View Full Version : Modified JK Tech
- About to purchase a used 2013 and have some questions
- ball joints
- Gamma electric ignition coil
- grabars for 4 door jk
- Install of 3.8 lower intake
- Does any know what doors these are?
- Stock Tire Carrier Reinforcement
- 100k mile jk club!
- LOD rear bumper
- Turbos, Intercoolers, Superchargers. Educate me.
- Opinions: ARB premium bull bar vs lod mid width
- Program tire size
- Questions on upgrading to 2.5 lift
- New Tires question...
- RIPP Superchargers 3.6L JK DYNO. No BS, just what it is.
- Anyone running the Rancho Rock Gear Diff gliders?
- Rough Country End Caps for Stock Bumper
- AEV 2" spacer suspension vs 2.5" teraflex budget boost
- front to back
- Offset question
- roof rack and snorkel combo
- Custom Stinger Build
- lift break in question
- Failed Emissions
- someone please help me with the sizing of these rims I'm going to be getting
- Please help
- RSE bumpers
- 30 min LED back up lights using the stock bumper
- Painting my pro comps
- 35's - same make, diff price?
- info on running 35's
- HID Projectors from HIDProjectors.com
- How Much ($$$) Has This Addiction Cost You
- BBK Longtube Headers
- 2010 JK 3.8L Hypertech Programmer Settings
- Rear track bar relocation bracket
- Prestaging for 37s
- TRE Suggestions
- Do I even need spacers?
- Thinking about next mod- looking for outside opinions
- Is my transfer case shot?
- The AEV rear slider??
- BDS suspension 3" lift. Reviews? Reputation?
- Upper and Lower Ball Joints....What to do???
- Dynomax vs Gibson dual exhaust review
- HELP, JCR bumper discontinued
- Look out....FNG with kit questions...
- MAGNUM SQUARE Blind Spot Mirrors - OEM Look..ish...
- Rubicon Dana 44 axle shaft lengths
- Some questions about my 07 Sahara Unlimited
- Sway Bars
- SO i need a clutch.....help with deciding please!
- Help - Coil spacer not centered?
- Please help with wheels!!
- Help me find a thread please!!
- Banks Monster Exhaust on 13' Rubi 3.6L
- Thinking about this set up
- Tread Lightly! Floor Liners
- Adj track abr
- Rubicon Axels vs pro rock or currie
- Steering issues after Front axle truss & ball joint install
- Rattling tranny or drivetrain noise when cold
- HELP!!! Rear outer axle seal leaking again!!
- What brand wheels are these
- 3.5" lift, 33's
- About to pull the trigger - down to 4 tire choices
- Transmission ratios?
- Need new shocks ASAP -- Rancho RS9000XL or Bilstein 5100
- Trimmed my pinch rails...lots of pics
- Genright / Evo Carrier Quick Release Pins
- Help with tire carrier lug size-Poison Spyder carrier
- Nitro sleeve axle shaft install question
- death wobble
- Dynomax exhaust
- OXFORD Tyre Valve Caps
- Fox ats stearing stabalizer question and RK developed ove syear and wonder. Help.
- I have RK 2.5 lift and have a few questions.
- Roof Rack
- First Jeep. 2014 Willys Unlimited Need Advice
- New Rear Bumper and Tire Carrier
- What to get first
- Looking for someone to straighten an axle housing
- Mud/Slush mats- Mopar Vs. Quadratec
- Soft top jeep jk's
- JK suspension swap
- Upgrading axle shaft questions
- Diameter of hub flange change from 2007,08 to 2014? Problems with wheels
- lift question...
- cut fender question.
- Eibach 3.5 progressive springs...anyone running these
- Tire size(295/70/17) and back spacing
- evo c2 axle gusset question?
- Flex arm questions.
- Got my Bushmaster Flats & We installed them
- Steering torque specs
- Help me figure out my alignment report please
- sway bar links
- Paint Sahara Fenders to Match Black Plastic
- 2007 rubicon rear locker not engaging
- MidWest - St. Louis Metro - 2013 JKU Sport regear questions
- EVO tire carrier question
- Tuffy Security Deck & Kid's Carseats??
- header/o2 sensor/code question
- Importance of proper torque?
- AEV Rear bumper holes?
- Looking for front skid plate to work with smittybuilt stubby xrd.
- Rebuilfing warb 9.5 cti
- 2.5 teraflex lift ... Shocks??
- No death wobble, just loose
- filter help
- Gobi rack with new ruged ridge snorkle
- Soft top brackets?
- Jk unlimited rubicon rock sliders
- I need Fox shock advice
- suspensions beaten to death topic
- Winches and components there of
- Are Headlamp Protectors Worth It?
- opinions on best gear brand options??
- I finally got Rubix all built up, I have some problems...
- trail grappler fail
- Re gearing for 285/75/17 tires
- Rubicon coils or keep saving
- Grill mod and winch install
- 2010-2013 Jeep JK Wrangler Exhaust by Gibson w/ Metal Mulisha Tips HOW TO and Sound
- 10 Things Every JK Should Have Added
- Quick Feature: Road Race Motorsports 2012 JK Wrangler
- Nitro Sleeves
- A Blank Canvas
- Cable or rope winch?
- Selling my 2012 rubi jk8 aev everything,6.4 hemi manual 6speed
- Smittybilt Door Surrounds
- Body lift question...
- Has anyone mounted a Hi Lift on XRC rear bumper?
- Question of Sway Bar Disco's
- Rockridge4wd LED Tail Light Conversion Kit?
- Looking for stubby front bumper experience/opinion
- How does this parts list look? RE lift +
- Question regarding using a 2 post lift (MaxJax) for installing Metalcloak lift
- Might be a Stupid question. 2 different brand name control arms lower and upper
- Mtr w/ Kevlar or Duratrac's?
- Weird noise
- dry filter
- Rear Bumper + Tire Carrier Options, Please
- shrockworks
- Magnetic oil filters and drain screws
- Are THESE The Answer To The DREADED JK DRIP?
- Buy tires from...?
- Anybody running cherry bomb glasspack kit?
- Got a trac bar question?
- Need help with picking an exhaust....
- Lift and Gears
- Swapping Door Locks
- Spod Woo Hoooo
- Level height help
- 3.8l 2 door with 35s, Regearing Question
- Billet JKU Wheels - All Black, Machined, or Combo
- Which Bilstein 5100s for 2.5" lift??
- Wheel Offsets
- ? about replacing front bumper on 2008 JK
- led lights
- Anyone running limiting straps?
- tire question
- Axle exhaust questions
- what jack points do you guys recommend?
- Just Empty Every Pocket
- gear noise
- 2 1/2" suspenion lift kit
- Taxman Came Through and I Pulled the Trigger
- Rugged ridge trash
- Sloppy steering
- rancho 9000 or pro comp 9000 shocks?
- Proper placement for Hi-Lift jack
- Will These Fit??? Sale ends tonight!
- exhaust options
- What long travel shocks?
- Decision about skid plates
- R&P Self-installation???
- Synergy tie rod and 16's
- Cross Country Trip Preparation
- Jeep kinda wonders????
- Recent Alignment...should I be worried?
- EVO gears
- Jeep re-gear prices in San Diego Ca area
- My JKUS Build
- COD?MOAB owners that have installed winch
- lift install question
- Rough County 3.25 lift, upgrade or replace?
- Replacing coils and springs
- Jet Stage 1 Chip
- TL's without pulse width modulation
- Teraflex: big brake kit help
- engine possible donors
- Level advice help!
- 255 85r16 or 285 75r16
- Manual tranny
- *Universal stinger!*
- Help wanted on piecing together a 3" Lift.
- fuel eco and snorkels
- 2.5" Rubicon Express BB
- ESP system
- Can I use a TJ rear bumper for JK?
- Srt 8 rims on a 2010 jeep jk?
- 2.5" lift: install at home or pay a shop?
- So what should I do next
- Mopar springs
- Wheel spacers need help!!
- Rubicon springs under a jk
- Terra Grapplers or Trail Grapplers
- Black Rock 909 wheels + stock 16" caps?
- When to reprogram?
- Rampage trail cans fitting in OR-Fab Tire Carrier
- OR-FAB Rear tire carrier w/Jerry Cans Mounts
- Rough Country Budget Boost Question?????
- Help picking out a snorkel :3
- Side armor that allows for front fender removal.
- shocks
- Need to replace my drag link & stabilizer: any guidance?
- Headers or back with Manifolds?
- Raising spare tire up couple more inch's?
- Repair bill contest- guess how much
- 2007 Soft Top On 2012?
- Ruffstuff Offset Tie Rod Kit
- Thoughts on a lift? Help??
- Anyone use TF, and KEEP the rake?
- I received my gears and front ring is chipped, advice pls.
- Synergy mount question
- insulating the hard top
- Wheels for cheap
- Need Spring advice...
- Any source for cheaper hardware for OEM softtop? (pins/screws)
- slight steering pop
- RIPP Superchargers DEALS EJS 2014 in MOAB! Prices too low to advertise!!
- LED Headlight Conversions...lack of heat concern
- Tinted windows for JKU Soft top
- Tinting
- Bedliner w/o Carpet (Spray in or Quadratec?)
- Softop for the summer
- Fab Fours Lifestyle Winch Bumper with Pre-runner Grille Guard Reviews????
- Vector Off Road Exo Mount
- Let the guessing games begin
- Shock question
- Spring and shock swap questions
- Best Shocks for rough roads
- Frt drivrshaft
- Lift/Leveling Kit Question
- What is this?
- New 4.88 gears with stock tires.
- Question: Driving after Gear Install
- Suspension parts
- Rancho or RockKrawler lifts
