View Full Version : Modified JK Tech
- Gear & Locker Gurus
- rugged ridge sliders,,does any body have r just ur opinion please
- need advice on OME lift kit
- Who has installed a bar pin eliminator on their JK?
- Center Cap
- Violent Shudder after Wheel install?
- 37s first then evos coilovers/lever system
- new poll
- Cutting tube bumper
- wheels?
- HD "X" Springs vs. Rubicon Springs
- Which Lift for 2dr?
- Rear control arms
- Are these Jeep wheels still available?
- Spacer a bad thing?
- Is death wobble worth fixing???
- Front coil spacer???
- Rugged Ridge Front Skid Plate under ARB Bumper
- Hi Jack Mount off by 1" -- Any Solutions??
- Death wobble, I can't get this figured out..
- 6.5 BDS-Suspension
- Rear Bumper: Mopar vs. Rugged Ridge
- Rubbing question...
- Oh another Driveshaft twisted
- OX Lockers
- What 4" TeraFlex lift should I be looking at?
- Front Dash Removal
- INTERCO Super Swamper M16 All Terrain
- Play in front drive shaft question?
- Rugged Ridge, Husky, Quadratec, or Weather Tech Cargo Liners?
- Jack Stand Location - Lift/Spring Install
- Rancho Rear bumper/tire carrier?
- How much things cost?
- 35's, Gears, MPG, Transmision
- LoD Signature Mid-Width: Fog Light Issue
- Any news on OX Lockers???
- Specific Combo
- What is needed to run 40's???
- 35" mtz's, claws, or pro comp extreme m/t?
- bump stops
- wheels
- Need help with tires...
- $1,700 ???
- pics of 285's on stock steel wheels
- Chromoly axles: should I notice a difference?
- coil spacer sag
- Yukon 5.13s on the way!!
- Exhaust Inlet/Oulet?
- Coil, BB, Suspension Lift.
- Storage box?
- Will Nitto Mud Grappler 37" tires fit AEV Pintler Wheels?
- PICs of a 2 door with a 6"
- 2008 JK Lift
- Driveshaft Install
- Ox Diff Covers on a Rubi?
- Front track bar question
- Rough Country 2.5 Lift
- Performance Accessories vs M.O.R.E. Jeep JK 1" Body Lift
- Heavy steering
- Decisions...
- Tires
- Bumper question...
- Medalist Mud King tires...any info?
- sway bar disconnelct
- What 17" wheels with 37" tires?
- ARB compressor wiring
- help me out!! jeep shakes like crazy at 70 mph!!
- front adj track bar?
- PRESS RELEASE: Off Road Evolution EVO 44 Magnum Sealed Axle Sleeves
- Offset Ball Joints
- ome 2" lift ?
- good shock and springs combo
- MOPAR Military Spec Front Dana 44 Assembly
- Bestop Tire Carrier....anyone?
- still dont know what tire to get new poll
- Help me decide
- Wheels Unbalanced
- anyone running Wild Country Radial RVT tires
- teraflex disco/wrangler surprise
- Who makes hub centric aftermarket wheels?
- Adjustable control arm settings??
- ARB Locker & Dana 44 issue
- Mickey Thomson Weels question
- Olympic 4x4 Bumper
- 17x8 Pro Comp 7089 Rims??
- 4" Lift Questions From a Mechanical Idiot!
- Axle Manufacturers
- Transfer Case Question
- BDS 3" lift
- What color cargo netting?
- Lift Kit Help
- DIY -- brakeline extenders
- ESP BAS and steering recenter
- InterCo
- Rear Axle Wrap
- TF kits on back order... sooo what about this
- Suspension Lift "Actual Height Gain" database
- Rough Country 6'' Lift ?
- Exhaust??
- Warranty Issues
- Snorkel question
- spring rate values
- front fender mod
- dana 30 axles
- harness vs seat belt light?
- Brain Fart!
- Paint for Riddler diff. covers?
- need help with coil springs
- Swaybar disco's on lifts...
- TF 2.5 Coil kit
- Body Lift vs Suspension Lift
- arb locker modifications
- full traction question
- lift kits
- BFG Baja T/A...anybody know them?
- Recommended 2.5" to 3.5" lift for these specs?
- more lift
- JK part numbers - springs and shocks
- 4" Stainless steel step rails
- Camber bolts
- Front axle gussets?
- shock question
- Need Help Identifying Weird Brake Noise
- Anyone w/Rubi-Unlim. springs on JK-X?
- D-ring Mounts
- rancho sport brackets
- sway bar link ?
- Front Bumper Mounted my High Lift Jack
- lift questions
- How to add strenght to the front axle track bar mount ?
- strataglass???
- Driveshaft and Pinion Flange Nut question
- Alignment after a lift
- Cutting 1/8" metal bracket
- Issue with 35's rubbing...
- another tire question
- Teraflex Front Lower Flexarms, Help!!
- Soft 8's
- Wet okele's or whatever they are called :)
- Larger Gas Tank
- Good shop to do Gears in Midwest
- Put on 2.5 lift now what?
- Rough Country Spacers
- Interco IROK Bias?
- Smooth Tailgate
- Skyjacker Budget Boost
- brakes
- 33x10.5's or 33x12.5's?
- 5.5 & 6" Spring & Shock lifts
- Procal Warranty?
- Where do you put the Tag?
- Dana 44 gears-Whats the best available?
- Need some expert Help with rear sway bar Link
- Need 2in lift help
- NEED MORE PROTECTION! Any suggestions?
- wheel back spacing?
- lift and tow question
- Starting my JK Salvage Project
- Stubby or Mid-Width Stock Bumper
- OME lift - Do I need any other Upgrades?
- Yeah another DW thread
- Broken rear trackbar mount->safe to drive 15 miles?
- Rough Country lifts
- Evap canister skid plate
- Power and gas mileage????
- What kind of Grease?
- Replacing shocks...on the ground or on jack stands?
- ARB front plus LOD rear
- trac bar
- Tread Life? - INTERCO Super Swampers
- Superchips announces Jeep FlashPaq
- How long on Walker Evans wheels?
- new tires and spare
- lift question
- Rhino Lining the Interior
- Necessary Skid Plates
- Lower Control Arms..
- 4.7 to our 6 speed
- New bumper = New Hardware?
- Air Compressors
- Wheel width for 37" tire?
- Royal purple gear oil
- Seat covers
- Caster vs Pinion angle! Anyone spin axle tubes in pumpkin to set both?
- Another Newbie Lift Question
- likely a simple backspacing question!
- ProCal OBD Programmer
- esp problems after lift
- smittybilt
- Winch connection to battery
- teraflex 2.5 driveshafts or no
- Need help w/ a gear swap? 373 to 410
- Caster: I want the truth !!!
- rear winch mount
- Rear track bar
- Best deal on AEV pintlers
- Help...stubby front bumper
- Solid diff cover question
- Integrated hitch mount?????
- New Gears and Pinion Bearing Goes out
- Rear Spring install question
- head lights
- D30 center section material?
- 3.21 gears in an auto
- Banks exhaust
- River Raider flares vs. Warrior Products
- Smittybuilt Winches
- Where can i get one of these...BOARDRACKS
- Risks of failure with 33" tires -- warranty denials
- 33" M/Ts REGEAR
- Getting partial lift kit...what else do I need?
- With or without shock adapters?
- Fog=Rock Lights?
- Rubicon Express 3.5 Superflex
- 2.5 '' coil lift...
- 4 dr shaft on a 2 dr
- Sway Bar Disconnect
- ZONE 3" or 4"
- Cheapest site for RC 2.5" coil kit?
- Gas Mileage
- aFe Magnum FORCE Stage 2 Sealed Air Intake System with Pro Dry S™ Filter
- stubby bumpers that work w/ garage pro grill guard?
- Front Rubi locker in the Rear of my X
- CAI running to lean
- XDI vs. Volant CAI Need Some Good Info.
- 4" FT long arm and skid pans
- Seeking opinions for the uneducated. Tires / track bar
- a bit of a bulge?
- Which Adjustable Front Trackbar
- Anybody got smittybilt neoprene seat covers
- opinions on BDS 3" lift vs Rusty's Offroad 3 1/4"
- Got rubi D44 axles...
- RC 2.5" Spring kit
- BDS 3" vs Rusty's Offroad 3 1/4"
- RC lift and spacers
- Max tire width for Stock 18"x7.5" rims
- TF 2.5 BB kit
- How much $$$ for labor to swap out gears?
- My first aftermarket purchase... rock sliders... but which?
- can't decide...need help!
- Safari Top Mods? For fit and speed--
- Low pro mudders
- Will any 37" tire fit a 18x9 Wheel?
- Wow! a successful meeting
- Rugged Ridge tailgate stop
- Pro Comp 4" Stage II vs Teraflex 3" Elite Lift Kits
- mud grapllers or km2s
- OME 2" Install... did I break it? Help please
- Cheapest way to recalibrate for bigger tires?
- 37" Tires
