PDA
View Full Version : Modified JK Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 [197] 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296
  1. EVO Rock Stars - input needed please?
  2. will stock D30 resist with 35" ? CRD engine
  3. Teraflex 3" vs Rock Krawler 3.5" vs Old Man Emu HD
  4. tire size with chopped fenders or bushwacker flat fenders
  5. Need an 18" Wheel for 37s
  6. Flashpaq Software compatible with a Mac?
  7. What Do I Need To Buy
  8. upgrading to Rubi coils and shocks?
  9. Need help with Rock Crawler Rim sizes - PLEASE
  10. What is your 35" full size spare mounting solution?
  11. Anyone ever run the Rock Krawler 5.5 lift?
  12. Rear Swaybar Bent
  13. What size wheels??
  14. LPG Conversion
  15. RR XHD Front bumper install problem
  16. Looking for Dana 44 Front axle info
  17. JK unlimitted Trunk
  18. Mileage drop with bumper
  19. Sliders and Long Arm Kits
  20. Installed new Body Armor rear bumper
  21. orv rugged ridge nitrgen charged steering stabalizer ??
  22. Rubi shocks on my Sahara
  23. Xenon Flare Question
  24. body lift???
  25. Re Gearing questions
  26. Which Skid Plate Setups work with Tera Flex Long Arm Suspensions?
  27. Tire size reality?
  28. 33's
  29. Front Bumper Sag
  30. ARB Bumper without Winch
  31. Which Cold Air Intake?
  32. tie rod w/RC SS kit, which one?
  33. Will the seats fit?
  34. which manufacture makes the best gears
  35. MBRP Aluminized Exhaust - Rustoleum Ultra High Heat
  36. best and least expensive lift (Complete package)
  37. In what order should i perform my mods?
  38. Yukon gears, Motive Gear bearing kit - need opinion
  39. Good Year SilentArmor, or MT/R Kevlar? Opinons?
  40. JK Mirror Relocation Brackets
  41. New front bumper, no air dam, MPG drops
  42. Which do you recommend?
  43. started to collect parts for my lift.
  44. dd sahara mods-tires and budget boost
  45. KORE Suspension Systems
  46. AEV or RE
  47. Olympic 4X4 A/T Rock Rail Guards are Rusting!
  48. Wild Bore Racks w/ RTT
  49. vht
  50. Problem with TF rear upper control arm lenght and 2.5" lift kit
  51. 513's Strength
  52. Need help please
  53. 2DR Windjammer (wraparound) on a 4DR - pros and cons
  54. Width of Cargo Basket
  55. upgrade shocks?
  56. Full-Traction 3" Long Arm Lift
  57. Fox 2.0 IFP shocks
  58. TRE Part Number
  59. XRC rollcage kit
  60. What length of the shocks should I get?
  61. Question about 275 70 R17
  62. How does discount tire ship?
  63. LOD & 37's
  64. $$ mopar parts question$$
  65. dry start ticking finally stopped!
  66. Superchips Shift points
  67. relocate muffler to mid section on a two door?
  68. JK front Rubicon locker question “I need some help”
  69. Tried breaking into my glove box
  70. write-up for changing upper ball joint????
  71. AEV Snorkel Ram Air & Pre-filter Attachment advise requested
  72. cargo Net
  73. Diggin the Airaid CAI
  74. Recommendation for Extreme use of Tires
  75. river raider snorkel with winshiled lights
  76. Teach me about tires.
  77. tinted windows
  78. <sigh> I found a downside to frame-mounted sliders: changing the tranny fluid!
  79. 1 inch lift?
  80. 4" Lift, Ugly Rake, New Bumper... Options?
  81. any advice on paint? need pictures too.
  82. Rugged Ridge XHD bumpes paintable??
  83. Lift Install Time
  84. Bikini Top Hardware
  85. Teraflex 2.5 BB good are bad ?
  86. Bestop Safari Flapping.. fixes?
  87. AEV's Procal??????
  88. Teraflex 2.5 BB plus driveshaft question???
  89. What is going to happen if the shocks are longer than the coil springs?
  90. installing a lift kit. how hard
  91. pitbull tire question
  92. 5.13 or 5.38 Gears?
  93. Where can you order JKS trackbars?
  94. how wide without big problems
  95. Tire carriers holding 35's!
  96. Where is the least expensive place to buy toyo mt's and bfg km2's?
  97. Optima Yellow Top Issue, HELP !!!!
  98. another lift question...
  99. XRC bumper problem
  100. Where is the cheapest place to buy toyo mt's, bfg km2's, and mtr w kevlar??
  101. MPR with new tires
  102. Gears Install Kit vs. Overhaul Kit???
  103. Rugged Ridge Mirror Brackets
  104. Velocity Off Road
  105. Best fuel mileage setup for lifted Jeep on 35's or 37's.. Gear ratio? Mileage?
  106. Shift Knobs for us Auto Dweebs
  107. custom bumper !!
  108. Axles,axles,axles.... experienced please..
  109. 20" KMC XD Series Addict & 325/60R20 BF Goodrich Mud-Terrain KM2
  110. what could it be?
  111. differences?
  112. Mopar or daynatrck?
  113. Mopar or daynatrck?
  114. Caster Problem and Correction Help
  115. 35" Goodyear MTR-K on 15" Cragers
  116. TF lift on a Rubicon
  117. Speedometer/ Odometer changes
  118. Rough Country Lift Opinions?
  119. Stock Bumper to stubby kit.....Not the one from RC....
  120. Smittybilt XRC rear bumper...which D-Ring Shackle
  121. front differential leak after new drive shafts
  122. Alignment issues with 35s?
  123. Need your opinion of Jeep dealers 2' Mopar lift on 08 2 dr Rubicon
  124. got alignment still pulls left bad please help ideas
  125. rugged ridge 8500 winch rust questions ??
  126. Lift Questions...
  127. Opinions - Teraflex BB or Rubicon Express BB
  128. Old issue but WTF?!?!?!?
  129. Stock tube and end forging (the 'C') vs ProRock
  130. Replacing rear dana 35
  131. I want some MT classic II blacks before they stop production-questions in thread!
  132. Short girl, tall Jeep
  133. Slant back top..
  134. Do all after market Driveshafts make noise?
  135. Starting Phase 2 this summer.....
  136. Bull Bars
  137. Teraflex Sway-bar link zerks too deep, hitting bushing
  138. MPRB Exhaust some issues and overall writeup
  139. Superchips and Speedometer Correction
  140. Control Arms Question!
  141. skids
  142. Just Ordered TF 2.5" Coil/Shocks Lift...CAM Bolts?
  143. Body Armor
  144. Superchips Data Logging
  145. Question about a new Woods front drive shaft
  146. GY MTR's or BF Mud Terrain
  147. modifying a TJ bumper to fit a JK
  148. rugged ridge xhd winch bumper with 8.5 ton winch installed,pics
  149. time for gears..for d30 questions
  150. Good Steering Stabilizer?
  151. 3" lift
  152. 315/70R18 or 345/75R16
  153. driveline ?s
  154. New black grill
  155. Maximum ft. of Synthetic on a Warn PP?
  156. New & Novice Rubicon Owner Seeks Insight from Experienced Handlers
  157. Magnaflow muffler
  158. AEV 3.5 Premuim Lift
  159. Death Wobble = Holy $#|+!!!
  160. Rocker Guards on a Stock 2dr
  161. Neec advice for a driveway fix
  162. Questions on Teraflex 4" lift
  163. Possible/Definate Rub
  164. MOPAR lift
  165. Newb question
  166. Question about TeraFlex Leveling Kit vs. others
  167. rock rails with factory side step
  168. 3 or 4" lift help driveshafts??
  169. Windshield light bracket help
  170. Rhino Line or Linex?
  171. I have some Superchips questions!
  172. IHE and ECU
  173. removable steps
  174. **Rock Rails Advice?**
  175. CAI vs. Superchip???
  176. Teraflex D30 gussets
  177. 2010 Rubicon 4dr side steps
  178. Need winch advice!
  179. Poison Syder Rocker Knocker Question..
  180. MBRP Exhaust
  181. grease...
  182. Would you risk using this?
  183. Air tank instead of stock jack?
  184. Genright Auxillary Fuel Tank
  185. Cleaning True flow XDI foam filter
  186. JKS & Teraflex Control Arms - Flex Arms
  187. Shock upgrade
  188. Add '09+ console storage net to '07-'08?
  189. Average Cost of regearing (Labor + Parts)
  190. Would bumper weight effect tire clearance?
  191. mbrp
  192. Highrock Element doors and bolting them on?
  193. Tie Rod Ends/ball joints
  194. Track Bar Choice Emergency
  195. Installing a Rubi rear elocker into a non Rubi d44 of an X
  196. A Teenager Needs Help With His Build!
  197. which heavy duty steering stabalizer ??
  198. EVO Lever or RubiCrawler?
  199. SOLID covers wont stop dripping!
  200. Bought my first Jeep. Need some info.
  201. My Jk's ride sucks now! What air pressure should I be running on 33's
  202. Thoughts on this lift combo?
  203. New Garvin Special Rack
  204. bushwacker vs. xenon size-wise
  205. About the pull the trigger on a rear bumper, need your advice
  206. Spidertrax Wheel Spacer Safety
  207. Fox Shocks
  208. Do spacers "settle"?
  209. Steering feel & Caster questions
  210. Body leveling...
  211. Not Happy With How Lifted Jeep Rides
  212. Installed lift, now ESP / BAS warning light is on
  213. Off-Road Unlimited Roof Rack / Defender Rack
  214. Impresions of ARB lockers RD-157/RD-147 35 splines
  215. Winches for AEV front bar
  216. Coil over insight???
  217. How old are BFG ATs?
  218. Rancho 4inch lift? Anyone try one here?
  219. Jks acos pro.
  220. not again.. steering.
  221. how bad is it
  222. Stock Spare Tire Holder
  223. ORE fenders with NO flares??
  224. Winch's: Steel Or Synth
  225. Tom Woods & JE REEL
  226. help with lift!!
  227. auto sway bar disconect messing everything up
  228. xenon wide vs xenon narrow??!!
  229. Deciding on which way to go on the lift
  230. 2.5" body lift!!! Help!!!
  231. Bestop Bikini Header Channel Bent Backwards
  232. Hard Textured Black Plastic Spare Tire Cover... ANYONE SEEN THIS???
  233. 15" wheels that fit without grinding?
  234. Shocks
  235. Improve driving
  236. Anyone Tried zRotopaX Fuel Pack System
  237. TeraFlex Front SpeedBumps and serious rubbing
  238. My Transfer Case is going to Explode...Warranty?
  239. Hand Winch versus electric winch
  240. Lookin For More Juice
  241. Variable Mile marker Winch
  242. Hey, BDS GUYS!!!
  243. 33's on no lift?
  244. Nitto Tires
  245. New wheels, tires & TPMS...anything needed with computer
  246. Coast 1310 HD drive shafts or J.E.Reel 1310 Driveshafts?
  247. Bilstein shock part # 3" lift
  248. 17x8 Wheels
  249. OME LT with teraflex bb people
  250. Front Bumper capable of holding factory Fog lights?
