View Full Version : Modified JK Tech
- rear LED work/back up light plug and play?
- torco gear oil?
- rubbing with 4.5 backspacing and 13 wides?
- 3" Lift & Exhaust Spacer Question
- best black trim restore?
- 15x8 with 5in backspace possible for 33x10.5?
- Angry Eyes and Headlight Guards?
- Which shocks are better?
- Snow and 35x12.50 R17 BFG T/A KM2's
- need opinions on color scheme for jeep.
- Order Question - VON
- Ways to Mount Power Tank
- fender flare I.D. please!
- Tailgate Vent Cover
- Who's running 40's?
- Lifted and having overheating issues
- Traction control question
- How would you respond to this situation?
- Idea on cost to switch gears
- Quick M116A3 Trailer build
- JCR Front Bumper
- Synergy long arms Q's
- Jeetops
- Hi-Lift jacks and shovel mount on hood
- Engine Leaking Coolant/ Questions
- Dealer scratched aftermarket wheels
- Please help, front end "floating or light" after track bar bracket
- Upgrading from Budget boost
- Rock Krawler Max Travel vs. X-Factor
- Paint Rock Rails
- HHELP! Rancho 9000's or Bumpstops?
- Teraflex Big Brake kit versus Dynatrac Pro Grip brake kit
- Exhaust extension
- Wrangler JK 3.6l easy 20HP gain?
- Offroad Heroes fastback top
- 1.25 teraflex body lift questions
- Help! KC lights gremlin at install
- 2" coil spacer on top of 3.5" lift
- Shimmy and Shake in steering wheel
- Largest tire that can fit in 2 door JK after removing backseat?
- Control arm recommendations
- Addictive Desert Designs side step/ rock rails
- Suspension issues & not sure what to look at first
- "Angry Birds" style grille?
- How much arguing did do with the tire shop?
- Best Price On Superchips Flashpaq 3872?
- superchips flashpaq or bullydog gt
- Question to all who have installed the 2.5 RK Max travel kit...
- Settings on Bully Dog GT 2010 JK
- New Cold Air Intake and Exhaust... GREAT!
- BFGoodrich All-Terrain T/A KO2 IS HERE!
- Modified JKs at SEMA
- Dynomax rebate?
- Freedom Panels
- High pitch whistle/whine problems
- Stock bumper bull bar addition....pics if any!
- Thots on Lift?
- Best sway bar disconnects for stock jk
- Choosing a locker, all input welcome!
- Disconnecting with Teraflex BB?
- What lifts do you recomend for 35"s?
- JK8....thoughts?
- Seat advice with herniated disc on lumbar spine
- Poison Spyder JK Brawler MID Front Bumper
- Need Help OME Heavy or Light Duty springs???
- Longer springs or spacers ? JK is lower at the front
- Regear rear axle only?
- DDM Tuning HID headlights
- Can someone tell me which front bumper and fender flares these are and where to buy?
- RK control arm question
- Cause of my Wobble??
- Protecting my underside
- My Lift/Tires/Gears experience
- LOD Slider Install - Did I screw it up?
- Full Metal Fabworks Apex Pinnacle winch bumper
- Loose Steering after lift
- Yeti gets a Sprintex supercharger
- Labor Cost on Lift Install
- JKS trackbar installed, new clunking and ect intereference
- Shopping for a programmer
- Mounting 33 inch spare
- Sleeves and gussets
- Teraflex9550 vs bilstein5100
- Springs
- Calibrating speedometer - bigger tires - superchips flashcal
- New G2 Core 44 Rear Axle Housing. DO NOT BUY!!!!!
- Quadratec winches
- foot rest pedal
- ruffstuff diy long arms
- Ford conversion in jk
- 37" tire options for 18" rims
- Is this normal?
- JKS Adjustable coil spacers
- Best options for snow
- How good are rubicon shocks?
- Hub nut locking?
- "Radial pull" - tire question, need opinions
- Rubi rear 44 locker in sahara 44?
- high steering kit
- Half door arm rest?
- SEMA Product Partner Spotlight: Sprintex
- Diablo Sport trinity
- AEV Procal + Tire size update = No Reverse, 1st gear or Electronic Shift, What gives?
- identifying parts and help
- Diablo Sport Trinity
- BB 2.5 - creaking - only when turning.
- Click in 4wd front d/s slop
- Gears
- Economical Fix for sloppy Jk tailgate Hinges
- towing with evo plush coils
- 2.5" Lift & Stock Rim Question
- 2 door passenger sag
- flex joint preload
- Teraflex Ball joints??
- Feedback - which bumper
- Max tire size for leveling kit?
- BFG KM2 or Cooper STT MT
- Wheel size problems
- Another MPG Thread ( But Different)
- 2015 alpine option
- D window street lock
- Need new diff cover, will it rub?
- Tire size on stock Moabs ?
- Dealer-installed lift, now it pulls to right on highway, likely cause?
- 2013 JKU rear seat parts diagram?
- Check out Rock Krawler putting a RIPP Supercharger through it's paces in Glamis CA!!
- Tummy tuck
- Magnaflow 15237 cat-back.......?
- hissing sound. brake booster leak?
- Black Rustoleum sprayed over Plasti-Dip?
- JKS track bar and PSC diff cover......
- Some offset advise
- Wild Boar Products - Ordering, Customer Service, your experience?
- TF44 Housing question:
- Clutch replacement...Dual friction?
- hears theres a mod for psc louver
- Need a bumper ID
- 2009 x front hub stuck to axle
- Newbie Questions on a JK Build
- Installed rear upper adjustable arm noise
- Rock krawler rear upper arm install
- Pitman Arm Question
- Spare tire carrier 35"
- Pic Request: OEM Mudflaps
- TPMS issues
- bucket seats in back on unlimited
- Post up aftermarket tire carriers...
- Heavy bumpers on stock suspension
- mod shops in north jersey?
- Score!!!!
- Genesis mud flaps and do they check in New York State?
- metalcloak or crawler conceptz inner fenders?
- AEV vs. RK 2.5 - RK takes over when?
- Clicking / Popping Sound from Rear
- Jeep problems. Help!!!
- Poison Spyder Brawler Mid for 2015 Rubicon 2 door
- Soft Top Selection help
- ARB Twin Compressor mount with airlines
- Teraflex leveling kit sway bar link help
- Which Single exit exhaust to get
- Jeep trans wont engage... Help
- Installing Rough Country 2.5" Sway Disconnect kit...HELP!!!!!
- Installing Poison Spyder fenders...
- SEMA Product Partner Spotlight: Genesis Offroad
- Anyway to bang this dent out?
- Twin arb compressor durability??
- Help
- Lockers: how much better are they?
- Replaced E-disco on rubicon with Currie RJ Anti rock sway
- 2009 JK X best wheel bearings?
- spark plug wires
- wheels that would fit General Grabber 35's
- Single Action Rear Bumper/Tire Carriers
- spare tire removal
- Wheel Fitment Help Please- wanting to buy Enkei ST6 - images & specs included
- Gibson exhaust help. Side or rear exit?
- Camber issues - Dealer warranty?
- Advice needed on Lockpick V5 before I buy...
- Tuffy lock box. 3'x 20"
- Rubi axle swap into JKU sport
- New coils and 35s bumpstops question
- Control arms
- spring question
- Need exhaust recommendations for a RIPP SC'd 3.6 please
- Track bar or control arms first?
- Track Bar a Must?
- Rocker Panel protection recommendations
- bushing removal
- What should I mount to my bull bar?
- Flexible solar panels
- Bilstein 5160 shocks warrenty/ service question
- best performance intake and cat back exhaust system for my 2012 jeep jku?.
- Transmission coolers
- How much lift do i have?..
- Ori struts
- Product Partner Spotlight: Omix-ADA
- No drill rear door folding tray/MOLLE panel
- Mystery bumper and the failing tire carrier latch
- Anybody considering this radiator replacement? Flex-a-lite aluminum radiotor
- Drop pitman arm
- New to jeeps. Ride normally rough?
- Another re-gearing ?... Bla bla bla
- what Jerry Can and holder should I get?
- Fitting tow hook through Hause aluminum fairlead
- Front Stubby
- Rear tube fender (ace) pushed into the body
- level with me about sector shaft braces
- 2.5-3inch lift
- Front drive shaft sputtering grease... 2011 JK Auto OME HD lift 2"
- Need Help With Death Wobble
- Sct tunner out fir wrangler. Anyone have more info?
- Gobi rack and High Rock bumper / tire carrier on 14 JKU
- Chopped Fenders DONE!!
- Psc reservoir with stock air box on 3.6
- Recommendations for windshield lights
- Ideas on extending auto shifter or new knob
- what is the best spark plug wires and spark plug for jk2010 3.8
- Finally gears!
- Control arm drop bracket
- Replacment for rotting factory exhaust?
- Rusty ujoint
- side plates for protection
- How much extra weight would be considered going overboard...
- Poison spyder rear bumper HELP !!!
- TeraFlex tire carrier in Rancho Cucamonga
- Stock track bar and BB?
- BYOB? (Building your own bumper)
- Hub questions
- Issues jeep is wondering
- Another dumb driveshaft length
- Drag link/pitman arm
- mtr stickies 40/13.50/17
- Mpg
- Questions about installing rest of rk arms when flex all ready installed.
- Install of rubicon 3.5" lift
- Actual Increase in Height 2" to 4" OME Lift
- modified a MT shift knob into a AT shift knob. what do you think?
- ReadyLift SST Lift Kits
- Harbor Freight winch?
- TP Dash Light
- small lift opinions
- 6 inch lift springs
- Looking for a Shop/Installer San Diego area
- Do You Really Need Grade 8, 9/16", Fine Thread, Partially Threaded Replacement Bolts?
- Cold Air Intakes
- PS Rockbrawler Rear Carrier Mount Hole
- Trouble Reaching Pedals ?
- transmission lines leaking vs transmission cooler confused as h----
- what's up with Ferrari wheels?
- 3.5" AEV - Which hole on the Geolocation bracket?
