View Full Version : Modified JK Tech
- More on-road power
- Accident Advice :(
- Warn Zeon 10K on a PSC BFH
- Axle tube end dust covers for Teraflex R44 Housings
- Upgrading Axle Shafts
- Resonator delete
- Gobi roof rack with smittybilt tent
- Piecing together a lift kit....advise, experience?
- total make over interior
- jk with limited slip diff and brake lock diff is it enough
- Anti-rock
- Rock Slider time for my 2dr JK!
- Anybody taken the "cheap header plunge"?
- 5.13 Strength vs 5.38
- Tactik heavy duty carrier install= rattling tailgate
- 2 Door quarter panel armor?
- JK 2013 6.1L nAG1 to NV3500?
- Dissectting the Dreaded Jeep Windshield Wiper
- 2017 Headlights
- Rancho rs9000
- Front end clunk driving me nuts! Please help!
- Anti rock bars--
- Spline count
- Rim to Tire Size advise
- 4.88 or 5.13 with 6 speed manual and 38's for a daily driver
- Installing jks rear track bar bracket or no bracket
- Clear coat bumpers as opposed to paint or powdercoat?
- 2.5 Teraflex lift vs. 4 inch rough country
- Lifting soon, need to know if there is anything else I need?
- Those wondering about tire size with no suspension lift
- More Technical Gearing Question
- Tailgate Hi-Lift Mount
- Rear axle shafts 4340 vs 4140
- Rough Country Light control
- Loose steering after lift and 35" tires
- Rugged Ridge XHD bumper - compatible winches
- Is my front drive shaft on its way out?
- Ripp vs LS?
- Mod stickie idea
- Stt pro owners, street PSI?
- ACE / Maximus 3 tire carrier reviews?
- 2012 Wrangler steering wander. NEED HELP!!!!!!!!!!!!!!!!!
- What should I do next to improve ride quality
- No turning back now... at home regear
- Side shafts possible issue
- Need help with which soft top to get
- wheel spacers and time
- Show me your 2 door with 2.5" lift
- The "steering wheel dance" only works once...
- Poison Spyder Crusher Flares Bracket Material
- Bumper Swap Fitment
- HELP! Bad Steering Clink Noise (video link in post)
- removing spacers help
- King coilovers
- What ratio should I pick?
- Time for dual battery set up?
- AEV 2.5, 2017 Automatic, 35" Tires
- 4.88 vs 5.13 strength ?
- more oompa
- Couple of DIY regear questions...
- front control arms
- Major vibration and clicking at low speeds?
- Is there a better hitch reciever than what comes on the JK?
- Teraflex Falcon Shocks and Steering Stablizer
- Stock pitman arm 2015 JKU
- tire choice
- 315/75r16 VS 315/70r17
- Rear Bottoming Out over Bumps
- Superduty Dana 60 Swap Questions with Artec Swap Kit
- Opar blade bumper.
- Coil rubbing on steering box bolts
- Synergy drag link flip , new rear TB relocation bracket required
- King coilovers
- 17x8.5 4.75 backspacing
- wheel purchase
- Advice on ovaled out bolt causing DEATH WOBBLE?
- 4.56 or 4.11?
- Jk lower steering shafts?
- Help with a JK Suspension Installer in Missouri
- Ripp headers info
- Rampage Trailview Soft Top (JK 2 Door)
- HELP !!Water coming in from the passenger side.
- Where to buy UD60's
- Where to mount a switch for compressor.
- 3" lift dropped my mpg 4 miles
- Heavy duty suspension
- High Clearance Exhaust
- Where is my jack? Speaker is in tub
- Alignment issues after TeraFlex Leveling Kit Install
- Soft top
- ARB twin, will it fit in the cargo area?
- Not even 24hrs home.
- Teraflex rzeppa high angle opinions
- Bestop Cargo Cover and Cab Curtain
- Front Axle Sleeves
- Superchips 3571 Flashcal for Jeep 07-16 Jeep JK
- Headlights.
- MOPAR bull bar for 10A HR front bumper
- 3.6L power loss?
- Military Rims and Tires
- Accurate Inline Tire Gauge
- Name this rear bumper!
- Anyone added .5 inch or 1 inch spacers with a Teraflex 2.5 coil lift?
- Jack question
- What else is needed to complete this lift?
- Lift kit recommendations??? Airbag lifts??
- JCR Vanguard flares
- How-To Spotlight: JK Starter Modifications
- 4.5" or 5" backspacing wheel? It matter?
- 3.8 JKU, 2 cats vs 4 cats
- Tyre Carrier Suggestions??
- 16 jku tailgate strength??
- p285 70 17 or lt285 75 17 falken wildpeak
- Death Wobble Help
- JK 3.8 Oil leak problem
- esp off switch install
- soft top repairs
- Steering angle?? Some Bump steer/ rough ride with bigger tires
- questions about jk mods
- Pinion gear
- Help me learn about wheels= offset recommendations?
- Secure my Traildash2--
- wheel spacers
- Artec front truss + Teraflex long arm = problems?
- 2dr and 4 dr rock slider same?
- powder coated wheels
- Teraflex or smittybilt HD tire carriers (non swing out)
- Noise from the driveshaft or underneath near the rear will well?
- backspaced rims
- Hemi 5.7 - Heater Hose Coolant Flow Direction - Poor Heat - Sporadic Temps (Solved)
- Balancing 40's
- Just got hit......time for upgrades.
- Poison Spyder Rock Brawler lite skid plate install
- Poison Spyder hood louver
- Help How to fix Emergency Brakes on Jk 11
- Torque Converter lockup after gears and flashcal
- 2.5 shocks with 37s?
- Re-gear 2016 2-dr Jk
- Bad knock on driver wheel side
- Easiest Soft Top Option for 4 Dr Hardtop
- Re-gearing JK
- 2012 2DR with teraflex 4" lift and double carden D/S front and back
- Coil spring location
- ACE bionolt-on slider for the JKU (Question)
- 2017 4 Dr Jk Tuffy Security Enclosure 299-01/Fab Fours 2060-1 and Freedom Top storage
- Teraflex Dual rated manual sway bar
- Short or long arm for jku
- Adams drive shaft fitment
- 295/70/17
- LED front turn signal and side marker recommendations?
- Evo Double D Pro kit - Tweaking
- Rebel Off Road Recon DSS (Dual Shock System)
- Need opinions for Rims/Tires
- Extra Side Step
- Lift Kit Swap?
- Ecoboost JK. Thoughts?
- AEV 3.5 or other?
- double triangulated rear end
- New to JK Forum....have a question regarding tire rub
- Rim and Tire Purchase Advice
- 34s vs 35s
- Regearing and reusing old shims
- Help
- Gonna go for it. MoTech LS conversion.
- New JK and Lift recommendations
- Lift for sport JKU
- D44 Replacement Axel recommendations
- Anyone know of some aluminum door handle replacements?
- Tire recommendations
- Should my springs bow & hit stuff like this?
- Rubicon transfer case really better?
- Fabric Doors
- Code P06DD
- Was lifting your brand new JK worth it?
- Rugged Ridge Elite Non Locking Fuel Door for 07-17 Jeep Wrangler JK
- BFK ko2 34 x 10.50
- Snow Chains recommendations for 315/70R17 BFG AT KO2s
- Skinny tires
- V8 and D44's
- Sprint Booster Version 3 quasi-technical review
- What should I upgrade for more highway power?
- Help with Timken Bearing Speed Sensor Replacement - JK
- Bump steer
- Student Budget
- JKU Cracked manifold again... need advice
- AEV Hood
- Go 4.56 gears or don't use OD?
- Question about body-mounted tire carrier
- Questions on set up.
- Question on installing 2.5" lift kit
- 08 JKU Rubicon
- The budget friendly upgrade to 37" tires for a pavement princess
- Control arm brackets or nah?
- 285/70/17
- Dynatrac PR44/60 or PR60/60
- MCE Fender Questions
- Offroad Heros and Doors Question
- Griffin Radiator "5-00152" in a 2015 JKU
- Nitto Trail Grappler 275/70R18
- Mickey thompson tires
- JK Front Wheel Hub/Bearing
- Mounting Hi-Lift on LOD carrier
- Looking for ideas (3.8 jk with RIPP Supercharger) sealed airbox?
- JKU 3.5" Rock Krawler Not level
- NEED HELP - EVO Pro Series Front Bumper
- Front hitch & tow bar possible?
- Rhino or Linex factory flares???
- Success/Fail with Supercharger installed on JK Unlimited 16 3.6l Auto
- New tires just came in!
- Pro comp vs tera flex
- Upgrade Priority
- Tire carrier do i NEED?
- Trying to relocate rear sway bar mount location
- flat flares with stock rear bumper?
- Do I need to replicate sahara stock wheel offset with aftermarket wheels?
- AUX FUEL TANK..Do you have one?..Do you want to get one?
- Transmission linkage bushing
- 07 JKU with LS motor swap, trouble with registration/emissions in AZ (kinda urgent)
- RJ 44 has arrived!!!
- 2016 JK 2 door Sport S mods
- Painting Inside Hardtop Black?
- Dana-Spicer Ultimate 44 Issues
- RK Offroad Pro Long Arm Length vs Other Brands
- Teraflex slams the Tire Carrier copycats
- TeraFlex Falcon Shocks and Nexus Steering Stabilizer
- Well, time for a new axle
- Lift Suggestions
- Tire Carriers
- Mix & match suspension components opinion/advice
- External Lighting vs VA State Inspection
- 3" lift with no driveline angle problems
- Connector hose side to the valve stem name?
- Gear Question 4.88 vs 4.56 on 35's JKU
- Tube Doors, let's see what you've got!
- Any idea what wheel this is??
- Smittybilt 2781 and 35s
- JK Front Fender Frame Rail Removal
- Drag link & tie rod upgrade
- 4" lift, and 35's question
- Opinions???
- Steering linkage
- Putting the 3D printer to work
- Help Upgrading to 37"s
- JK Inner Fender options
- What PSI do you run on the street? (On 35s)
- 4" Lift
- Light Bar Deal - Anyone Ever Use a Pyle Light Bar?
- Front bumper modification question/help
- JK front seat replacement for tall guy , any good options ?
- What To Look For When Buying A Used JK With High Miles
