View Full Version : Modified JK Tech
- Finally got the DW... yikes
- Got a little bit of cash need help with.
- which brand is the best lift kit brand you guys think?
- Smittybilt SRC Rocker Guards anyone?
- Opinions wanted on my wiring diagram I have drawn up for my lights
- 2013 JK and Superchips...2012 JK and Superchips...2011 JK and Superchips
- flighty steering
- Teraflex tunned fox shocks
- aFe CAI with AEV snorkel?
- 2012 lifted jk, how did you solve ds clearance
- Beefing up axle????
- Thoughts on Painted Mirrors?
- Will Rugged Ridge 11025.04 Mirror Relo kit fit 2012 JK?
- Stock Rubicon eLockers and 37s
- Roll Bar Identification
- Poison Spyder hood louver anyone?
- Programer help!
- purejeep/poison spyder tube fender mesurements
- 35 pline rear shafts!!!!
- Aftermarket Wheels Stock Rubi Tires
- Wheeling with 37's amd 4.10s
- Not sure what bed liner paint to get
- Will my spare fit?
- Looking at new bumper, loop or stinger??
- Mopar differential covers?
- Has anyone installed the JKS sector shaft brace kit. And what are your thoughts
- welding your Cs.
- Simple question aev coils vs rock krawler
- Making a super 44 rear?
- Stupid winch question.
- Bedlining tub
- Falken Wild Peaks vs. Falken Rocky Mountain ATS
- Considering 37s...
- Anyone running 8.5" wide rims with 285/70/17s?
- Delaminating stock radio
- Gobi Stealth Rack + Aftermarket Bumper?
- OR-Fab tire carrier
- Axle truss
- Can I get an adjustable trackbar install thread?
- Removing cargo rack - cover plates?
- My Exhaust trial and error thread..
- On a serious note, which mod is best...for zombie apocalypse?
- Tire with stock axel issue
- Nitro Sleeve install?
- 68004460AA vs 68024461AA Mopar rear coils...... Anyone know the actual differences?
- Tailgate plate cover and 3rd Brake like- Combined?
- How do i know what size lift i have on my newest jeep?
- 4.75" backspacing vs 4.25" backspacing
- EVO Plush coils question
- ???? RC 2.5 spacer lift with Mopar HD coils ????
- Of all the mods you've done what would you consider the best ??
- Opinions
- Tire question
- Need Your Guys .02
- Mounting winch to JEEP steel front bumper
- New coil springs
- What Kind Of Lift Is This??
- Quick disconnects for front sway bar
- Freedom panel clips
- Shaking steering when turning, need advice
- Lift parts I've gathered
- Snorkel and duel battery set-up
- Pitbull Rocker Tire Pressure
- Dealer labor hours on gear swap!!!!!
- Smittybilt xrc armor
- Buy a new adj track bar or replace stock bushings?
- cold air intakes
- Mopar lift kits
- Tire carrier for New 35' spare
- trail stinger build
- Should I trade my 295/70/18s for 37's
- 2012 stock 16'' wheels w/ aftermarket tires
- Airbags
- New Shoes tomorrow! quick question
- Another Gearing Debate
- 1.5 spacer on sport tires
- rusting rocker guards and bumper
- need ideas for new tires!!!
- 2012 Rubi build...37's with 5.13 or 5.38 gears??
- TF 2.5" Coil Lift Issues...opinions wanted
- JK Hardtop changes?
- whats the best lift for my budget?
- Skid Plates - which OIL PAN is best?
- Torn CV
- Bilstein 5160 Remote Reservoir Shocks vs Fox Racing 2.0" Factory Performance shock
- Thinking about beginning the emptying of pockets...
- Tire size help bf ta ko
- Cant decide on aftermarket Wheels and Tires! Looking for opinions
- Warn Spydura Synthetic Winch Line ?????
- Mounting a 35" tire in rear cargo area ?
- Spidertrax spacers with 295/70/17's on MOABs?
- Pinion problems help!
- offroad issues with 1.75 lift
- Big problem
- Trying to determine maximum rim width for tire
- HELP - CAN'T SLEEP UNTIL I FIX A PROBLEM installing a 2.5 lift....
- 2012 jk engine swap into 2007 jk
- Need tire opinions, pics... and anything else you can add
- Aev tire carrier install on stock bumper
- Bent tow mount!
- flighty steering which is best option
- AEV Pro Cal 2012 JEEP... Worth it?
- Headers
- Body armor swing arm help?!?
- HELP! I need to know what size tire I can clear.
- How do I adjust Teraflex lower control arms?
- Will factory half doors fit the Sport?
- Fender ideas, anyone have any?
- License plate mount help
- Can I Remove Front Lower Shock Bolts Without Lifting Jeep?
- Actual Height of 35" MTR with Kevlar
- Stock Fog light wire colors
- Jack/Lift do i need to have aftermarket or will stock work for lifted jeep?
- pro comp extreme a/t
- How many of you installed your own lift
- What more do I need? Have 4 in suspension kit from Rough Country.
- Vengenance wheelbase stretch - why?
- Weight of ORE quarter pounder with stinger???
- Interior question
- 3 point retractable seatbelt harness with stock seat
- FINAL decision on lift kit, help?! PLEASE
- Tires, help meout here!
- Reasonable time AND cost for instal front, rear bumpers and side steps/krawlers...?
- OME LT Rear Springs on a JKU
- Rear axle leaking need help!
- Help me pick a stubby bumper
- Suspension help
- Tires
- What tires should i buy with a 2.5 in lift
- need info to install detroit lockers on rubicon??
- Rough Country Lift Quality??
- Shock boots? Run em or no?
- Supercharging a JK?
- Tuffy Tailgate Security Enclosure NOT the Security Deck
- Smittybilt Universal Jerry Can Mount- Anyone Have One?
- New JK, need lift/35s, and backspacing questions
- 2.5 and 35's
- 35's
- Suspension question
- Expert please explain: Difference between 4" lift and 2.5" with 1.5" body lift
- OR-FAB Rocker armor PICS
- Budget kit or leveling kit and what kind
- Lift and components ordered today!
- SPRING question
- Adjustable front track bar length
- Idea on spare tire in cargo area of 4 door.
- Opinions of the OR Fab stinger bumper
- 35 inch tires and a factory spare
- Bicycle carrier on OR-FAB tire carrier?
- New Wheels?
- Tactical Black, or not?
- Bumper and tire carrier
- RK 3.5 Max Travel w/ Fox 2.0 IFP ?
- load E tires
- Annoying squeak coming from undercarriage - Help
- Soft Top/Accessories Questions
- I've searched, but need lift help
- Rookie ball joint question?
- Fun weekends always end up costing $$$ for parts....
- Leveling/Lift Kit Install Help? Davenport - IA
- Good adjustable control arms with greasable Johnny joints?
- Hide that ugly window mount
- I have $1000.00 to spend- which bumper/rearbumper/krawlers? Durable/light/comb?
- Dip vs. Rhino: Pics, pros, cons
- Toyo open country 37x1250x17 pull to the right?
- LOD Door Linked Tire Carrier Question
- Re-gearing for a Newb
- Rubicon transfer case
- First Impressions - Hankook Duratrack ATM
- New swaybar links for 2.5" lift?
- Need help quick! Manual Transmission will not shift
- Best tire for mixed use?
- Nitto 35 tire question
- 2011 and up front brake line bracket removal???
- Need ideas for Aux switches...
- Front Pinion Seal
- Are Nitto Dune Grapplers 315/70/17 any good?
- rough country "xflex "
- Src rear bumper with tire carrier
- rock rails for 2012 JKU Sahara
- ACE rock rails
- Muffler confusion!
- how much weight did it take to balance your 35s
- New D44 axle Cs
- 2012 jku stability control light on.
- I spent some time with my jku this weekend
- Question on replacing rear driveshaft
- "New" Benchmark Designs Oil Pan installation question
- Coast Rzeppa Driveshaft Reviews
- Loud pop. Please help.
- Smittybilt SRC rock rails...
- Best deal on ACE Rockrsliders
- Fog Lamp Installs - help - rock crawler bumpers
- Budget Boost real world
- EVO 1/4 Pounder install question
- Need advice re: rubbing
- Genright Tie Rod
- Finalizing my lift project, what am I missing?
- advise on putting rubi coils on an X
- Tire PSI Help
- Need help with tire pressure!
- Tie Rod
- Help. Flashpaq shift point mod
- AEV Pro Cal or Superchip Flashpaq?
- Should I carry a spare tire?
- Gearing Woes
- Under Body Paint
- King 2.5 Bypass Shocks Fitment Issue w/ possible solution
- Driveshaft Play with (multiple) videos
- How i fixed my rough ride
- Help, steering stabalizer!
- Help diognosing noise...
- Prerunner Wheels
- Bestop Wraparound Windjammer Problem
- True tire sizes
- lift advice anyone please:-)
- Remove crash bar?
- NEW smittybilt mod stinger bumper
- 36x13.50x17 will they fit
- While my JKU was at the dealership...
- What is the most true measuring 35s
- How flexible should CA heim joints be?
- I found a piece of steel and made a high lift tailgate mount
- If you have any Rough Country parts please read!!!
- Need help choosing wheels
- Finally time for my upgrade, heres what I'm planning!
- Poll: Install now or wait?
- First time owner needs advice
- Front or Rear Locker First
- Mopar 3" lift with Fox socks
- Sahara Front Fenders
- My JK is "Walking"
- Rattle can help
- Alignment procedure
- Need a rear bumper w/2" receiver, 7-pin, carrier, Jerry cans
- removable fenders
- Suggestions on 35' tires!
- 2012 Rubicon, teraflex leveling kit questions
- Best AT 33's?
- Coilover vs standard sping lift
- Wheel Spacers for 35" Tires
- Fix crack in hard top??
- Bushwacker hood guard, bug guard, or hood bra?
- Wheel weight question (alloy vs steel D window example)
- AEV. TF. RC. SL. Too many lift options...need help/advice!
- Suspension part that has the biggest impact on road "feel"?
- Pic request
- Brake pads need to be replaced....
- 2012 Rubicon Sway Bar Disconnect
- Fuel Revolver Wheel
