View Full Version : Modified JK Tech
- MOPAR 17" Wheel Backspacing???
- I Have A Dana 60 front axle, and rear 14 bolt already built need answers please
- what is a draglink????
- Evo Rock Stars skids w/ TF leveling kit
- Front Lower Control Arm ( To Buy or Not to Buy)
- Teraflex BB problem or installation problem?
- Yet Another superchip question
- Best Dif cover
- Aero 2525 Muffler
- 4:88 manual trans 37's??
- Bestop versus MOPAR soft top window bar??
- New wheels and tires now I need fender flares
- 2 inch BB vs. 4 inch lift
- Where to buy Superchip Flashpaq ?
- Advanced Transmission tuning for Superchips
- Make Stock 4dr rails for 2dr? Worth
- Alright now I'm confused about gears.......... AGAIN
- Lift kit thoughts
- NEED ADVICE on SKID/ARMOUR...........
- Hi-Lift on a Rear SRC, anyone do it?
- Detroit True-Trac ?
- tire width question
- Front Axle Housing Reinforcement
- Help my stock JK get unstocked!!
- Katzkin Leathers?
- Popping noise after budget boost
- 345/75r16 km2
- 5X5 to 5X4.5 wheel adapters?
- 2" spring lift - Max Tire size???
- Steering shaft hitting headers(banks) after lift.
- 303 Aerospace Protectant - Awesome stuff!
- Ball joint noise
- Newbie: Just bought my Full-Track 3" kit anything i need to look out for?
- What do you do for your pups?
- Trying to choose between 16" and 17" wheels for 35" tires (or Moab's with spacers)
- Squeak Squeak..........
- Can I add 1.75" spacers to 4" lift?
- Coil spring replacement?
- Trying to See what everyone Thinks??
- The Game Plan??
- How to fit 35's for every budget
- Help! Popping/Snapping noise coming from rear end!
- DIFFERENTIAL COVER/SKID/GUARD recommendations?????
- Anyone know of an 18" steel wheel?
- Warning! Rugged Ridge XHD Rear Tire Carrier Metal Breaks!
- Question on 285s again...
- Best All Terrains
- Rear tire carrier question
- A Stock Clearance Measurement
- Rock Sliders
- Check my lift kit
- Rock Krawler Advice Needed ASAP
- Off Camber Fabrications - Spare Tire Reinforcement Kit?
- Question about Superchips programming - return to stock
- Leveling Kit Worse Case Scenario
- new axle u joints
- Budget Boost caused Death Wobble for me...now what?
- 2008 2-Door JK Lifting
- What's on your Jeep to-do list?
- are 37 inch toyo mts aS GOOD AS BFG KM2S AT MOAB
- Fender Flare ?
- corbeau front bucket seats in!
- Shovel
- Third brake light options
- Biggest tires with the smallest lift (Rubicon Unlimited)?
- Steering Assist Cylinder Bracket
- Do I need to raise the track bar
- Has anyone seen/made/bought a.....
- going from 33" baja mtz's to 35" baja mtz's worth the 400 dollar upgrade?
- Which Intake? Chip?
- Help with Backspacing
- Loose, Loose, Loose steering after my new lift.
- Superchips users...did you change the temp the fan comes on at?
- TOYO OPEN COUNTRY M/T vs ?
- Took the JK on a 3 hour road trip felt like the Jeep was all over the road..
- Front (Only) Locker
- Rubi vs. Sahara/X sway bar
- teraflex ?
- Ready for some comfort.
- Grinding my calipers this weekend. First time using an angle grinder!
- Tires rubbing on XHD end caps at full tuck/turn
- 4.88 or 5.13's which one do I get?
- Anyone Running 33's with OME 2" lift?
- Fender flare modification - cropping "DUMBOS" ears
- Pro rocks 44
- my axle is crap
- Well I got the DW today
- Exhasut whistler?
- Coil spacers / body lift and shock suggestions
- Help: TeraFlex kit and new tires/wheels
- need help on rock rails
- 5 inch lift
- BOBBLING from the TAILGATE
- Skyjacker Dual Steering Stabilizer
- Wheel Sizing Question
- Teraflex 2.5 coil lift
- Rebuilding CA Joints
- Gear Question
- River Raider Skids
- Reccomend me an aggresive 35" MT
- readylift leveling kit
- Steering Stabilizer Recomendations
- Cold Air Intake Users Only
- 4.5 inch lift but I still hit bottom on a bump....on a paved street....is this OK?
- Axel truss???
- Axle sleeves or Trusses ... which one?
- What can I do for tire coverage so the police stop breaking my balls
- Modified JKS Front Track Bar
- Stock intake or cold air?????????
- pics of my stock JK and my master plan for it.....
- Strongest front track bar ???
- need a little less wimpy of a horn...looking for deep sound, plug and play.
- i want a wild boar rack!
- ride quality
- Throttle Body Spacer????? Worth it? or not?
- Did I Jinx Myself
- Wipers and Flashpaq issue
- Rugged Ridge Front Skid Plate - problems for 2010 Wrangler
- help me make up my mind?
- Gear swap PROBLEM!
- steering help
- bds 4.5" long arm kit
- pro comp wheel problem
- Rancho Drop Bracket Removal Questions
- Tire Pricing
- Anyone replace JK backseats?
- Bumper decision help, LoD VS. Rock Hard
- Help me pull the trigger on a superchip!
- Recommended PSI?
- WTF blew up my gears! Only got 10 feet after the install
- Need some help choosing tires Please
- Steering Stabilizer Rubbing?
- Stock airbox on K&N CAI intake Tube???
- Lange QD Mirrors
- Hybertech or Superchip
- JK Fenders
- Yakima SpareTime Bike Carrier
- Mods for 2011 JK Rubicon, 37s, etc
- Black JEEP logo for front grille? Can't find this anywhere! Also, doing a few mods!
- Down to two wheel choices. Help me make a decision????
- '10 jk running 15" rims?
- Tire help
- ESP Question
- Well one mod done and more to go. On-board ARB Air Compressor
- Rancho Rear Bumper/Tire Carrier
- 4dr Driveshafts and 5.5" lift
- ARB front bumper & skidplate?
- Lod front skidplate install?
- Re-Gear Question
- Suspension Company Discounts
- ROOF RACKS help!!!!!!!!!!!!
- 16's vs 17's Tires and Wheels
- how much lift did you get
- Daily Driver's
- Stupid Gear Question
- will 37's fit on stock 17's?
- Pro Comp 7005 / Rugged Ridge 15301.01 and TPMS sensors
- Detroit Locker Swap
- Pulled the trigger on GY Dura Tracs
- Which CAI is best??
- engine knock???
- Looking for a new muffler. Suggestions?
- Rock Krawler Drag Link
- What would I need to do to make 37's fit??
- Bushwacker / Rugged Ridge Cowl Scoops...
- How high, Unlimited
- 3.73 gear ratio and limited slip
- control arms
- 08 JK x Pro Comp Stage 1 4" lift kit question
- 3.25" lift kit for $400
- Heavy Duty Springs
- Body Armor Extreme Rock Rails
- Door Hinges
- Dont buy a Gibson Exhaust
- Your opinion on oil pan protection
- Screamin Demon Ignition Coil ? anyone ?
- JKS Quicker Disconnects and brake lines
- looking like CRAZY for the roof rack mount!
- Looking for a lightweight solution
- Factory and G2 Ring and Pinion Problems?
- Axle Seal Help, Please...
- Question regarding new shocks
- Anything else i'll need?
- Factory Rake - Any real advantages?
- Want to remove fuel line on engine.
- help needed
- Calling All 2010 JK Unlinited Gobi rack owners
- Bedlining the back of the hinges? Your thoughts please.
- Easy on/off surfboard rack?
- Wrangler Duratrac or BF All-Terrain T/A KO? 275/70/18
- Dumb question... Kind of
- B & M Tranny Cooler location???
- Rugged Ridge XHD VS LoD bumper.
- XRC Tire Carrier
- Disconnects...Do they make any noise?
- LOD bumper, textured vs. matte finish
- cant get door hinges to line back
- Tereflex steering Damper
- low budget- control arms or rock sliders? 3inch lift
- Driveshafts
- Putting an order together
- Goodyear "Duratracs Mileage Numbers"
- Difference in Wheel offset adapters
- Aeroforce Gauge Problems?
- Will a thicker rear sway bar make the back less tipsy and bouncy over bumps?
- Anyone replace their drag link boot?
- D-ring mounts on stock bumpers
- Spidertrax Installation question
- Owners of Element doors. Think it's possible to thread the hinge pin?
- Smittybilt. I dont think I am going to give them another chance.
- 33x12.50 or 33x10.50?
- Rear Tailgate
- Where to mount Smittybilt Dual Cylinder Air Compressor ?
- PSC steering w/ 6-speed
- PRESS RELEASE: Full-Traction 3.0″ Premium Plus SRS™ Zero Maintenance Lift System
- BFG Krawlers?
- Coil spring shift
- 16 or 17 inch wheels??
- Gobi Racks and kayaks
- I know this is for Jk and that we have a wj section but the info will still transfer
- Help! winch for Shrockworks mid-width front bumper
- ideas for mounting mag lite
- Experienced first death wobble
- Snow tires?
- Water temp gauge help!
- Building our 3.8
- ask for wheel and need pics steel blue with addict(black)
- EVAP skid plate or relocation???
- Wheel Spacers, which size to get? 1". 1 1/4" or 1 1/2"
- Springs & LCAs--help me decide!!!!
- Superchip and TPMS
- Body lift and tire carrier swingout alignment?
- Is it ok to have a little play in my front track bar?
- Rear bumper, HELP!
- 3 inch teraflex lower control arm not lining up
- Suspension noise/rattle on bumpy roads?
- Quick question about wheels
- Trimming the LCA axle mount?
- Fab Fours full width bumper and lights
- Dark Charcoal - Best rim colour?
- Dark Charcoal Jeep Rim Colour?
- Aftermarket DS Flange making contact with Fuel Tank Skid at t-case side
- Newbie question about re gearing
- Advice Needed PLEASE!!! what is needed after gear install???
- Rancho 4" lift kit
- Looking for a 2.5-3.5"ish lift for my '10 4dr Rubi...help
- Problem with Teraflex leveling kit installation
- ordered 35s,they better fit,lol
- Gerry can
- will evo axle sleeves work wth rcv axles
