View Full Version : Modified JK Tech
- Regearing - Opinions needed
- Questions on parts for replacing clutch
- looking for new setup for a 2012JK
- Leveling kit
- Steinjager disconnects -- any remedy for the noise?
- Drop down tire carrier
- Anyone using 5.13 gears on an auto JKU?
- Help identify noise... videos
- need hole size & location for Ace cargo rack
- Stock lug nuts on Tracker 2s (need definitive answer)
- Clusterf*cked After Blowing Out Rear
- Extremely Poor Service from Hanson/Pure Jeep
- 3.8 jk traction control off
- Hemi MDS delete - how much did you delete?
- Ace engineering stand alone tire carrier sagging
- Help Critique my Lift-Kit build
- Cab Cover Advice/Experience
- Hard top damaged; need replacement rear window
- Jeep People, is it legit?
- RIPP 3.8 Fuel Economy Troubleshooting
- ABS And Traction control lights
- Smittybilt rear bumper
- Choosing a 37" tyre...
- Genright rear fender 0" fender delete questions
- New tires installed, Falken Wildpeak A/TW3s trip report.
- Has anyone installed AEV vents in a Call of Duty/ MOAB hood?
- 02 and cat not ready!
- OBD Port Cover?
- Unusual "Suspension Recommendation" request
- Spongy steering. What can I do?
- JK Tailgate Plugs
- Regear + Locker add - Pros & Cons
- Bolt Size for Rear OEM Bumper help???
- Calling any 3.6L, 3.21gear, 315's users
- What spacer thickness to use 2017 JKU 17" wheels with 4.75 backspace.
- Current Setup with Pics... More Lift or leave it and extend bumpstops???
- TPMS Issues on new 37s... is there a fix??
- Loud clunk after installing evo lcg coilovers
- River raider snorkel
- Steering/handling improvements question
- Jeep Wrangler PCM, ECM, ECU, TCM - Plug and Play - Well Below Dealer Pricing
- New G2 Gussets Pre Notched?? See Pic
- Aev precleaner
- 2012+ with 5.38 gears
- metal cloak 2.5 mid arm vs. teraflex 2.5 long arm
- Modifying aftermarket front bumper?
- Rubicon Express 2" Hydraulic Bumpstops ?
- Shop botched lift - Advice Appreciated.
- 37" Nitto Trail Grapplers, or your Tire Brand... What is your street PSI????
- Lund International-Be careful if you buy from them
- Broke Sector Shaft- Can't get Traction Control light off
- Is a Load E, 10 ply tire to much for a JKU?
- Front Rubi D44 Truss or Sleeve Dilemma with 37s..
- Front Bumper Option
- 300m Vs. 4140 chromoly..... worth it?
- Should body mount to ball joint measurement be the same on both sides?
- 2011 JKURL gearcharts dont match my info
- Driveshaft spacer kit...has anybody used these?
- Throwing lots of codes and wanted some input before Replaced every code
- Fenderless question
- JK07 Rugged Ridge Snorkel ... Fix?
- 1/2 inch spacers question
- Recon Front License Plate Cover Removal
- 2WD to 4WD conversion Transmission Question
- Is my tie rod bent?
- Grease lower ball joint
- 3.8 Engine swap from Automatic into Manual
- EVO NoLimits On Demand and ARB
- Help with Tires and Lift
- Opinions on brakes & rotors
- Question on engine swap..
- Looking for best price on ATX Slabs
- Hemi motor info needed
- HELP - Mud Puddle Nightmare
- Trimming M.O.R.E skid
- Too Tall for Spiderweb Shade?
- Geolander be Wilpeak
- What size D-rings are on the ACE hammertown Rear bumper?
- 3.73 to 4.10 or 4.56
- JEEP JK 3.8 Engine swap using Caravan motor. DIY with Pics
- Big Bore PSC Steering Gear (buzzing sound)
- Drag link set up question?
- Locking gas cap or locking gas cap door?
- Nitto Exo Grapplers
- Changing gears in 2010 JK Sport
- Inner fender gaps
- REGEAR 2010 JK Sport 6 speed manual
- Airbag and clockspring recall. Issue with Superchips?
- AEV Vs. Metal Cloak Vs. Other Lifts
- Welding on a jk
- Measuring LCAs with flex joints and bends?
- Rear DS Boot Torn But no Grease Splatter
- Hose above front drive shaft discharging water
- Jeep jk psc ram hose routing
- Teraflex Alta Rack
- Front Dana60/44 Hybrid DIY Conversion planning discussion (Fushion 4x4)
- Dana 30 Project Axle
- Seat Heater under Bartac seats?
- 2 Door Stretch Help
- Melted Dana 44.
- Nitro Gears or what Brand to buy?
- Bushwacker Flat Flares - 2/4 Door Fitment
- Have you Line-X'd your Jeep? If so, how do you like it?
- Rear locker won't unlock!!
- Correct pressure for 20" tires
- Teraflex 2.5 post install questions
- 2.5" budget boost upgrade opinions on shocks ect.....
- AEV High Steer: Loose Drag Link
- Regearing a 2007 Rubicon at 70,000 miles
- Tie rod / drag link play
- Mishimoto Is Seeking Out a 2012+ JK 3.6L!
- Jerky Steering Wheel
- Descriptive Review of Bestop Windjammer/Duster/Freedom Panels
- PS Trailgate
- Need Help With Rear Shocks
- 3.5" metalcloak or 4" evo plush for 40s?
- ISO of a Temp sensor plug. '12 JK
- Electronic swaybar problem
- Caliper grind, time for some upgrades
- Superchips
- Need Help ID'ing Suspension Mods
- Opinions on Lift kits
- pooling on trek top nx
- Procal needed for BFG ko2's?
- Superchips Traildash 2 question
- Toy Hauler for a JKU
- Stripped Pinnion Nut
- Rock Crawling = Manifold Leak??
- Team Tech Offroad S-Tech
- Toyo 35"s or KM2 37"s? Want a lil more clearance but still need to fit in the garage
- Factory Seat Issue? 09 X Model
- Tires and Lift kits
- Steering Adjustment Help
- Falcon shocks-whats the difference?
- Installed the AFE Power High Tuck exhaust this past weekend
- How to identify a lift?
- Molle pistol holster on trek armor seat cover?
- Has anyone dyed their seats?
- Creaking noise when in 4WD after lift
- Upgrade Intake or Keep Stock??
- Mismatched Gear Ratio Question
- Things I Lost in the Mud...
- Stupid front driveshaft question
- Rugged Ridge Headlight Bezel Removal
- My 4x4 SPOD caught on fire
- U joint ears hitting yoke?
- Is a long arm suspension more likely to get damaged playing in rock gardens?
- Electronic Sway Bar Disconnect?? Saving Weight
- 4.56 gear rpms
- Wheel spacers and axle stress?
- Ripp Transmission Cooler Bypass Question
- JK Passenger Airbag Recall - Dash panel no bueno!
- Question about york oba
- Installing 2.5" Budget Boost - Jack Stands
- Thoughts/Ideas going forward
- Prorock 44 Adding Hyrdo Assist Tabs to NON Raised Track Bar Bracket
- Automatic transmission cooler help
- Installed Genesis Dual Battery System
- lifted jku sagging
- Pinch seam trimming
- 2013 unlimited, modified
- Falcon Shocks 3.3 Piggyback Review
- Best track bar set up front and rear?
- Driver's Seat will not recline
- Insurance
- 37's and the on road daily commute. Coil/Shock or Coilover?
- Lets talk pinch seams.
- The big 3 or rather 4 electrical upgrade
- Help me find some fun rock lights.
- Suspension upgrade/ Rancho to MC
- power steering rebuild kit
- 2012 JKU automatic won't shift
- Aries product thoughts?
- OR-fab rear bumper with lights
- Whose found a good insurance company for a very modified JK?
- Paint or Powder Coat - EVO Hood Breach?
- Will this fit?
- Optimum Overall Crawl Ratio for rock crawling
- Best Axle Back Exhaust for Performance Gains without the noise
- Rear shock help
- Upgraded alternator options
- 2 door corner options nonexistent??
- Atlas 2-speed questions
- Reid or Rancho Knuckles
- Stock 2012 Wrangler Sport Tires/Rims
- Custom Front Mount Bike Rack
- Bump Stop question
- Next phase for my JK - EVO double throw down w/Lever system, but long or short arm?
- Rancho 7000mt vs rough country n2.0
- Anyone running dv8 fastback
- Do you know how to install an Atlas 2 speed transfer case?
- Custom interior part request! Please!!!!!!
- Coilover options for one tons
- Sway Bar Disconnects: Does Length Matter?
- Show me flag pole mounts
- Pulls left after lift 4''
- Adjustable track bars or brackets for 1.5 springs
- Red seat belts
- SPOD install help
- New Modded JK Recon in the Garage....
- Barricade roof rack squeaking
- 2.5" Metalcloak Overland Elite Suspension Question
- Shop recommendations near Santa Clarita
- Best shocks for an unlimited 4" lift with 37" tires
- Discos installed!
- Fuel Pressure Gauge
- Automatic transmission temps?
- 2008 Magnuson SC running issue
- 2013 Wrangler gear replacement
- Raptor liner exterior
- Anyone think this is a problem?
- How-To Spotlight: Jeep JK Wheel Spacers
- Speedo Reprogram vs Flashcal?
- Front runner owners...
- Spray On Bedliner for Factory Fender Flares?
- Dynatrac elite prorock XD 69/80 set
- arb compressor mounting
- Starter Help
- 2 post lift advice
- Pizza Time! Why 235/85R16 32" on 16" Steelies Work
- BFG AT KO2 vs. Goodyear Duratrac
- Can a Rubi front Tru-Lok be installed in a rear X D44 axle housing and work?
- Alignment help
- Skid Plates and HD Crossmembers
- Replacing Pinion Bearings
- ACE Expedition Front bumper - Fairlead issues?
- Hot Head
- Front upper control arm bushings
- roof rack with factory bumper question
- How to tell if wheels were painted or originally black from factory
- Need more stopping power
- Strong head wind makes jeep go backwards!
- 2015 Wrangler Sport - Which rear axle??
- TeraFlex 1.5 coil lift with Bilstein 5100 and 1/2 spacers Good idea?
- Jks vs rock krawler vs teraflex
- Suggestion
- Soft Top Replacement
- Heavy Duty axle experiences?
- Supertop NX Twill Help
- 2.5" lift on 2dr JK
- Fusion 4x4 shipping
- This Turbo Has a Jeep Wrangler Attached to It
- Teraflex Leveling Kit and Coil Compressors
- Looking for stock black Sahara fender flares
- Baja xrs vs. baja rs
- 37" Wrangler tires hitting Teraflex disconnect brackets.
