View Full Version : Modified JK Tech
- Tire/Rim question
- Seat Belt Extenders - Fixing the constant locking belt
- Help OBA
- 2012 Power steering pump, chink in the armor??
- Goodyear Kevlar Adventure 285/70-17
- Sway bar disconnect electric motor protection with stock bumper?
- Bonesliders
- 2007 Unlimited Sport
- C gussets
- OPINIONS WANTED: Rampage Front Stubby Recovery Bumper
- Bumper questions from a newbie
- lifting my jk 4 dr
- Exhaust
- smittybilt xrc bumper/tire carrier
- no more DW (as of yet)
- 2012 JKUR Gearing 4.56 vs 4.88
- Fox ATS and TF monster track bar
- Need Recommendations on Selecting a Locker
- Oil pan tranny skids that work with exhaust extensions
- Pics of 33 and 3 inch lift
- First winch install need advice nefore I start.
- All American gears/lockers?
- DW troubles in Italy too
- TF complete 4" or 4" long arm...?
- Tire pressure
- 2014 Rubicon Unlimited X Fitment Question
- Choosing the right Old Man Emu (OME) expedition suspension
- Military tires on JKU?
- Lock mess monster
- Most complete 3" lift for the money?
- Tire pressue monitoring system
- Leather seats
- fuel cutoff??
- Rubicon x hood part numbers ??? Anybody anybody ???
- Best winch for the best $$$?
- 3.21 to 4.10 has anybody done it recently?
- Toyo Open Country AT II or Cooper discoverer AT3?
- Best place to mount cb
- AEV Drop Brackets and EVO Protek Skid System Compatibility?
- Sprint Booster for 11'?
- looking for a good shop in annapolis surrounding area for front drive shaft install
- Best 4wd shop in Jacksonville fl area
- lockers
- Rusty's bumpers
- Need new sneakers.... have Kelly Safari TSR's 315-70-17 on now....
- brake light and esp light on.
- Skid plated and crossmember with RK lifts
- Rancho 7000 vs 9000?
- Jailbreak your.... 430N
- 35's or 37's ?
- Where to buy rims? Best price
- Rugged Ridge Engine/Trans Skid Plate w 2.5" lift
- 12 JKU RUBI lift/suspension help
- Resonator Delete
- Advice
- RK Heavy Duty Deep Sump Pan Vs. Skid Plate
- Too high in the rear??
- Sway bar Disconnect with AEV lift
- Affordable But Quality Light Bar
- 2.5 Inch Lift with 37's
- Is it level?
- NR Bolt Kit Install Question
- 3.5" AEV, factory fenders, and 37's
- AEV 2.5 lift right rear sagging
- Anybody run 35" with 3.21 rear end?
- Will the rear end sag?
- Aussie Locker
- OX brand rear chro-mo shafts?
- Supercharger, Tuning Issues
- 4" skyjacker 35's or 37's and best fender choice?
- Big difference?
- gussets
- Buying a used Bestop Trektop
- New tires and rims but tires pressure error wont turn off
- Bigger is better?
- Full on Death Wobble
- H4 lens assembly (adding halos) & separating headlight lens from the body
- 3.5" rc lift 35s? Regear?
- XD Addicts or Pro Comp 7005 Quality
- aftermarket drive shaft ujoint
- death wobble
- Clayton Off Road Lower Control Arms
- No spare tire
- Ring & pinion
- Auto dimming side mirrors
- balljoints and C gusset
- JKUR w/ rk 2.5 MT and PSC rockbrawler 2 bumper.. Towing?
- "Lift theory", regearing and rubber
- New gen2 Rock Krawler coils being released?
- Factory Bumper Reinstall and Blue Tooth
- 2011 JKU Regear- Advice - 4.88 vs. 5.13 befor I blow $
- removing transfer case from '11 JK - question
- driveshaft/exhaust spacers with AEV 3.5 kit
- locking hood problem
- 33's on stock JKU
- TF 2.5 or RE 3.5" lift for Expedition JKU
- New front Bumper.
- Paking Brake Indicator Light
- Superchips update
- Running light issue
- Where to dyno tune in Denver CO for diablo tuners
- Polyurethane fender repair/paint
- Winch size?
- Screamin Demon ignition
- Smittybuilt XRC fenders
- Swapping d30 & d44, worth changing brake lines?
- Lod sliders vs shrockworks
- Axle Install Problem
- Offroad Shop Lancaster, PA
- Issue Resolved with Discount Tire Direct
- New LRG 101 17x9s installed today (hubcentric wheels)
- Suspension lift plus Body Lift?
- Need help in stalling winch/custom bumper design
- Identify These Wheels?
- Weird noise
- Antifreeze leak
- Painted Rubi Rails? Anyone
- Do I need wheel spacers?
- Install price gears and gussets
- Rock Krawler 2.0 Coilover
- 2.5" budget boost pics and specifications
- 35s on a dana 30
- GT for Jeep, in CA
- Noises after installing Rough Country 2.5" spacer lift
- gears and shafts
- What lift to order ??
- *Need Advice* - Death Wobble
- Small interior storage ideas (feel free to add your own)
- More power with RAT Attack Stage II
- tire size
- LOD sliders????
- Removing the Jeep emblem
- Rugged ridge reuseable air filters
- Front passenger brake catching
- Raptor style grille lights
- Full cage for jk ?
- Not another gear question!
- Magnaflow high-clearance on 2013 fitment issue
- 285/75/17s on xd wheels? ???
- Ways to truly increase engine power or is the jk pentastar just that good?
- pa speaker
- Metalcloak or synergy springs
- swaybar position ???
- Need Help now. Front driveshaft ujoint replacment.
- Gear install help!
- Ram Assist Steering
- Lightest 35-34 in tires
- Need help!!!!
- New fender dimple
- spacers??
- Instrument Panel Backlighting
- Gears, ProCal and MPG
- 35s or 37s on Dana 30?
- Full Jeep cover to include cage
- 2011 Sound bar drowned out – I want to keep it stock if possible
- 6.4 hemi build turned to a disaster :gaah:
- Winch plates for stock JK bumpers?
- Teraflex front lower control arm help
- Need advice with a custom bumper build.
- What size rim width / backspacing ?
- Anyone running pro comp 7036!!!!!!
- 15x8 MB TKO Wheels on 2014 JK
- HELP Please! Identify these for me...
- 2014 Bestop Floor Mats
- Warn XD9000 too hot
- Deer Hauler?
- Bestop High Rock 4x4 Bumper
- 295/70/17
- Front-end noise mystery, please help!
- Shocks?
- Air tanks
- Goodyear MTR/K's - looking for the actual measured size of MTR/K's in 35" and 37"
- Picking out ARB compressor kit and where to put locker buttons!?
- Evap canister engine code
- 3.8 headers
- Thinking big horn maxxis
- JKR 3" Daystar Lift. Am I making a mistake?
- Hurricane Fender Flares by Rugged Ridge
- 285/70/17 duratrac stock wheels rub or no rub
- Flexing with Teraflex leveling kit?
- 2013 Front brake line question
- A question on backspacing, and yes I read the FAQ
- Engine rebuild questions
- Will it fit?
- D30 Axle upgrades
- Help - spacers to compensate sag on TF 3" lift?
- Hurricane fender flares by Rugged Ridge
- soft top fitment
- Lift Questions....
- Help Looking for a good programmer
- Build Dana 30 or Atlas???
- Warn Power Interrupt Kit
- Steering
- Longarm up front only?
- Latest Ace Engineering Accessory - Fuel can storage on tire carrier
- Shocks
- What winch do I want?
- replace my swaybar links??
- Roof Racks: Does this exist???
- 09 Auto Regear any thought?
- smittybilt over head console and hard top
- 285/70r17 with 2007 Dana 35 Rear Axle
- Disable Steering wheel lock?
- Cutting coil springs
- Who's running 33x12.5 r17?
- HELP - Rock Krawler DS Pinion Angles
- Quadratec QR4
- Anyone running the ProRock 80?
- Disco question
- Replacing ball joints?
- Which wheel size?!?
- Rocker Armor and Fender Removal
- Ace Engineering mid width bumper and 37"
- Help!!! Airbag sensor's on underside of 07 Wrangler seats after installing Corbeau
- Fender Flares
- Signal mod works on 2014
- 2013 procal is ok on 2014
- Suspension leveling question
- Fender mod
- Teraflex hd carrier...
- What Does Your Oil Pressure Gauge Read?
- Jeep Jk rear body mount
- Not sure what happened here
- PSC Brawler Lite Winch Mount Question
- Ballistic Fab gussets
- PR44 upgrade questions
- 2 jks 1 problem
- 4.56 vs 4.88 cost difference
- Will a 10th anniversary rubicon hood fit a 2012 model jeep?
- Spare Tire Bike Rack
- AEV winch plate for 10th anniversary JKUR does it fit?
- Custom Fab Tube fenders....
- Is the Plastic Engine Cover Necessary?
- 5 speed manual in a 2007 that came from the factory with a 6 speed manual.
- Drill Out RockKrawler Lower Control Arm?
- Custom inner fenderliner / mud flaps
- Caster vs Pinion Angle?
- Pinch seam
- Rubicon Express lift
- 12/13/14 TWO door Sports only. What do you have to help me build mine?
- New 2014 JK Black on Black / Need real advice about tires....Please!!!!!!!!!!!!!!!!!
- How to check pinion angle.
- Help identify what this is
- Drive-shaft drop kit
- Newbie Tire question
- 2007 Fog light bulb upgrad
- 2014 JK wrangler parts
- Rugged Ridge hood completed
- How to use tintable U-Pol raptor liner?
