PDA
View Full Version : Modified JK Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 [240] 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296
  1. Spidertrax Question
  2. Xdi cai
  3. Driveshaft for 6" lift
  4. baja claws...
  5. level help please..
  6. one more engine swap question
  7. Currie D60 & JE REEL
  8. How did you fit your 35's on the tire carrier?
  9. Front end shimmy trouble shooting help
  10. I broke it!
  11. Easier said than Done!
  12. Wheel Offset Stress?
  13. Budget Boost / ESP issue...
  14. BB vs. Coils
  15. what bumper was this??
  16. Traction Control - issues...
  17. Driveshaft Manufacturer Experience
  18. Hypertech programers
  19. alignment
  20. anyone put mattracks on their jk
  21. 75W-140 RP Gear Oil
  22. 17x9 w/ 4.5 backspacing
  23. questions about regearing...
  24. 2-Door Muffler Relocation???
  25. 4.7 swap?
  26. Driveshaft Priorities
  27. Will 285/65/18 fit on stock spare tire bracket?
  28. Body Lift
  29. 42RLE Auto trans T-converter Regulator Valve
  30. About to place my order, anything I'm missing?
  31. Dynatrac Differential Cover and Rubicon compatibility
  32. PRESS RELEASE: Hypertech Application Release!!
  33. Dick Cepek Mud Country...Opinions?
  34. Dynatrac Pro Rock 44
  35. Newbie looking for help w/lift
  36. PRESS RELEASE: JKS Adjustable Rear Spring Mounts
  37. Soon to be Rubi Owner with questions...
  38. Upper of Lower Control Arms
  39. OME Long Travel Kit from Northridge
  40. rancho oil pan skid
  41. Newbie needs answers: Headers & performance
  42. here we go again with the gear debate
  43. Chiping it out...or programing?
  44. I want a 2.5 BB, but not death wobble...?
  45. Need help with MX6 shocks
  46. steering stabilizer replacement
  47. 6spd-auto swap
  48. Were to get a d44 housing
  49. 33's with 3.73 auto
  50. AEV Bumper and winch Coil Sag
  51. switching front dana and rear 35
  52. 4" lift install question?
  53. Opinions on what Bodylift to get.
  54. Ome lift, shock question
  55. fog light mounting brackets
  56. Bestop Slider Step. Has anyone tried these
  57. backspacing for a 14.50?
  58. My Build any other suggestions..
  59. Rock Rails
  60. ?? Can I use the rear locker in 2 wheel drive on my 08 rubicon??
  61. Looking for Side-Steps that Double as Rock Rails
  62. 33's to 35's?
  63. FT 4" ultimate trackbar drop bracket
  64. Recalibrating speedometer after lift?
  65. rocker panel, line x, bedliner etc....
  66. Cheat on BB install
  67. Rough Country 2.2 Shocks
  68. Computer flash for new tires
  69. Throttle Body?
  70. 4dr rubi springs vs. 4rd x with tow pkg
  71. kumho tires
  72. Pro Comp 7005's and 35's
  73. Ball joints: Any aftermarket solutions yet? Any good? Bad?
  74. Tire ?'s
  75. Bumper Question?
  76. 35in tires
  77. Makin a list... where to find 5.38's tho.
  78. Overall height
  79. Tire Weights
  80. Rough Country 4' lift
  81. What bumper is this?
  82. rugged ridge tire carrier help
  83. Extending the Brakelines?
  84. Upgrade to coils or keep coil spacers?
  85. Mopar lift kits, anyone?
  86. Installing locker in the X Dana 44
  87. Rims
  88. Ordered a 2" OME Lift. Any tips for install, etc?
  89. Dick Cepek's
  90. Loudest exhaust
  91. Tire sales??
  92. Wheel balancing???
  93. Homemade Swing out Tire Carrier on Stock Bumper?
  94. trans input shaft.
  95. Dana 60
  96. Axle Build question
  97. Help me choose my 3" lift kit
  98. Largest backspace available for 15" rim??
  99. SOLID spyntec hub conversion in the works.
  100. Smittybuilt XRC8 or Superwinch LP8500?
  101. Help with wheels
  102. Rough country 6" kit
  103. budget boost?
  104. Best body or body+frame mounted rock sliders
  105. Cooper STT vs S/T-C vs S/T
  106. Skyjacker Swaybar problem.
  107. Bumper Light options..?
  108. Went to Local Muffler Shop today....
  109. Wild Boar Camper top?
  110. Yes, Another Bumper Thread
  111. Rally Jeep
  112. will a 14.5" tire fit?
  113. 35s with 15" rims on a JK????
  114. Windshield protection
  115. will this work?
  116. New Wheels, need pics of Mamba M4 - Anyone running these?
  117. wheel spacers
  118. Diff Glide Plate vs. Diff Cover
  119. Building up d30 and regear to 4.56s
  120. Shocks
  121. Rim Size Question (Procomp 8179)
  122. 35-12.50-17 Toyo Mt Vs BFG KM2
  123. Trek Top
  124. Help me choose...
  125. Jeep hit while on vacation...Advice???
  126. Which wheels for my steelblue 2 door rubicon?
  127. Rough Country 2.2 SS
  128. Procomp SS
  129. Building up the stock Rubi 44...
  130. Not Another Stock Stubby
  131. Corner Guards
  132. Tough Stuff Hood Rack?
  133. JK Tire help
  134. What 35" Tires do I buy?
  135. How much power can you get out of a 3.8
  136. Best site to search for wheels?
  137. MP3 Bracket and some extra storage
  138. LOD Stubby Front Profile Too Deep
  139. Can you go from 5x5 to 6x5.5/
  140. AEV Procal High Idle not working?
  141. Anyone running Jet Stage 2 with stock JK?
  142. Cargo Rack or someting Else
  143. Highrock Bumper Storage Box??
  144. a little help please
  145. Body lift help
  146. Stock Rubicon Tires/Wheels w/3" Lift?
  147. Selection of Re-Gearing Shop
  148. Daystar Adjustable Control Arms
  149. PSC Steering Box
  150. Does 4 inch lift on 4dr need shafts
  151. Confused!
  152. hypertec regular v prem
  153. front axle swap
  154. Bumpstops for OME lift?
  155. Value of OEM Parts After Upgrades?
  156. Rock Hard Sport Cage Tips
  157. Best Price for Bushwacker
  158. Rear Swaybar links hitting Axle
  159. HELP w LoD slider install!!!
  160. installing shocks. need advice
  161. AEV Procal Gear Ratio Manipulation
  162. JKS quicker disconnects
  163. any tips for installing tuffy console?
  164. Pics for project needed
  165. trailer hitch
  166. 4 dr Rubicon suspension on a 2 door X ?
  167. 5.13 Gears, Problems...or All Good?
  168. ome lt kit
  169. Rugged Ridge Modular XHD pics please
  170. Lowering the Driver's Seat
  171. Disconnects?
  172. Need to level my Jeep.
  173. 2Dr lift
  174. So how quiet are your gears?
  175. Flowmaster Muffler
  176. Need to order soon...
  177. Wobble and a leak...
  178. pre runner jk?
  179. Help with re-gearing information
  180. Rear Bumper / Tire Carrier
  181. Has anyone tried 15" Cragar V-5 wheels?
  182. Spidertrax spacers...?
  183. Lockers, Gears, Chromo Axle shafts
  184. RC 2.5 BB – Need alignment?
  185. lift tricks and tips?
  186. teraflex track bar bracket 1954202 install?
  187. TIRE QUESTION...Nitto Terra Grapplers, or Pro Comp Extreme All Terrain??
  188. Rock Hard Skids & Teraflex long arm?
  189. Help! Front track bar hits new Solid diff cover
  190. question on noise when at idle speed...
  191. lift question please help!
  192. Some probably silly questions
  193. Stage 2 List
  194. fixed control arms vs. adjustable control arms?
  195. Best Tires for Stock Rims on 08 Sahara Unlimited
  196. Mickey Thompson Center Caps
  197. Will 2door lift work on 4door?
  198. Rough Country 4" lift
  199. Hypertech Update
  200. mickey thompson classic 2 lug nuts?
  201. 4dr springs to 2dr...how much lift did yours get?
  202. Dana 30 Question
  203. 2 mod questions: Morpar rear and Pro Comp
  204. Need advice
  205. Help with Tire Choice...
  206. driving lights
  207. Smittybuilt XRC 8000lb winch
  208. Need help with Mopar lift
  209. Kore lift kits?
  210. tires?
  211. Simply lift help
  212. Got DRL's
  213. Detailed Questions re Lifting 2008 JK 2-Door
  214. U-Joints for my JK
  215. Toyo open country m/t tires
  216. spyderlocks + mudgrappers help
  217. Bushwacker Flare install PITA???
  218. Tire question?
  219. tie rod play!!!!!
  220. oil pressure gauge/sending unit installation
  221. back spacing for 37x13.5 toyo?
  222. Driveline angle / adjustable control arm question...
  223. What to do about EVAP Canister
  224. Bosch bracketless wipers
  225. Coast front driveshaft - tranny pan/stock skid
  226. New Quadratec Floor Mats
  227. Hey Teraflex
  228. Flashing computer
  229. Rock Sliders for Body Lift??
  230. Superchargers in canada
  231. Hypertech - Speedo not matching GPS after programming
  232. Clutch safety deactivate?
  233. I bought the wrong gear overhaul kit. My mistake?
  234. ARB Compressor, Which One?
  235. Driveshaft or Tranny?
  236. Bumper Fog Light Idea
  237. Off Road Evolution Light Covers
  238. EVO Gussets Install - Would You Complain?
  239. tire size conversion
  240. Rough Country 4" Lift.
  241. 37 inch BFG KM2's
  242. Quick tire question
  243. Old Man Emu Steering Stabilizer????
  244. new lift need help
  245. Hankook MT road tire pressure...?????
  246. 35x12.5 tires on stock rubicon wheels?
  247. Dash holddown clips
  248. Tire Siping - Don't know why I waited
  249. windjammer
  250. Have aftermaket CV shafts? We need some help
