View Full Version : Modified JK Tech
- Thrush muffler
- Best lift for 35"s
- Best Chip/Programmer
- What width bumper?
- 3.5” Entry Level Rock Krawler, what else to make it work?
- Is a "305" to big?
- Lift questions 2 door vs 4 door
- performance mods worth it?
- tuffy overhead console
- Center Consoles???
- Any ideas
- dual steering stabilizer
- Rusty's Budget boost install questions-Installing now
- MBRP Spare Tire Bracket Reinforcing Kit -- A Few TIPS!!!
- Dang!!! Do I need spacers?
- shocks
- Winch, Fairlead, license plate question
- Teraflex 2 1/2 Coil Lift
- 37" Tires w/ min lift?
- Winch Warn 9.5 TI vs. XRC10 Comp Series
- Which Control Arms Do I Need?
- Which lift to run? Re or rockcrawler
- Homemade rear bumper (help me decide)
- s.o.s.pressure steering shock-absorber fox
- AEV programer video
- 35s on stock rims
- Smittybilt src Bumper
- Couple of questions for a Euro Diesel JK
- Doetsch Suspension Systems?
- Rake haters
- air bag suspension
- TF 2.5 BB - reality check
- I need a new LEVEL stance..
- Lift springs and spacers
- Teraflex GUSSETS!!!
- Gears, 2 vendors, 2 different sets, 1 decision...
- 4.10 gears in a "X" D30
- Teraflex Steering Stabilizer - Leaking
- Anyone try this thing out yet?
- Bump Steer gone - what I did...
- Just ordered a set of 35" KM2's and the new series 98 pro-comp
- 2" Suspension System by Old Man Emu?
- What size spacers for my stock X wheels and M/Ts
- skyjacker vs Rubicon Express vs Rugged Ridge which 4 inch coils
- Canoe rack anyone??
- .... How many of you install headers?
- Purejeep vs. LOD
- new drive shaft vibration
- Jackhammering JK in Oz
- Rugged Ridge modular bumper end cap durability?
- Wheel adapters
- WARN 9.5xp Self-Recovery Winch VS. 9.5ti Thermometric Self-Recovery
- Does anyone make a wheel spacer smaller than 1.5"?
- Full Traction Vs. AEV
- Tuners for '10s?
- help jk newbie
- Will these wheels fit?
- Rancho Sport Lift Caster...
- I am looking for a total suspension rebuild
- Garage Pro Rack - JC Whitney. Any installs?
- Front Break Grinding Noise??
- Rocker Guards with a Body Lift
- speedometer cal on a 2010
- winch advise
- Jack Stand height for 4" lift??
- wheel spacers for winter
- What locker switch to use?
- AEV snorkel with KC windshield lights and brackets???
- Extended Brake Cables & ABS Cable
- wheel spacers
- Painting centercaps
- More Death Wobble problems
- Wheel not centered after wheeling...
- Slant back hard top!!!
- Is anyone running a 36-37" tire on the Rugged Ridge Rear Bumper & Tire Carrier?
- Superchips update trouble....
- TeraFlex Flip Draglink Installed
- Install Winch AFTER Lod Mid Width Front Bumper?
- !5 inch Mickey's on a 2008 Rubicon
- Auto to manual transfer case
- What am I missing on this comparison..?
- Rockkrawler 3-link rear end conversion
- Mix and match tire carrier?
- FYI re: latest generation Trektop
- Need Some Info
- I'm learning, but slowly.
- 16.5" wheels
- Lift Upgrade
- Rancho Rock Gear Front Bumper??
- 295 vs 305 tire size
- Popping noise....ugh!
- Smittybilt raised winch mount?
- Changing Tires and Wheels
- Just got the lift ordered...
- Turning off esp?
- Suspension Lift Preferences
- Rotor Clips?
- New front Axle?
- Wheel Spacers
- 4dr springs on 2dr mod: questions
- Any thoughts on this tire?
- help rubicon sway bar
- where to buy equal balancing powder
- Help needed -- MBRP Catback install.
- New Shocks vs. Long Arm Kit vs. Coilovers vs. ?
- 33s that are good in the snow?
- TF 2,5 Lift Kit without Adjustable front track Bar
- Install Q - order of install...
- DAYSTAR 1.75 Pics-Pros-Cons Please
- PRESS RELEASE: PUREJEEP Bare Bonez Crawler Front Bumper Combo
- PRESS RELEASE: Olympic 4×4 Products JK Jacklite Brackets
- How does one replace control arm bushings?
- Non-Mechanic needs help.
- Teraflex or Rockkrawler control arms
- Lift Upgrade
- bushwacker pocket flare
- Can't afford the a Hemi, check this out
- Milemarker hydraulic winch and aftermarket bumpers
- Rocker help
- Parts check - make sure they all work well together
- Assembled rear diff w/ locker install.
- Full Traction long arm Suspension Systems
- need some input
- What size crescent wrench for lower Teraflex arms?
- Tool Box
- no Swing gate?
- Help with locked front axle
- Question about 33's with stock 3:73 and Auto
- 35s or 37s???
- rear bumper
- Front Adjustable Lower Control Arm (LCA) - Recmomendations & Install Guide?
- Drive shaft upgrade??
- Swinggate to tailgate conversion?
- rough country 1.5'' spacers
- On Board Air Install with Train Horn
- mirror relocation
- backspacing?
- procomp 8069 black center caps
- Carpet Protection
- Check out what this clown did...
- Diff Cover vs. Diff Skid Plate
- Can I do the Yoke conversion to stock Drive shaft?
- 2" Front coils lift, will it be 2 inches of lift?
- Aftermarket Driveshafts vs stock??
- Auto Trans Cooler
- 15'' wheels, good idea or bad idea.
- What about 34s?
- Combining RC 2.5 BB and RC 2.5 progressive kit?
- york oba
- EVO Rockstar skids question?
- Tailgate vent cover
- Who manufactures wheels with 4" or less backspace?
- 35's and towing ability
- Idiot Check Me
- How much Lift will Do? opinions on fitting 37s
- 2.5 to 3 lifts, 4 door auto or stick any difference?
- questions on 2.5'' teraflex coil lift
- River Raider Jeep
- AEV Air intake Grill
- Any recommend Rugged Ridge 17x9 with Rock Ring?
- synth vs dino oil question
- AEV 3.5 vs TF 2.5 lift?
- Arggghhh!! 35"s out of stock!
- 37's too much for D30?
- teraflex owners
- Rubicon transfer case upgrade questions
- Wheel offset & 37" Tires
- Alignment after a Teraflex leveling kit?
- Reduced MPG and Shifting poorly after TSB Scantool and AccuPro update
- Soft doors
- Poison Spyder DIY Rico Step Kit... Thoughts
- XHD non winch mod for winch install
- Steering and Font end problems
- AEV Snorkel Question
- Anybody installed the Gear Jammin Rock bumper
- AEV Hood
- Suspension Ideas.....need opinions
- which seatcovers?
- new jk!!! now what to do with it!!! HELP!!!
- Which Body Lift
- Wheel Spacers Required For OME lift
- Argent 17" Pintler vs. 17" Black Steel Procomp 98's?
- Recommened Tire Pressures question
- Wider wheel + stock tire. Will it work?
- About how long for the OME kit install?
- 33" Duratracs on stock 17"s
- Castor issue
- ESP turns on on high speed corners
- 4.88 gears
- The JK rake...what is it?
- how much does 5.13 gears cost?
- MBRP Spare Tire Bracket Reinforcing Kit -- I could use some info
- Anyone Cryo their axles on their JK yet?
- drive shafts oem flanges or cv ?
- rear axle shifted forward?
- Lift and Tires VS. voided warranty
- Teraflex 2.5" vs 3" with coils and shocks
- Rubi Springs/Shocks on an Unlimited X
- 37" club need some gear advice
- rustys 3 1/4 lift with 33's
- which ply for tires
- track bar questions
- Those of you with Beadlocks for DD...
- Shocks; up or down?
- which lift and tire size????
- Need your opinions!
- Full traction Ultimate lowers cracking bushings..
- NEWBIE WITH A RUBI (mod questions/ideas)
- Tires
- lug nuts?
- rear locker
- Skid Plates
- 35 inch Duratrac's
- Opinions on Bestop bikini top.....
- Help with picking a lift and offset
- Can you run 37's on a 4" lift?
- Goodyear MTR w/Kevlar - Reviews?
- Superchip w/87 octane?
- vibration when going slow
- Does anyone run 40's on a DAILY DRIVER?
- Cold Air Intake install - Got 3 Grommets?
- Using winch on stock bumber
- Cam Bolts..
- weight of xd hoss
- Popping noise
- Could this be my Death Wobble culprit?
- River Raider or ARB DIFFERENTIAL COVERS....
- Lod stinger
- Well,, what next
- another way to remove front axle??
- Axle or Lockers?
- A few questions about AEV Pintler Beadlocks...
- Looking for pics
- Any issues with parking decks and 2.5 lifts/33s
- Superwinch 160 amp breaker !!!
- No more Death Wobble
- Anybody running 33x10.5R16???
- Anybody done this???
- Axle seal leak-EVO 44 mags
- ARB VS Vivar?
- plz help..
- wobble wobble wobble
- Tire size help
- Rain in snorkel...
- exhaust
- Tom Woods rear drive shaft...
- Lifted JK short wife need step bar suggestions
- Question about Bushwacker Pocket Style Fender Flares (2007+ up models)
- Suspenison tips...?
- D30??
