View Full Version : Modified JK Tech
- Installing tires from an online vendor?
- From X Shocks To Rubicon
- Rocknob causing excess movement rattle?
- Upgrading to Better Brakes: Suggestions From The Pros?
- coil springs swap?
- Body armor front bumper
- Rugged Ridge Overhead Consol
- teraflex 2.5 budget boost with shocks
- Gas milage with Gobi?
- Swaybar disco's - what am I doing wrong?
- Cooper Tires
- smittybilt src front bumper?
- 35's vs 37's, 4 inches vs 6 inches, 513's vs 538's, Short arms vs Long arms.....
- Rancho 4inch Long Arm
- LT285/70R17 or LT255/75R17 for a stock JKU suspension and no back spacers?
- TeraFlex 2.5" lift - Question about spacers ...
- Better for crawlin/muddin? 35"or37"
- Broken Trackbar Bracket
- Currie Rock Jock III with stock knuckles?
- Alignment Help, Did I bend my axle?
- 4.10's and 35's highway power.
- RRC Side Armor ?
- Teraflex coil springs will they correct my front rake?
- Riddler Diff Covers
- Best mod for fuel economy
- Anyone tried Fitch Fuel Catalyst's in their JK?
- Anyone tried to install the rear backup bumper 'beepers' in their bumper?
- BFG KM2's just got more noisy, any ideas?
- Ru$t
- What 35's are better?
- 2008 JK Rubicon - Need ideas for next mod
- Fabtech 5"?
- Will the Gobi 4 door roof rack fit inside the unlimited.
- Rock Krawler 3.5" lift or rouh Country 4" lift???????
- Stock Control Arms
- What did you use to paint your Riddler Diff covers?
- OEM Hub-Centric JK Wheels List
- How much driveline vibe is too much? TW shafts.
- bilstein shocks
- 17" change to 16" ?
- Rampage Rear Tailgate Gas Strut
- Bumper paint to match RC end caps
- Get new gears?
- PSI on GY Duratracs?
- Thoughts on MOPAR 2.5" Lift
- Biggest Gears?
- Tires/stock rims?
- wheel spacers
- Gobi rack size question
- best bang for my buck?
- superchips question
- What to check for-lift.
- Teraflex 1.5 lift
- Need rear bumper/tire carrier opinions
- Jk unlimited springs and rough country 2.5 bb question?
- Superchip latest update? 1/1/11
- 35" tires with 2.5"/1.75" lift?
- Help with Superchips
- Shocks
- JP Magazine new issue.......less = more in regards to lifts.
- Rugged ridge XHD Bumper Question
- Mopar or Rugged Ridge Tail Lamp Gaurds ???
- 37s with Gears???
- Is a stiffer (not larger) spring available to resist front end sag from winch?
- Steering Issue after 2" SKYJACKER Lift
- Rustys or Rubicon Express Radius Arm
- Hood scoop
- Modifying Transmission Skid Plate
- Disconnects & Brake Lines
- quick dana 60 question
- mopar sun bonnet (hardtop version) question.
- How To Change Out Gas Shocks ???
- Ramsey REP8000 winch question
- Can you recommend an upgraded shock for a STOCK '07 Sahara Unlimited?
- Question 'bout Rugged Ridge bumper with a Warn 9.5ti, hoop, and side extensions
- Rugged Ridge flat fenders
- need an opinion on what to do with this driveshaft
- Need ideas for front bumper?
- Driveshaft squeak. Thoughts please
- Tailgate kit for Skunkwerks Rubicon King?
- Full width or stubby rear bumper?
- Teraflex 2.5" lift with or without shocks??
- Tire induced death wobble
- Which aftermarket bumpers allow for factory tow hooks?
- Welding washers on tracbar mount questions
- Getting Flashed! ....not like that :(
- Looking for info on Ring and pinion install
- running 37s on OME+40 and stock fenders?
- Actual tire size of 33" hankook dynapro mt
- 20" Wheel Question
- Pro Comp vs. TeraFlex (2.5 Coil Lift)
- Need help removing stock drag link!
- Adding Coil Spring Spacers to Existing 2.5'' skyjacker suspension lift
- Cat back exhausts
- Help with a new vibraton...
- 35's with 3" lift or 5"
- Gorilla lock nuts
- Pro Comp 2.5 Inch Lift Kit with ES9000 Shocks
- XRC SMITTYBILT FENDERS does anyone have these?
- Help me o vibration god
- rockers and rear bumper?
- Control arm install question
- Daystar Hoodwrangler question
- Problem (?) with Viking synthetic winch line
- Need help asap
- wheel size
- Smittybilt c.r.e.s. Netting?
- Dealer Reflash and Non stock tuning
- Wheel Adapters & Wheel Options ...
- Beating An Old Horse
- Lug nuts on steelies
- Suspension Lift Recommendation for running 33" tires
- Why turn Overdrive off with 35s?
- Smittybilt Front SRC Bumper with Winch Mount
- JK 2 Gallon Air Tank Mount Kit jeep sawg
- Adj track bars
- Goodyear DuraTrac: Load Range E?
- Track Bar Help
- Pitman arm
- full time transfer case
- rock hard bumper and tire carrier
- Procomp Suspension???
- A-Pillar switch panel
- Advice on spings/setup
- Coil spring issues
- Looking for some input from my fellow Jeepers
- JKS brace and RK drag link compatible?
- Lower control arms 23" or 23 7/8"
- Wheel-well space
- Budget Tube fenders?
- Teraflex
- Adjusted RE Long Arm Lift. Much Better!
- First Post Idea's for modifying jeep
- Whell size for '07?
- lift
- Control arm leaking grease
- Header Bolts
- front lower control arms
- any tire rubbing issues with 35 km2 bfg and 3.5 AEV lift?
- JK axle bent at 21K miles - anyone else have this problem?
- Rock Krawler track bar
- Modest lift for 2010 Rubicon
- Pro Comp 2.5'' Lift
- Thoughts on aftermarket air cleaners - 2010 Rubicon
- Death Wobble - add me to the list!
- PRESS RELEASE: TeraFlex LCG PreRunner Suspension
- 20"x10" KMC - XD775 Rockstar Black
- HELP vibration at lo speed/new lift
- LOD Mid-width front bumper question
- Rugged Ridge Front XHD bumper... What skid plate to use?
- Who makes front 60's?
- What flat fender to get?
- AEV 3.5, flat flares, & 37's?
- Poison spyder brawler lite
- Lift spring question
- reinforcing the d30 axle
- Gibson Dual exhaust and AFE CAI ..... more power
- Backspacing questions...
- DEATH WOBBLE after lifting!!!
- Roof Rack With Safari Snorkel?
- Newvie and Jeep Mod info on Rock Rails
- 35s on stock rubi
- Rough Country users
- 1 1/2" wheel spacer/ESP problem
- guys with RIPP SC, i need help
- Need Quick help please...Can't get axle shaft out
- Looking for DEEP DISH Chrome 18" Wheels--
- 35's, 6 speed, 4.88's and 5.13's. MPG's?
- suggested winch info
- I need an aux onboard air tank. What works best?
- EVO Front King Bump Stops
- 265/75R16 Treadwright Guard Dawg MTs
- SMittybilt SRC with Fog Lights?
- Who makes the Mopar Bumpers?
- New Tire Size Speedometer Fix or Chart
- JKS vs Teraflex trackbar brackets
- You build it
- Lift Kit feedback!
- Seat cover preference........
- RC 2.2 Shocks Length?
- Replacement Shocks for my 08 4door JK
- porc ring and pinion for $129 any good?
- LoD rear Bumper / Hi-Lift
- after market power windows
- rough country 3.5
- Rock Krawler Shock Relocation Backets
- ride quality ?'s
- Gonna change gears.... i need advice!
- Has anyone intalled an Econoaid?
- Help...added Spidertrax Spacers and my Jeep "Floats"
- Discount tires
- Lose power with aftermarket exhaust?
- rock krawler tie rod/drag link and 16" wheels
- First experience with Cepek FC-II in snow
- first post but important
- factory tow hook stud removal
- Upper Control Arms causing DW?
- Questions about shocks???
- ProComp Wheels
- 1/4 pounder bumper winch compatibility
- Front axle u joint's both D 44 & D 30
- Powder Coat or new wheels???
- Sahara 4inch lift : "Help I just got stuck !!"
- Enhanced Rock Rails.....Worth it?
- BFG KO's
- Old Man Emu Shocks 2" actual lift question
- American off road muffler
- 1310 & 1311 Driveshaft Difference?
- Cost of an adjustable offset ball joint installation
- Pro Comp or Rough Country 2.5" Lift
- What lift kit would be recommended for my stock 2010 JK Rubicon?
- Winch help
- Rugged Ridge Wheel center cap missing
- wheel spacer question, again
- ARB Compressor
- 15" Wheels????
- My jk.
- XRC10 Comp winch line install problem
- Narrowed down to 2 lifts
- Rough country basic 2.5 lift vs series 2 lift?
- Heated seats, Mopar or?
- Help! I'm lopsided!!
- What is the best 4.5 or 5 inch lift for the money
- Gears for 255/85R16
- New location of trans-cooler w/fan
- Spare Tire
- Need Tire Help!
- 2010 Unlimited Sahara...Need Modification Suggestions
- balancing beads
- Installing OME kit, bottle jack or floor jack?
- Body Lift? Daystar VS. M.O.R.E???
- MBRP grill guard instructions
- daystar lifts?
- Price to install lift?
- ESP issues
- Ride height Q
- Fuel Mileage, with 35's and 5:13's
- What do your BFG KM2 35s measure out to?
- lift kit options!
- JKS disconnects or Mopar OEM Rubicon Edition Sway Bar Disconnect?
- Goodyear Duratracs Info
- Need Swing-Away Tire carrier mod for ARB rear bumper...
- I've got a pull
- Need to get level!
- Dirtydog netting/pet dividers.
- "Johnny" bushings
- Wheel tire question please help
- can dealer set TPMS to lower psi?
- merry xmas to me
- Wheel Balance Experts: Where Do Wheel Weights Mount?
