View Full Version : Modified JK Tech
- Gear ratios
- Help turning my Sport into a Rubicon
- Light Bar Power Outage
- Fox shocks
- Experience with Nitto Terra Grappler G2?
- Need help
- Need help
- Disconnecting Battery With Tune
- How to Open Currie Antirock Say bar to fit on the bar
- Old Man emu
- Front end fluttering/grinding sound
- Observations after new lift and new driveshaft, is this normal?
- Cam Bolt Removal for Installation of Adjustable Lowers - Stock Bolt Info Please
- Effects on rear springs when you rotate axle?
- Spidertrax 1.5" Wheel Spacers
- What to re-gear with
- Problems turning after 2.5" lift installed - HELP!!
- Cooper discoverer MTP
- Jeep drift issue
- trailsash 2 questions
- future proof tuner for ripp supercharger later
- Rough country sway bar disconnects
- Alloy USA ball joints 11800
- NOICO Sound Deadening/Dampening
- Quick shout out to Marcus at Riverside offroad and Dave from Synergy!!!
- AEV 3.5" / 4.5" Rear Sway Bar Link Length - Help Needed
- Salvaged transmission or rebuild?
- BOLO Stolen Jeep
- Nutserts?
- What to do with stock JKU Sahara springs?
- "The real off road crowd" water crossings.
- 15x8 Steel Wheels
- 37s questions
- Stock fenders no rub with 35s (315/75r16s) needed bumpstops
- Caster question for those who have adjusted it.
- Combo windshield mount bracket...
- Improving Ride Quality
- CANNOT REMOVE BOLTS FROM BUMPER - Help!!
- DIY LS swap questions
- Looking for a pic of method machined on jeep
- Kikbax mirrors
- exhaust help
- Modify upper shock mounts for more up-travel?
- Drag Link Flip Re-do...Currie RJ to Synergy
- Method Hole in Magnesium
- shocks for overlanding AND crawling
- Jeep Jk Front Bumper Recommendations
- Adams drive shafts
- Help - trying to find reputable shop in Central Wisconsin for a re-gear
- Increasing Offroad Capability w/o Breaking Bank...
- Atlas 2 transfer case opinions
- Upgrading my lift
- PSC Steering box Vs. Stock w/ PSC standards
- Best top trektop thoughts
- JKS Adjustable Track Bar
- ARB Solenoid Wiring to SPOD
- Looking to Lift 2008 JKU
- RIPP Superchargers Holiday 2015 sale
- New powedercoated steel bumper rust prevention
- Poison Spyder Bumpers
- Installed a ARB intake manifold [PICS]
- Stock SR/A vs. Duratrac
- Lift
- MasterCraft Seats vs. Junkyard Leather?
- New shock recomendations
- Are Rubi shocks any better than the Sahara shocks ?
- cutting 4dr Rubi rails for a 2dr ??
- How much has your lift settled?
- Trail dash custom shift points
- Trucklite fog lamps on an AEV bumper
- PS body armor question
- Ram assist, need expert advice.
- Recipe for T-case grenade.....
- Control Arms and Crumble Zones
- Inner fenders
- Question for 3.8L guys with forced induction and automatic trans
- Jeep jk chevy 350 swap
- Cold Start Oil Pressure as measured at sandwich plate adapter
- OMG not another 1.25" Body Lift thread :0
- Delima with bushings on new cross members
- Evo coil overs front and rear 4" evo coils
- Transfer case output shaft seal leak. bearring?
- Engine Swap Vs Trade for New
- JK Heavy Duty Crossmember
- stock JKUR 315/75r16 Duratacs
- 6 inch lift?
- 305 70 17 BFG KM2's all stock other than gears
- Aev 2.5 lift and 35's on rockmonsters. any chance for rubbing.
- 3" teraflex question
- RK Sport Ram Air Hood
- Trail-Gear duraline synthetic winch rope?
- How-To-Tuesdays: Brakes Mods Are Cool Too
- Rubi Transfer Case vs Sport Transfer Case
- JBA shorty header gaskets
- Automatic gearbox trouble
- Obx racing long tube headers
- Rock Krawler 2.5 stock mod
- TeraFlex 2.5" lift or MetalCloak 2.5" lift?
- Antifreeze spill
- MPG on LS swap - JK?
- Synergy 3" Stage 1.5 Lift Kit
- Soft top replacement help!
- transfer case replacement.
- RC 3.5 coil swap help
- New 35's info
- Coilover + Hydrolic Bump Adjustment
- 17" wheels with least backspacing
- Spline count and lockers
- JKS drop brackets or non adjustable lower front arms?
- spare tire wreath
- pic request, MC 3.5" 2dr
- Steering upgrade structure question
- Steering stabilizer bolt
- JCR OFF ROAD JK rear fender flares install issue
- ESP/ABS/traction control and rpm flutter
- Stock Rubi Rims, what is the largests tire before Spacers are needed?
- Reference on Transmission cooler lines remove/install???
- Invalid skim key
- Protecting tow bar base plate tabs
- MY new C.C Rear bumper doesnt fit my AEV Carrier???
- Question on winch
- Gear shops in Indianapolis
- Do I need a drag link flip?
- Jk cargo security drawer by tuffy, need HELP!
- Winch plate for 10a bumper
- Benchmark Design Oil Pan Plug Replacement
- Tire wear
- Best Clutch/TOB
- Grade 8 kit
- Ruffstuff tre dust boot
- The Hooniverse Takes Rugged Ridge's Kilroy for a Spin
- guys with superchargers, exhaust question
- Sons jeep body lift
- 37's with 4.10 gears
- Winch in wet cold weather
- Bushwacker Flat Fender Flare Turn Signal Issue
- flashpaq jk issues....
- Leaking zip air locker
- If you're going hydro assist and V8... a bit of advise...
- Perfect Rear 44???
- flashpaq. ..3872
- Superchips Flashpaq 3872 issues- partial solutions
- Rigged Ridge Spartan Bumpers or Tactik Bumpers
- upgrades
- Dismounting Tires on Beadlocks
- Painted inside of hardtop
- Flat today. What would you do?
- Replacing 4 Mud Tires sucks!!
- Bedtred and drain plugs question
- Any Lift Recommendations ? yes, another lift posts but i want to be sure :)
- Semi float 60 ... let's hear from some who run or have run them!
- Snorkel Options 3.6
- Air Shocks for sag on snow plow help
- Wheel and Lift Combo Recommendation
- switches for heated seats and power
- Alignment specs
- Stock Rear DriveShaft with Lifted JK ??? Need Advice !!!
- 2011 auto transmission problems
- difference between D44 and super D44?
- Muffler options.
- Crawler concepts inner fenders
- JKS front track bar bracket
- Stock to rubicon axles worth it?
- Wheel Choices for 37x13.50 Toyos
- Fox 2.0 Evolution for 2dr?
- BF Goodrich T/A KO2 review & pictures
- Hydro Assit or Fox ATS
- Anyone have a 4BT JK? (Bruiser or otherwise)
- Have Federal Couragia tires improved in quality?
- reputable shop in florida for gear change
- Rear stubby bumper build
- Cannot decide on Lift!
- 2009 Sahara JK Performance
- JK Forum Launches How-To Tuesday, Just for You
- Dana 30 upgrades worth it?
- Nutsert tool
- Cat back exhaust system or axle back
- Rock hard cage powder vs paint and what color
- Hellcat-Powered Jeep Wrangler
- Thoughts on these PR44 set ups
- Brushguard opinions needed!
- JKU Sport Plan for 35s
- New shocks
- winch mount
- New lift re-assembly process question
- Front Coilovers
- Can i mount this 30" led bar to my hood without brackets???
- Loctite Differential Cover
- Redneck ram
- Posion spyder front flare install
- Custom exhaust help.
- 33s with 3.21 gears
- Stock Bumper Mods - What you got?
- New 2016 JKU - $2k suspension budget - help
- 4" lift for 2 Dr. drive shaft questions.
- enhanced rubi rails??
- D30 axle
- Reinventing my '13 JK Sport axles
- Looking for flat fenders
- Thump in rear end when slowing down.
- Mopar Big Brake kit install...need help
- 35lbs/hr injectors
- Back space for 8x15inch rim
- JK Lift & Tires
- JW Speaker Evo 2 vs Trucklites
- P0132 and P0152
- 2012 2dr Rubicon suspension ???
- Opinions on Superchips Flashpaq, HELP!
- question on muffler heat shield
- Black Friday Deals
- Bead locks
- 1310 Driveshaft Still Hits Exhaust Crossover
- people with the warn elite bumpers, did you get alot of sag in the suspension?
- 2012 unlimited rubicon 3.5 lift changing to 4.56
- Rumble when accelerating. Could it be pinon angles?
- Upgrade Shocks??
- MetalCloak, shocks?
- Trail dash and random jeep chime
- Irok Sizing Question
- rota pax mounts
- HP upgrades
- Oil/trans skid plates
- Pro Rock 44 Unlimited
- Which air shocks for snow plow sagging
- Looking for a diagram showing the ABS system on a two door JK
- changing my lift and have questions
- ANOTHER lift question
- 35" on Stock 18's, slight rub, need help
- Changing front Rubicon axle seals
- Cat/axle back exhaust
- CAD files???
- Regearing Follow-Up
- Need HELP FINDING BLUE PRINTS!
- Shocks
- Actual input on the Prodigy turbo kit?
- Feeling Vibration
- RK lift and steering/ lights now on help
- Rear sway bar link length?
- Locker - ARB or E-Locker? (front)
- Kanati Trial Hog tires, possible 37" winter rated off road tire
- Oversized Spare Tire Carrier
- I need help with jk project!
- 2DR Stretch Questions/Help
- Ruff Stuff Toe Rod 2x LH
- Synergy Ball Joints, Tie Rod, Drag Link Upgrade
- Jk lockers, gears, dif cover, sway bars FORSALE
- RCV's or G2 Gold front shafts
- Best Direction on Rear Axle /Coilovers
- Whats to do next?
- Questions about superchip flashpaq
