View Full Version : Modified JK Tech
- tires are ordered
- 6" LIFT.... Which manufacture do you reccomend? post pics of your 6" lift
- TIre and rim size recommendations
- I need a suggestion on a Steering Stabilizer Kit
- Teraflex 2.5 BB additional work?
- Valentines Gift Help a woman out
- Conflicting info on 35 for dana 30
- Adding Daystar 3/4"spacers to TeraFlex Performance leveling kit ??
- 2012 wrangler 2 door project.. Questions
- MBRP Offroad cat back exhaust
- Smoked turn signals with paited black grill
- Lurching when getting on and off the gas?
- Another tire?
- Just ordered my Superchip, what should i expect
- Supercharger regearing question?
- Wife wants a smooth riding shock. Suggestions please.
- Tailgate Table Install
- Help find me some black rims...18x9
- Drop pitman arm vs stock question
- Smittybilt XRC-Tow question
- ARB-CKMA12 Air Compressor
- lift/ spaced help
- Thoughts on RSE - Rock Slide Engineering Front bumper
- Sleeves and Gussests Really Needed on Dana 44
- 35's and regear in MA.
- Wide Flat fenders
- Rough Country Lift question.
- Best place for regear Atlanta, GA
- Co2 Tank Storage Ideas
- Rockhard Skid w/ no Stocker?
- Detroit Soft Locker? Pro's Con's?
- Need help picking out a lift kit!
- ARB diff covers install, correct fluid amount?
- Full Front Fender Replacements
- AEV Pintler on stock tires
- Question on ABS lines under flex
- Jk Lift
- Control Arms
- Spare 37 doesnt fit on my aev carrier
- Does anyone make the Jeep J8 bumper, i want one!!!!
- So Many Questions! Please Assist!
- The Great Bumper Debate
- Stock jeep Unlimited
- Coil spring question?
- Front skid plate on stock bumber options, what do you run (pics needed)
- check engine light.
- Flighty sterring with new wheels
- bushwacker vs rugged ridge w/liners
- 10 mpgs.
- KMC Strike Wheels...anyone have them?
- I got the Death Wobble...FML
- Need Some Help with Bikini Top and Doorless
- C.A.R.B. approved CAI or Headers???
- 2012 JK Unlimited rear tailgate organizer availability???Any
- Lfit Kit questions
- Custom DIY hood or tailgate strut
- Mojave 3.73 6 Speed Re-Gear
- Bilstein or King?
- ATX ledge Teflon Black on 33" Duratrac - Pic Request!
- Duratrac rotation (4) front back or x-pattern ?
- 18" Wheel Dilemma
- My Sprintex Super Charger install thread for my Jeep JK 3,8 l..., Under $3995.
- Teraflex springs with elka shocks
- Terra Grappler/XD Monster Wheels
- I need help building up a stock Jeep!!!
- "New" 2010 JK
- Poisen Sypder Fatties Steel od Alum?
- Sorry gear question but need help
- MPG gains from air filter change???
- help with tires and wheels
- AEV Heat Reduction Hood
- 2012 regear owners.
- JKS Adjustable Rear Spring Mount with Teraflex Rear Trackbar Bracket?
- How much backspacing do I need to fit 15" wheels on my '11 JK?
- Help my O2 sensor!!
- Anyone have the vinyl console armrest pad?
- Quadratec AEV Hood Paint Quality
- 2012 vacuum pump bracket removal?
- TF 3" coil question
- Cooper Discoverer S/T
- ordered ne wheels and tires today!
- anyone running ripp headers without the tune
- Help shopping for a roof rack!
- Jerry can rack instead of spare tire?
- what do you recommend for the best rear bumper/tire carrier?
- stock shocks question
- (: Installing River Raider Skids on 2012 and have a torque question :)
- Wheel size selection help
- 33" toyo m/t tire pressure help
- ARB Diff Covers / Gear Oil
- NFAB nerf bars?
- Slingin' Grease
- Toyo OC MT's?
- Track Bar and Shocks
- LOD Mid Width and stock tires
- Simple spacer lift
- Question for those with OME HD lifts on 2-Dr..
- Do i need upper control arms with 4in lift?
- Need a measurement (Instatrunk/Security Deck)
- Front drivers side break line bracket relocation help
- buy tire online
- Intake an exhaust combo
- squeaking?
- What wheel back spacing do I need? Please help
- Tuffy or besttop truck enclosure??
- 2.5 teraflex coils
- 35" tires rubbing on the front splash shield
- Metal fenders
- Magnaflow 15115 Catback System for 2012 Wrangler Unlimited
- So, my wife comes home and tells me it is too small...
- question about coil spacers???
- Can anyone help? Im getting a suspension soon.
- 37's - 5.5" lift - flat fenders
- Leaking
- YET another LIFT question DAYSTAR
- Painting Chrome Rims
- New to me JK! Is it lifted?
- Cleaning stinky gear oil from diff overfill?
- please help me choose?
- New Jeeper how to change wheel/tire question
- Installation difficulties
- Emergency soft top
- ESP/BAS and Car with swerve marks went on.
- (: 2012 Center Console Help :)
- besides a re-gear from a 3.21...
- Gear solution
- New Hypertech features available
- Bumper / Winch or Rock sliders / OBA
- Need a solution
- Transfer Cases
- 285/70/17 or 295/70/17
- 37" spare on stock carrier
- Spyderlock rims
- My new 5.38's?
- Anyone running 5.13 gears?
- Squeeky noise when accel?
- will i have esp issues with bumper and winch install
- axle sleeve install ??s
- difficult tire choice...
- Mirror Relocator Kit
- Strange vibration/bouncing effect
- JcrOffroad rear bumper/carrier
- Hemi question
- SuperChips Flashpaq - I give up!
- Best first upgrade
- LCA Cam bolts for caster/pinion adjustment after lift question.
- Trimming for 37s
- is it possible to paint lights?
- Rear bumper fabrication
- EVO Protek Skid Plate vs River Raider Skid Plate
- Lockers for stock rear D44 w/ 5.13 gears
- Back to 34 psi
- Lift????
- Pro rock 44
- Rock Crawler exhaust and evap canister
- No rear bumper?
- Need Help with Gear noise / Additives
- RC 2.5" 4dr lift on a 2dr
- Pinch seam measurement before and after lift
- Narrower tires
- Bilstein 5100 Install
- could 5in backspace work?
- Procal vs. Superchips
- Penastar Engine Swap
- Diy bed liner ?
- Bought a moded JK and i have a question. please help
- 2.5 front springs vs. 2.5 TF spacers
- looking to get a set of KMD Rockstars for my 2012 JKU - Need help
- Steering sector shaft braces
- rear bumper and tire carrier
- Dunlop fierce attitude tire
- If you modified your seats with Katzkins.... do you like them? Post Pics Please!
- Anyone running 35s on stock rims
- Ace Rock Sliders vs. Smittybilt SRC Side Armor
- 35s with no lift? Anyone have pics?
- Gears for a 2011 JK wrangler
- mounting treadwrights
- New wheels came in
- Narrow D60 Swap / Stock H1 questions.
- MBRP offroad Cat Back Exhaust System 2012
- First mod...lift kit?
- M-80 BMF Stealth Wheels
- Teraflex Monster Front Trackbar with steering stabilizer bracket
- Which LSD / Locker for sand dunes ONLY driving ?
- BLD without ESP ?
- Vibration on when turning??????
- On Board Air Compressor???
- Bed lining stock sport fenders
- E-autogrilles led front bumper
- Rough Country 4" and 6" lifts x-seriies lifts
- Detroit TrueTracs front and rear - opinions
- Looking for help with lifts! Teraflex
- Exhaust question
- Waterproofing an 09
- US Steel Rock Crawler Wheels
- Westin 422015 trailblazer bumper
- Fitfing 33's with no lift
- Help me plan for 35's
- Thanks 4 all the help. Newbie finnalu got his jeep!
- Bds 3inch lift, fox shocks
- EVO Enforcer Install
- Bedlined wheels?
- Opinions on rear bumper
- Kayaks and Softtop?
- Next Steps...?
- I have 40's swap to hydro assist
- Aftermarket Rock slider question
- Tuning Programmers For 2011 JK?
- Good lift kit?
- Towing and lifts
- OME 4" lift
- Suspension questions.
- Superchips Adavanced Transmission Tuning Schedule
- 255/75R17 Fatory Tires on 8.5 inch rims - Anybody running this setup?
- Tire carrier question
- Lucky me! I have a dana 35!
- What does this do?
- Pavement Ends Rear Bumper but want to keep my hitch receiver...
- Or-Fab tire carrier with Nato Cans
- Gears and Bumper
- Going Spare-less
- Stupid question
- Rubi rails
- 2.5 lift
- Anyone Running Rough Country Control Arm Relocation Brackets?
- Plasti-dip for a bare steel bumper
- Emergency rain Summer top options?
- 12 Driveshaft on a 07?
- Rough Country 2" coil spacer vs 1.5" body lift?
- Mopar transmission cooler part no.
- Ultra Magnus Wheels
- Driving with no rear swaybar links
- Chopped front fenders
- Unlimited on 37's question
- Bushwacker Flat Style Fender Flares
- Aftermarket front drive shaft???
- LoD bumper :-)
- Dynatrac ball joints and RCV axles rub together?
- Rubicin express 3.5 inch with stock rubi tires
- 2011 / 2012 JK steering wheel inserts
- powder coating
- tire, spacer, and rim question
- Body Removal w/o lift
- Rough Country Winches?
- Lift guidance
- How long are people hearing Duratracs are on backorder for?
- Driveshafts?
- Aev 4.5 vs Teraflex 4 in lift
- Where can I buy a cover (indoors and easy to take on and off)
- electrical gremlin... please help
