View Full Version : Modified JK Tech
- 54,000 miles later...
- Looking for the best gears.
- rear doesn't level.. blown shock?
- rugged ridge alloy rims, enough BS?
- Started My Install
- Spacers needed?
- front bumper
- 36x13.50R18
- Sway bar link relocation brackets
- rockhard evap skid - install help
- synthetic fairlead
- Tight Trackbar
- Handling in 4wd after gear install
- Leveling question...AGAIN
- Driving with broken passenger side Sway Bar Disconnect
- Drivetrain question, looking for helpful answers
- Coils, shocks, long arms, short arms, suspension lifts, coils lifts...
- 2.5 inch lift - coils VS shocks?
- Splined Vs. Free Spinning Hub
- Need a definite, correct answer for transfer case swapping.
- Got my Rock Krawler degree shims, but how the heck do I install them?
- Ripp Supercharger
- Installing 4 inch TF with control arms..
- Budget Boost...Need New Driveshafts?
- Ultra Magnus Wheels
- Want a Stinger
- SOS: Lower control arms...again...
- Question for fitting 15" wheels on Sahara
- Black Grille Inserts - need opinons
- R.C. Disco's w/Teraflex L.K.?
- Full Traction 3" -vs- Tereflex 3"
- Anyone have a hitch mounted cargo carrier?
- smittybilt XRC rear bumper and tire carrier
- Nitrous oxide
- winch trouble
- 33's on a stock sahara
- rear camber question/ need help
- high lift question
- Help!
- Can I use Yukon Dana 30 Carrier with OEM 4.10 gears?
- wheels on jk
- fab fours bumper light install?
- Currie LCA to magical 6-7 caster
- Ten Factory shafts w/CTM joints or RCV (Longfield) shafts
- help me pick shocks
- Rear Track Bar Brace affecting Coil
- Expedition 1 trail series front bumper
- will 36s really hurt
- Fenders question
- Which Tuner?
- Winch mount on factory bumper?
- EVO Rockstar skids, TF 3" w/9550s, ? about shock length
- Shrockworks slider question.
- Bushwacker Flat Fender Flares
- OME HD Lift Install Question
- 2.5 spacers with 4 inch lift???
- Help! w/rear axle housing removal
- Engine light after lift install
- extending breather tubes
- 37'' daily driver
- Installing the 2.5 Teraflex coil kit tonight.
- Which wheel size is best for 33x12.50?
- AEV Front Winch Bumper Install
- After Evo gussetts and sleeves?
- Km2 psi
- Regear in Philadelphia, PA area
- How to run wires...?
- Question on Mounting Front License Plate
- Pro comp xtreme m/t wear
- rubi t case or not???
- Which Wheels for a silver Rubicon
- Xenon narrow flares with black 4 door
- Best wheel search site?
- teraflex leveling kit
- shrockworks stubby question
- overhead storage
- "Thump" When taking off from 1st
- 33" tires need help/information
- Bedlining the cab
- Adding weight to front of Rubicon need help with lift/springs
- Need some Longer Links for you BB? Try Moog K80042
- Tf bb help
- on board air
- Cooper Discoverer STT or BFG MT KM2 ?
- Will this spare fit on my carrier?
- Custom Lift Kit
- What 35s on Sahara Wheels?
- which coils?
- Front Drive Shaft
- Windshield Light Mount Bracket by Olympic
- OME Coils And TF Shock adaptors bad news?
- 35 inch mtr's 5 tire rotation or not
- Rough country 2.5" progressive lift : Problems !!!!!!
- 5.38 gears
- Bump Stop extentions?
- Custom ecu???
- MBRP exhaust install question
- Cheap winch cover
- I've got a bad lift, what to do?
- Stability Control
- Gear install d30
- Teraflex Disco Brackets/Pins with Stock Links
- 35's on Stock 08 JK - 4 Door?
- zone 3" coil lift
- Cheap extended sway bar links
- Edge Products
- Hi-lift mount question
- Riddle me this, Batman...
- Teraflex 2.5 coils?
- what will be the correct sequence of uprgrade job
- Trackbar Bracket
- Reducing lift height ?
- I was about to get Rockstars but....
- PRESS RELEASE: Die-Tech Off-Road Seat Mounted Fire Extinguisher
- HELP with wheel spacers!!!
- lower control arm brackets destroyed
- X model adding Rubicon lockers
- Too much front-end dive
- clayton 3.5 lift
- Adding two inch spacers to 4" Skyjacker lift
- Anyone using Full Traction Economy Lift?
- Mopar Lifts.. Opinions please
- How come I didn't need brake extensions???
- Leveling kit shakes
- Upgrading BB - What do I need?
- Spacers on top of OME HD Lift???
- MBRP exhaust
- New lift spacers or leveling kit?
- Warn 9.5ti ......
- ARB compressor vs Viair
- 3in teraflex long arm?
- Bilstein 5150 shocks
- AEV snorkel + stock hood
- xrc bumper/tire carrier!!!
- any tips on chips?
- Diff Glide Plate
- Anybody regrets on the snorkel?
- lube Locker?
- Wheel width???? 14.50 wide tire???
- Fabtech 3" & Eibach Spring Question????
- RockKrawler Tie Rod Ends
- River Raider Diff Breather Kit
- How much noise should poly bushings make?
- Question about bedlining
- Steering Box
- ARB Safari Snorkel - SS1066HF coming soon!
- 2008 rubicon...37'' tires...drive line mods???
- Winch Covers ... you use one ???
- How much does factory front bumper weigh?
- Any Opinions on Gear Manufacturers
- Spartan locker on a JK
- Whats the best tool for the fender chop
- Factory Locker with 37's
- Opinions
- Extending Diff and Tranny Breathers
- 2.5" Coil Lift + Spacer in Front?
- roof racks
- didnt fit
- Factory Limits Torque in 1st and 2nd
- Problem with the body lift
- 33's on stock wheels
- First post with a question on 33's.
- Removing Teraflex bumpstop extension
- Runnin 35x10.5"
- I searched but could not find. REAR FENDER TRIM
- stock rims with 325/65/18's ?
- Frustrated... Need help/ Advice
- rear spring guide - top mount
- TF 2.5'' vs. Skyjacker
- Riddler D44 Diff cover owners: which Trackbar doesn't rub ?
- Axles seals and warranty ????
- part numbers for rubicon transfer case planetary gears
- Upgrade Choice: Axle Gear Ratio or Transfrer case?
- Rugged Ridge or ARB
- Which Track Bar
- Torquey Cams for 3.8L motor
- new drive shaft opinions
- Shock Bump stops..
- Request for Advice on Rubicon Long Arm 2dr Installation
- Dana 30 arb air locker
- 2.5 in teraflex bb and 2 in ome springs
- Rubicon stock suspension on X???
- help! ripped off lower control arm bracket!
- Driving a drum
- Rubi or not?
- Questions for Cooper STT and BFG KM2 Owners
- Lockers
- Flat Fenders with Stock Bumpers?
- tailgate hinge covers
- Superwinch and fairlead
- MBRP Spare Tire Bracket
- 36 inch tires
- Lift Choice.
- Which gift for my 1yr. anniversary??
- How can I tell if a shock is broken?
- Lift Problem Need Help!!
- Brake line brackets with 2.5" lift?
- Brake Issue
- stock performance shocks or TF
- how to take advantage of my current stock configuration
- Smittybilt rock rails
- Need help with TF 3" lift Spring hitting TB
- Remove rear sway bar connects?
- does anyone have 16" cragar soft 8's?
- Need Some Bumper Info
- bumpstop question
- TF vs OME
- How to get crush sleeve out of steering stabilizer?
- POLL: which brand driveshafts?
- How to Clock or Flip Electro Disco?
- Steering box sounds like a pirate ship!!
- electronic Sway bar discos on my x
- First Upgrade?
- AEV 3.5 vs Clayton 3.5 lift
- Performance exhaust
- extra travel from disco's
- short, long or mid????
- what is the best lift kit.
- Lift Kits In Africa. Help!
- Did anybody upgrade axle gear ratio by himself?
- Spacer lift kit questions
- what do you think?
- Clamp For Tire Carrier
- Driveshaft Upgrade Help
- Who has the Rock Krawler lift
- Teraflex rear track bar bracket
- Winch solenoid issue?
- Rugged Ridge touch up?
- Teraflex 2.5" Spring Lift Install ???s
- First upgrade with $400????
- Stinger vs. hoop
- Stupid axle leaks
- rugged ridge bumper d rings PITA
- teraflex 2.5" bb
- ss brake lines
- Need help with spare sizing.
- ESP/BAS lights
- E-Lockers and axle questions
- tube fenders do you need the plactic under protection
- Rubicon Gears in an X
- Effects from cutting the hood and not covering it?
- Daystar 1¾ spacer question
- best headers ??
- Road Armor Stealth Front Bumper w/Guard
- Rocker guards...
- Gauge pod?
- SOLID diff cover, H14 hex bit? seriously?
- Just had alignment, now grinding noise
- Wheel Size
- Center of Mass - Wheel Spacers to widen stance?
