PDA
View Full Version : Modified JK Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 [126] 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296
  1. Installed...5.13 gears and Expedition One rear bumper
  2. Programmer dilemma
  3. White Bedliner?
  4. Shocks for aev 2" bb
  5. Coilover suspension worth it?
  6. crush sleeve
  7. 2012 4" Lift, Slight Left Pull
  8. Mounting hardware size for Rubi rails
  9. GForce chips
  10. MPG Results - Highway for 740 miles
  11. Desert Driving
  12. 2011 Jeep Wrangler HID Fog light kit
  13. Mamba m7 wheel who has it
  14. Spare Tire/Wheel - Mount it on the Roof or Tire Carrier?
  15. Rear passenger-side knock when turning right...
  16. 37s vs 38s
  17. What is this tire carrier???
  18. Spare Tire Relocation Bracket????
  19. Cooling engine compartment
  20. Security for Winch
  21. RPM/MPH formula
  22. 2012 JK Light Weight Parts
  23. help me decide rugged ridge wheel silver or hyper silver?
  24. Speed bleeder size for 2012 JK 2door Rubi
  25. 2012 exhaust questions
  26. JKS Adj Tracbar question
  27. Help!!! Stuck on Brawler Rocker install!!!
  28. 08 jku lift
  29. Gearing Question
  30. Superchips Flashpaq for MANUAL trans. Are you happy with yours? worth it?
  31. 2012 lift kit
  32. Just Installed Hypertech Max Power, few Q's.
  33. 33's with 5.13 gear question...
  34. Newbie needs help from one/all of the many JK gods out there!
  35. Duratracs
  36. What gears do I have?
  37. Tera Flex 2.5" lift wheel spacer
  38. *please help!!* brake line issue
  39. What's your treadwear life?
  40. Tire and Wheel Packages
  41. Lockers on a Sahara
  42. Rattle noise
  43. Best lift and what makes it the best
  44. need suggestions to fix my spring sag? if i have it
  45. New JK owner, What lift is this??
  46. New Tires
  47. Wheel and Tire advice
  48. TF exhaust spacers installed - issues
  49. 2012 Lifting Clarification
  50. Best place to mount ARB (air compressor) CKMTA12 on '12 JK (not the single/EVO)
  51. Back Windows Tint
  52. How to find gear ratio on a 2012
  53. Upgrading to 35" tires with 2.5" lift and 4.10 gears
  54. Need help light bar
  55. question:what is the 'real' backspace of a rugged ridge wheel?
  56. Rain/water proof when topless?
  57. 12' JKUR 2.5 in lift
  58. Is it ok to remove rear trackbars relocation bracket?
  59. Who makes these mirrors?
  60. 37" tires on 2.5" lift
  61. Rock Krawler track bar issue
  62. Spare tire inside jk
  63. Sway bar causing death wobble?
  64. Wheel spacer question
  65. Ball joints
  66. Steering sector shaft braces.
  67. are bfg krawlers louder or quieter than nitto mud terrains
  68. Need Help! Old Drag Link won't come off!!! middle of install.
  69. another tire tread
  70. Gforce chips
  71. Fiberglass Deck lid...JK?
  72. 5.13 gears on Dana 30
  73. Can u move the ss mounting bracket?
  74. Official “MPG” Database
  75. mod to rear interior for storage etc
  76. locker in hi Vs traction control
  77. dropping tcase down
  78. 2 inch BB with SRA's
  79. another question about camber...
  80. Everybody running RC 4" on a 2 door please read!!!
  81. 2dr mopar add- a-trunk in 4dr
  82. Intallation Daystar Switch Panel 2011+
  83. Driveshaft?
  84. Rock Hard License Plate Relocation Bracket
  85. thinking about buying a snorkel
  86. Teraflex leveling kit 1155200
  87. Winch line attached to yoke attached to hook - how to remove yoke?
  88. Half/Tube Doors - lets hear it...
  89. Question about suspension
  90. Bestop Trektop Hardware issue
  91. AXLE swap question !!!
  92. Which warn winch would you pick?
  93. Hood mounts for my jack
  94. Pricing advice on Open Country MT
  95. Finally installed!
  96. Pro Comps - 7036 Black? PICTURE REQUEST and questions?
  97. Anything similar in 17" version of the cragar street locks?
  98. anyone using Cooper ATP tires?
  99. What's it take to put hooks on a non hook stock JK bumper?
  100. 2 sets of tires and rims
  101. Control arm/caster question(s)
  102. Running JKU Mopar Sunbonnet all summer
  103. Rubbing issues with 4.75" backspacing on a 17" wheel running 12.5" wide?????
  104. Got a 2.5" to 3.5" lift plus a winch? I need a measurement please...
  105. Need advice: WARN VR10k vs. Smittybilt X20 10k
  106. 2012 w/ 35's and 3.73s
  107. RK 2.5 Max Travel........Bumpstops?
  108. 2012 JK Gears
  109. 2.5 spring lift or budget boost?
  110. frame mount points for rails
  111. Front drive shaft help
  112. BRAKE PADS & rotors???
  113. Rear bump stops and damaged bump stop mounts(?)
  114. White Letters OUT or IN? Opinions on the pic
  115. general grabbers srl
  116. 4:88's Or 5:13's
  117. Warn Elite Bumper (87750) Installation Problem
  118. first report on new tires
  119. Lug size
  120. Exhaust help?
  121. New AEV 2.5 v.s Rock Krawler 2.5 Flex
  122. Newbie with some Mod questions...
  123. Warn 9.5 Ti bolt size?
  124. Jks rear trackbar rubbing coils
  125. Thinking of replacing my 3" BDS lift
  126. Performance/driveability mods
  127. New coils
  128. Does changing the gear ratio with aftermarket tuner/device actually matter?
  129. Need advice on tire size, gearing, and problems associatd with upgrades.
  130. the annoying suspension question!
  131. how do you keep your lights yours?
  132. Swapping lift
  133. 2012 JKU Lift VS warranty
  134. Crown or moog tie rod end es3426?
  135. will it work: Dana 44 + 35" + 6.4 Hemi
  136. 33"vs 35"
  137. Stubby Bumper Tow Loop D-Ring Bracket
  138. 2008 - 3.73 - Auto - HELP!
  139. Rear drive shaft
  140. 4" pro comp lift with coils and shocks only.
  141. Weight difference on tires - big concern?
  142. i need to know where this goes! i think its a track bar relocater
  143. Anyone have an opinion or any experience with RC front control arm relocation kit?
  144. Springs with least sag
  145. Air Intake and Exhaust
  146. Need info for 2.5-3" lift
  147. Suggestions for first mod to JKU Arctic Editon
  148. high flow water pump
  149. Pics oj jk's with leveling kit
  150. Pulling the trigger on lift, couple questions
  151. 2012 mw3
  152. What do I need to run 40 inch tires.
  153. Leveling kit question.. Realignment?
  154. Gearing Question
  155. Bushwacker flats and fading vs. elements
  156. Which rails/sliders should I get?
  157. 4.88 gears ?? help
  158. hose clamp post i can't find
  159. 4.88 disapointment
  160. Front end gets loose when weight is off
  161. Shock ?
  162. Steering stabilizer the culprit of a shimmy?
  163. OME HD lift & brake line question
  164. AEV Procal question
  165. Aftermarket rear bumper w tire carrier with a 2 inch body lift?
  166. Rock Krawler 3.5"
  167. 35s minimum lift on a Ruby JKU
  168. Gear Question
  169. Rear end not flexing
  170. Best STREET Shocks? Looking for a SOFT Ride
  171. winch running
  172. transmission cooler by dealer
  173. Rough Country Springs and Bilstein 5100s?
  174. 35's - MT/R Kevlar vs Pro Comp Xtreme vs Cooper STT
  175. using Teraflex hardware kit with JKS quick discos to hold swaybar up???
  176. good deal on RE 4.5" lift springs
  177. gears for 2012 jk
  178. Lift Size
  179. Steel wheel question
  180. Silver jk with black rims
  181. Popping noise after diveshaft install
  182. 4.88 with 35s
  183. BUSHWACKER POCKET FLARES - Is there a bumper that meets the flares at the corners?
  184. Loose trac bar and stabilizer bars?
  185. New AEV 2.5" DualSport XT Suspension Lift Question
  186. Steering stabilizer
  187. Best Differential Cover
  188. Break Lines
  189. need mod recommendations
  190. Locker Switch relocate
  191. Anyone heard of trimming JKU trans bracket?
  192. Advise on new 2012 sport 2 door
  193. EVO draglink flip kit, will it work with...
  194. What is causing this 40-50 MPH shimmy?!
  195. Need advice on a setup
  196. Interco tires first impression
  197. Bumper installation question.
  198. Olympic Tuff n n EZ tire carrier....
  199. Soft 8s
  200. OME LT or not?
  201. 2.5 Max Travel Control Arms and Evo LinxLok
  202. need help with TF 2.5" install
  203. No muffler on my 2007 jk
  204. Where can I get Goodyear MTR/K 40x13.50r17?????
  205. Teraflex 2.5" Lift Question
  206. Spare tire cover options?
  207. Rancho exhaust
  208. Beadlocks
  209. Upgrade help
  210. aev lift
  211. Help me spend some money
  212. RC 2.5 BB = bump steer
  213. Poison Spyder Bolt-Together Trail Cage Kit - anyone run it?
  214. Help!!!!!!!!!!!!!!!!!!!
  215. V8 Engine Swap
  216. Help with teraflex lift
  217. Aev/bds/ome
  218. Teraflex Leveling kit discontinued?
  219. anyone tried these shocks?
  220. Dynomax 17263 OR Dynomax 17230???
  221. AEV Pintlers with Deep Water Blue Pearl JKU-Help me Decide Please
  222. Sudden Death Wobble this am....
  223. Weight of wheels
  224. Weight of wheels
  225. New Shoes
  226. Clunking noise when on 4x4
  227. 242 on JK
  228. what size tires on xd cranks 17x9 with backspancing of 5
  229. What can be expected with 35s?
  230. 33s to 35s questions.
  231. Real world tire size data
  232. cam bolts how do they work
  233. Can you convert a Sahara Transfer Case into a 4:1 ???
  234. Front Drive Shaft Swap Question
  235. 2.5" rough country or teraflex?
  236. Tightening the Sway Bar Links
  237. Pitbull/irok/MTR/Toyo MT's
  238. Cargo Restraint System (CRES) by Smittybilt for Jeep -- need help before I buy!!!
  239. Best shocks for 1-2" Lift
  240. Cargo net
  241. 15" or 17" wheel? w/ 35" MTR Kevlar
  242. So I got a 6.1L with all running in a bench! HEMI JK project
  243. Been-There-Done-That Guys: I Need Advice on Lift, Tires, Bumpers, Winch, Swaybar
  244. hot oil light
  245. What wheel size?
  246. Gunmetal or Anthracite wheels
  247. Stock gears with 37's??
  248. Mesh/Net Seat Covers
  249. What do you know about rear sway bar links?
  250. 5.13s with 32s???
