View Full Version : Modified JK Tech
- Opinions on rear 3 links?
- Thinking about the JCR Offroad Vanguard Front Bumper, but I have concerns
- Stupid danna 44 question
- Tell me why not!!!!!
- im looking for good led replacements for reverse lights
- Steering wheel wobbles.
- Popping noise
- Serious problems after adj arms install!!!
- LS Swap Nsg question
- dana 30 help please
- Wilwood brake kit
- Bent Axle Sway Bar Mount? Pics
- Pic request
- Tires
- Rev much
- Adj control arms with drop brackets?????
- Best top nx?
- Help me decide and are there any issues I may encounter? Nittos TG, Toyo OC, ProComp
- Exhaust
- Looking for expert advice
- Need Advice PLEASE!!
- Disconnecting e-locker wires from diff centre
- Which lift?
- Full width rear bumpers - pics plz
- Rancho Rs9000XL shocks good?
- Exhaust question
- Front Brake lines a problem with 285 75 17 stock rims no wheel spacers
- What bumper and tire rack is this?
- What bumper and sidebars is this?
- Front end "clunk" noise on my '13
- Corner panel carnage
- Lets see those 40" tires
- drag link options??
- Do You Know This bumper?
- Click/rattle? Noise at 57mph only
- Rear mounted LED light bar
- Alignment spec sheet questions
- Draglink removal-Need help
- Bestop Trektop NX Blacktop
- Rear Window Part Question
- Rk rear upper arms
- Pro Comp MT2 Balance Problems
- Teraflex ball joints
- Steering stabilizer
- Never used a programmer, soooooo.......
- JK with 2.5 lift
- Engo winches pros abd cons
- Pure Jeep rear bumper woes
- Do i need a new carrier for dana 30
- Yet another lift question!
- Teraflex Exhaust Spacer Kit
- Borla headers / check engine :(
- Trektop nx
- guys with 4" evo Plush on JKU I need a measurment
- Front driveshaft with budget boost and trackbar
- Which Rancho 9000s for my Dad's '07 JK?
- KC HiLiTES 5-Watt Cyclone and Amber C-Series LED Lights
- Help! What rim is this? (pic)
- Lift from shocks and springs only?
- Help me decide which 2.5 lift - RK, OME or MC
- Something to Consider About Your Gearing
- HEy!! Can i get away with this?
- help! I need lift kit advice.
- Whats this??
- Bumpers
- Excited!!!
- Help with wheel issue-hutchinson's
- Wheel Hub TIp
- Soft tops
- Noises with teraflex 2.5 lift
- Hankook Mt or Maxxis Bighorns.. Anyone?
- 3.21 and 285/70-16
- Part numbers for Bilstiens used on the AEV 3.5" and 2.5" lifts?
- Any AEV Differential Cover Reviews?
- Tops/Covers
- Bumpers, Bumpers, Bumpers,
- drive schaft tom woods
- Swapping 2 door to 4 door, any problems?
- Coating on grille
- Looking to Sell Jeep - Need Price Opinion
- Long Arm Upgrade
- 3" lift and 1.25" body lift... anyone have any pics... getting mine done.
- Fog light delete questions
- FNG With 35's on 15s + Trimming Fenders + 2.5 coil.. What else?
- Pro comp stage one lift
- Which lift?
- Fluid Film?
- Steering Clunk
- taller coil...Evo plush 4" or MC 3.5" ?
- Sleeve fitment on ome stabilizer
- square led taillight manufacturers? (flushmount)
- Sway bar light, lights flicker, abs light, brake light, cruise shuts off, and a ding
- Need opinions please on what you would do
- Will Nitto Trail Grapplers 35x12.5x17 fit on my Stock 17 Inch Rims?
- Whats an example of "to heavy on the skinny pedal"?
- Really bouncy ride
- chopping front bumper
- XJ Roof Rack
- Northern California Hemi Swap Shop
- Track bar question
- 35's or 37s on a Dana 30! (Budget and Check list)
- Jk rear cargo area
- Offroad Camping Trailer Under 1k
- 33,s with stock suspension?
- Future Modification List
- If you're having death wobble, read this!
- 4.1 stroker? Who's done it? Pros vs cons
- pics of Poly Performance 4.5" lift
- Tansmission woes
- Gas octanne in 3.6
- 37" tires
- Grill Guard Question
- are certain front coils more narrow than others?
- FOX Shocks UpTravel Question
- rear brake rattle?
- Water proofing
- Which rear track bar relocation bracket?
- Who's running 37's and what sector shaft brace are you running on your JK/ JKU?
- I'm in Bumper Limbo
- Anybody running 35" Maxxis Bighorn's?
- Ok look my mistake on posting virus thing with northridge
- additional parts for this lift
- Suspension and hitch-mounted motorcycle rack
- what donor engine do I need?
- Frankenlift 2"-2.5"
- Bully Dog GT 40440 Not Fully Compatible W/2012-14
- Heavy bead locks + 35's - do I need front axle kit?
- Question on Artec Spring Perch Installation
- regear sanity check - yes another one
- side mirrors
- Welding help
- OEM Seats from another vehicle
- Post lift install: Advice
- Gear Whine?
- Oil Filter part #
- 4:1 tcase ratio to program in superchips
- Front bumper
- Old man emu 2.5" lift parts
- Hemi Swap
- Rough Ride
- Minimalist console options?
- Rear Sway Bar Links - How do I determine the right length?
- quadratec question
- evap canister noisy!
- Where can I get a stock driveshaft??
- How Much Do I Fill With A Aftermarket Diff Cover?
- Spring Isolator Question
- Ideas for 2014 freedom edition
- Long arm versus short arm? Comparission
- what's the height of your rig?
- 2013 jeep wrangler door hinges
- Question about the smittybuilt Atlas full width bumper
- 14 bolt vs sterling 10.5 vs dana 80 (rear)
- Which Programmer/tuner?
- Jeep newbie lift and wheels
- Lifted, 35's, auto trans, the Highway and gears
- Transmission overheating probs
- best/most user friendly high steer kit?
- Cargo Restraint System
- New grille?
- Best 35" tire
- Dynatrac Prorock60 ball joint replacement
- Diff oil change after regear
- Violent Shaking
- Aluminum front & rear bumpers....
- Nitro Sleeve Question
- Which "hybrid" tire?
- Need wheel/spacer opinions - 15" wheels, pre-existing spacers
- Front end noise in 4wd
- Speedometer change?
- 255/80/17 copper st maxx
- Bedlined Hinges
- Got keyed!!!!!
- Highway vibration
- Bestop wrap around wind jammer
- JK Rear Axle locker connector
- SPOD Wiring Questions
- Quick Question
- Superchips Flashpaq Question
- TJM Engine Skid Plate
- Nitro Sleeves loose.
- Yes another tire question....heard of these?
- Bolts for door hinges
- 2013 soft top on a 2008 JKU
- those who understand alignments
- Stock front bumper trashed...
- Spare Rear tire mounting
- the coolest thing happened today....
- New 2014 Wrangler Unlimited Rubicon X - Best Soft Top and other questions?
- Codes P0369, B157B, C121C, P2638 only when towing (under load)
- On board air
- Help needed: Trying to build a Freedom panel soft top insert
- Paint color match - Tracker black wheels
- That black hole gap between the front seats and the console....
- Beware:AEV Hemi Conversion kit leaky radiators and blown catalytic converters
- Spacer lift
- Regrets - post them here
- Used Suspensions...Yea or Nay?
- what does your jkur weigh?
- "Whoop" Noise when turning all the Way Left?
- Marathon Seat Covers with dual gun loops
- Teraflex Discos, solution needed
- Hydrolock Motor With Fuel
- Wheel Question
- Falken Rocky Mountain ATS 2 feedback
- Post-mod Shake
- Used Jeep, do i need a procal/superchips
- Golden Eagle Hood decal
- Chalk test results [PICS] [HELP]
- Rubi Rails with OEM Steps
- My 2011 Wrangler regrets!!!!!!
- Clutch Issues
- JKS trac bar brace
- Drag Link Bolt & Adjustable Lower Control Arm Question
- What exhaust is this?
- 33's and spare tire weight?
- Paint the roof: bus kote, plastidip, or it makes no difference?
- Front end noise
- Auto trans issue after trans cooler.
- northridge 4x4 website issues??
- Anyone have a clayton high steer kit AND a fox ATS 2.0 steering stabilizer together?
- Newbie needs advice!
- Can c gussets wait??
- Trektop NX Owners come in!
- Best place to get an AEV 2.5 Lift for the BEST price.
- Fuel Rail Not Getting Fuel
- Tubular doors
- Moparpartsoverstocked.com
- My Jeep Won't Start with My iPhone Near
- Lift, Tires, and Stance
- 285/70/17's on stock 2013 Rubicon wheels?
- Shops in Northern VA?
- Noob- Color question (Amp'd)
- exhuast systems
- Center Caps?
- rear axle pushed forward
- Rubicon Express 2.5 rear bottoming out
- 5.13 Gears 37inch MTR shifting issues
- What to do with center brake light
- Air dam replacement with skid plate
- 2 piece soft doors with premium (twill factory) soft top?
- AEV 4.5 lift issues
- Does size really matter? We are only taking 1/2" or so...
- Oil changes..,bla...bla...bla
- Cold air intake risks???
- Evo drag link flip kit failed
- Bedliner
- Nebie Question-Tire Sensors
- intake,tuner and exhaust
