View Full Version : Modified JK Tech
- Can 35's fit with 1.75 inch lift and Flat fenders?
- What tuner
- Rubi Shocks vs Sport Shocks
- Which ball joints?
- Rear Folding Seat Lock
- Best pure off road tire? (radial)
- New Rubi T-Case stuck in 4hi
- Narrowed Down Wheels Choices
- A little help with my jeep
- 4 door kit in a 2 door
- Rear Track Bar Necessary?
- Will someone confirm my thoughts and answer a couple questions.
- Changing JK rear interior
- 10A Stock Lift Question
- Horrendous 3.8L Gas Mileage
- future upgrades
- Dust covers
- LCA Rubbing
- Rock krawler 1.5 with tri rate coil
- Front Spool With Hubs
- Smittybilt XRC tire carrier handle?
- input on this set up.
- Which Warn
- remote start installation
- 2 door stretch
- What does it take to make a mean Jeep?
- Superchps Flashpaq Detailed Options - maybe a sticky?
- tire question
- 2012 Jeep Wrangler Sport 2 Door
- Gear, locker, and electronic disconnect help
- 33" Duratracs or 34" Toyo AT's???
- 2012 Rubicon Unlimited with plan for Metalcloak 3.5" lift, considerations?
- What to do next...?
- Good Replacement Radiator?
- teraflex tire carrier help!
- Foglight blub replacement question
- Fwd knocking
- Shock help
- Antracite rattle cans
- is terraflex the only one?
- Shocks... Need help...
- Springs hitting frame @ front trackbar mount?
- Drove up on wall now pulls too left and steering not straight
- Flashpaq help
- Iroks
- Body lift?
- Winch Options for Stock bumper??
- wheel options for 38x14.50x17 Mtrs
- Checking front axle housing
- What alternatives to a rear tire carrier?
- I did it
- need help quick
- Stalled in Water Won't Start
- Show your aftermarket seats
- kc hilights stopped working
- Body armor 4x4 trail doors?
- breather tube locations
- Tires
- Replacing springs with Rock krawler
- Will a synergy front track bar work at stock height and 2.5" lift?
- Anyone running an ARB Diff cover on factory 44 with factory lockers
- Lift help!
- Northridge 4x4
- Goodyear Duratracs
- 2.5 lift + 1.75 on a 2dr
- Front dana 30 on 37s
- Barricade roof rack cross bars-same size?
- Review my mild lift shopping list
- Spring Sag?
- OME SS & relocation bracket install???
- What control arms are necessary?
- who is running this setup?
- 5.13 gears on 07-11 jk auto with 33's
- Can i run 33 12.5 17 baja mtz on classic 2 wheels no lift?
- AEV XT 2.5" lift install questions
- KC lightbar and lights effecting MPG??
- Throttle body spacers
- Anybody familiar with Black Rhino wheels?
- Am I crazy buying this lift?
- Black Teflon finish on wheels - Good, Bad, Comments?
- Need input from those that went from Flashcal to flashpaq.
- 35x12.5x17 help!!!!!
- guys i need help with my rear diff the original welding on the diff was broked
- Need answers on gear, tire combo
- Regear pinion and Ring brand
- 2014 2 door with 35's
- 15" Rim Questions
- Dual Rate Springs Strong Enough
- Quietest but most Aggressive AT Tire?
- Rubicon springs.. Will these fit??
- rk 2.5 stock mod
- Ive searched and read and still cant find my answer
- Do I understand planman's post correctly?
- Another good experience with Northridge
- Help with Vibrating noise near A/C Knobs
- Painting wheels
- Flat Fender Pictures & Info
- My rubi has 3.73 gears? What!
- Bent Front Spring?
- Moving up to 37's... And once again the same old Axle question's
- New Product Request !!
- Yet another roll cage thread
- wich bolt is best for gibson headers on jk 2010 stage 8
- Smittybuilt Oversized Tire Carrier for Spare Anyone?
- prodigy turbos
- Arb On board air Questions Opinions ?
- Tires. Which ones. I have no idea
- Metal cloak 3.5 vs rock krawler 3.5
- Budget Boost with disconnect Question????
- Anyone have this spyder rear bumper and tire carrier?
- Another wraparound wind jammer on 4 door question
- 4 inch rough country equal to a 3.5 RK?
- 08-13 rear bumper and rails ?
- light weight combo
- Newbie Question Regarding 15x8 and 1.5 wheel spacers
- Trade in Jeep
- Preparing my JKU for 37"/38" Tires
- I just regeared looking for help with Flashpaq
- Upgrading lift! What to do?!? Metal cloak or other?
- New here Modifed v. Stock
- Replacing 2.5" TF BB w/ 3" Evo Plush Ride Coils?
- Are Rotopax Legal ??
- Teraflex Tire Carrier vs Aluminum Genright Carrier...
- Jeep springs
- RC 2.5 Lift Settling?
- gorilla flush mount valve stems
- LOD Gen 4 Rear Bumper/Tire Carrier Linked Installation Help
- Need Help Finding a Bumper!!!
- Steering feels sloppy after lift and alignment
- Advice on Suspension Lift Kit for my JK?
- mickey thompson classic 2s help
- Currie Heavy Duty Steering
- Olympic bumper w/tuff n ez tire carrier
- rotten rear bumpstops
- poison spyder hood
- ProCharger Super Chargers for 2011 JKU 3.8l
- new mods
- Atx slabs
- xrc8 synthetic on JKU.
- Tire pressures
- Jku gear ratio
- Window Tinting
- Rear bumper fascia, frame cover
- light bar help
- JK Front lower & upper arms change bracket
- Egrilles roof rack with basket? Anyone ?
- New wheels tmps ?
- roof rack questions
- More HP?!?!?
- What Black Lugs are you using with the Rugged Ridge Satin wheels?
- Gear swap cost???
- Katzkin install questions
- Southwest michigan or northwest indiana 4 wheel shop
- Question on EVO GUSSETS
- What color leather in white jk
- Brakelight and license relocation
- Determine amount of actual lift.
- Is it a big job to add rear spacers?
- exhaust
- 4.88s installed = Amazing!!!!!
- I got a popping in my front end
- First Post-Just installed 10th anniversay springs
- 16 Inch Black Wheels?
- Electronic sway bar disconnect on a Sport?
- Caster setting
- Rear bumper that fills the gap
- newbie question...
- 5 directional tire rotation
- What exhaust?
- Anyone running the Rugged Ridge Engine/Trans Skid on a 13' Rubicon?
- FlashCall Issues with TPMS
- Advice getting a little more clearance..
- Just changed my manual tranny fluid a few questions??
- 2014 Transmission and cooler
- JK LED MILITARY TAIL LIGHT CONVERSION ISEE Systems
- Mod stock airbox to be more water tight?
- Front swaybar link hitting coil on drivers side only.
- Bumper light bar position advice please
- northridge grade 8 or synergy full hardware kit?
- 35 duratracs
- Tailgate Rattle - Thinking about a Teraflex Tailgate Hinge
- Upgrade Time - Need Help
- looking to join the 37in club!
- AEV 2" Spacer lift - Anyone?
- Dip my rims today did a write up
- Advice before I pull trigger?
- Drag Link/Tie Rod Ends
- Daily Driver, 2014 Rubi, 4.10gears, AEV 2.5 Lift, 35's... Do I Need to Regear???
- Daily Driver, 2014 Rubi, 2.5 AEV Lift, 35's... Should I Regear???
- tie rod ends
- New LOD Offroad Gen 4 Rear Bumper/Tire Carrier
- Lift install price??
- Genright tire carrier - install time?
- Where to get this done?
- Modified smittybilt src rear bumper?
- 2.5 Spring lift question.
- Best extended brake lines?
- RK lift question
- Transmission lines
- Body bolts' nuts spinning freely - help needed.
- Wheels
- Failing Hothead Liners - Here's The Answer
- Help with new lift for 37s - any recommendation based on use of vehicle (below)
- Aries or Fab Four
- Oil on pitman arm
- An offer you can't refuse
- eBay/amazon snorkel
- Wheel liner ideas
- where should I take my build from here?
- Running hydro assist with aluminum tie rod
- Color choice help.
- Wheel size
- Thoughts on rampage bumpers
- short gibson headers on jk 2010 i need help
- Anybody have kumho venture kl71 315/70/17? if so post pics.
- HELP!!!! Rock Jock front 60 installed and now steering is flighty/all over the road.
- Does anyone know what brand bumper is?
- Rear plate got torn of off-road, replacing with spare tire plate and 3rd brake light
- Track bar help
- Show us your head and tail lights!!
- Do I need C Gussets?
- Aftermarket headlights and tail lights??
- What temp does you JK run at?
- JKUR Coils and Shocks on a JKU
- Treadwright tires for long trips
- bestop trektop nx
- Looking for a 36 or 37 for a 18 inch rim
- So Cal Shops
- Am I on the right track?
- Using stock fog light wiring for KC's w/ new XRC front bumper??
- Is EVO serious?!?!
- Plastic Dip Rims
- Need help - Left turn signal will not shut off
- Diesel conversion???
- reviews and info for trailmaster lift kit
- AEV procal, superchips fladhpaq or flashcal
- people with the 2.5" aev lift on a JKU can you meausre center wheel to fender?
- will they fit?
- Leveling kits
- jeep build with a super 60/sterling setup
- My initial impressions of the Goodyear Duratracs
- 2013 jk 2dr- Need Help
- Misc. lift questions...
- Gonna break out da cash!
- Shock question WHAT SIZE ???
- Need ideas
- After Market Bumber ideas
- Stock carrier?
- Teraflex w/ 35x12.50's
