PDA
View Full Version : Modified JK Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 [207] 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296
  1. Teraflex 2.5" lift ?
  2. XRC Back bumper
  3. Mopar Rear Bumper Questions
  4. About to order 3.5 Rock krawler
  5. Front 1350 Driveshaft with Auto Trans?
  6. Quick toe in question
  7. Full-Time 4wd?
  8. Going Broke
  9. UPDATE: Figured out what rims... NOW TIRES! Ordering tonight!!!!!!!
  10. camo V-Tec wheels
  11. short front sway bar links
  12. Measuring toe in. how high on the tire do you measure?
  13. Brake line relocation bracket bent?
  14. which 6" lift should i go with?
  15. PSC Tube Flares
  16. Wheel Spacers ?
  17. jeep cover
  18. Rock Krawler Tie Rod.....what ends?
  19. Autohome Maggiolina Airland Tent
  20. Help me decide my next mod
  21. Best Lift Kits For The Money
  22. Under 6'-0"
  23. WALKER EVANS or HUTCHINSON ROCKMONSTERS
  24. Anyone used the Teraflex 3'' long arm ?
  25. Monster vs. Magnus
  26. OME LT vs AEV Lift?
  27. Wheel Spacers or Not???
  28. shocks?
  29. JK Unlimited TF leveling kit and 315's
  30. Beadlocks in salty roads, oxodizing rings
  31. 2.5" Coil lift and 1" body lift
  32. Tell me about rough country
  33. license plate and 3rd brake light solution?
  34. 33" spare tire needs to be spaced out 1/2"
  35. Need Help on suspension decision
  36. 30,000 mile service. Replace diff covers?
  37. front trackbar bolt/nut size?
  38. Modded Dana 30 vs Stock Dana 44
  39. Max tire for Dana 30
  40. After Market Plug Wires
  41. Lift and tire size?
  42. Rugged Ridge Skid Interferes with Disconnect?
  43. Opinions on this 4" lift
  44. Ready lift and spare tire problem
  45. steering.
  46. ride quality
  47. d30 gears
  48. TF 2.5" Coil Lift - To Track Bar Bracket or Not....
  49. Portal Axles
  50. Painting Rusted Coils/Springs
  51. Final position for rear bumper.
  52. Build on a budget (here is what I did)
  53. Very Low MPG? Burning Oil?
  54. help with my lift shopping list
  55. fab fours front bumper aux light mount
  56. Flashpaq and Procal, oops I mixed the two
  57. mertic tire conversion for 35"& 37"
  58. Caster Angle - Control Arms?
  59. THE cure for the wimpy 3.8L...
  60. what to do to my 2008 jeep jk rubicon 4 door???????
  61. Anyone with Teraflex 2.5 springs lift and Rancho 9000XL?
  62. Anyone have the MBRP catback?
  63. rustys 3.25
  64. WARN M8000 vs. Ramsey 8.5e/Ramsey 9.5e
  65. Shrockworks Stubby or Mid
  66. lift ?'s
  67. 5.13 and 33" tires
  68. JKS Quick Disconnects Choice
  69. Pro Comp wheels w/TF 2.5" lift
  70. Replacing the "Straight Across Rear Bar" in a 4-door?
  71. TF 2.5 spring with or without spacer in front?
  72. Just installed RC 3.25 kit and now I have a drive shaft question?
  73. Just curious
  74. Winch/bumper question
  75. SprintBooster ??????
  76. Dick Cepek DC-1 Black Painted Alloy Wheel
  77. Will these lug nuts fit a JK?
  78. 35's and crawl ratio?
  79. Teraflex 3" or 4" lift w/ 1" body lift
  80. Adding coil spacers?
  81. Another Wheel and Tire question
  82. Superchips disables O/D on Auto Trans. JK's!!!!
  83. aev procale module question? need help
  84. Smitybilt XRC Front Bumper
  85. Vibration??
  86. lift kit help
  87. Superior, Yukon, alloy USA gears
  88. DIY roof-rack camping?
  89. Mile Marker 8000 or Ramsey Patriot 9500?
  90. Baja MTZ vs ATZ
  91. Question about my shocks and 2.5 TF coil lift
  92. pinion angle
  93. Hanson Bumper, Stock Plastic Guard?
  94. TF BB vs Coil lift?
  95. TIRES ARE COMING! Things to prep? Help plz
  96. What factory length shocks go on a 3" lift?
  97. Goodyear MT/R w. Kev... warranty $ ?
  98. OME Pkg vs. AEV vs. RE Superflex
  99. Taxes = Toys Need help
  100. Rock Rail Question
  101. Dana 30
  102. Question on 2.5" TF bb
  103. ECU Cracks on 3.8 V6
  104. XRC sliders and src rock guards.
  105. Best Rear Bumper (under $600)
  106. Questions? Comments? Bright Ideas?
  107. A few rig-planning questions
  108. Taller Springs vs Spacers
  109. Track bars joints: Spherical bearings or bushings?
  110. Looking for a good onboard Compressor...
  111. Daystar 1" body lift?
  112. question on backspacing and spacers
  113. I need gearing advice
  114. Nightshades and Tinted Turn Signals
  115. jks rear trac bar install help
  116. Cylinder Head compatability
  117. New axle advice w/carnage pic
  118. TF 2.5" coil lift with shocks, .5" sag...
  119. 2DR Rubi shocks & springs on 4DR X...any benefits?
  120. Quick Help
  121. Who makes the Mopar JK lift kit???
  122. shock question
  123. Tube Fenders....How Big Tires?
  124. Who makes the best gears?
  125. Locker Indicator Switch
  126. Wider tires than 35X12.50?
  127. Superchips - Case & Mounting Ideas
  128. Front mud flaps, non-mopar
  129. EVO Rear Bump Stop
  130. 5.13 or 5.38's with auto and 35's?
  131. winch?
  132. Front Bumper
  133. stubby stock front bumper
  134. MPG w/ 35's, check my math?
  135. Pro Comp 8179 problem....
  136. stock d30 front +31in of snow + 4lo= this
  137. 15x8 Unique 42 Wheels
  138. Jeep JK SkyCap
  139. My first MPG report with Superchip Flashpak...
  140. Rough Country 4" x-series lift
  141. Nitto Mud Grapplers or Toyo M/T
  142. Project JK.com
  143. Sheet metal inner fenders
  144. The best road tire.35x12.5.18
  145. Air pressure gauge help
  146. Iron Bull Bumpers
  147. Rear JKS Trackbar rubbing on Tereflex Coil
  148. Mounting Automatic Transmission Cooler Behind Radiator
  149. JK Jack stands & TF lift
  150. Currie AntiRock Swaybars
  151. Actual diameter of your 37" tires?
  152. Have you seen this roll bar?
  153. Is it worth the money????
  154. Adj Control Arms
  155. Programmers
  156. OME HD lift contemplation
  157. Poison Spyder Tube Fenders
  158. Rear driveshaft removal (factory)
  159. Rust
  160. Decisions about what to get
  161. Steering Stablizer
  162. Cat Back Exhaust
  163. Gear Ratio vs. Stock Tires and eventually 33's
  164. Help Installing Teraflex Retainer Kit for rear!
  165. Mile Marker Mifi news
  166. Rock Sliders
  167. Trail Master Leveling Kit
  168. Help!!!!
  169. How do I find out my gear ratio?
  170. Need to know some things about 37's
  171. question for herculined interior
  172. Gears...
  173. One final question before lift install?
  174. wheels
  175. Let's hear your epic fail/win at d.i.y. projects!!
  176. Popping in my steering......need help!!
  177. Zone Lift Kit Questions
  178. Wheel studs?
  179. Tuner and gearing questions
  180. RC 2.5" Coil vs OME
  181. Anybody running 33's on a stock JK?
  182. bds suspensions
  183. control arm help
  184. MT noise level coming thru soft top
  185. My hardtop panels are backordered and I'm 1/2 topless
  186. OME +40 Lift
  187. Full or Mid Front bumper advice
  188. Any MOPAR vendors on here?
  189. Newbie Install Daystar 1 3/4: What Tools? Pics?
  190. 0"-3" disconnects-have a question
  191. evap skid dimensions
  192. Downsize my lift?
  193. Amp research steps
  194. Teraflex Steering Stabilizer
  195. Fat Bob
  196. In preparation for 37's...
  197. DW what speed
  198. YILES! First death wobble.
  199. daystar 1 3/4 leveling kit instal
  200. Pacer flexy flares
  201. IPF H4 headlight install
  202. Wheel spacers- steel or aluminum
  203. Spare Tire Fit Backspacing/Tire Size?
  204. TeraFlex 2.5" Coil and 35's (2DR)
  205. Wwyd
  206. tire size question
  207. help me choose rims.. before feb 10th
  208. spacers, coils, or new lift kit
  209. New trim option for all you Fender Choppers
  210. Base plate setup for JK
  211. PSC Hydro Assist Install Questions
  212. Upgrading Dana 30 to 4.56
  213. Another JK build I want to share (34's with 2")
  214. Help with MBRP Spare Reinforcing Bracket
  215. ESP problems
  216. Steering problem / maybe I need a new gear box
  217. Stainless Steel Braided brake Lines
  218. A little help with XRC front bumper and winch install
  219. Opinions needed - Winch Selection
  220. RC X-series arms on a TF 3 inch lift??
  221. My input...looking for yours...build sheet
  222. EVO full corners??? anyone?
  223. Ripp Supercharger, FlashPaq and SprintBooster?
  224. Mile Maker SEC8 Winch...
  225. About wheels and tires
  226. Opinions Needed! New Rear Bumper-Need A Tire Carrier?
  227. rusty MBRP tip
  228. calling all mechanics
  229. Duratraks
  230. Looking at 36 0r 37's
  231. Tuffy full console
  232. Stock Moab Wheels 35's
  233. Any one have a JK X running 4 inch and 37;s
  234. Steering Geometry issue???????
  235. 40s and 17 inch spyderlocks
  236. 315/70r/17 on stock rim?
  237. Brake Bleeding Problems
  238. New Tires/Rims = Death Wobble?
  239. OME Lift.
  240. Rear Bumper Help
  241. Walker Evans Info
  242. Anybody running the new dick cepek 18x9
  243. Power drop after lift and 35's?
  244. Can I run my 37's with a 3" Teraflex spring?
  245. Anybody running xd797 wheels
  246. jeep pulling when hit puddles
  247. KM2 (Dicount Tire Direct Rep)
  248. Is there a front trackbar difference between X/Sahara and Rubicon
  249. kinda mad...
  250. Lift kit installation question
