View Full Version : Modified JK Tech
- Rocker guards
- ProCal or wait for 11 Superships?
- Bedlined rear wheel well area?
- How about BFGoodrich Krawler™ T/A® KX
- What bumper is this?
- installing warn 9.0rc on XHD Bumper... Help please
- 3.8l v6 Engine Enough power ?? for 37 tire?
- Need some advice on what's WRONG with my Jeep!
- Can anyone identify this roof rack?
- Whats needed for 37"s
- Air'em up. What's you got.
- Bully dog code 203, 2011 jk
- Any Advice on SUPERCHIPS ???
- Water+winch=?
- 295 or 35" trail grappler
- gear package?
- lug nuts
- VDP Stubby Bumper... not just another pic request...
- axle sleeve
- Brake lines rubbing?
- Bullet Liner????
- RIPP supercharger Emissions Test
- Any spare tire racks that will work with XHD rear bumper?
- No shock extensions with Teraflex 1.5" leveling kit?
- Ruh roh, what do you all think?
- Which rear cargo rack in the Unlimited will hold an ARB fridge?
- Hi Lift Jack with Olympic 4x4 Xtreme Double Slider Bars
- anyone here haave rough country 1.25 body lift and ACE rock sliders??I need help!!
- Daystar 1.75" lift
- First Oil Change to Pennzoil Syn
- 1.25 Body lift questions...
- Spring question
- How much does your modified JK weigh?
- 16 or 17" rims for my Jeep?
- tube seal leaking
- Help with spring rate, off camber situations with a heavy rig
- Differences between the Rubicon Express 3.5" "std" kit and the 3.5" Super flex?
- Installing 4dr fuel tank in a 2dr
- what did you put on your OME lift
- Best Programmer???
- When is the 3.8 most efficient?
- 2011 Hard top on 07?
- Winter tire decision and sizing question
- Control arms are important!
- Spray on liner over chipped owder coat?
- Help finding thread
- Corsa db exhaust
- Flash, Programmers and that computer stuff
- Installed aeroforce gauge, now big problens!
- do you guys keep your rear sway bar on after lift??
- Advance Adapters upgraded transfer case cable install
- Where can I get it??
- Onboard Air Issue
- Swaybar help.... Please..
- Leveling Required?
- Hemi swap people.
- Bad u joint?
- Body Armor 4x4 Rock Rails
- Lower dash panel
- Long ranger additional 43ltr fuel tanks for 2 door jk
- Duratracs.
- Regearing JK 2Dr Auto 2010 to 4.88
- M.O.R.E. Rear Bumper with Tire Carrier - Have it? What u think?
- Duratrac, Fierce attirude, or Falken Wildpeak?
- 18-23mpg in high elevation (8,000-10,000 feet) in Sierra's and only 12-13 mpg in LA?
- Need help with JKU sliders
- Rock Krawler Tie Rod Problem
- Help with JKS steering stabilizer bracket
- Any suggestions on painting my new PS bumper
- 35's and Budget Boost on a 2011 JKU really bumpy
- 2012's and gearing upgrade
- Need some Help. Replacing rear brake rotors...and they won't come off the hub!
- What type of grease for trackbar?
- D44 Riddler Diff Fluid change question
- Teraflex diff cover question
- Tuff stuff rock sliders
- Steering
- Crawl setting on superchip
- Lug nut question regarding aftermarket wheels
- Front soft doors on a 4 door?
- Hub centric?
- 40's
- Rack project
- Tired of 4x4 shops not knowing whats going on... aaaaand gear oil question
- Rear Axle Options.
- weird vibration?
- Stinger for the Rear
- Install done but
- Different tire sizes?
- ARB oil capacity on D30/D44
- Aluminum pedals?
- Bushwacker Flat Fenders - rear fender inside molding for off roading question
- Anyone with 6spd 4.56 and 35's
- Rusty's Offroad front 3.25" coils
- Warn Powerplant with an external tank?
- Poll Pick my gears!
- Fierce attitude M/T
- Anyone ever install a screen top?
- Welding gussets
- Light setup, how about this...
- People with 33s, how does your Jeep drive now?
- Aftermarket exhaust...worth it?
- New Lift
- smittybilt cab cover
- 4 dr axle on a 2 dr?
- Hemi 5.7 or 6.1
- First Jeep would like some help.
- Headlight Guards
- Who's running a TF 2.5" lift on a 2DR
- Installing RC 2.2 SS kit... Any heads-up ?
- Picture Request - 2.5" Teraflex Coil / Unlimited / 32-33" Tires / Stock Fenders
- Are you horny?
- Bfg km2 or toyo mt
- Painting steel bumper?
- Death Wobble?
- Olympic rear bumpers
- Duratrac 295/65R18
- remove my antenna
- How much does YOUR Jeep weigh?
- I Like it what do you think?
- how about Toyo Open Country m/t
- Smittybuilt Question
- Smittybilt tailgate G.E.A.R. installed... my impressions...
- Spiderweb shade install help
- Need Help with Shock Install
- Anyone have the RCD 4" Lift Kit for 2dr JK
- Best Bikini Top for an Unlimited?????
- Trektop NX came in today
- 15 inch wheels
- license plate and winch
- Kool Breez screen top
- Any snorkels compatible with a light bar?
- Highrock (Bestop) Rear Bumper with tire carrier?
- wheel backspace
- Rough Country Lift
- Replacing Tie Rod and Drag Link
- Any drive shaft issues caused by running Teraflex 2.5" 4-door coils on a 2-door?
- 35x12.5x17 Toyo MTs on ATX Crawls
- 35s on 15s pics?
- Exhaust System Question, Recommendations Requested...
- Brake upgrades
- Front d/s boot torn, how long do I have?
- Next Step Up from Teraflex Levelling Kit
- 2.5" vs 3" teraflex
- Bumper Recommendations
- Anyone have the Ironman suspension?
- Regearing to 5.38 my 2dr 08 Rub
- Aftermarket Throttle Body
- High rock high access front bumper first impressions
- Chromoly axles with u-joints?
- irok radials????
- Question about wheels
- squeek/squeal from rear wheel area after welding
- Running Ligths on hardtop like H2s?
- Newbie: Street biased wheel help?
- Getting ready to order 4:88's and need opinions
- HELP! New Hemi tranny (545RFE) stuck in 2nd gear.
- can i drive without i shift boot
- Dropdown Tailgate and OR-FAB Gecko Skins
- 2011 JKU Rubicon stock height ?
- 2011 interior
- Door Hinges
- Just skiddin...
- 33's or 35'
- Warn m8000. Need a cover.
- 4dr coils on 2dr question
- JKS Adjustable Sway Bar Links - Drilling required on Rubicon?
- SRT-8 conversion?
- Clicking noise when braking...
- Better Shocks???
- How this was done?
- Long Wait at Shrockworks?
- ARB Long Ranger Aux Fuel Tank
- Air intakes and exhaust upgrades questions?
- 3 - 3.5 Recommendations
- Got my Teraflex Leveling Kit installed! Couple pics to show y'all!
- Can't get stock mirrors out of the brackets
- Quadratec grab handels.....
- Front bumper?
- Help searching for 37x12.5x20 inch tires
- moving the spare tire lower on the Rugged ridge xhd rear tire carrier
- Tire pressure for 285/75r16 mt tires ?
- Engine compartment extra hot??
- Help identifying jeep parts
- Traveling
- 1.25 body lift and Ace rails
- coast front drive shaft
- Seat Covers
- Parking Sonar / Radar
- "Progressive" Springs
- Vote: My Last Big Mod
- Non-dot approved tires
- Teraflex 2.5 coil spring type?
- What skid
- 35" tires / stock suspension - quick question
- What gears does he have?
- Gears- brands?
- Roof Rack
- Warn VR8000 VS Warn M8000 ?
- Towing with OME and TF
- Cant Decide On A Lift
- Whats the next step?
- Superchips Flashpaq > Will it pass emissions?
- Hole in Diff Cover
- Drive shaft replacement help
- Help! have i done damage?!
- 2012 unliminted sport help
- Moving steering wheel controls?
- 16s vs 17s for 35's
- For people running OME Lift with track bar bracket only
- Will it fit?
- bestop trail cover vs smittybilt cab cover - one in the same?
- Death wobble and leaking stabilizer after lift
- Help me build my jeep!
- ORF Cage creak noise
- lift question
- Tire size decision 2012 Rubicon Unlimited with TF 2.5 coil lift with bilstein 5100
- Heavy LOD Rear-What size spacer?
- Need help picking out front winch bumper
- Wheel Locks
- Spare tire roof rack **LOW BUDGET**
- Tires..tires..tires! Yep i need them...
- Mods?
- 3.73/4 spd auto on 35's?
- ARB Locker blowing oil out the air line solenoid when turning off?
- Bad track bar bushing: How to fix?
- 33's or 35's ???
- When are brake line extensions needed?
- Intake/exhaust
- So who has a 2012 Sahara Unlimited with 3.73's, auto and installed 35's?
- Corporate 14 for JKs??
- Wheel fitment questions
- ARB Winch Cover Plate Install Question
- 2012 Jeep unlimited lift kit
- Has anyone used the AEV control arm brackets?
- Is Buschwacker flat rear driver's flare supposed to have a dimple?
- What to buy next?
- Just wondering....
- Coil spacers to make up for lift sag.
- One Rear Wheel Spacer?
- LoD Front Bumper on 2012 - Cannister in the Way
- C gussets and sleeves
- Rusty's Offroad Exhaust System?
- 2" or 1.75" wheel spacers?
- American Eagle Classic on stock SRA's
- Snorkel or No Snorkel?
- squeaky clutch
- Can Adjustable Control Arms be used for less Caster?
- Clear 2 peice top.
- Finally going to order tires. Final questions?
