bar links
- can't make up my mind on a lift
- wheel spacers - front or both
- looking to upgrade my suspension from stop to possibly 4 inch lift NEED ADVICE
- Rescue green color matched top?
- rc four inch lift
- Headlight Eyelids?
- Prodigy Performance Turbo impressions
- Tie rod dis-assembly
- Teraflex hinged carrier or?
- New Lift installed = Death Wobble
- Stock spring length
- 37" still rub after triming rear wheel well.
- Identifying brackets- part of my frame or bumper??
- What does this give me?
- Gas cap light!!!
- Opened my front diff... What is this?
- Spacers
- Rock krawler front coil bow
- Summer tops
- Refinishing Mopar step sliders
- Painted Bushwacker Flat Flares
- More Squeaky Brakes thread... 2012 Rubi
- Rear seat relocation??
- Lift Kit Parts and Pieces
- can I mount a 33" on the stock spare with some accessories?
- Lifted?
- Rock slide engineering sliders vs Teraflex rockguard sliders
- Best winches for the money
- What lug nuts are you using?
- Water inside Rigid Dually?
- Can I re-gear on stock tires?
- Door removal
- Rear back up light
- Ooop's
- XRC Front and Rear fender armor
- Leaking soft top
- dynatrac ball joints, how to grease?
- Help
- Gearing questions
- Gears and lockers
- Finally!
- battery and procal
- Leveling kit questions
- Superchips help!
- Rock Krawler Powder Coating
- Gears for 33
- steering stab
- RR XHD front bumper?
- Nitto tires
- level 8 correct wheel offset
- Making a freedom top one piece?
- What is this wire?? I found it cleaning out my horn
- How big are my nuts
- How much would you pay?!?!
- confuse buy sport manual 2013 or 2011 ripp sc?
- tie rod with 15" wheels
- What order for installing a lift
- Who has the lowest prices on LOD bumpers??
- Soft Tops
- Dont buy from t&t customs
- UNinstalling a warn front bumper and winch...how on earth???
- Manual Valve body for a 42RLE?
- Help with violent vibration
- Painting Rugged Ridge Rim Protectors?
- So you want a smoother ride?
- Smittybilt XRC and XRC Atlas rear bumper/tire carrier thoughts and reviews.
- Tire carrier question...
- Complaints or praises for your rear bumper / tire carrier
- Advise on bedlining Rock Sliders.
- Opinion on this set up
- LOD Full Width Front Bumper - Bull Bar Length?
- Traction control light comes on
- Jku roof rack?
- AEV front bumper (MOAB)
- Best door less mirrors??
- ATLAS' build-up thread... A little differently
- Axle Questions
- Fortec ceramic coated gibson black muffler
- Winch for Metalcloak bumper
- ATX Slabs Question
- What air filter to use?
- Tires 265/70/17 BFG mud terrain
- How Hard
- Custom Borla exhaust
- Pic request RR XHD with stinger
- Warn 87750 elite series bumper
- BullyDog GT tuner - only tuner to change swaybar and locker settings on 2013?
- Call out to Tuffy
- Teraflex 4" sway bar end link bushing problems?
- 2009 JKU Rubi w/ 4 Speed Auto, Super Charger and 35s - What gears? Please help
- Spidertrax ?
- Are these shocks from a 10A Rubi?
- What type of paint for refinishing winch body?
- Why do states limit tire size?
- Where to mount after market exhaust?
- EVO Coilover and Long Arm Build Questions
- OME and long arm kit
- Input on spider gear issues needed
- Gear brands
- Cargo Racks??
- Winch on 10th Annavesary rubicon
- 2 in spacer lift
- Performance exhaust
- Mud tires???
- JKUR shocks and coils on a 2dr sport?
- Anyone cut colour matched fenders!
- Need ideas...
- Rubicon springs on x
- Coil springs
- Best programmer
- Post lift drag link slop???
- Gear question. I thought i knew what i had.
- Fog-light assembly removal?? Water Damage
- Cut stock fenders
- Measuring shock length?
- Bushwacker Flatie Install
- EVO Double ThrowDown vs. MetalCloak 6Pak
- First suspension mod!
- rattle can or powder coat
- Need advice on my first lift
- Bed lining and rocker panels
- La Paz Wheels
- For those with wheel spacers
- Can you splice wheel sensor?
- Mopar engine oil for my 2.8crd jk
- Help Wanted - tires for south tx brush country
- Mods
- 3.6 cutting out
- Welding Question: EVO Rock Sliders (or similar)
- AFE Mach Force Hi-Tuck 2.5in vs 3in
- Motor mounts
- Knock under load
- Installing seat covers with seats off??
- Rancho oil pan cover
- 2012 JKU Sport regear??
- "Tough Stuff" winches? Reviews?
- First Mod Painted the Muffler
- PR44 FINALLY here :) CONCERN THO...
- Truth about regear with 2012 JKU
- Teraflex shock extenders compadibility with Bilstein 5100 (Y or N)
- old man emu 4 inch lift
- Hoist for Hard top
- 3.6 JKUS Air Intake
- Help !!!! Need advice & .02 cents !
- Was I supposed to extend/relocate my brake lines when I did my lift?
- Northridge 4x4 X viair onboard air ?
- Bikini top
- Going from Spacer Lift to Coil Lift?
- AEV Procal / Extending Drive Shaft ...
- Seat belts
- Rock Hard Oil Pan, Transmission & Catalytic Converter
- Winch control relocation.
- Always check your parts list before install
- Brakes
- Or Fab Rocker Panel retrofit on a 2013. Will it work?
- Help me decide between these two 33's
- Poison spyder hood louver?
- Rear upper shock mount bolt size????
- Trading my 08' for a 2013 jku
- super loud driveline hum
- Wheel size
- Best way to re-finish a bumper?
- Does this Teraflex combo work?
- 38s on a budget
- Lift
- Help with a mesh top please
- second guessing Duratrac 35's for my 3.5" lift..
- Lifted JK Coil questions.
- carrier and spider gears
- Procomp wheels
- Air Pressure with 35's
- Bestop Supertop NX Issues!
- backspacing for 40x13.50
- 13 JKUR rock krawler 2.5 max travel lift
- What would an ideal wheel back spacing be?
- Spacers?
- Help me beef up my 2010 Wrangler Unlimited Rubicon!
- 13 jku bumper options
- calling all owners of poison spyder rockbrawler rear bumper!!
- help me decide muffler options!
- Anyone have AEV lift with Currti AntiRock Front Swaybar setup?
- Code P0330, check engine light, overheating and tcv came on
- Need Serious Help on ReGearing Ideas
- Orange mesh grill insert?
- Anyone else seen these lights?
- Finding Fenders
- Unwanted rusty tuning from Smittybilt and KC or just bad quality review
- Installing IPF 901xsd driving lights to a S-pod
- Need help with upgrades.
- Lift question
- Anyone have the rock hard 4x4 oil pan and transmition skid playe directions.
- 2013 Rubicon hood ,, 10th Anniversary ...how much$$
- Cool cheap mod
- Winch experts: Buying a used winch- what should I know and check for?
