View Full Version : Modified JK Tech
- Full coverage inner fender liner
- Actual tire size reading
- JKU Rubicon regear question. Bought with 35’s on 3.73’s. Changing to 37’s.
- 15 Jk cylinder 3 mis fire (head replaced)
- Help me diagnose what is leaking
- What have i done now with this Superchips thingy
- Synergy Adjustable Ball Joints
- JKS adjustable end link help
- Bottoms up
- Rear 2.5" Bypass Shock Mounting
- extreme rough idle
- Need a measurement for rear body armor
- Coolant leak
- Steel braided brake lines for lifted JK
- U11C2 Error code questions
- Anyone have a Trektop Pro Hybrid for a 2-door?
- Rear Passenger Axle Seal Leak
- Death wobble help!!
- MetalCloak 2.5 on a rubicon, sway bar and other questions
- Hot Oil warning when starting engine
- Lift kit install quote
- Drag link question
- Anyone regret 4.56’s on 35’s? (2 door, 3.6 auto)
- PCM replacement
- intermittent oil light on startup
- Rock Slide Eng. Powersteps with a body lift?
- Drivetrain issues, i need help!!
- 2010 wrangler Ls Swap
- 2007 JKUR knock, knock, knock
- Track Bar Rubbing on Rear Differential Cover
- No Brake Lights on JK moded
- Air Lift for Squat Reduction
- Steering/front wheels Rubbing when turning right
- Need advice on if the wheels I'm looking to buy will work with my stock Rubicon
- Vacuum Pump reorientation question for offroad sway bar
- Which programmers are capable of flashing a JK (or any) ABS Module? /ABS Module Repai
- Axle update choice for JK 3.8 and 35"
- LED help
- Synergy Draglink backwards
- HookeRoad Stubby Front Tube Bumper
- Lifted JK w/ Fox shocks…. Question about heim
- Overheating/ headgaskets
- Hidden winch on Hard Rock bumper
- 3.8 head gasket failure
- Open carrier for Dana 44 front?
- Helo with ideas to mount Barricade bumper missing hardware
- Looking at JKU's...had a couple of questions
- Jeep Wrangler JK Unlimited - 2.5 lift recommendations
- Long term review of stainless steel door hinges
- J Scan Purchase Help
- Thermostat questions/heating
- Drop pitman arm?
- Roof racks for Roof top Tents
- AEV Compatability
- Vibration between 1000 and 1700rpm
- fighting against the wind!!! riddle me this..
- Optimal Lift size for 35 inch on Jeep JK unlimited
- NRG Quick Release on 2008 JK
- To loop delete or not to loop delete, that is the question.
- Experience with amazon winches like X-bull or Zesuper?
- Recurring clutch bearing issues, need help
- Quick steering question
- Looking to confirm possible broken front axle inner seal.
- Axle resistance
- Leaking axle housing
- Jeep jl skid plate on jk
- Adding adjustable headlights to US JK?
- Rear shock looseness
- Jku tie rod play?
- Rubicon axle install, Switch option
- Need repair manual for JK 2007
- Not Another Lift Question (Dirtman, Planman)
- Best Stock Height Suspension?
- 2013 Rear Bumper w/ Swing away tire carrier OR Bumper and Hinged tire carrier?
- Lots of questions 16’ JKU
- Brake upload and relocation?
- Light Bar for Garvin Wilderness Expedition Rack
- Canadian cats
- Bumper ID
- 2017 Jeep JKU Automatic w/Eaton TruTrac Rear: Getting ESP Light
- jk Frames
- 14” shocks
- 50 MPH Wobble
- steering issues
- 4" Rough Country Long arm lift JKU. Install or Nah.
- Winch wiring questions
- Rear Bumper and Tire Carrier Hardware
- Skid Plates
- Why is this hardtop so cheap?
- New Owner, Help Identifying Suspension
- 4.1 or 4.56 for 3.8L 6spd
- Steering is terrible.
- Will a 2018 JL hardtop fit my 2007?
- Dana 30 to Dana 44 drag link and tie rod compatible
- JScan App & OBDLink MX+ (OBDII Bluetooth)
- How to identify Falcon 3.3 SP2 shocks
- Out with the old in with the new?
- Is this price too high for gears and locker?
- Tow hooks and Tube Bumpers
- Regear cincy oh
- Gears
- Ball Joints need some advice
- Oil Cooler Replacement, no start...
- Can't find anyone to weld LCA mounts
- Hauk vs genright corner armor
- 2010 JKU 6 speed manual keeps “blowing out” clutch slave cylinders
- TeraFlex Shocks 2D vs. 4D
- JK 2 Door Stretch - Help with decision
- Drag link flip
- Talk to me about balance beads
- 2015 sway bar link angle
- ARB Bull Bar questions
- Update Lift Help - 2008 JKUR
- Lift and Towing
- Shocks help - 6" lift
- Jeep with bad manners
- Shock Review
- Tie down project
- Throttle Body Questions-Mods
- Pistol holster
- Need your advice to improve a JK X 2007
- Hydraulic Bump Stops Compared to Standard
- Rubbing back of grill at full stuff on passenger side
- Help- flooded engine (JKU 3.6 engine_Auto)
- PSC steering assist fluid & filter change
- Reinstall ball joint after welding gussets?
- Recommendations for $10k budget
- P1731
- Tera flex ball joint preload
- Brake questions bbk pressure bleeding etc
- Track Bar Bushing
- Your $10,000 Modified Advice
- RCV Axle CV Joint Diagnosis
- Sometimes I hate my jeep
- OME BP-51 KIT LIGHT (OMEJK4DBP51LK) Components
- Lowe control arms question
- Coolant issue
- 2008 JKU Regearing help: 5.38v5.86 on 37"s
- PSC Hydro Levels
- Pulls Left - Alignment
- Out of alignment???
- Rear D44 Truss - Cheap Insurance?
- 2016 engine in a 2012
- Noise/vibration at 75 MPH or faster
- Suspension - Defying Gravity
- A different kind of cooling fan problem (need your help)
- HELP NEEDED IAT P0113 won’t turn off
- 2 Door Exhaust Crossover?
- Help with A pillar broken nuts...
- Uneven ride height
- Driveshaft thoughts
- Clicking/clanking noise only in 4wd
- Bilstein 5160/5165
- Suspension Suspension Suspension
- What 35” tires?
- Currie/ RockJock Antirock REAR Sway Bar Kit Question
- Jk rear diff sound
- 35” tires, highline fenders, now what?
- What's going on with the DIY hemi swap venders?
- Anyone with a Poison Spider Bruizer Front Bumper
- Drag Link Install
- Stock Rubicon under armor durability
- H1 Wheels on a JKU
- Most comfortable lift set (2door JK)
- Alternative to Anti-rock swaybar(raptor swaybars)
- How dependable are D44 lockers?
- Regear/Locker Upgrade
- Any AfterMarket/DIY to stop soft top wind noise ?
- 2008 JKU Squeal
- Hydro bump stop slap
- Looking for Body Lift answers
- Crunching on Articulation
- Bump-steer and SEVERE stability issues ON JKU
- Intake gasket replacement
- Death Wobble PSA - Frame Crossmember Crack!!!
- Coil spring sizes
- Drilling into underside of hard top
- nsg370
- 2011 Jeep Jk Manual Transmission Sounds
- I want to add a thottle idle lock like my old TJ had
- Handling Issues
- Adams 1350 Question
- Axle trusses: Artec or Evo?
- Rear passenger coil spring
- 2007 low speed Death Wobble (HELP)
- JL door checks on JK?
- Steering Wheel
- P0301 Code issue 2009 JKU
- Spray Undercoating 2015 JKU
- Jk best springs
- LSD advice
- Misfire issues
- P2096, P0137, P0133 Codes on 2013 JKU
- Blue Ox baseplate with aftermarket bumper
- Grinding noise.
- Need Some Gearing Advice
- JK 2-door rear end or driveline issue
- Help with Frankenstein Lift! Adjustable Rear Sway Bar + Metalcloak GC
- In-Line Radiator Filter
- Slight Steering Wobble
- Newbie Steering Question
- Manual tranmission question.
- Yukon Gear & Axle Driveshaft
- Pod lights causing computer issue
- Rightline Gear Guy-less Canopy
- Bestop Core Door Modification
- Quick question
- Another bumper like this?
- Anyone regear keeps near page Arizona
- STL Files for Interior Trim
- Can I level with ya...?
- Am I missing anything?
- Centering your steering wheel with Jscan
- More lift?
- Leak by C?
- Smitybilt JK Stinger - Not Flush Fitment
- Quick suggestion / opion on lift height / springs
- 392 Radiator
- Spacer lift to full spring
- JKU Rubicon Overheat Issues
- JScan settings for towing
- Jeep special list shop
- Need help! Welding Jk front TB bracket.where does this peice go?
- 08 Suspension Questions
- 2010 jeep jku sport steering/suspension problem
- 07JK - MagnaFlow Converter Cat & Rock Crawler Cat-Back System
- Teraflex HD front track bar quick question PIC inside
- Need Adjustable Control Arm for Double Cardan DS?
- Drag link flip / track bar for better handling
- OBD2 Scanner in continuous use with Manual Transmission?
- Mystery rattle clunk squeak noise driver footwell
- Death wobble ..Synergy front TB bracket cracked along with factory bracket cracks!!!
- Jeep Wrangler 2012 not working
- Synergy Front Track Bar and Sector Shaft Brace Kit???
- Spacer add question
- Front Axle identification
- Headlight Kit Reccomendation
- Upgrading my brake system in stages!
- 5.3 Gen V LS/LT Swap-Lessons Learned
- Green Leak on transfer case?
- Trail Dash 2 giving me some stupid issues
- 34 in tire, brake recommendations
- Diff gears
- Recommendations to upgrade my rear LCA on my JKU
- AFE Rock Basher
- Spinning rivnut
- What is this?
- Can I remove 2" coil spacers without removing shocks ?what's easiest way?
- 2009 JK X - Emergency upgrade needed - lift, front axle, etc.
- Hinge mounted tire carrier
