View Full Version : Modified JK Tech
- Any info on Big foot X/T tires
- Recommend an all terrain tire..
- Magnaflow Muffler Retrofit
- 5.13 Auto Unlimited Miles???
- Performance Upgrades from Stock- Priority List
- Teraflex Leveling Kit
- 3.21 gears and 35s chime in please
- Diff Cover Vs Rancho Skid?
- Back to stock?
- Xenon Fender Flares and Fabfours rock sliders
- help
- O2 sensor on 2.8 diesel
- Teraflex leveling kit and Super Swamper M16s?
- Seat Covers
- 2nd thoughts about Flowmaster 50 suv install!
- Done a diff gear change yourself????
- Tire/rim switch
- TeraFlex BB to TersFlex Coils
- TeraFlex product install instruction link
- Help Choosing Tires please
- Evap canister relocation
- 37's on 6Speed Rubi (4.10's)
- 4" Lift Install Cost Comments
- Jk inside temp prob.
- Should I get new shocks after 2" spacer body lift?
- POWERTRAX No-Slip Locker
- Anyone wish you did NOT relocate SS
- Body Roll on TF 2.5 Budget Boost
- ome lift kit?
- Lower rear shock mount............
- Wheel
- manual transmission and water
- Gears Installation Kit advice
- skyjacker 2.5 coil
- Truth About Driving New Gear......
- Standard Clevis D-Ring Mounts on Rugged Ridge XHD??
- Rocker Guard Recommendations
- Tuffy Security Deck quality
- Swaybar Link Help
- Hard Top Cross Bars!!
- Zone Lift Kit
- new cable soft top
- new jeep so many questions
- Wife needs step for the new lift, so I improvised
- "Toe In" Question?
- Install help,-front end "castor"
- need some advice on my possible set up
- Question on Stainless steel Hinge kits
- Smittybilt SRC Side Armor...... what a joke
- Rampage "Sliders"
- Rear Drive shaft died Need help
- 4.5" Rub Express Longarm problem with skid plate.
- A Good Rear Tire Carrier
- Oil Leak..
- ???which lift???
- whats the point?
- TERAFLEX 2.5" lift
- Yes I tried searching
- lod rear bumper
- driveline vibe?
- Winch regrets?
- After Market Exhaust
- Install Help!
- Matching X fender color
- Airbag & LOD bumpers
- Tire/Wheel fit
- Dual Battery Control!
- 3.21 carrier
- Can I swap axles from 2dr to 4dr
- Cooper STT's Anyone running them.
- Currie front track bar bracket and Woods SS bracket?
- Recenter front and rear axles?
- Which Lift Should I Buy?
- What About G2?
- Is it worth the $
- skyjacker help
- 255/85/16 on 16x8 wheels
- New RubiCrawler! Lower your crawl ratio!
- Superchips Login/Email Registration; First Thoughts
- warn rear bumper inventory turn
- the truth about spacers
- Just my luck....
- Questions Regarding Specific Set-up
- d30 & 37" tire discussion
- Superchip flashpac
- RR Front Bumper
- Teraflex 2.5 Coil Lift w/OME LT Shocks
- Regearing Jeep
- Noob...wheels, tires, etc...
- When Do You Need Bearings?
- Grill mod questions:
- Diff Covers!!!!
- rubicon express new 3.5" lift
- Any Olympic Smuggler Front Bumpers Out There?
- New Tera Flex Trac Bar
- 33s on a stock jeep
- Rough Country 2.5" Suspension Lift?
- R E driveshaft
- Auto chart!!!!
- Teraflex 2.5 question
- need help with lift mods
- Too Much Caster??
- 4.56 with 32's, 6spd, anyone??
- Gerry Can mount on SmittyBilt XRC
- Anyone have 5"backspace without spacers???
- 15"rims no grinding
- Superlift swaybar link bottom bushings gone?
- Diff fluid and towing
- Another 4" teraflex w/ arms install question
- RC 4" lift and front shaft
- 33's on stock rims?
- auto transmission cooler - too cool?
- Re-gear after the Lift
- Diff Oil Weight Question
- Gear oil in ARB diff covers
- OME 3" Coils and Long Travel Shocks??
- Please help me interpret backspacing for: 17" x 7.5"x 47.3 mm Offset Jeep Steel Wheel
- 1-2 inch supension lift???
- ARB vs Expedition One Front Bumper
- Flashpaq Data Aquisition
- Improvement question(s)
- best tires
- New driveshafts
- Riddler or G2?
- One more about lift kits...
- 4:88's and 35's
- Stuck between a rock and a hard place
- Rear Bumper with carrier
- TF 3rd Brakelight & Exp1?
- G2 covers
- New Suspension Lift for Friend
- AEV 3.5 lift!!!
- Mid-length Stock Bumper help.
- Drivers Side Drag Link Boot Cracked?
- New Gears
- Noise
- How do you know when..
- Steering Wheel Play after the lift...
- Aev procal module
- Lift help
- biggest tire for a dana 30
- Bike carriers with oversize spare tire
- Regear in colorado
- 16.5" Wheels?
- wheel spacers
- Seat covers?
- LOD shorty vs LOD midwidth for winch height
- Rear track bar
- driveshaft angle or tire balancing??
- grade 8 bolts for new suspension
- Disco lengths
- Squeaky Mopar Rear Bumper...Tire Carrier
- replacement driveshaft on a lift kit?
- Currie suspension
- Newbie Wheel Questions
- Rear Disconects???
- what lift kit will work best?
- Front Castor Angle with Aftermarket Driveshaft
- What backspacing to run?
- Rubicrawler
- tire carrier?
- Anyone with Romik side steps?
- Who makes the best grab handles?
- AFter lift having Traction control and ESP BAS lights coming on and brake issues.
- mixed style tire
- Aussie Locker D30 Install Question
- question about track bars
- 4.10's in a sahara - straight gear swap
- New 33" skins question
- Spacers with lift
- How to disable TMPS sensors
- body lift questions...
- Rubicon Express ???
- Popping/Clicking sound when front lockers engaged
- 255/85/16 or 285/75/16
- Rubicon Sway-Bar
- Hot Oil
- My axle is too weak for 4.10 gears?!
- Dropped frame side Vs Raised Axle side Track bar
- Which MT tire would you NOT recommend?
- Dropped pitman arm or flipped drag link?
- Superchips flashpac
- what gear oil is everyone using after new gears
- Help with TF 2.5 coil lift
- Driveshaft Measuring Question
- eBay seat covers?
- What should I do with the kc hood light bar
- Rear swing bumpers
- Benchmark Dual battery instructions - ?
- will 1.25 bl be to much for manual
- Various sized coil spacers
- King oem shocks or coilvers
- E3 Spark Plugs with rippmods SC
- Quick Q on Olympic bumpers
- Dreaded Lightning Bolt
- Who has the best ring and pinion?
- Flashpaq Settings
- KM2 vs MTR w/ Kevelar - Which is better on road? Quieter?
- Airraid CAI and Throttle Body Problem, HELP!!!
- 4" Lift with 38s
- Air Vent Surrounds
- Tuffy lock problem - Help!
- adjusting a JK's computer for different gears and tires?
- What are the length, strock specs for OME Shocks?
- evo rocker guard rock skin writeup?
- NEW Rugged Ridge Winches
- What is the heat shield glue inside the tub and how to remove it?
- Goodyear Duratrac E rated tires
- Lube Winch Cable?
- RC Steering Stablizer/ JKS Track Bar HELP!
- Gear Ratios? What does it all mean?
- ReGear Install Help!!!
- NEW Rough Country Quick Discos
- LoD Signature series bumper highlift jack
- rock hard rear bumper who has one good or bad
- rock jock 3
- Transfer Case Swap
- AEV Pro-Cal Module - defective?
- Squeak...heim joints? opinions wanted
- Help from the lift install pros
- Newbie would like to use the hardtop. & get a softop.
- Fitch Fuel Catalyst Placement under JK Rubicon Hood
- AEV Procal Q?
- Can I get away with LT305/70/R16 on a 4" lift and stock tires
- tires? 285 70 r17 on raceline renegades
- 37's on Stock Rubi Rims
- Rancho 4" sport lift
- Leveling
- Tire and wheel question
- smittybilt winch plate
- Info on Regear and driveshaft???
- Need help lifted drivetrain question
- Smittybilt XRC Hardware?
- Replacement for stock shocks?
- Warn M8000
- Best of both worlds?
- Spal fan update important info
- what gears would be best for me?
- Bumpers Stubby, Midwidth or Fullwidth
- Interesting adjustable spacer lift
- Rear Lower control arm adjustment question
- new rear bumper question
- Sector Shaft Brace + High Steer
- Flashpaq owners - flash back to stock!
- Rugged Ridge Mirror Relocation
- Bolt size and grade
- Creeper Breathers
- Rubicon Express vs. TF
- Waterproofing your Clutch/Transmision
- Do you know if,...
