View Full Version : Modified JK Tech
- 3.5" AEV - Which hole on the Geolocation bracket?
- Help - ARB RD157 install in a Rubicon Dana 44 housing
- Rocker Armor, what do you think after installation?
- Teraflex 2.5" Budget Boost Concerns???
- Northern virgina shop
- Teraflex Big Brake Kit Install Question/Problem
- Which hitch?
- Pulling left / rear axle not centered
- Springtail Solutions M-Pac MOLLE Side racks
- Flat black wheels fading/dulling
- Rims
- Blew up rear brakes
- Issue with Bestop Highrock 4x4 Oversized Tire Carrier
- Supercharger Tech: Should You Intercool Your Charged Air?
- Shocks with TF Performance Kit
- Armor for a 2013 JKU
- 17s to 16s inch rims
- Stock brake system VS modified brake system
- Newbie suspension question
- Code P0218 2009 Rubicon
- Duratrac sidewall proof
- rubicon express lift
- Question about Teraflex adjustable track bar and alignment issue
- Will new rear coils cause problems?
- Vertical play in front driveshaft
- New Ball Joints?
- Gears+mph+rpm
- Tires suggestions
- Using programmer before/after inspection
- Nasty wobble
- LA front/SA rear
- Will synergy draglink flip fit my aev lift
- steering shake
- Trying to decide between these 2 exhaust system. Any advice appreciatted.
- Bestop trektop question
- Powertank under rear seat options
- need recs for a transmission cooler for 08 rubicon aut0
- Door hangers
- 35in tire paradox....
- Cargo mat for 2015 rubicon
- Any feedback on Flowmaster Force II Cat-back Exhaust System for the 3.8
- Synergy Drag Link and tarck bar Review
- Beadlock threat
- 6.4 Hemi Tuner
- 33" on 20" rim Tires
- THINGS TO KNOW WHEN GETTING 35s
- JK8 thoughts
- Tramp stamp third brake light
- dana60 hub/bearing regreasing
- Stock rubicon wheels
- Superchips Traildash Settings Questions... Go
- Fender flare options
- Speedometer drops to zero occasionally while driving
- power steering issues
- Drive shafts
- Warrior Products front bumper. Quality/Thoughts?
- Front Passenger Hard Brake Line
- Looking at dash top consoles , which do you prefer?
- Time for new tires
- Black mountain bumpers
- 35s and no lift?
- teraflex mount broke loose
- Tailgate table
- What warning signs should I look for!!!!!!!????
- Can anyone identify this ski rack?
- shock downward travel. how much?
- What do I need to ask this guy?
- For the Fuel Trophy and Anza owners
- New wheels needed for lift kit?
- I'm soo glad I decided to go through my winch!
- Wheel swap
- 4" lift on 35's
- Driving without crash bar
- 17x9 0mm or -12mm offest?
- My thoughts on the Superchips 3872
- Metalcloak Bushing Life?
- RK lift help
- Beefing up stock Rubicon axles
- Rancho RS9000XL shocks: I'm a believer
- King Coilover Compression Adjusters
- steering wheel Shimmy
- Is it possible to realign the spare tire?
- FRESH CANVAS 2015 also ?'s
- Ladies and Gentlemen, I need some help!
- Stock shock with 2" lift = ok?
- Its Finally Here, LoD Jeep JK Patent Pending Roof Rack!!!
- Rubicon rock sliders
- Hardrock 4x4 harness bar for front seat
- aev style snorckle and light mounts
- Traction Control
- Couple questions about stock rims and lift and tire size.
- 3.25" lift, 37s and stock flares. Can it be done?
- Why 17" wheels over 18"?
- Need help Tie Rod/ Drag Link
- ARB air locker issue
- Leaving the front and back wheel wells out?
- digital oil temp, oil pressure, transmission temp gauge?
- Another 4.10 vs 4.56 question
- 4.56 w/37" BFG MT
- Bent rear axle flange - OK leave for a while?
- Build Help
- JK lift local advice Minnesota
- 35s no lift?
- Bedtred by Bedrug
- Seat Covers that Accomodate Airbags
- Anyone Running R-SE Rear Bumper??
- RK 2.5 max travel?
- Need Photos of JKUs running AEV 2.5 XT lift and 33s or 35s.
- Problem installing ACE sliders
- Rubicon express disconnects frame retainers.
- 2 doors with 33/12.5s no lift
- Differential Cover Options
- Flashcal on 2015?
- Jks discos
- How fast is too fast? In 4wd
- Fierce Attitude MT 35x12.50R17
- anyone running poly bushings
- Metal Cloak or Rock Krawler
- Do I need new gears
- Jw fog lights
- make it tighter
- Brake upgrades
- Help identifying front bumper
- Replacing Teraflex Flex Joint and Clevite Bushing with Johnny Joints on Long Arms??
- '14 Rubicon crossbar needs to be cut off for new bumper???
- afe exhaust raspy
- Neep input on water rush noise in pentastar JK.
- skid plate question
- Are E rated tires always too stiff for a JK?
- Teraflex w/ 33s Pictures!
- Exhaust
- Stuck on a Quadratec Winch Install
- River Raider Sport Cage Prep...Disaster Strikes
- anyone ever seen these??
- step rails
- Raceline Simulated Beadlocks questions
- Brake Tech: Bedding Brakes
- Duramax tow mirrors on jeep jk
- Any reason not to get an ARB twin? - CKMTA12
- Centerforce Clutch Rattle?
- D44 or PR44?????
- JK Inner Fender Options
- Mo970
- 2001 hummer H1 VS 2014 jku Sahara
- 4" Long arm fit 40's?
- Track bar question
- Steps that fit over stock rubi rails?
- Mud Grappler Mileage
- got a chance too mess around with the new lift 3.5in gc
- Best price on 35x12.50x17 MTR/K?
- Hard top hoist
- Death Wobble after tire rotation??
- Lubricating Control Arm Bushings
- Strange Noise After Vacuum Pump Reloc
- Rear shock mount driver's side rusted through.
- AEV Gen 2 Snorkle does NOT fit into Original Air box HELP
- Help! No power!!
- loose front shocks?
- Ace gate plate with 3rd brake light...
- California Side Mirror Laws?
- Axle question
- Seals around freedom panels??? HELP!
- Tire carrier
- If you have Nitto Trail Grappler MT 295/70R18, what is weight & installed hight?
- Teraflex 2" leveling kit advice
- Does anybody know what rims these are?
- New Poison Spyder Aluminum Flate Fenders - to paint or to polish?
- Need Computer flashed.......set Flashpaq back to Stock?
- Axel housings
- Help with lift options on wife's 15 JK!
- 2012+ Transfer Case Help Needed ASAP!!!
- Engine break-in
- Best aftermarket clutch
- Drone Free Muffler
- Another Body Armor tire carrier latch fix
- Spectra Air intake systems?
- Ruffstuff long arms
- Limiting Strap Setups. Requesting Pics/Advice Please
- 2.5 Teraflex spring lift
- Wanted to share some info on stock vs modified characteristics of our JK
- 2014 Sahara tuner.
- Help with new tires
- AEV Procal and 2014 Rubi
- Looking for opinion on cost of lift kit installation
- AFE Mach Force XP Exhaust System Installation on Jeep Wrangler JK Dyno Results
- Rick rails snapped bolt
- Sprintex and CAI
- Resonators
- 37" on a rubi springs and tf budget boost
- 2.5" lift question
- New off road tires with the mountain snowflake symbol.
- Smittybuilt src side armor problems
- Axle Tech: What Do Axle Splines Do?
- First few minor modifications for new JK owner and looking for opinions
- I need a new transmission ... and advice
- Raditor Replacement
- Artec Armor Axle Kit
- Want to make a lift kit recommendation?
- One way exhaust valve?
- modified hard top
- Am I sagging too much?
- Looking for aluminum fender ideas...
- EVO Rock star skids help.
- regearing installation question
- Hood prop picture
- wheels and bumpers
- Auto - 3.6 w/ 3.21s vs 3.8 w/ 4.10
- JKU Full Cage Suggestions and options
- The Bushwackers are toast, just ordered Poison Spyder front and rear fenders
- ARB diff cover, do they hit the track bar?
- Rack system
- New Tires!
- Question about cutting pinch seam and rubi rails
- Fox vs Fox (steering stabilizer)
- Transmission Just Crapped Out On Me - Had To Get My Jeep Towed :( HELP!!!!
- Replace stock shocks?
- KM2 and actual tire size...
- What psi do you guys run
- Tailgate Cargo Solution...
- Ramsy HYD winch
- Airlutions brushless motor forced air intake
- 6.1 hemi install need to identify tube
- front JKS trackbar broken
- Thoughts on FOA coilovers
- Painting Poison Spyder Crusher Flares (Cost & Application)?
- Teraflex adjustable tire mount cracked
- HiLift Jack mount
- cant find my spark plugs
- Upgrade to d44
- Rubicon express lift question
- Cure for tracking on the Highway???
- steering is a little squishy. Pitman arm issue???
- G2 core 44
- Poison Spyder Diff Cover Install Issue
- Steering wheel shakes need help
- Bumpers with HiLift holes?
- Metal cloak is having a sale!
- Headers
- 7° caster ok if modifying axle?
- drag link ends
- Jk suspension..
- Highest tire size
- 2" Rancho lift, 16" Pro Comp wheels, and 315/75R16 DuraTracs - will this combo work?
- Front driver coil spring rubbing
- Traction control kicking on when turning right?
- down-sizing 35" to 33" tires worth it?
- 50 " light bar and soft top
- Tires....
- Raceline beadlock rims
- questions about adding a 2.5" budget boost lift
