View Full Version : Modified JK Tech
- Which winch ? Electric or Hyd.
- impatient....
- soft top insulation - any ideas?
- 17x10 2.5'' backspacing fit???
- milspec front dana 44 or d60
- Clayton Flip link kit
- Rough ride with new lift?
- Longer shocks
- Disco question
- Bent steering stabilizer bracket?
- Best upgrade for 350 - 400 bucks
- 2.5" coil lift and e-discos
- New Gears Comming
- Long Arm
- ARB locker installed in front or rear first?
- How about this idea
- Check out this camo! what will they think of next...
- tinted windows metal half doors ?
- what is biggest tire size that stock axle can handle
- EVO axle sleeve seals
- Are there any programmers that work with 2010's?
- Jack mount
- jks ACOS adjustable coil spacers
- Start Out in 1st Gear in 4-Hi?
- Spare wheel and tyre.
- Anyone out there with WARN rockcrawler with tube guard?
- Best Steel Fenders?
- Anyone running the EVO Sector Shaft brace?
- Anyone have EVO Rockstar skids?
- Lift Kits and Swaybar Disconnects
- 4.25" Backspacing on 17's beadlocks possible?
- Spidertrax spacer install question
- TF 3" or TF 4" for Unlimited on 35s?
- trek top question
- mods now
- TeraFlex 2.5" BB Shocks vs. 3" Full Flex Shocks
- Beadlocks
- Whats the diff between rock guards and sliders
- MBRP exhaust T 409 muffler relocation
- Quiet Performance Exhaust
- Need help with lift....
- what if i want but dont know... need help ....agaiiiinnn!
- Greasing Teraflex Control Arms..
- 2" pucks with stock shocks, bad?
- Regearing JK Rubicon
- What is the BEST order of upgrade jobs
- newbie exhust question?
- JK frame
- Rock Sliders
- Synthetic line exposed to dust
- Diff Cover Purchase....David is the Man!!!
- Winch: is it a good deal
- JK frame
- stubby or mid width???
- Spring Question
- Transmission swap
- need advice
- OME lift installed, what happened?? WOBBLE WOBBLE
- RIPP supercharger and snorkel?
- Tracking a Rough Country 2.5 Coil Lift
- is it smoother if.......
- TF 2.5 BB install
- Question...
- nology vs Granatelli (spark plug wires)
- back spacing
- 33x12r17
- Teraflex BB 4dr vs. 2dr
- smittybilt xrc & src tire carrier whats different?
- supercharge or not?
- Springs - Progressive v's linear
- For those running the Teraflex HD Trackbar..
- $ 2,700.00 + deciding on a lift = ?
- RC body lift question
- smittybuilt tire carrier? any good?
- Will truck bed liner hold up on a bumper?
- help with esp,abs,tc, lights
- Hi-lift rack on a stock bumber
- 17''or 16''
- Maybe its new driveshaft time??????
- Need Skid Plate for a lifted Rubi 07 4 Door
- skid plates for Long Arm Teraflex
- BFG Mud KM2, wich size ...help
- Ready to replace my front D30 assembly with something stronger - Need Advice
- What's better...
- READY LIFT BB vs TERAFLEX !
- Manual - Auto tranny swap?
- Red Rock Fab DIY rock steps
- best bump stops for setup
- Lod Rear Bumper Question - Rear tire secure?
- stock wheels on 2" lift will it work?
- Rock slider help
- 4" Lift + Stock Brakelines
- Can't afford gears
- Diff cover opinions..
- adjustable track bar : need help
- Rear Ended Again
- Help with Teraflex Lower Control Arm Noise after install
- Rock slider / side step suggestion
- Steering issue
- Installing Differential Skids Heads Up - Prepare for Leaks
- Tires?
- 295/70/17 Tire Question
- plugs and wires
- Rough Country 2.5 Coil Lift Question with pics.
- aev hood owners.
- Am I ready for 37's? A few ?'s
- Could be wrong GAs mileage ?
- Winter Off-road tire
- Bikini / Safari Tops
- What Air Filter? K&N or Mopar?
- Winch plate for a stock bumper
- Synth. rope and winch
- Wheel Spacers causing esp problems?? with tera 2.5BB
- ESP,BAS, Traction control lights
- Backspacing Question
- Pro Comp MX-6 or Rancho RS9000XL
- Toe-in with 33-35 in tires
- ore gusset install
- Automatic, 2 door, 35s and 5.38s
- Trek Top Question
- Flashpaq and precvous tire correction
- Does Anyone Else Feel....
- Adjustable Shocks...pro comp
- Rock Hard Oil Pan Skid Q
- huge question
- Snorkel opinions please
- M/T's Tread issue
- Snorkel Diameter Poll
- Change position of oil filter?
- mbrb or dynomax
- Factory Fogs
- Jerry can cap
- Aftermarket brake rotors
- Tuffy Security Deck Enclosure...
- Loss of power
- Mopar rubber floor liner
- do it one time.
- Looking for a way to lock my hood
- Steering stabilizer?
- Press in bushings..
- Please don't laugh...really dummy question
- PCD (performance chips direct)
- Don't understand HP issue, please explain.
- Brake/Clutch Master Cylinder Upgrade
- Wheel Bearings bad...
- Slave Cylinder
- chopped fender question.........need advice
- Highlift Jack question
- Upgrading my stock Rubicon
- Getting ready to outfit my new JK!
- Is this bad? (lift related)
- Spring rate and ride quality
- 275/70/17 wiith no rubbing?
- Viair Compressor
- Old Man Emu Stock-Light Load vs. Heavy Load
- Where to mount my CO2 Tank?
- Thoughts on Rough Country lifts.
- Stinger Bumper
- will 15" wheels fit
- Black Rock Wheels
- snorkel
- window tint %?
- Preventing Water in Airbox?
- Other superchargers?????
- Bedlined front grill
- Nerf Bars?
- need advice
- Steering upgrade options
- ProComp Tire and Rims....are they good?
- winter tires and lift
- backspacing
- driveshaft question
- a rampage bumper + lights question
- gerry can in hardtop window?
- dont knwo what to get/??????
- low gear noise..
- Lift question?
- X Stock Axels
- evap. relocate to inside
- Can I mount a winch to a non-winch Purejeep bumper?
- Does anyone know where to buy the Maxxis Creepy Crawler?
- Skid Plates
- vibration
- Does anyone have experience with..
- tires psi and spare
- Steering Wheel Replacement
- Coast Driveline with adaptor plates
- Quick question! rotor retainer clips.
- RC 2.2 quick question
- Bigger tires on my X ?? need help Ottawa or montreal
- Ripp Supercharger Question
- MBRP SS Catback Exhaust System
- Lift Kit question "how big?"
- To those with Or-Fab gas can & tire rack:
- 2.5" Lift Question/Suggestion
- Axle upgrades, Rear vs. Front
- Yakima Rack on 2DR Hardtop? Pics?
- superchips help
- Drum access to change winch line
- Which BL?
- Has anyone seen this snorkel?
- Front Bumper Recommendation Please
- Install Time
- Help - Jeep is leaning to the right
- Teraflex leveling kit or a Teraflex Budget Boost?
- Dynatrac ball joints
- who makes these mags
- Tranny temps with the B&M cooler
- Cheap mods??
- Synthetic Rope
- Gibson single or dual exhaust??
- rough country 3.25 lift
- snorkel vs stock or cai intake temps
- How many bent front 44's long side tube..
- stock trans skid???
- Transmission Skid
- Transporting a Kayak
- Shock boots
- Fitch Fuel Catalyst
- Olympic Slider or Shrockworks Slider. Need help?
- Change pads now, rotors later?
- Mpg
- fog install
- evo gusset install question
- My 4inch Superlift kit is making my Jeep drive and feel rough.....
- Anyone using Champion beadlocks?
- Rear bumper w/ tire carrier (LoD vs Shockworks)
- Can i get this bumper for less that $1000?
- Mile Marker 8000
- Hi all.
- Money to spend
- Dana 30 and Dana 44 Knuckles the same
- 3" Center cap/plug for XD Wheels
- Question for people w/ Bedlined Grills
- Can your JK fit in the garage with a lift?
- Rough country 3.25" vs. Zone 3"
- factory warranty and a supercharger
- Using Hi-lift with MBRP rails
- need help
- Regearing a Jk
- AEV Front bumper Lights
- Drililng through shocks to bleed them out.
- increasing horsepower
- 33" wheel and Procal?
- Jerry cans ?????
- question about the RC 2.5" coil spacers
- AEV snorkel with supercharger on 09 X.
- Black Rock Wheels
- superchargers
- Teraflex Control arm clicking noise
