View Full Version : Modified JK Tech
- changing rubi shocks
- Roof Rack Thoughts?
- New Bilstein SS + Dominion Relo = Alignment Issues?
- Swaybar discos...Teraflex of JKS?
- 2.5" Lift Questions
- back spacing issues.
- OME HD vs. OME MD
- Question on Pro Cal
- Alignment ?
- Rear ARB Air locker to replace LSD?
- AEV Spacer Suspension Lift
- Some Advice and Info for Wheel size and tires...
- Should i
- Mounting & Balancing 35" Toyos
- Best track bar and lcas
- D-Rings, stock bumper
- AEV procal and Superchip Flashpaq
- Flat Flares
- problems with teraflex 3"
- 2011 front skid plate other than RR?
- Options for balancing 37s
- Re-centering wheels
- Transmission cooler temp sensor... will this work?????/
- Will cutting front frame rails void warranty
- New Mopar winch bumper for 2011/2012?
- Rock Krawler 3.5" X-Factor Lift Kit.... Any suggestions?
- Rear track bar and high steer kit
- Any solid 4" Lift Kits under 1K?
- tire chalk test question
- help on deciding on rock rails
- License Plate Location
- PSC Rocker Knockers: Best way to finish?
- 4 inch lift with 35 inch tires on stock gearing
- What Tire Pressure
- Do I need a winch plate ?
- 35's mounted and balanced pricing?
- Suspension Questions?
- CAI people?
- LD or HD?
- Gears and locker this weekend... should I do seals?
- 33's with TF leveling kit spacers requred?
- Death Wobble - Track bar help
- Aluminum vs Steel
- Air Scoops ???
- Teraflex 2.5" lift quick question..
- Electronic Brake Control System Problems
- Eaton rear electric locker ?
- long arm, short arm
- 295/65/18 vs 275/70/18
- Question - Rubicon Express 3.5 lift
- Fender trim
- Shock Time!
- Wheel spacers?
- Poison Spyder Tramp Stamp Question
- lift question
- Very Specific mileage question
- 10 rubicon springs fit 07 2wd
- seat covers with no air bags?
- Length of control arms with PR44?
- Teraflex 2.5" BB or ReadyLift 3" SST?
- Max lift on stock
- Let me see the 2drs with 37's or HIGHER
- Thought on an Alternative wheel...Mustang to Jeep option
- XHD Vs. XRC
- Squeaky Gobi
- 45 psi ?
- Lower bumpstop extension question
- Adjustable Track Bar Question
- Body lift pros/cons
- Bumper Warranty
- Best winch for 600
- If you have installed a TF 2.5 Coil lift please chime in.
- MTR/Black Rock 909 Question
- Olympic rear bumper?
- help me spend 2400 on stock jku
- Chrome or Black Lug Nuts on XD Addicts?
- Rough Country X-Flex Control Arms (LF)
- transmission tempature
- what does a superchip do?
- Bumper questions?
- Just order tires and rims!
- Let the build up Start!!!
- drive shaft vibrations after install
- XRC Body Armor questions
- What is the best 35" for a street DD?
- 5:38 gears in a non rubi rear dana 44
- Teraflex LCOG long arm kit with Shrockworks Sliders????
- Bestop Trek Top NX???
- Leveling Kit Advice
- Air Compressor attachment
- Death Wobble in the making....???
- what do you really think about rough country 4'' kit?
- Superchips error code
- Warn 9500 Power Plant
- Bully Dog Triple Dog GT Gas Tuner
- Cut Sunrider into Bikini Top?
- Rock Krawler Tie Rod.....and alignment issuses
- Old tires not perfectly balanced, rock them for another year?
- Heat shield
- Jk ome suspension lift
- Trek Top or Mopar OEM (soft tops)
- How to find out what gear ratio I have?
- TF 3" coils or OME 2" HD??
- How much to tint front windows
- Sway bar Links
- Where do I get this "thing"
- axle options
- Are the stock lug nuts on my JK Moabs "Acorn Style Lug Nuts" ????
- can a wheel not work because of a offset.
- How wide can i go
- superchip programmer
- Gearing question
- Front diff cover leaking
- Full-Traction Crossmember
- MBRP Spare Tire Relocation Bracket who runs them with 35" tires?
- Strange squeaking noise
- Line-x help
- 3.5 lift and drive shaft
- Initial feeling/thoughts after regearing
- What lift not to get?
- Cragar Soft 8s in 16x8 or 16x7???????
- Axle question
- Rear Dana 60 Options
- Front LCA install question
- Need you opions on MPG for....
- 33 vs. 35 and Appropriate Modifications
- What's the deal with axle widths?
- Need help on measurement on various for diamond plate
- ripp gen 2 question
- Need help on measurements, doors, patkbrake and shifter.
- Coast 1310 front drive shaft
- Nitrous bottle to co2
- Transmission Cooler - Warranty
- Kumho KL71 Mud Terrain...
- To prime, or not to prime.
- Buy Coils for Existing 2.5" BB?
- Gears & Lockers
- help needed: front swaybar link clearance from coils
- teraflex rear brake line extension problem
- help on alignment specs
- New Bestop Supertop NX
- 35's with 3.73
- 2012 JK Rubi Purchase this Fall - Planning mods now
- Warn Rock Crawler Front Bumper Cutting
- Tire sizing question...help
- Lod Rear Bumper - Getting rid of space from body lift
- 2011 Unlimited Rubicon with 33s
- zone three inch lift
- Which Locker to go with?
- Upper control arm oops...
- Help please! :( (tire size question)
- Lange Mirrors
- tire inflation octupus
- Cooper STT's 285/70R17 Issue
- maybe a dumb question...but need to know about tire/wheel size and speedo calibration
- explain offset
- Ripp Mod's Super Charger and Warranty?????
- Rear sway bar links..
- Pure jeep - pj1005: Jeep jk grill-guard hoop front winch bumper
- lifts and warrantys
- Anyone heard of the "wheel winch"??
- rugged ridge xhd rear tire carrier
- Tire light
- 2.5" lift owners, what control arms are you using?
- drag link flip
- dialing in lift
- Coilovers?
- Which Lift?
- looking hard at recon winch
- What is the finish like on the unpainted Bushwacker pocket fenders?
- treadwright??
- 37's on JK X?
- Rusty's 3.25 lift?
- New 5.38 gear option for D30?
- Allignment post OME HD Lift
- What bumper do you guys like???
- 2.5 inch lift and 35s?
- Superchips ?
- 4.56 or 4.88
- AEV Rear Splash Guard Feedback Wanted
- Pinch Seam - Bend or Cut?
- popping noise to front left tire after lift kit.
- control arm length
- Dom tube for links
- AEV 3.5 Driveshaft concerns?
- what should I know
- NEW for 2011: Baja Claw TTC Radials
- How much will 5.13's set me back?
- Rubi Rear End in a sahara??
- anyone use the pintlers with +25mm offset? 3/4" further out than stock.
- TF 2.5" Coil kit and 3/4" spacers who has kind of set up?
- How to mount a Warn M8274?
- JK Bikini Top like the Sunrider?
- Rubicrawler or Rubi T-case?
- Is it possible? LoD mid-width to stubby
- New Wheel questions - need advice
- Towing Questions...
- Synthetic Rope winch for my shrockworks bumper
- Superchips axel lock feature
- Wheels and Tires 1K, is it possible?
- regearing...what parts do I need?
- quick question about extending breathers
- RE drag link ends bad...help
- Teraflex 9550 steering stabilizer shock
- What Size Wheel?
- T&T Customs Rear Bumper and Tire Carrier
- 3" Full-Traction SRS kit rear spring looks bent
- A CAI, is a CAI, is a CAI
- Best roof rack system for ARB tent
- superchip questiom
- Rough Country bb install
- Front DS...
- Shock bushings getting old...
- front track bar and lower control arms
- Lift: Black Diamond, Terra Flex or AEV?
- 37 nitto muds on stock 17s???
- Clayton Lift
- Rancho 4 inch lift
- Rugged Ridge Tail Light Guard Rust?!?!
- Grille mounting interference with 1.25" body lift *pics*
- Chip flash required with 2 - inch lift?
- terraflex 1.5" Leveling lift
- Zone 3" Lift - Rear bump stops
- Request! Specs for a RE 3.5 Long Arm Kit-HELP
- removing front hub assembly to remove axle shaft
- Which skid plate with RR XHD Stubby Bumper?
- Front and Rear Bumpers and Tire Carrier
- Teraflex 2.5 loft
- discount tire replacement warranty?
- Overheating question...Help?
- Rotating swaybar disconnect motor?
- wheeln with bad ball joints
- Wheel Coatings: Bedliner vs. Powder Coat
- Long travel kit
- lift and 35's done, now gear sets?
- Atlas 2 speed
- Superchips 'Easy Update' NOT easy! Not helpful
- Here are the stats from 3.73 to 4.88!
- TeraFlex Budget Boost, how many times has TF revised the design????
- Installed Smittybilt winch, but its not spooling, help!
- rough country
- new gears
- Rear spare tire saver
- Those with performance mods, question.
- Bedlining rims
- how do i choose gears?
- Removing cheap rattle can bedliner
- Rubicrawler on jk x with 3.73 gears and 31" tires
- Broke something, clank coming from rear on sharp turns?
- Another soft top question
